Modeling 8 node solid element in Staadpro
I tried to model a concrete block using solid element (to simulate a pile cap).  However, the block does not seem to look right in Staad.  I numbered the nodes sequentially in one direction for the upper nodes and similarly for the lower nodes.  There seems to be some cross over lines between the upper and lower nodes.  Is it just the way that it is presented visually in Staad or am I not doing this correctly?  Please advise.  Thanks.
Parents Reply Children
