No members loaded for a floor load generated
I am modeling a digester tank , there is a walk above the dome resting on rcc wall, to transfer the slab dead load and live load i have created dummy elements over the walls and applied the dead load and live load as floor loads by grouping the beams, the staad in the modeling mode it shows the load distribution of floor load but when I run the model the warring shows up saying , NO MEMBERS LOADED FOR A FLOOR LOAD GENERATED
Can i ignore the warning or is there some other way to transfer the dead load and live load to the walls without modeling the slab itself
  • Here with I have attached my stars file
    STAAD SPACE
    START JOB INFORMATION
    ENGINEER DATE 29-Aug-17
    END JOB INFORMATION
    INPUT WIDTH 79
    UNIT METER KN
    JOINT COORDINATES
    1774 10.5298 1.12121 0; 1775 10.4897 1.12121 0.917733;
    1776 10.4897 1.12121 -0.917733; 1777 10.5298 1.94421 0;
    1778 10.4897 1.94421 -0.917733; 1779 10.5298 2.76721 0;
    1780 10.4897 2.76721 -0.917733; 1781 10.5298 3.59021 0;
    1782 10.4897 3.59021 -0.917733; 1783 10.5298 4.41321 0;
    1784 10.4897 4.41321 -0.917733; 1785 10.5298 5.20754 0;
    1786 10.4897 5.20754 -0.917733; 1787 10.5298 6.00187 0;
    1788 10.4897 6.00187 -0.917733; 1789 10.5298 6.7962 0;
    1790 10.4897 6.7962 -0.917733; 1791 10.5298 7.59053 0;
    1792 10.4897 7.59053 -0.917733; 1793 10.5298 8.38486 0;
    1794 10.4897 8.38486 -0.917733; 1795 10.5298 9.17919 0;
    1796 10.4897 9.17919 -0.917733; 1797 10.5298 9.97352 0;
    1798 10.4897 9.97352 -0.917733; 1799 10.5298 10.7678 0;
    1800 10.4897 10.7678 -0.917733; 1801 10.5298 11.6265 0;
    1802 10.4897 11.6265 -0.917733; 1803 10.5298 12.4851 0;
    1804 10.4897 12.4851 -0.917733; 1805 10.5298 13.3437 0;
    1806 10.4897 13.3437 -0.917733; 1807 10.5298 14.2024 0;
    1808 10.4897 14.2024 -0.917733; 1809 10.5298 15.1726 0;
    1810 10.4897 15.1726 -0.917733; 1811 10.5298 16.1428 0;
    1812 10.4897 16.1428 -0.917733; 1813 10.5298 18.1243 0;
    1814 10.4897 18.1243 -0.917733; 1815 10.3698 1.12121 -1.82848;
    1816 10.3698 1.94421 -1.82848; 1817 10.3698 2.76721 -1.82848;
    1818 10.3698 3.59021 -1.82848; 1819 10.3698 4.41321 -1.82848;
    1820 10.3698 5.20754 -1.82848; 1821 10.3698 6.00187 -1.82848;
    1822 10.3698 6.7962 -1.82848; 1823 10.3698 7.59053 -1.82848;
    1824 10.3698 8.38486 -1.82848; 1825 10.3698 9.17919 -1.82848;
    1826 10.3698 9.97352 -1.82848; 1827 10.3698 10.7678 -1.82848;
    1828 10.3698 11.6265 -1.82848; 1829 10.3698 12.4851 -1.82848;
    1830 10.3698 13.3437 -1.82848; 1831 10.3698 14.2024 -1.82848;
    1832 10.3698 15.1726 -1.82848; 1833 10.3698 16.1428 -1.82848;
    1834 10.3698 18.1243 -1.82848; 1835 10.171 1.12121 -2.72531;
    1836 10.171 1.94421 -2.72531; 1837 10.171 2.76721 -2.72531;
    1838 10.171 3.59021 -2.72531; 1839 10.171 4.41321 -2.72531;
    1840 10.171 5.20754 -2.72531; 1841 10.171 6.00187 -2.72531;
    1842 10.171 6.7962 -2.72531; 1843 10.171 7.59053 -2.72531;
    1844 10.171 8.38486 -2.72531; 1845 10.171 9.17919 -2.72531;
    1846 10.171 9.97352 -2.72531; 1847 10.171 10.7678 -2.72531;
    1848 10.171 11.6265 -2.72531; 1849 10.171 12.4851 -2.72531;
    1850 10.171 13.3437 -2.72531; 1851 10.171 14.2024 -2.72531;
    1852 10.171 15.1726 -2.72531; 1853 10.171 16.1428 -2.72531;
    1854 10.171 18.1243 -2.72531; 1855 9.89478 1.12121 -3.60141;
    1856 9.89478 1.94421 -3.60141; 1857 9.89478 2.76721 -3.60141;
    1858 9.89478 3.59021 -3.60141; 1859 9.89478 4.41321 -3.60141;
    1860 9.89478 5.20754 -3.60141; 1861 9.89478 6.00187 -3.60141;
    1862 9.89478 6.7962 -3.60141; 1863 9.89478 7.59053 -3.60141;
    1864 9.89478 8.38486 -3.60141; 1865 9.89478 9.17919 -3.60141;
    1866 9.89478 9.97352 -3.60141; 1867 9.89478 10.7678 -3.60141;
    1868 9.89478 11.6265 -3.60141; 1869 9.89478 12.4851 -3.60141;
    1870 9.89478 13.3437 -3.60141; 1871 9.89478 14.2024 -3.60141;
    1872 9.89478 15.1726 -3.60141; 1873 9.89478 16.1428 -3.60141;
    1874 9.89478 18.1243 -3.60141; 1875 9.54325 1.12121 -4.45009;
    1876 9.54325 1.94421 -4.45009; 1877 9.54325 2.76721 -4.45009;
    1878 9.54325 3.59021 -4.45009; 1879 9.54325 4.41321 -4.45009;
    1880 9.54325 5.20754 -4.45009; 1881 9.54325 6.00187 -4.45009;
    1882 9.54325 6.7962 -4.45009; 1883 9.54325 7.59053 -4.45009;
    1884 9.54325 8.38486 -4.45009; 1885 9.54325 9.17919 -4.45009;
    1886 9.54325 9.97352 -4.45009; 1887 9.54325 10.7678 -4.45009;
    1888 9.54325 11.6265 -4.45009; 1889 9.54325 12.4851 -4.45009;
    1890 9.54325 13.3437 -4.45009; 1891 9.54325 14.2024 -4.45009;
    1892 9.54325 15.1726 -4.45009; 1893 9.54325 16.1428 -4.45009;
