*WARNING- NO MEMBERS LOADED FOR A WIND LOAD GENERATION
I tried finding anything regarding this warning in the output viewer but found nothing. What could cause this warning to show up? I reviewed the applied wind load and everything looks normal. I have this warning repeated 4 times at different lines of the input.
File attached.
Thanks.
RESIDENTIAL BUILDING 23.std
Can you please upload the .std file here? For first warning please refer below link.
https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/118211/warning
For second warning, please check the range values. Wind load is generated on a closed panel. Please check the same.
3146.p1.std
HERE IS THE FILE
THANKS FOR RESPONSE
