Sir I am New to Staad SSI 5 and while running a Truss model, i am getting the below error
**ERROR** ELASTIC MODULUS (E) NOT ENTERED FOR MEMBER/ELEMENT/SOLID NO. 2
Pls help me in solve the same.
You probably not entered section properties for that member. Assign some properties from section database and run the file. If you still face any problem please upload the .std file here.
Thanks & regards,
Abhisek M
Global Technical Support
Subscribe Here
Now it is okay. And i am getting new warning
*WARNING- ZERO STIFFNESS IN DIRECTION 5 AT JOINT 5 EQN.NO. 17
Upload the file
Truss New.std attached file
You have provided wrong member release at support points. Please find the modified file without any error or warning.
Truss New_Modified.std