    1894 9.54325 18.1243 -4.45009; 1895 9.11908 1.12121 -5.2649;
    1896 9.11908 1.94421 -5.2649; 1897 9.11908 2.76721 -5.2649;
    1898 9.11908 3.59021 -5.2649; 1899 9.11908 4.41321 -5.2649;
    1900 9.11908 5.20754 -5.2649; 1901 9.11908 6.00187 -5.2649;
    1902 9.11908 6.7962 -5.2649; 1903 9.11908 7.59053 -5.2649;
    1904 9.11908 8.38486 -5.2649; 1905 9.11908 9.17919 -5.2649;
    1906 9.11908 9.97352 -5.2649; 1907 9.11908 10.7678 -5.2649;
    1908 9.11908 11.6265 -5.2649; 1909 9.11908 12.4851 -5.2649;
    1910 9.11908 13.3437 -5.2649; 1911 9.11908 14.2024 -5.2649;
    1912 9.11908 15.1726 -5.2649; 1913 9.11908 16.1428 -5.2649;
    1914 9.11908 18.1243 -5.2649; 1915 8.62551 1.12121 -6.03965;
    1916 8.62551 1.94421 -6.03965; 1917 8.62551 2.76721 -6.03965;
    1918 8.62551 3.59021 -6.03965; 1919 8.62551 4.41321 -6.03965;
    1920 8.62551 5.20754 -6.03965; 1921 8.62551 6.00187 -6.03965;
    1922 8.62551 6.7962 -6.03965; 1923 8.62551 7.59053 -6.03965;
    1924 8.62551 8.38486 -6.03965; 1925 8.62551 9.17919 -6.03965;
    1926 8.62551 9.97352 -6.03965; 1927 8.62551 10.7678 -6.03965;
    1928 8.62551 11.6265 -6.03965; 1929 8.62551 12.4851 -6.03965;
    1930 8.62551 13.3437 -6.03965; 1931 8.62551 14.2024 -6.03965;
    1932 8.62551 15.1726 -6.03965; 1933 8.62551 16.1428 -6.03965;
    1934 8.62551 18.1243 -6.03965; 1935 8.0663 1.12121 -6.76843;
    1936 8.0663 1.94421 -6.76843; 1937 8.0663 2.76721 -6.76843;
    1938 8.0663 3.59021 -6.76843; 1939 8.0663 4.41321 -6.76843;
    1940 8.0663 5.20754 -6.76843; 1941 8.0663 6.00187 -6.76843;
    1942 8.0663 6.7962 -6.76843; 1943 8.0663 7.59053 -6.76843;
    1944 8.0663 8.38486 -6.76843; 1945 8.0663 9.17919 -6.76843;
    1946 8.0663 9.97352 -6.76843; 1947 8.0663 10.7678 -6.76843;
    1948 8.0663 11.6265 -6.76843; 1949 8.0663 12.4851 -6.76843;
    1950 8.0663 13.3437 -6.76843; 1951 8.0663 14.2024 -6.76843;
    1952 8.0663 15.1726 -6.76843; 1953 8.0663 16.1428 -6.76843;
    1954 8.0663 18.1243 -6.76843; 1955 7.4457 1.12121 -7.4457;
    1956 7.4457 1.94421 -7.4457; 1957 7.4457 2.76721 -7.4457;
    1958 7.4457 3.59021 -7.4457; 1959 7.4457 4.41321 -7.4457;
    1960 7.4457 5.20754 -7.4457; 1961 7.4457 6.00187 -7.4457;
    1962 7.4457 6.7962 -7.4457; 1963 7.4457 7.59053 -7.4457;
    1964 7.4457 8.38486 -7.4457; 1965 7.4457 9.17919 -7.4457;
    1966 7.4457 9.97352 -7.4457; 1967 7.4457 10.7678 -7.4457;
    1968 7.4457 11.6265 -7.4457; 1969 7.4457 12.4851 -7.4457;
    1970 7.4457 13.3437 -7.4457; 1971 7.4457 14.2024 -7.4457;
    1972 7.4457 15.1726 -7.4457; 1973 7.4457 16.1428 -7.4457;
    1974 7.4457 18.1243 -7.4457; 1975 6.76843 1.12121 -8.0663;
    1976 6.76843 1.94421 -8.0663; 1977 6.76843 2.76721 -8.0663;
    1978 6.76843 3.59021 -8.0663; 1979 6.76843 4.41321 -8.0663;
    1980 6.76843 5.20754 -8.0663; 1981 6.76843 6.00187 -8.0663;
    1982 6.76843 6.7962 -8.0663; 1983 6.76843 7.59053 -8.0663;
    1984 6.76843 8.38486 -8.0663; 1985 6.76843 9.17919 -8.0663;
    1986 6.76843 9.97352 -8.0663; 1987 6.76843 10.7678 -8.0663;
    1988 6.76843 11.6265 -8.0663; 1989 6.76843 12.4851 -8.0663;
    1990 6.76843 13.3437 -8.0663; 1991 6.76843 14.2024 -8.0663;
    1992 6.76843 15.1726 -8.0663; 1993 6.76843 16.1428 -8.0663;
    1994 6.76843 18.1243 -8.0663; 1995 6.03965 1.12121 -8.62551;
    1996 6.03965 1.94421 -8.62551; 1997 6.03965 2.76721 -8.62551;
    1998 6.03965 3.59021 -8.62551; 1999 6.03965 4.41321 -8.62551;
    2000 6.03965 5.20754 -8.62551; 2001 6.03965 6.00187 -8.62551;
    2002 6.03965 6.7962 -8.62551; 2003 6.03965 7.59053 -8.62551;
    2004 6.03965 8.38486 -8.62551; 2005 6.03965 9.17919 -8.62551;
    2006 6.03965 9.97352 -8.62551; 2007 6.03965 10.7678 -8.62551;
    2008 6.03965 11.6265 -8.62551; 2009 6.03965 12.4851 -8.62551;
    2010 6.03965 13.3437 -8.62551; 2011 6.03965 14.2024 -8.62551;
    2012 6.03965 15.1726 -8.62551; 2013 6.03965 16.1428 -8.62551;
    2014 6.03965 18.1243 -8.62551; 2015 5.2649 1.12121 -9.11908;
    2016 5.2649 1.94421 -9.11908; 2017 5.2649 2.76721 -9.11908;
    2018 5.2649 3.59021 -9.11908; 2019 5.2649 4.41321 -9.11908;
    2020 5.2649 5.20754 -9.11908; 2021 5.2649 6.00187 -9.11908;
    2022 5.2649 6.7962 -9.11908; 2023 5.2649 7.59053 -9.11908;
    2024 5.2649 8.38486 -9.11908; 2025 5.2649 9.17919 -9.11908;
    2026 5.2649 9.97352 -9.11908; 2027 5.2649 10.7678 -9.11908;
    2028 5.2649 11.6265 -9.11908; 2029 5.2649 12.4851 -9.11908;
    2030 5.2649 13.3437 -9.11908; 2031 5.2649 14.2024 -9.11908;
    2032 5.2649 15.1726 -9.11908; 2033 5.2649 16.1428 -9.11908;
    2034 5.2649 18.1243 -9.11908; 2035 4.45009 1.12121 -9.54325;
    2036 4.45009 1.94421 -9.54325; 2037 4.45009 2.76721 -9.54325;
