I'm pretty new using staad foundation, and when I try to run an analysis for a mat foundation (I have followed the example in the tutorial to practice) I obtain a pop-up windows telling that : Analysis results are not available. if someone have already be in this situation, or have an idea of what I do wrong.
Thanks a lot!
"Analysis Results are not Available" is a generic message that comes up when the analysis fails to complete. There could be various reasons ranging from supports not being assigned to the mat to job not being properly defined and so on. If you could upload the model ( zip it first ) then we can take a look.
Instructions for uploading a file is available at
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/28129/how-can-i-upload-files-in-the-bentley-communities-forum
Thanks for your concern Resort Hotel.rar
The STAAD Foundation Advanced file you sent has an extension of .afs which is a very old file format. So you must be using an outdated version of the STAAD Foundation Advanced program. I would suggest that you use a more recent version of STAAD Foundation Advanced for which the file format is .sfa. The version number available now is 08.03.00.20 and in a couple of weeks a newer version is going to be out.
Coming to the problem, the mat was modeled at 0 m elevation whereas your column point elevations are at y=9.0 m. So you need to move the mat to the y=9m elevation. The mat job was assigned to just one support as opposed to all supports. Also you only need to use the service and ultimate load in the job and leave out the first two cases.
A modified model is uploaded for your reference RH3_modified.zip
Thanks a lot. but I am one more error 09:14:14 [ERROR] NO LOAD CASE ASSOCIATED WITH THE CURRENT JOB...RH3_modified.sfa
Pls what can I do.
You have not included any load cases in your mat foundation job. Include the service and ultimate load cases in the job as shown in the attached screenshot.
It works, thanks alot.
