Hi!
Can I use STAAD.Pro V8i and STAAD.Pro CONNECT Edition at the same time and same machine if i only have one license?
Thanks!
The answer is YES. STAAD.Pro V8i and CE can co-exist in same PC and both the versions could be executed as and when required. Note that STAAD.Pro V8i doesn't allow users to use design codes not purchased. Therefore there is a potential cost involved for using additional Design code license(s). However, STAAD.Pro CE allows users to use all design codes supported by STAAD.Pro CE. We strongly recommend to use STAAD.Pro CE