    2038 4.45009 3.59021 -9.54325; 2039 4.45009 4.41321 -9.54325;
    2040 4.45009 5.20754 -9.54325; 2041 4.45009 6.00187 -9.54325;
    2042 4.45009 6.7962 -9.54325; 2043 4.45009 7.59053 -9.54325;
    2044 4.45009 8.38486 -9.54325; 2045 4.45009 9.17919 -9.54325;
    2046 4.45009 9.97352 -9.54325; 2047 4.45009 10.7678 -9.54325;
    2048 4.45009 11.6265 -9.54325; 2049 4.45009 12.4851 -9.54325;
    2050 4.45009 13.3437 -9.54325; 2051 4.45009 14.2024 -9.54325;
    2052 4.45009 15.1726 -9.54325; 2053 4.45009 16.1428 -9.54325;
    2054 4.45009 18.1243 -9.54325; 2055 3.60141 1.12121 -9.89478;
    2056 3.60141 1.94421 -9.89478; 2057 3.60141 2.76721 -9.89478;
    2058 3.60141 3.59021 -9.89478; 2059 3.60141 4.41321 -9.89478;
    2060 3.60141 5.20754 -9.89478; 2061 3.60141 6.00187 -9.89478;
    2062 3.60141 6.7962 -9.89478; 2063 3.60141 7.59053 -9.89478;
    2064 3.60141 8.38486 -9.89478; 2065 3.60141 9.17919 -9.89478;
    2066 3.60141 9.97352 -9.89478; 2067 3.60141 10.7678 -9.89478;
    2068 3.60141 11.6265 -9.89478; 2069 3.60141 12.4851 -9.89478;
    2070 3.60141 13.3437 -9.89478; 2071 3.60141 14.2024 -9.89478;
    2072 3.60141 15.1726 -9.89478; 2073 3.60141 16.1428 -9.89478;
    2074 3.60141 18.1243 -9.89478; 2075 2.72531 1.12121 -10.171;
    2076 2.72531 1.94421 -10.171; 2077 2.72531 2.76721 -10.171;
    2078 2.72531 3.59021 -10.171; 2079 2.72531 4.41321 -10.171;
    2080 2.72531 5.20754 -10.171; 2081 2.72531 6.00187 -10.171;
    2082 2.72531 6.7962 -10.171; 2083 2.72531 7.59053 -10.171;
    2084 2.72531 8.38486 -10.171; 2085 2.72531 9.17919 -10.171;
    2086 2.72531 9.97352 -10.171; 2087 2.72531 10.7678 -10.171;
    2088 2.72531 11.6265 -10.171; 2089 2.72531 12.4851 -10.171;
    2090 2.72531 13.3437 -10.171; 2091 2.72531 14.2024 -10.171;
    2092 2.72531 15.1726 -10.171; 2093 2.72531 16.1428 -10.171;
    2094 2.72531 18.1243 -10.171; 2095 1.82848 1.12121 -10.3698;
    2096 1.82848 1.94421 -10.3698; 2097 1.82848 2.76721 -10.3698;
    2098 1.82848 3.59021 -10.3698; 2099 1.82848 4.41321 -10.3698;
    2100 1.82848 5.20754 -10.3698; 2101 1.82848 6.00187 -10.3698;
    2102 1.82848 6.7962 -10.3698; 2103 1.82848 7.59053 -10.3698;
    2104 1.82848 8.38486 -10.3698; 2105 1.82848 9.17919 -10.3698;
    2106 1.82848 9.97352 -10.3698; 2107 1.82848 10.7678 -10.3698;
    2108 1.82848 11.6265 -10.3698; 2109 1.82848 12.4851 -10.3698;
    2110 1.82848 13.3437 -10.3698; 2111 1.82848 14.2024 -10.3698;
    2112 1.82848 15.1726 -10.3698; 2113 1.82848 16.1428 -10.3698;
    2114 1.82848 18.1243 -10.3698; 2115 0.917733 1.12121 -10.4897;
    2116 0.917733 1.94421 -10.4897; 2117 0.917733 2.76721 -10.4897;
    2118 0.917733 3.59021 -10.4897; 2119 0.917733 4.41321 -10.4897;
    2120 0.917733 5.20754 -10.4897; 2121 0.917733 6.00187 -10.4897;
    2122 0.917733 6.7962 -10.4897; 2123 0.917733 7.59053 -10.4897;
    2124 0.917733 8.38486 -10.4897; 2125 0.917733 9.17919 -10.4897;
    2126 0.917733 9.97352 -10.4897; 2127 0.917733 10.7678 -10.4897;
    2128 0.917733 11.6265 -10.4897; 2129 0.917733 12.4851 -10.4897;
    2130 0.917733 13.3437 -10.4897; 2131 0.917733 14.2024 -10.4897;
    2132 0.917733 15.1726 -10.4897; 2133 0.917733 16.1428 -10.4897;
    2134 0.917733 18.1243 -10.4897; 2135 6.5892e-008 1.12121 -10.5298;
    2136 6.5892e-008 1.94421 -10.5298; 2137 6.5892e-008 2.76721 -10.5298;
    2138 6.5892e-008 3.59021 -10.5298; 2139 6.5892e-008 4.41321 -10.5298;
    2140 6.5892e-008 5.20754 -10.5298; 2141 6.5892e-008 6.00187 -10.5298;
    2142 6.5892e-008 6.7962 -10.5298; 2143 6.5892e-008 7.59053 -10.5298;
    2144 6.5892e-008 8.38486 -10.5298; 2145 6.5892e-008 9.17919 -10.5298;
    2146 6.5892e-008 9.97352 -10.5298; 2147 6.5892e-008 10.7678 -10.5298;
    2148 6.5892e-008 11.6265 -10.5298; 2149 6.5892e-008 12.4851 -10.5298;
    2150 6.5892e-008 13.3437 -10.5298; 2151 6.5892e-008 14.2024 -10.5298;
    2152 6.5892e-008 15.1726 -10.5298; 2153 6.5892e-008 16.1428 -10.5298;
    2154 6.79878e-008 18.1243 -10.5298; 2155 -0.917733 1.12121 -10.4897;
    2156 -0.917733 1.94421 -10.4897; 2157 -0.917733 2.76721 -10.4897;
    2158 -0.917733 3.59021 -10.4897; 2159 -0.917733 4.41321 -10.4897;
    2160 -0.917733 5.20754 -10.4897; 2161 -0.917733 6.00187 -10.4897;
    2162 -0.917733 6.7962 -10.4897; 2163 -0.917733 7.59053 -10.4897;
    2164 -0.917733 8.38486 -10.4897; 2165 -0.917733 9.17919 -10.4897;
    2166 -0.917733 9.97352 -10.4897; 2167 -0.917733 10.7678 -10.4897;
    2168 -0.917733 11.6265 -10.4897; 2169 -0.917733 12.4851 -10.4897;
    2170 -0.917733 13.3437 -10.4897; 2171 -0.917733 14.2024 -10.4897;
    2172 -0.917733 15.1726 -10.4897; 2173 -0.917733 16.1428 -10.4897;
    2174 -0.917733 18.1243 -10.4897; 2175 -1.82848 1.12121 -10.3698;
