I'm using STAAD.Pro V8i (SELECTseries 5) version 20.07.10.64 together with the CHANGE command to analyse a structure and get the following error after the analysis has run for approximately 2 seconds.
Exception [Access violation] Raised! Aborting Analysis.....
I have tried changing the MEMORY and SET NL command without any luck.
Can someone help me?
Kind Regards
Tobias Jungbark
RB_main_rev13.std
Hi Tobias,
I've opened your staad model with staad V8i-serie 6-built 20.07.11.90, here is the error message :
" *ERROR- TOTAL DOF AFTER CHANGE COMMAND MUST NOT EXCEED THE TOTAL DOF BASED ON FIRST SET OF SUPPORTS. YOU MAY TRY REVERSING THE ORDER OF SUPPORT SETS AND CASES. ORIGINAL TOTAL DOF = 443 PRESENT TOTAL DOF = 444"
So there is probably a problem in your number of DOF.
A modified version of the file with modifications made to the support specification is attached.
The E for the STEEL_STIFF material may be changed as shown next as otherwise it would be too stiff
ISOTROPIC STEEL_STIFF
*E 2.05e+012
E 2.05e+010
POISSON 0.3
There are a number of warnings as you have entered some LOAD LIST commands which refer to load cases that are not defined at that point of time.
Modified_RB_main_rev13.std
