Can not find PREVIOUS SELECTION TOOL in STAAD.Pro CONNECT Edition - Version 21.00.02.43
All selection tools are in the Select ribbon menu.
Can not find the same in the ribbon menu:
Please help if you find one.
I can see it in build 21.00.02.43:
Are you sure that you are using build 21.00.02.43?
Well, what I am looking for in this version of staad is a tool that helps you to select the "previous selection".
This is a snap from older version of staad..
The question was, where do I find the same tool in new version?
Yes, I cannot find this icon in STAAD.Pro CE either. I will check with the development team and get back to you.