    2176 -1.82848 1.94421 -10.3698; 2177 -1.82848 2.76721 -10.3698;
    2178 -1.82848 3.59021 -10.3698; 2179 -1.82848 4.41321 -10.3698;
    2180 -1.82848 5.20754 -10.3698; 2181 -1.82848 6.00187 -10.3698;
    2182 -1.82848 6.7962 -10.3698; 2183 -1.82848 7.59053 -10.3698;
    2184 -1.82848 8.38486 -10.3698; 2185 -1.82848 9.17919 -10.3698;
    2186 -1.82848 9.97352 -10.3698; 2187 -1.82848 10.7678 -10.3698;
    2188 -1.82848 11.6265 -10.3698; 2189 -1.82848 12.4851 -10.3698;
    2190 -1.82848 13.3437 -10.3698; 2191 -1.82848 14.2024 -10.3698;
    2192 -1.82848 15.1726 -10.3698; 2193 -1.82848 16.1428 -10.3698;
    2194 -1.82848 18.1243 -10.3698; 2195 -2.72531 1.12121 -10.171;
    2196 -2.72531 1.94421 -10.171; 2197 -2.72531 2.76721 -10.171;
    2198 -2.72531 3.59021 -10.171; 2199 -2.72531 4.41321 -10.171;
    2200 -2.72531 5.20754 -10.171; 2201 -2.72531 6.00187 -10.171;
    2202 -2.72531 6.7962 -10.171; 2203 -2.72531 7.59053 -10.171;
    2204 -2.72531 8.38486 -10.171; 2205 -2.72531 9.17919 -10.171;
    2206 -2.72531 9.97352 -10.171; 2207 -2.72531 10.7678 -10.171;
    2208 -2.72531 11.6265 -10.171; 2209 -2.72531 12.4851 -10.171;
    2210 -2.72531 13.3437 -10.171; 2211 -2.72531 14.2024 -10.171;
    2212 -2.72531 15.1726 -10.171; 2213 -2.72531 16.1428 -10.171;
    2214 -2.72531 18.1243 -10.171; 2215 -3.60141 1.12121 -9.89478;
    2216 -3.60141 1.94421 -9.89478; 2217 -3.60141 2.76721 -9.89478;
    2218 -3.60141 3.59021 -9.89478; 2219 -3.60141 4.41321 -9.89478;
    2220 -3.60141 5.20754 -9.89478; 2221 -3.60141 6.00187 -9.89478;
    2222 -3.60141 6.7962 -9.89478; 2223 -3.60141 7.59053 -9.89478;
    2224 -3.60141 8.38486 -9.89478; 2225 -3.60141 9.17919 -9.89478;
    2226 -3.60141 9.97352 -9.89478; 2227 -3.60141 10.7678 -9.89478;
    2228 -3.60141 11.6265 -9.89478; 2229 -3.60141 12.4851 -9.89478;
    2230 -3.60141 13.3437 -9.89478; 2231 -3.60141 14.2024 -9.89478;
    2232 -3.60141 15.1726 -9.89478; 2233 -3.60141 16.1428 -9.89478;
    2234 -3.60141 18.1243 -9.89478; 2235 -4.45009 1.12121 -9.54325;
    2236 -4.45009 1.94421 -9.54325; 2237 -4.45009 2.76721 -9.54325;
    2238 -4.45009 3.59021 -9.54325; 2239 -4.45009 4.41321 -9.54325;
    2240 -4.45009 5.20754 -9.54325; 2241 -4.45009 6.00187 -9.54325;
    2242 -4.45009 6.7962 -9.54325; 2243 -4.45009 7.59053 -9.54325;
    2244 -4.45009 8.38486 -9.54325; 2245 -4.45009 9.17919 -9.54325;
    2246 -4.45009 9.97352 -9.54325; 2247 -4.45009 10.7678 -9.54325;
    2248 -4.45009 11.6265 -9.54325; 2249 -4.45009 12.4851 -9.54325;
    2250 -4.45009 13.3437 -9.54325; 2251 -4.45009 14.2024 -9.54325;
    2252 -4.45009 15.1726 -9.54325; 2253 -4.45009 16.1428 -9.54325;
    2254 -4.45009 18.1243 -9.54325; 2255 -5.2649 1.12121 -9.11908;
    2256 -5.2649 1.94421 -9.11908; 2257 -5.2649 2.76721 -9.11908;
    2258 -5.2649 3.59021 -9.11908; 2259 -5.2649 4.41321 -9.11908;
    2260 -5.2649 5.20754 -9.11908; 2261 -5.2649 6.00187 -9.11908;
    2262 -5.2649 6.7962 -9.11908; 2263 -5.2649 7.59053 -9.11908;
    2264 -5.2649 8.38486 -9.11908; 2265 -5.2649 9.17919 -9.11908;
    2266 -5.2649 9.97352 -9.11908; 2267 -5.2649 10.7678 -9.11908;
    2268 -5.2649 11.6265 -9.11908; 2269 -5.2649 12.4851 -9.11908;
    2270 -5.2649 13.3437 -9.11908; 2271 -5.2649 14.2024 -9.11908;
    2272 -5.2649 15.1726 -9.11908; 2273 -5.2649 16.1428 -9.11908;
    2274 -5.2649 18.1243 -9.11908; 2275 -6.03965 1.12121 -8.62551;
    2276 -6.03965 1.94421 -8.62551; 2277 -6.03965 2.76721 -8.62551;
    2278 -6.03965 3.59021 -8.62551; 2279 -6.03965 4.41321 -8.62551;
    2280 -6.03965 5.20754 -8.62551; 2281 -6.03965 6.00187 -8.62551;
    2282 -6.03965 6.7962 -8.62551; 2283 -6.03965 7.59053 -8.62551;
    2284 -6.03965 8.38486 -8.62551; 2285 -6.03965 9.17919 -8.62551;
    2286 -6.03965 9.97352 -8.62551; 2287 -6.03965 10.7678 -8.62551;
    2288 -6.03965 11.6265 -8.62551; 2289 -6.03965 12.4851 -8.62551;
    2290 -6.03965 13.3437 -8.62551; 2291 -6.03965 14.2024 -8.62551;
    2292 -6.03965 15.1726 -8.62551; 2293 -6.03965 16.1428 -8.62551;
    2294 -6.03965 18.1243 -8.62551; 2295 -6.76843 1.12121 -8.0663;
    2296 -6.76843 1.94421 -8.0663; 2297 -6.76843 2.76721 -8.0663;
    2298 -6.76843 3.59021 -8.0663; 2299 -6.76843 4.41321 -8.0663;
    2300 -6.76843 5.20754 -8.0663; 2301 -6.76843 6.00187 -8.0663;
    2302 -6.76843 6.7962 -8.0663; 2303 -6.76843 7.59053 -8.0663;
    2304 -6.76843 8.38486 -8.0663; 2305 -6.76843 9.17919 -8.0663;
    2306 -6.76843 9.97352 -8.0663; 2307 -6.76843 10.7678 -8.0663;
    2308 -6.76843 11.6265 -8.0663; 2309 -6.76843 12.4851 -8.0663;
    2310 -6.76843 13.3437 -8.0663; 2311 -6.76843 14.2024 -8.0663;
    2312 -6.76843 15.1726 -8.0663; 2313 -6.76843 16.1428 -8.0663;
