STAAD.Pro CONNECT Edition Joint Load GUI Default values
Dear Folks,
I am using STAAD.Pro CONNECT Edition, the trouble I am facing is while putting joint loads using GUI, staad takes erratic value automatically. E.g. if we input some value only as FY=10.50 but staad takes it as Fz=0.5, Mx=0.50, My=0.50, Mz=0.50, ref snap attached;
Similar troubles are with load on member.
If anyone is aware of the fix of this problem then please respond. Your response will be highly appreciated.
Thank you !
