Building2.std
I have attached the Staad File. Please Help !
There were modelling errors in your file. So many beams were not broken in the intersecting nodes. I have broken all those beams at all intersecting nodes and now all floor loads have been generated as expected. Please find the enclosed modified file.
Building2_Modified.std
Answer Verified By: Nilay Patel
There are issues with connectivity in the model which is causing the floor load generation to fail for some panels. Many of the beams are crossing each other but not actually intersecting. To rectify the issue
In STAAD.Pro Connect Edition
Go to menu option Geometry > Highlight Intersecting Beams to highlight the members and Geometry > intersect Selected Beams to intersect the beams
In STAAD.Pro v8i
The same options are available under Geometry Intersect Selected Members > Highlight ( or Intersect)
A modified file is attached where I have made the change at the topmost level. You may change for the rest
Building2_rev.std
Thank you very much brother. Appreciat your help
Thank you very much brother I will reupload after assinging loads . It will be very helpful of you if you will check it once ?
Building2New.std
I have Assigned loads as per Indian Standard Code. If you can look at it and check , I will be very thankful.
