Hi everybody. I'm trying to use the Steel Design Module but STAAD report "This workflow is not available in this reléase". I'm using 21.00.01.12 versión.What I must do for use this workflow?. Thanks
Steel Design workflow has been temporarily removed from the latest versions of STAAD.Pro. I would recommend you to use the Batch model (Steel Design in the Modeling mode) for the steel design.
Answer Verified By: Alfonso Fuente
Thank you Aswathi, but I couldn't find "Batch Model". Where is "Steel Design" in "Modeling mode" .?
Best regards
