*WARNING- NO MEMBERS LOADED FOR A WIND LOAD GENERATION
I tried finding anything regarding this warning in the output viewer but found nothing. What could cause this warning to show up? I reviewed the applied wind load and everything looks normal. I have this warning repeated 4 times at different lines of the input.
File attached.
Thanks.
RESIDENTIAL BUILDING 23.std
Dear user,
there are 2 observations for your structure.
1. Your structure contains duplicate beams. You can check the same under Utilities>Beam Tools> Duplicate Beams, as shown below. Please merge those beams .
2. The Y range provided for wind load along X direction for the top portion of the structure is not correct. Please check line # 7146,7151,7161,7169. Please check the co-ordinates for Y range and change
YR 52.8 55.8
to
YR 51.73 54.73.
You may also change the Y range for others as the max height is 54.73m instead of 55.8m. This will solve your issue.
Cheers!!
Ofcourse, I forgot to change the ranges when I changed the building height, but unfortunately I'm still getting the warning. (Does the warning come after the line that has the issue or before it as a title?)
you need to change those 4 lines. If you still get warning please check all ranges once again. If you still can not find out then upload the latest updated file.
Answer Verified By: dImeNsiOnFifTh
Yes it worked, i just noticed I didn't change one side of the range only.
HELLO
i have two problem, i struggle lot but couldn't done it any one can help me.
WARNING- One or more lines are too long and will be split into 2 lines. and *WARNING- NO MEMBERS LOADED FOR A WIND LOAD GENERATION.this is the modelp1.ANL
Can you please upload the .std file here? For first warning please refer below link.
https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/118211/warning
For second warning, please check the range values. Wind load is generated on a closed panel. Please check the same.
3146.p1.std
HERE IS THE FILE
THANKS FOR RESPONSE
