Do I need to skip load the live load around column while using AISC 360-10 in RAM Steel Column? Also why is this important?
Yes, if your connections act eccentrically to the column centroid, then you should consider skip loading.
See also: communities.bentley.com/.../ram-steel-columns-faq
Answer Verified By: Karthik Madhur
Thank you Seth!
