Hey why is RAM Concept not capturing the entire mat footing? There is only one slab with prioirty one with thickness of 96 inches. The columns are all above the slab. This problem occurred when I deleted two columns on right of the core wall and then generated the mesh. Please help me with this. Thanks
Please share your model using the Secure File Upload link at the bottom of the page and then post a message here to let us know the file is uploaded.
I have another user with a similar issue (SR 7000813775). In his case the 3D view is truncated as if by a clipping plane. I just asked him to try updating his graphics adapter driver and/or overriding the hardware acceleration using the environment variables noted here: https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/38865/ram-concept-6-4-won-t-launch
You might want to try the same.
Thank you but it worked when I remodeled it.
