How can I do a P-Delta Analysis using spectrum response load? In order to do modal-spectral seismic analysis.
I read a question about tension/compresion members can not be used with spectrum response load, so it means that a meber tension can not be used too, is my understanding correct?
Thanks in advance
Pdelta and Response Spectrum do not go well together. The following wiki explains why
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/29006/p-delta-analysis-using-staad-for-response-spectrum-load-cases
An approximate way to account for dynamic effects in a pdelta analysis has been outlined by Raymond Curtis is his post below which you may refer to for guidance
https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/22867/p-delta-effect-plus-time-history-analysis-or-response-spectrum-analysis/51141#51141
Yes tension/compression cannot be used with response spectrum. The iterative Pdelta analysis in STAAD.Pro allows tension/compression though.