    2314 -6.76843 18.1243 -8.0663; 2315 -7.4457 1.12121 -7.4457;
    2316 -7.4457 1.94421 -7.4457; 2317 -7.4457 2.76721 -7.4457;
    2318 -7.4457 3.59021 -7.4457; 2319 -7.4457 4.41321 -7.4457;
    2320 -7.4457 5.20754 -7.4457; 2321 -7.4457 6.00187 -7.4457;
    2322 -7.4457 6.7962 -7.4457; 2323 -7.4457 7.59053 -7.4457;
    2324 -7.4457 8.38486 -7.4457; 2325 -7.4457 9.17919 -7.4457;
    2326 -7.4457 9.97352 -7.4457; 2327 -7.4457 10.7678 -7.4457;
    2328 -7.4457 11.6265 -7.4457; 2329 -7.4457 12.4851 -7.4457;
    2330 -7.4457 13.3437 -7.4457; 2331 -7.4457 14.2024 -7.4457;
    2332 -7.4457 15.1726 -7.4457; 2333 -7.4457 16.1428 -7.4457;
    2334 -7.4457 18.1243 -7.4457; 2335 -8.0663 1.12121 -6.76843;
    2336 -8.0663 1.94421 -6.76843; 2337 -8.0663 2.76721 -6.76843;
    2338 -8.0663 3.59021 -6.76843; 2339 -8.0663 4.41321 -6.76843;
    2340 -8.0663 5.20754 -6.76843; 2341 -8.0663 6.00187 -6.76843;
    2342 -8.0663 6.7962 -6.76843; 2343 -8.0663 7.59053 -6.76843;
    2344 -8.0663 8.38486 -6.76843; 2345 -8.0663 9.17919 -6.76843;
    2346 -8.0663 9.97352 -6.76843; 2347 -8.0663 10.7678 -6.76843;
    2348 -8.0663 11.6265 -6.76843; 2349 -8.0663 12.4851 -6.76843;
    2350 -8.0663 13.3437 -6.76843; 2351 -8.0663 14.2024 -6.76843;
    2352 -8.0663 15.1726 -6.76843; 2353 -8.0663 16.1428 -6.76843;
    2354 -8.0663 18.1243 -6.76843; 2355 -8.62551 1.12121 -6.03965;
    2356 -8.62551 1.94421 -6.03965; 2357 -8.62551 2.76721 -6.03965;
    2358 -8.62551 3.59021 -6.03965; 2359 -8.62551 4.41321 -6.03965;
    2360 -8.62551 5.20754 -6.03965; 2361 -8.62551 6.00187 -6.03965;
    2362 -8.62551 6.7962 -6.03965; 2363 -8.62551 7.59053 -6.03965;
    2364 -8.62551 8.38486 -6.03965; 2365 -8.62551 9.17919 -6.03965;
    2366 -8.62551 9.97352 -6.03965; 2367 -8.62551 10.7678 -6.03965;
    2368 -8.62551 11.6265 -6.03965; 2369 -8.62551 12.4851 -6.03965;
    2370 -8.62551 13.3437 -6.03965; 2371 -8.62551 14.2024 -6.03965;
    2372 -8.62551 15.1726 -6.03965; 2373 -8.62551 16.1428 -6.03965;
    2374 -8.62551 18.1243 -6.03965; 2375 -9.11908 1.12121 -5.2649;
    2376 -9.11908 1.94421 -5.2649; 2377 -9.11908 2.76721 -5.2649;
    2378 -9.11908 3.59021 -5.2649; 2379 -9.11908 4.41321 -5.2649;
    2380 -9.11908 5.20754 -5.2649; 2381 -9.11908 6.00187 -5.2649;
    2382 -9.11908 6.7962 -5.2649; 2383 -9.11908 7.59053 -5.2649;
    2384 -9.11908 8.38486 -5.2649; 2385 -9.11908 9.17919 -5.2649;
    2386 -9.11908 9.97352 -5.2649; 2387 -9.11908 10.7678 -5.2649;
    2388 -9.11908 11.6265 -5.2649; 2389 -9.11908 12.4851 -5.2649;
    2390 -9.11908 13.3437 -5.2649; 2391 -9.11908 14.2024 -5.2649;
    2392 -9.11908 15.1726 -5.2649; 2393 -9.11908 16.1428 -5.2649;
    2394 -9.11908 18.1243 -5.2649; 2395 -9.54325 1.12121 -4.45009;
    2396 -9.54325 1.94421 -4.45009; 2397 -9.54325 2.76721 -4.45009;
    2398 -9.54325 3.59021 -4.45009; 2399 -9.54325 4.41321 -4.45009;
    2400 -9.54325 5.20754 -4.45009; 2401 -9.54325 6.00187 -4.45009;
    2402 -9.54325 6.7962 -4.45009; 2403 -9.54325 7.59053 -4.45009;
    2404 -9.54325 8.38486 -4.45009; 2405 -9.54325 9.17919 -4.45009;
    2406 -9.54325 9.97352 -4.45009; 2407 -9.54325 10.7678 -4.45009;
    2408 -9.54325 11.6265 -4.45009; 2409 -9.54325 12.4851 -4.45009;
    2410 -9.54325 13.3437 -4.45009; 2411 -9.54325 14.2024 -4.45009;
    2412 -9.54325 15.1726 -4.45009; 2413 -9.54325 16.1428 -4.45009;
    2414 -9.54325 18.1243 -4.45009; 2415 -9.89478 1.12121 -3.60141;
    2416 -9.89478 1.94421 -3.60141; 2417 -9.89478 2.76721 -3.60141;
    2418 -9.89478 3.59021 -3.60141; 2419 -9.89478 4.41321 -3.60141;
    2420 -9.89478 5.20754 -3.60141; 2421 -9.89478 6.00187 -3.60141;
    2422 -9.89478 6.7962 -3.60141; 2423 -9.89478 7.59053 -3.60141;
    2424 -9.89478 8.38486 -3.60141; 2425 -9.89478 9.17919 -3.60141;
    2426 -9.89478 9.97352 -3.60141; 2427 -9.89478 10.7678 -3.60141;
    2428 -9.89478 11.6265 -3.60141; 2429 -9.89478 12.4851 -3.60141;
    2430 -9.89478 13.3437 -3.60141; 2431 -9.89478 14.2024 -3.60141;
    2432 -9.89478 15.1726 -3.60141; 2433 -9.89478 16.1428 -3.60141;
    2434 -9.89478 18.1243 -3.60141; 2435 -10.171 1.12121 -2.72531;
    2436 -10.171 1.94421 -2.72531; 2437 -10.171 2.76721 -2.72531;
    2438 -10.171 3.59021 -2.72531; 2439 -10.171 4.41321 -2.72531;
    2440 -10.171 5.20754 -2.72531; 2441 -10.171 6.00187 -2.72531;
    2442 -10.171 6.7962 -2.72531; 2443 -10.171 7.59053 -2.72531;
    2444 -10.171 8.38486 -2.72531; 2445 -10.171 9.17919 -2.72531;
    2446 -10.171 9.97352 -2.72531; 2447 -10.171 10.7678 -2.72531;
    2448 -10.171 11.6265 -2.72531; 2449 -10.171 12.4851 -2.72531;
    2450 -10.171 13.3437 -2.72531; 2451 -10.171 14.2024 -2.72531;
    2452 -10.171 15.1726 -2.72531; 2453 -10.171 16.1428 -2.72531;
