Since I moved from U2 to U3, I noticed this problem.
I noticed priority seems to be ignored when printing, I have a sheet with a drawing containing colored shapes. They cover each other, and I used priority to define the order.
When printing, this seems to be ignored, while before the update, the print of the same sheet was OK. Nothing changed to the file. When I check 'rasterized' the print is OK.
See example below:
1. not rasterized:
2. rasterized:
I noticed the same with the axes from the automated grid level, you can see the difference in the preview window between rasterized checked or not:
1. Rasterized:
2. Not rasterized:
All other settings remain the same, all I did was checking 'Rasterized'.
EDIT: I just started a new drawing and created a brown (priority 0) and blue (priority -400) square. It seems the priority is ignored when not using rasterized, but the order in which they were created is used?
I just checked with the keyin "wset drop" and "wset add", this seems to work to make the brown one get on top without rasterizing. If I'm correctly these commands work on the element ID, which is more or less the order in which they were created. So it seems the program ignores the priority...
Larry or any other U3 user,
Could you test this using my files?
I can send you:
I detached the pentable so this has no influence.
Notice that using the same files/settings in the U2 version just turns out ok....
Windows 10 pro
OpenBuildings Designer Connect Edition Update 10.10.01.151
StefanC,
Defect #891858 - [Print/ Plot] - print plot dialog does not obey the level priorities - has been opened for this issue. I'm checking into the use of a pen table to workaround the issue until a fix is made.
I'll report my results back here.
Larry
Thanks Larry, so far I didn't find a solution yet, so now I'm designing on a computer with U3 (since it's more stable to U2 IMO) and printing on another computer with U2, but this isn't ideal ofcourse.
Is it possible to install U2 and U3 on the same computer?
Unfortunately, U2 and U3 cannot reside on the same machine.
Sorry,Larry
Hi StefanC,
Can you please file a SR so that we can connect the Defect with the same.
Warm Regards,
Subhamoy Kundu
