When I try to "return to analytical modeling" from the physical modeller I get the following error: "Unrecognized Guid format." All I changed from the last time I updated the analytical model is some member releases. How can I resolve this error?
Can you send the model files? You can put them into a zip and insert into a reply or use Secure File Upload Also confirm your version please.
PREP PLANT REV D.zip
Please see attached model file. I am using STAAD.Pro Connect Edition - Version 21.00.02.43. Thank you
Can you send over the other files too? The ones in the same folder with similar name.
It wouldn't let me attach all of them, so I used the secure file upload you mentioned above.
I have the files and I can reproduce the problem. You can keep working with the file in analytical mode, of course.