    2454 -10.171 18.1243 -2.72531; 2455 -10.3698 1.12121 -1.82848;
    2456 -10.3698 1.94421 -1.82848; 2457 -10.3698 2.76721 -1.82848;
    2458 -10.3698 3.59021 -1.82848; 2459 -10.3698 4.41321 -1.82848;
    2460 -10.3698 5.20754 -1.82848; 2461 -10.3698 6.00187 -1.82848;
    2462 -10.3698 6.7962 -1.82848; 2463 -10.3698 7.59053 -1.82848;
    2464 -10.3698 8.38486 -1.82848; 2465 -10.3698 9.17919 -1.82848;
    2466 -10.3698 9.97352 -1.82848; 2467 -10.3698 10.7678 -1.82848;
    2468 -10.3698 11.6265 -1.82848; 2469 -10.3698 12.4851 -1.82848;
    2470 -10.3698 13.3437 -1.82848; 2471 -10.3698 14.2024 -1.82848;
    2472 -10.3698 15.1726 -1.82848; 2473 -10.3698 16.1428 -1.82848;
    2474 -10.3698 18.1243 -1.82848; 2475 -10.4897 1.12121 -0.917733;
    2476 -10.4897 1.94421 -0.917733; 2477 -10.4897 2.76721 -0.917733;
    2478 -10.4897 3.59021 -0.917733; 2479 -10.4897 4.41321 -0.917733;
    2480 -10.4897 5.20754 -0.917733; 2481 -10.4897 6.00187 -0.917733;
    2482 -10.4897 6.7962 -0.917733; 2483 -10.4897 7.59053 -0.917733;
    2484 -10.4897 8.38486 -0.917733; 2485 -10.4897 9.17919 -0.917733;
    2486 -10.4897 9.97352 -0.917733; 2487 -10.4897 10.7678 -0.917733;
    2488 -10.4897 11.6265 -0.917733; 2489 -10.4897 12.4851 -0.917733;
    2490 -10.4897 13.3437 -0.917733; 2491 -10.4897 14.2024 -0.917733;
    2492 -10.4897 15.1726 -0.917733; 2493 -10.4897 16.1428 -0.917733;
    2494 -10.4897 18.1243 -0.917733; 2495 -10.5298 1.12121 -6.5892e-008;
    2496 -10.5298 1.94421 -6.5892e-008; 2497 -10.5298 2.76721 -6.5892e-008;
    2498 -10.5298 3.59021 -6.5892e-008; 2499 -10.5298 4.41321 -6.5892e-008;
    2500 -10.5298 5.20754 -6.5892e-008; 2501 -10.5298 6.00187 -6.5892e-008;
    2502 -10.5298 6.7962 -6.5892e-008; 2503 -10.5298 7.59053 -6.5892e-008;
    2504 -10.5298 8.38486 -6.5892e-008; 2505 -10.5298 9.17919 -6.5892e-008;
    2506 -10.5298 9.97352 -6.5892e-008; 2507 -10.5298 10.7678 -6.5892e-008;
    2508 -10.5298 11.6265 -6.5892e-008; 2509 -10.5298 12.4851 -6.5892e-008;
    2510 -10.5298 13.3437 -6.5892e-008; 2511 -10.5298 14.2024 -6.5892e-008;
    2512 -10.5298 15.1726 -6.5892e-008; 2513 -10.5298 16.1428 -6.5892e-008;
    2514 -10.5298 18.1243 -6.5892e-008; 2515 -10.4897 1.12121 0.917733;
    2516 -10.4897 1.94421 0.917733; 2517 -10.4897 2.76721 0.917733;
    2518 -10.4897 3.59021 0.917733; 2519 -10.4897 4.41321 0.917733;
    2520 -10.4897 5.20754 0.917733; 2521 -10.4897 6.00187 0.917733;
    2522 -10.4897 6.7962 0.917733; 2523 -10.4897 7.59053 0.917733;
    2524 -10.4897 8.38486 0.917733; 2525 -10.4897 9.17919 0.917733;
    2526 -10.4897 9.97352 0.917733; 2527 -10.4897 10.7678 0.917733;
    2528 -10.4897 11.6265 0.917733; 2529 -10.4897 12.4851 0.917733;
    2530 -10.4897 13.3437 0.917733; 2531 -10.4897 14.2024 0.917733;
    2532 -10.4897 15.1726 0.917733; 2533 -10.4897 16.1428 0.917733;
    2534 -10.4897 18.1243 0.917733; 2535 -10.3698 1.12121 1.82848;
    2536 -10.3698 1.94421 1.82848; 2537 -10.3698 2.76721 1.82848;
    2538 -10.3698 3.59021 1.82848; 2539 -10.3698 4.41321 1.82848;
    2540 -10.3698 5.20754 1.82848; 2541 -10.3698 6.00187 1.82848;
    2542 -10.3698 6.7962 1.82848; 2543 -10.3698 7.59053 1.82848;
    2544 -10.3698 8.38486 1.82848; 2545 -10.3698 9.17919 1.82848;
    2546 -10.3698 9.97352 1.82848; 2547 -10.3698 10.7678 1.82848;
    2548 -10.3698 11.6265 1.82848; 2549 -10.3698 12.4851 1.82848;
    2550 -10.3698 13.3437 1.82848; 2551 -10.3698 14.2024 1.82848;
    2552 -10.3698 15.1726 1.82848; 2553 -10.3698 16.1428 1.82848;
    2554 -10.3698 18.1243 1.82848; 2555 -10.171 1.12121 2.72531;
    2556 -10.171 1.94421 2.72531; 2557 -10.171 2.76721 2.72531;
    2558 -10.171 3.59021 2.72531; 2559 -10.171 4.41321 2.72531;
    2560 -10.171 5.20754 2.72531; 2561 -10.171 6.00187 2.72531;
    2562 -10.171 6.7962 2.72531; 2563 -10.171 7.59053 2.72531;
    2564 -10.171 8.38486 2.72531; 2565 -10.171 9.17919 2.72531;
    2566 -10.171 9.97352 2.72531; 2567 -10.171 10.7678 2.72531;
    2568 -10.171 11.6265 2.72531; 2569 -10.171 12.4851 2.72531;
    2570 -10.171 13.3437 2.72531; 2571 -10.171 14.2024 2.72531;
    2572 -10.171 15.1726 2.72531; 2573 -10.171 16.1428 2.72531;
    2574 -10.171 18.1243 2.72531; 2575 -9.89478 1.12121 3.60141;
    2576 -9.89478 1.94421 3.60141; 2577 -9.89478 2.76721 3.60141;
    2578 -9.89478 3.59021 3.60141; 2579 -9.89478 4.41321 3.60141;
    2580 -9.89478 5.20754 3.60141; 2581 -9.89478 6.00187 3.60141;
    2582 -9.89478 6.7962 3.60141; 2583 -9.89478 7.59053 3.60141;
    2584 -9.89478 8.38486 3.60141; 2585 -9.89478 9.17919 3.60141;
    2586 -9.89478 9.97352 3.60141; 2587 -9.89478 10.7678 3.60141;
    2588 -9.89478 11.6265 3.60141; 2589 -9.89478 12.4851 3.60141;
