Beam 1,2,3 and 4 are welded connection At joint 35,36,37 and 38.
is it need to give support at that joint?
because of the load at cantilever end, there is high displacement.
STAAD SPACESTART JOB INFORMATIONENGINEER DATE 19-Apr-18END JOB INFORMATIONINPUT WIDTH 79UNIT METER KNJOINT COORDINATES3 3 0 0.75; 4 0 0 0; 5 1.4 0 0; 6 0 0 1.5; 7 1.4 0 1.5; 10 0 0 3; 11 1.4 0 3;12 3 0 2.25; 13 0 -3.1 0; 14 1.4 -3.1 0; 15 0 -4.2 0; 16 1.4 -4.2 0;19 0 -4.7 0; 20 1.4 -4.7 0; 22 1.4 -3.1 1.5; 23 0 -3.1 1.5; 25 0 -4.2 1.5;26 1.4 -4.2 1.5; 27 0 -4.7 1.5; 28 1.4 -4.7 1.5; 29 0 -3.1 3; 30 0 -4.2 3;31 0 -4.7 3; 32 1.4 -3.1 3; 33 1.4 -4.2 3; 34 1.4 -4.7 3; 35 0 0 0.75;36 1.4 0 0.75; 37 0 0 2.25; 38 1.4 0 2.25;MEMBER INCIDENCES1 35 36; 2 36 3; 3 37 38; 4 38 12; 5 4 5; 6 6 7; 7 10 11; 8 4 35; 9 35 6;10 6 37; 11 37 10; 12 5 36; 13 36 7; 14 7 38; 15 38 11; 16 4 13; 17 13 15;18 15 19; 19 5 14; 20 14 16; 21 16 20; 22 6 23; 23 23 25; 24 25 27; 25 7 22;26 22 26; 27 26 28; 28 10 29; 29 29 30; 30 30 31; 31 11 32; 32 32 33; 33 33 34;34 13 14; 35 15 16; 36 23 22; 37 25 26; 38 29 32; 39 30 33; 40 14 15; 41 22 25;42 32 30; 43 13 23; 44 23 29; 45 15 25; 46 25 30; 47 14 22; 48 22 32; 49 16 26;50 26 33; 51 13 25; 52 25 29; 53 14 26; 54 26 32;START GROUP DEFINITIONMEMBER_COL_1 16 TO 21 28 TO 33_COL_2 22 TO 27_CRANE-BEAM 1 TO 4_T-BEAM 8 TO 15_BRACING 34 TO 54_TIE-BEAM 5 TO 7END GROUP DEFINITIONDEFINE MATERIAL STARTISOTROPIC STEELE 2.05e+008POISSON 0.3DENSITY 76.8195ALPHA 1.2e-005DAMP 0.03TYPE STEELSTRENGTH FY 275000 FU 407800 RY 1.5 RT 1.2END DEFINE MATERIALMEMBER PROPERTY CHINESE1 TO 4 TABLE ST HW200X2005 TO 7 16 TO 21 28 TO 33 TABLE ST TUB1001004.034 TO 54 TABLE ST TUB50503.022 TO 27 TABLE ST TUB1201205.0MEMBER PROPERTY BRITISH8 TO 15 TABLE ST TUB2001005.0CONSTANTSMATERIAL STEEL ALLSUPPORTS19 20 27 28 31 34 PINNEDLOAD 1 LOADTYPE Dead TITLE GKSELFWEIGHT Y -1 JOINT LOAD13 FY -0.623 FY -1.12529 FY -0.83LOAD 2 LOADTYPE Live REDUCIBLE TITLE CRANE LOAD 1JOINT LOAD3 12 FX 1.08 FY -26.9 FZ 2.69LOAD 3 LOADTYPE Live REDUCIBLE TITLE CRANE LOAD 2MEMBER LOAD1 3 CON GX 1.08 0.71 3 CON GY -26.9 0.71 3 CON GZ 2.69 0.7LOAD 4 LOADTYPE Live TITLE CRANE LOAD 3MEMBER LOAD1 3 CON GX 1.08 01 3 CON GY -26.9 01 3 CON GZ 2.69 0LOAD 5 LOADTYPE Live TITLE CRANE LOAD 4MEMBER LOAD1 3 CON GX 1.08 1.41 3 CON GY -26.9 1.41 3 CON GZ 2.69 1.4LOAD 15 LOADTYPE Live TITLE PLATFORM IMPOSED LOADJOINT LOAD13 FY -1.723 FY -3.429 FY -2.5LOAD COMB 6 LOAD COMB: 1011 1.0 2 1.3 15 1.3 LOAD COMB 7 LOAD COMB: 1021 1.0 3 1.3 15 1.3 LOAD COMB 8 LOAD COMB: 1031 1.0 4 1.3 15 1.3 LOAD COMB 9 LOAD COMB: 1041 1.0 5 1.3 15 1.3 LOAD COMB 10 LOAD COMB: 2011 1.35 2 1.5 15 1.5 LOAD COMB 11 LOAD COMB: 2021 1.35 3 1.5 15 1.5 LOAD COMB 12 LOAD COMB: 2031 1.35 4 1.5 15 1.5LOAD COMB 13 LOAD COMB: 2041 1.35 5 1.5 15 1.5 PERFORM ANALYSISPARAMETER 1CODE EN 1993-1-1:2005CHECK CODE MEMB 1 TO 4PARAMETER 2CODE EN 1993-1-1:2005CHECK CODE MEMB 5 TO 15PARAMETER 3CODE EN 1993-1-1:2005CHECK CODE MEMB 16 TO 33PARAMETER 4CODE EN 1993-1-1:2005CHECK CODE MEMB 34 TO 50FINISH
I don't think that supports at these nodes are required if in reality there is nothing to restrain movements at these nodes.
