Deflection Checking - Canadian Code - Serviceability Envelope
I am hoping to use STAAD for beam design for a run of simple span beams with dead and live loads.
I currently can not get the program to stop designing for deflection based on factored loads.
I was strength design based on envelope 2 and deflections for envelope 1. Is this possible for Canadian Codes?
STAAD SPACE
START JOB INFORMATION
ENGINEER DATE 30-Jul-18
END JOB INFORMATION
INPUT WIDTH 79
UNIT FEET POUND
JOINT COORDINATES
1 0 0 0; 2 15 0 0; 3 25 0 0; 4 50 0 0; 5 71 0 0;
MEMBER INCIDENCES
1 1 2; 2 2 3; 3 3 4; 4 4 5;
DEFINE MATERIAL START
ISOTROPIC STEEL
E 4.28151e+009
POISSON 0.3
DENSITY 489.024
ALPHA 1.2e-005
DAMP 0.03
TYPE STEEL
STRENGTH FY 5.28819e+006 FU 8.51708e+006 RY 1.5 RT 1.2
END DEFINE MATERIAL
MEMBER PROPERTY CANADIAN
1 TO 4 TABLE ST W360x39
CONSTANTS
MATERIAL STEEL ALL
SUPPORTS
1 TO 5 PINNED
MEMBER RELEASE
1 TO 4 START MX MY MZ
1 TO 4 END MX MY MZ
LOAD 1 LOADTYPE Dead  TITLE Dead
MEMBER LOAD
1 TO 4 UNI GY -150
LOAD 2 LOADTYPE Live REDUCIBLE TITLE Live
MEMBER LOAD
1 TO 4 UNI GY -330
LOAD COMB 3 Generated NBC 2005 ULS 1
1 1.4
LOAD COMB 4 Generated NBC 2005 ULS 2
1 1.25 2 1.5
PERFORM ANALYSIS
DEFINE ENVELOPE
1 2 ENVELOPE 1 TYPE SERVICEABILITY
3 4 ENVELOPE 2 TYPE STRENGTH
END DEFINE ENVELOPE
PARAMETER 1
DFF 360 ALL
CODE CANADIAN
LAT 1 ALL
PARAMETER 2
CODE CANADIAN
TRACK 2 ALL
SELECT ALL
FINISH
  • You need to use the LOAD LIST ENV 1 2 to before the design to ensure that the design process uses the envelopes. Also I have commented out a few redundant PARAMETER and CODE CANADIAN commands to clean up the file.
    In addition, when you do a SELECT you should group members and do a reanalysis followed by a CHECK CODE. A modified file is attached for your reference.
    4705.Structure1.STD
    Answer Verified By: Jason Hoel
  • Thank you very much.
    To anyone who may find this post, I have experimented and found how to make a total load / live load deflection check separate.
    This checks the total load L/360 limit first, sizes the member, then checks the sized member against live load L/480 limit
    STAAD SPACE
    END JOB INFORMATION
    INPUT WIDTH 79
    UNIT FEET POUND
    JOINT COORDINATES
    1 0 0 0; 2 20 0 0; 3 51 0 0; 4 71 0 0;
    MEMBER INCIDENCES
    ISOTROPIC STEEL
    E 4.28151e+009
    POISSON 0.3
    DENSITY 489.024
    ALPHA 1.2e-005
    DAMP 0.03
    TYPE STEEL
    END DEFINE MATERIAL
    1 TO 3 TABLE ST W360X39
    CONSTANTS
    MATERIAL STEEL ALL
    SUPPORTS
    1 TO 3 PINNED
    MEMBER RELEASE
    1 TO 3 START MX MY MZ
    1 TO 3 END MX MY MZ
    LOAD 1 LOADTYPE Dead  TITLE DEAD
    MEMBER LOAD
    1 TO 3 UNI GY -350
    SELFWEIGHT Y -1
    LOAD 2 LOADTYPE Live REDUCIBLE TITLE LIVE
    MEMBER LOAD
    1 TO 3 UNI GY -770
    LOAD COMB 3 GENERATED NBC 2005 ULS 1
    1 1.4
    LOAD COMB 4 GENERATED NBC 2005 ULS 2
    1 1.25 2 1.5
    PERFORM ANALYSIS
    DEFINE ENVELOPE
    2 ENVELOPE 3 TYPE SERVICEABILITY
    END DEFINE ENVELOPE
    LOAD LIST ENV 1 2
    PARAMETER 1
    CODE CANADIAN
    DFF 360 ALL
    *CODE CANADIAN
    LAT 1 ALL
    *PARAMETER 2
    *CODE CANADIAN
    TRACK 2 ALL
    SELECT ALL
    *GROUP MEMB 1 TO 3
    PERFORM ANALYSIS
    LOAD LIST ENV 1 3
    PARAMETER 2
    CODE CANADIAN
    DFF 480 ALL
    CHECK CODE ALL
    FINISH
Reply
    STAAD SPACE
    END JOB INFORMATION
    INPUT WIDTH 79
    UNIT FEET POUND
    JOINT COORDINATES
    MEMBER INCIDENCES
    ISOTROPIC STEEL
    E 4.28151e+009
    POISSON 0.3
    DENSITY 489.024
    ALPHA 1.2e-005
    DAMP 0.03
    TYPE STEEL
    END DEFINE MATERIAL
    CONSTANTS
    MATERIAL STEEL ALL
    SUPPORTS
    1 TO 3 PINNED
    MEMBER RELEASE
    1 TO 3 END MX MY MZ
    MEMBER LOAD
    1 TO 3 UNI GY -350
    SELFWEIGHT Y -1
    MEMBER LOAD
    1 TO 3 UNI GY -770
    1 1.4
    1 1.25 2 1.5
    PERFORM ANALYSIS
    DEFINE ENVELOPE
    END DEFINE ENVELOPE
    LOAD LIST ENV 1 2
    PARAMETER 1
    CODE CANADIAN
    DFF 360 ALL
    *CODE CANADIAN
    LAT 1 ALL
    *PARAMETER 2
    *CODE CANADIAN
    TRACK 2 ALL
    SELECT ALL
    *GROUP MEMB 1 TO 3
    PERFORM ANALYSIS
    LOAD LIST ENV 1 3
    PARAMETER 2
    CODE CANADIAN
    DFF 480 ALL
    CHECK CODE ALL
    FINISH
