The file which I was working on suddenly can't pass to postprocessing mode. I was working in it yesterday morning and returned to it at the afternom end and when I analized the file, after doing the normal calculating process, the Staad showed me a window that said: " One more result files are not compatible with the current momdel and cannot be loaded. The model may have been modified after thes results were created or this .std has been saved over anoder file leaving the analysis results of the previous model. Do you wish to delete these files? YES <> NO".
Independently I answered yes or no, Staad showed a window saying "This workflow requires the result of the analysis, but currently these are not avaliable. Please run the analysis first".
I tried to return a previous file version with the Open Backup Manager tool and didn't work too. I copyed the code from the Staad.Pro Editor to a new file and didn't work too. Even I restarted the computer, but nothing worked, the same issue apeared always when I analized the file.
Next you have the .std file: 018-16-C09-R00.std
Has anyone found the same issue?
Thanks for your help!
Fernando Gago
Please upload the .upt file you have used for the model
Thanks & regards,
Abhisek M
Global Technical Support
Subscribe Here
Sorry Abhisek.
The web doesn't let me upload the .upt extension, so I changed the upt extension to std. Then you must return the extension to .upt for use the file
I attach it next: 0652.UPNHEA.std
Many thanks!
It worked OK for me with version 21.00.02.43 using just those two files.
Perhaps if you rename or move the .std and .upt files to a new folder (or delete the other files associated with this model) it will work for you.
Seht, I tried it.
I copied te file to other path and changed it the name. At the beguining, without any change, it worked, calculated well and let me go to the postprocessing mode.
But when I did some changes in the loads and recalculate the issue returned.
Seth, I forgot to tell you my Staad version is the same than yours: 21.00.02.43.
