Is there a way to Mirror/Reverse a Ram Structural system model?
The model move and merge tool can be used for that:
Details here: What is RAM DataAccess?
Tool here: Model Merge and Move.
Be careful as not all objects can be moved, mirrored as noted in the links. Be sure to make a local backup first.
Answer Verified By: AHedin
This move and merge tool does not seem to be working for version 17.01.01.05. Is there an updated tool I can use to mirror my existing RAM model?
The tool is version independent. It is required to have RAM SS installed on the same machine and the model must be in the matching version of RAM SS, however.
I have RAM installed and the model is in the same version. I keep getting errors when I try to run the mirror command. Do you know what is causing this?
This happens if you are using Ram DataAccess for RAM SS 17.01.01.05 with Microsoft Excel 32 bit. Do you have a 64 it version of Excel to use? If not I can send you some 32 bit dlls to install locally.
