I am using Structural Syncronizer to create ISM models from Tekla to import into STAAD.Pro V8i. The model has custom sections in it that have been defined in STAAD using a general section defined by coordinates. I have exported this section to a UPT and am trying to get the STAAD.Pro ISM module to recognise the UPT in the "Select equivalent STAAD Shape" dialogue under the User Table tab. Is there a specific file path I need to save the UPT to or a file I need to add data to like the Shapes19S3 file?
I am currently running STAAD.Pro V8i (SELECTseries6) 20.07.11.50 and Structural Syncronizer CONNECT Edition Update 2 10.02.01.147
Check this post for some details: ISM Section mapping and STAAD.pro
Otherwise you might send over your ism.dgn file.
