Can Ram concept be used to design a monolithic Slab-on-Grade (BRAB) Foundation?
Can Ram concept be used to design a monolithic Slab-on-Grade (BRAB) Foundation?  These foundations are widely used in Texas, and the WRI (Wire Reinforcement Institute) has a design aid which I am following, but would like to use Ram Concept and would like to know if others have done this too.
  • Thanks Seth.  The BRAB and WRI are more prescriptive methods, and the examples I have don't address point loads.  Which is why I want to use Ram Concept to be sure the moments induced by point loads is accounted for.  Would you recommend modeling the Area springs under just the beams/ribs or under the entire slab?  (Commentary from the Texas Foundation Performance-Structural committee indicated the slab and beams would both be on the area springs.)
Reply