    2590 -9.89478 13.3437 3.60141; 2591 -9.89478 14.2024 3.60141;
    2592 -9.89478 15.1726 3.60141; 2593 -9.89478 16.1428 3.60141;
    2594 -9.89478 18.1243 3.60141; 2595 -9.54325 1.12121 4.45009;
    2596 -9.54325 1.94421 4.45009; 2597 -9.54325 2.76721 4.45009;
    2598 -9.54325 3.59021 4.45009; 2599 -9.54325 4.41321 4.45009;
    2600 -9.54325 5.20754 4.45009; 2601 -9.54325 6.00187 4.45009;
    2602 -9.54325 6.7962 4.45009; 2603 -9.54325 7.59053 4.45009;
    2604 -9.54325 8.38486 4.45009; 2605 -9.54325 9.17919 4.45009;
    2606 -9.54325 9.97352 4.45009; 2607 -9.54325 10.7678 4.45009;
    2608 -9.54325 11.6265 4.45009; 2609 -9.54325 12.4851 4.45009;
    2610 -9.54325 13.3437 4.45009; 2611 -9.54325 14.2024 4.45009;
    2612 -9.54325 15.1726 4.45009; 2613 -9.54325 16.1428 4.45009;
    2614 -9.54325 18.1243 4.45009; 2615 -9.11908 1.12121 5.2649;
    2616 -9.11908 1.94421 5.2649; 2617 -9.11908 2.76721 5.2649;
    2618 -9.11908 3.59021 5.2649; 2619 -9.11908 4.41321 5.2649;
    2620 -9.11908 5.20754 5.2649; 2621 -9.11908 6.00187 5.2649;
    2622 -9.11908 6.7962 5.2649; 2623 -9.11908 7.59053 5.2649;
    2624 -9.11908 8.38486 5.2649; 2625 -9.11908 9.17919 5.2649;
    2626 -9.11908 9.97352 5.2649; 2627 -9.11908 10.7678 5.2649;
    2628 -9.11908 11.6265 5.2649; 2629 -9.11908 12.4851 5.2649;
    2630 -9.11908 13.3437 5.2649; 2631 -9.11908 14.2024 5.2649;
    2632 -9.11908 15.1726 5.2649; 2633 -9.11908 16.1428 5.2649;
    2634 -9.11908 18.1243 5.2649; 2635 -8.62551 1.12121 6.03965;
    2636 -8.62551 1.94421 6.03965; 2637 -8.62551 2.76721 6.03965;
    2638 -8.62551 3.59021 6.03965; 2639 -8.62551 4.41321 6.03965;
    2640 -8.62551 5.20754 6.03965; 2641 -8.62551 6.00187 6.03965;
    2642 -8.62551 6.7962 6.03965; 2643 -8.62551 7.59053 6.03965;
    2644 -8.62551 8.38486 6.03965; 2645 -8.62551 9.17919 6.03965;
    2646 -8.62551 9.97352 6.03965; 2647 -8.62551 10.7678 6.03965;
    2648 -8.62551 11.6265 6.03965; 2649 -8.62551 12.4851 6.03965;
    2650 -8.62551 13.3437 6.03965; 2651 -8.62551 14.2024 6.03965;
    2652 -8.62551 15.1726 6.03965; 2653 -8.62551 16.1428 6.03965;
    2654 -8.62551 18.1243 6.03965; 2655 -8.0663 1.12121 6.76843;
    2656 -8.0663 1.94421 6.76843; 2657 -8.0663 2.76721 6.76843;
    2658 -8.0663 3.59021 6.76843; 2659 -8.0663 4.41321 6.76843;
    2660 -8.0663 5.20754 6.76843; 2661 -8.0663 6.00187 6.76843;
    2662 -8.0663 6.7962 6.76843; 2663 -8.0663 7.59053 6.76843;
    2664 -8.0663 8.38486 6.76843; 2665 -8.0663 9.17919 6.76843;
    2666 -8.0663 9.97352 6.76843; 2667 -8.0663 10.7678 6.76843;
    2668 -8.0663 11.6265 6.76843; 2669 -8.0663 12.4851 6.76843;
    2670 -8.0663 13.3437 6.76843; 2671 -8.0663 14.2024 6.76843;
    2672 -8.0663 15.1726 6.76843; 2673 -8.0663 16.1428 6.76843;
    2674 -8.0663 18.1243 6.76843; 2675 -7.4457 1.12121 7.4457;
    2676 -7.4457 1.94421 7.4457; 2677 -7.4457 2.76721 7.4457;
    2678 -7.4457 3.59021 7.4457; 2679 -7.4457 4.41321 7.4457;
    2680 -7.4457 5.20754 7.4457; 2681 -7.4457 6.00187 7.4457;
    2682 -7.4457 6.7962 7.4457; 2683 -7.4457 7.59053 7.4457;
    2684 -7.4457 8.38486 7.4457; 2685 -7.4457 9.17919 7.4457;
    2686 -7.4457 9.97352 7.4457; 2687 -7.4457 10.7678 7.4457;
    2688 -7.4457 11.6265 7.4457; 2689 -7.4457 12.4851 7.4457;
    2690 -7.4457 13.3437 7.4457; 2691 -7.4457 14.2024 7.4457;
    2692 -7.4457 15.1726 7.4457; 2693 -7.4457 16.1428 7.4457;
    2694 -7.4457 18.1243 7.4457; 2695 -6.76843 1.12121 8.0663;
    2696 -6.76843 1.94421 8.0663; 2697 -6.76843 2.76721 8.0663;
    2698 -6.76843 3.59021 8.0663; 2699 -6.76843 4.41321 8.0663;
    2700 -6.76843 5.20754 8.0663; 2701 -6.76843 6.00187 8.0663;
    2702 -6.76843 6.7962 8.0663; 2703 -6.76843 7.59053 8.0663;
    2704 -6.76843 8.38486 8.0663; 2705 -6.76843 9.17919 8.0663;
    2706 -6.76843 9.97352 8.0663; 2707 -6.76843 10.7678 8.0663;
    2708 -6.76843 11.6265 8.0663; 2709 -6.76843 12.4851 8.0663;
    2710 -6.76843 13.3437 8.0663; 2711 -6.76843 14.2024 8.0663;
    2712 -6.76843 15.1726 8.0663; 2713 -6.76843 16.1428 8.0663;
    2714 -6.76843 18.1243 8.0663; 2715 -6.03965 1.12121 8.62551;
    2716 -6.03965 1.94421 8.62551; 2717 -6.03965 2.76721 8.62551;
    2718 -6.03965 3.59021 8.62551; 2719 -6.03965 4.41321 8.62551;
    2720 -6.03965 5.20754 8.62551; 2721 -6.03965 6.00187 8.62551;
    2722 -6.03965 6.7962 8.62551; 2723 -6.03965 7.59053 8.62551;
    2724 -6.03965 8.38486 8.62551; 2725 -6.03965 9.17919 8.62551;
    2726 -6.03965 9.97352 8.62551; 2727 -6.03965 10.7678 8.62551;
    2728 -6.03965 11.6265 8.62551; 2729 -6.03965 12.4851 8.62551;
    2730 -6.03965 13.3437 8.62551; 2731 -6.03965 14.2024 8.62551;
    2732 -6.03965 15.1726 8.62551; 2733 -6.03965 16.1428 8.62551;
