While running staad file (version SS6 ) following error message appears-
however I had checked syntax of input file also checked if there is an unnecessary space exists or not before STAAD SPACE command .but I did not get anything. Will you please mind to help. I also tried to copy contents in new staad file but that also faces same problem.
Aritra
Could you please upload the file?
You may check this Forum thread for a possible solution: https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/155457/staad-editor-corrupting-staad-file/463558#463558
boss as per my company's policy I will not be able to share it.....therefore I had attached selected snaps
Seems you are using STAAD.Pro SS6 version. In this situation, you are advised to perform the followings;1. Perform a full Virus Scan2. Open the input with STAAD Legacy editor. See the image illustrating process.3. Notice the junk characters at the beginning of input.4. Remove all junk characters, save the input file and execute.
