I am new using Staad pro and Ram.I have a question about how I can do a mathematical model of a beam using a discretization.
I mean, I want to analyze this beam (figure), I want to model as an area element, but I don't know how I can do that in Staad Pro.
discretization
I can analyze finite elements but I do not see how to discretize
You can do it using plate elements meshed as per requirement and using required thickness.
You mean this?How can I assign thickness to my mesh?
I have to created some of beam around to the mesh?
Like that
No you need not assign beams. You need to model plates and assign plate thickness to them. Try once if you encounter any problem please upload the file.
Structure_5.STD
I sent you the file. I have to assign 50 grade steel to this beams with this specification (Fy=350 Mpa and E=200 Gpa). And assign punctual load in the edge.
check out
