33kg73kgweb.lmc
Dear Sir,
Kindly check the attached file. SG value is correct but again I'm facing warning.
it is 60mm<80mm.
and software asking me design is not acceptable. all the parameters are correct.
Please under these loads review my connection and corrected file send me back,
Thanks.
waqas
The warning I see is:
Geometry Check:
*** WARNING -- *Bolt gauge, sg < 4 x dia.
This is with M20 bolts at sg = 65 mm (for the flange plates)
The problem is, if you increase the gauge (the distance between the bolt lines across the beam width) you will eventually run out of beam width and get an edge distance error instead. As long as you are comfortable attaching M20 bots to a UB 356X127X33 at 65mm gauge carry on despite the warning.
Answer Verified By: Waqas Ghani
Further query Mr.Seth how to resolve this WARNING: This connection does not satisfy all requirements of the model. Even if stated design is adequate the design may not be valid? Is that serious?
