I have an issue with the response spectrum mass source definition in Eurocode 8
I have 4 load cases considering earthquake forces in (X, -X, Z, & -Z) directions.
I define the mass source for the response spectrum calculations as per the following steps and I need to confirm if these steps are accurate and correct or not.
Response Spectrum_Eurocode 8.std
The best way to define the seismic mass is to add a mass reference load case. Please find the attached model.
It is suggested that you use the loading which is contributing seismic mass in the three orthogonal direction (X, Y and Z) and use unsigned loading values to get rid of cancelation of mass.
You can add X and Z directional loading. In load combinations, you can take the effect of -ve directional EQ loading.4150.Response Spectrum_Eurocode 8.std
Thanks.
Thanks for your concern.
All my best regards,
Ahmad Abdalla
NCIC Project, Area Lead Engineer
CSA Department
thyssenkrupp Industrial Solutions (Egypt) S.A.E. 6A Mostafa Refeat Street, Sheraton Heliopolis Area,
11799 Cairo, Egypt
Mob. (Ger): +49-(0)152-1568 3998
Mob. (Egy): +20-(0)10-0520 8762
Tel. (Ger): +49-(0)231-547 Ext. 3674
Tel. (Egy): +20-(0)2-2266 2885/6 Ext. 2002
Fax (Ger): +49-(0)231-5475 7052
Fax (Egy): +20-(0)2-2269 1147
E-mail: Ahmad.Abdalla@thyssenkrupp.com
URL: http://www.thyssenkrupp-Industrial-Solutions.com
Registered office: Cairo, Commercial register: Cairo No. 11062
Chairman of the Supervisory Board: Dr. Van Thiel; Executive Board: Thore Lohmann, CEO; Thomas Kufahl, CFO
