Windows 10 Update 1803 (Spring Creator) causes AECOsim Building Designer, MicroStation and other CONNECT Edition products to stop working. This Window update has impacted installation of these CONNECT Edition product on operating systems that are non-English such as German, Danish, Spanish and Italian to name a few. Bentley would recommend avoid taking this update. We are working with Microsoft to provides resolution to the Windows 10 version 1803 update notifications.
For further information regarding this issue, please reference the following wiki "MicroStation hangs on startup after Windows 10 Update (Spring Creator) has been installed"
Update Windows 10 sometimes is like a Russian roulette and the April 2018 version makes it clearer than ever.
Unfortunately, Microsoft don't give you the option to update or not anymore. You have to accept the update or stop using Windows 10
vpastor said:Update Windows 10 sometimes is like a Russian roulette and the April 2018 version makes it clearer than ever.
I have to agree. I have not problems with Windows updates in the past (I am aware such problems were reported by users, but maybe I had a luck ;-). But April 2018 update is far worse than all previous: I am not even able to install it on one specific computer, because even when it's installed from installation media, it halts during loading installation program. So it seems the installation from scratch will be necesarry :-(
MickyKom said:Microsoft don't give you the option to update or not anymore.
This is not quite true in my opinion. There are still some options how to reject Windows updates (or to delay them at least), but it's also true that it was confirmed by Microsoft (if I recall correctly) some updates under some conditions will be installed regardless Windows policy and network setting.
Jan
Standalone Windows 10 has the option to pause updates for 35 days (search the Settings for 'updates' then pick 'Advanced Windows Update Options') but that is only a pause:
Managed systems have the option to control updates including deferral of Feature Updates for longer periods.
Marc
