Issue when checking tension members to S16-14
crushing and screening updated 14-07-18.std
I'm running STAAD 20.07.11.90, and in my model I'm checking a tension only WT5x11 that by inspection passes easily, but STAAD appears to be checking the tension force as if it were a compression force. File attached. Member in question is 1958
