Openstaad "Run-time error '61704': Internal Application Error" when running VBA code
Trying to create a simple excel file that will create a new Staad model and adds one new node. When I run the code the new Staad file gets created properly. The very next command is "CreateNode" and this line is where the error "Run-time error '61704': Internal Application Error" occurs. Below is the full code:
Sub Main()
'Create an instance of OpenSTAAD file
Dim oSTD As OpenSTAAD
Set oSTD = GetObject(, "StaadPro.OpenSTAAD")
'Geometry;
Dim ostdGeometry As OpenSTAADUI.OSGeometryUI
Set ostdGeometry = oSTD.Geometry
'Window;
Dim ostdWindow As OpenSTAADUI.StaadProWindow
Set ostdWindow = oSTD.Window
'View;
Dim ostdView As OpenSTAADUI.OSViewUI
Set ostdView = oSTD.View
'Output;
Dim ostdOut As OpenSTAADUI.OSOutputUI
Set ostdOut = oSTD.Output
'Property;
Dim ostdProperty As OpenSTAADUI.OSPropertyUI
Set ostdProperty = oSTD.Property
'Load;
Dim ostdLoad As OpenSTAADUI.OSLoadUI
Set ostdLoad = oSTD.Load
'Table;
Dim oStdTable As OpenSTAADUI.OSTableUI
Set oStdTable = oSTD.Table
'Support;
Dim oStdSupport As OpenSTAADUI.OSSupportUI
Set oStdSupport = oSTD.Support
'Command;
Dim oStdCommand As OpenSTAADUI.OSCommandsUI
Set oStdCommand = oSTD.Command
'Design;
Dim oStdDesign As OpenSTAADUI.OSDesignUI
Set oStdDesign = oSTD.Design
oSTD.NewSTAADFile "D:\6.std", 1, 1
ostdGeometry.CreateNode 10, 12, 12, 12
Set oSTD = Nothing
Set ostdGeometry = Nothing
Set ostdWindow = Nothing
Set ostdView = Nothing
Set ostdOut = Nothing
Set ostdProperty = Nothing
Set ostdLoad = Nothing
Set oStdTable = Nothing
Set oStdSupport = Nothing
Set oStdCommand = Nothing
Set oStdDesign = Nothing
End Sub