    2734 -6.03965 18.1243 8.62551; 2735 -5.2649 1.12121 9.11908;
    2736 -5.2649 1.94421 9.11908; 2737 -5.2649 2.76721 9.11908;
    2738 -5.2649 3.59021 9.11908; 2739 -5.2649 4.41321 9.11908;
    2740 -5.2649 5.20754 9.11908; 2741 -5.2649 6.00187 9.11908;
    2742 -5.2649 6.7962 9.11908; 2743 -5.2649 7.59053 9.11908;
    2744 -5.2649 8.38486 9.11908; 2745 -5.2649 9.17919 9.11908;
    2746 -5.2649 9.97352 9.11908; 2747 -5.2649 10.7678 9.11908;
    2748 -5.2649 11.6265 9.11908; 2749 -5.2649 12.4851 9.11908;
    2750 -5.2649 13.3437 9.11908; 2751 -5.2649 14.2024 9.11908;
    2752 -5.2649 15.1726 9.11908; 2753 -5.2649 16.1428 9.11908;
    2754 -5.2649 18.1243 9.11908; 2755 -4.45009 1.12121 9.54325;
    2756 -4.45009 1.94421 9.54325; 2757 -4.45009 2.76721 9.54325;
    2758 -4.45009 3.59021 9.54325; 2759 -4.45009 4.41321 9.54325;
    2760 -4.45009 5.20754 9.54325; 2761 -4.45009 6.00187 9.54325;
    2762 -4.45009 6.7962 9.54325; 2763 -4.45009 7.59053 9.54325;
    2764 -4.45009 8.38486 9.54325; 2765 -4.45009 9.17919 9.54325;
    2766 -4.45009 9.97352 9.54325; 2767 -4.45009 10.7678 9.54325;
    2768 -4.45009 11.6265 9.54325; 2769 -4.45009 12.4851 9.54325;
    2770 -4.45009 13.3437 9.54325; 2771 -4.45009 14.2024 9.54325;
    2772 -4.45009 15.1726 9.54325; 2773 -4.45009 16.1428 9.54325;
    2774 -4.45009 18.1243 9.54325; 2775 -3.60141 1.12121 9.89478;
    2776 -3.60141 1.94421 9.89478; 2777 -3.60141 2.76721 9.89478;
    2778 -3.60141 3.59021 9.89478; 2779 -3.60141 4.41321 9.89478;
    2780 -3.60141 5.20754 9.89478; 2781 -3.60141 6.00187 9.89478;
    2782 -3.60141 6.7962 9.89478; 2783 -3.60141 7.59053 9.89478;
    2784 -3.60141 8.38486 9.89478; 2785 -3.60141 9.17919 9.89478;
    2786 -3.60141 9.97352 9.89478; 2787 -3.60141 10.7678 9.89478;
    2788 -3.60141 11.6265 9.89478; 2789 -3.60141 12.4851 9.89478;
    2790 -3.60141 13.3437 9.89478; 2791 -3.60141 14.2024 9.89478;
    2792 -3.60141 15.1726 9.89478; 2793 -3.60141 16.1428 9.89478;
    2794 -3.60141 18.1243 9.89478; 2795 -2.72531 1.12121 10.171;
    2796 -2.72531 1.94421 10.171; 2797 -2.72531 2.76721 10.171;
    2798 -2.72531 3.59021 10.171; 2799 -2.72531 4.41321 10.171;
    2800 -2.72531 5.20754 10.171; 2801 -2.72531 6.00187 10.171;
    2802 -2.72531 6.7962 10.171; 2803 -2.72531 7.59053 10.171;
    2804 -2.72531 8.38486 10.171; 2805 -2.72531 9.17919 10.171;
    2806 -2.72531 9.97352 10.171; 2807 -2.72531 10.7678 10.171;
    2808 -2.72531 11.6265 10.171; 2809 -2.72531 12.4851 10.171;
    2810 -2.72531 13.3437 10.171; 2811 -2.72531 14.2024 10.171;
    2812 -2.72531 15.1726 10.171; 2813 -2.72531 16.1428 10.171;
    2814 -2.72531 18.1243 10.171; 2815 -1.82848 1.12121 10.3698;
    2816 -1.82848 1.94421 10.3698; 2817 -1.82848 2.76721 10.3698;
    2818 -1.82848 3.59021 10.3698; 2819 -1.82848 4.41321 10.3698;
    2820 -1.82848 5.20754 10.3698; 2821 -1.82848 6.00187 10.3698;
    2822 -1.82848 6.7962 10.3698; 2823 -1.82848 7.59053 10.3698;
    2824 -1.82848 8.38486 10.3698; 2825 -1.82848 9.17919 10.3698;
    2826 -1.82848 9.97352 10.3698; 2827 -1.82848 10.7678 10.3698;
    2828 -1.82848 11.6265 10.3698; 2829 -1.82848 12.4851 10.3698;
    2830 -1.82848 13.3437 10.3698; 2831 -1.82848 14.2024 10.3698;
    2832 -1.82848 15.1726 10.3698; 2833 -1.82848 16.1428 10.3698;
    2834 -1.82848 18.1243 10.3698; 2835 -0.917733 1.12121 10.4897;
    2836 -0.917733 1.94421 10.4897; 2837 -0.917733 2.76721 10.4897;
    2838 -0.917733 3.59021 10.4897; 2839 -0.917733 4.41321 10.4897;
    2840 -0.917733 5.20754 10.4897; 2841 -0.917733 6.00187 10.4897;
    2842 -0.917733 6.7962 10.4897; 2843 -0.917733 7.59053 10.4897;
    2844 -0.917733 8.38486 10.4897; 2845 -0.917733 9.17919 10.4897;
    2846 -0.917733 9.97352 10.4897; 2847 -0.917733 10.7678 10.4897;
    2848 -0.917733 11.6265 10.4897; 2849 -0.917733 12.4851 10.4897;
    2850 -0.917733 13.3437 10.4897; 2851 -0.917733 14.2024 10.4897;
    2852 -0.917733 15.1726 10.4897; 2853 -0.917733 16.1428 10.4897;
    2854 -0.917733 18.1243 10.4897; 2855 -6.5892e-008 1.12121 10.5298;
    2856 -6.5892e-008 1.94421 10.5298; 2857 -6.5892e-008 2.76721 10.5298;
    2858 -6.5892e-008 3.59021 10.5298; 2861 -6.5892e-008 6.00187 10.5298;
    2862 -6.5892e-008 6.7962 10.5298; 2863 -6.5892e-008 7.59053 10.5298;
    2864 -6.5892e-008 8.38486 10.5298; 2865 -6.5892e-008 9.17919 10.5298;
    2866 -6.5892e-008 9.97352 10.5298; 2867 -6.5892e-008 10.7678 10.5298;
    2868 -6.5892e-008 11.6265 10.5298; 2869 -6.5892e-008 12.4851 10.5298;
    2870 -6.5892e-008 13.3437 10.5298; 2871 -6.5892e-008 14.2024 10.5298;
    2872 -6.5892e-008 15.1726 10.5298; 2873 -6.5892e-008 16.1428 10.5298;
    2874 -6.37962e-008 18.1243 10.5298; 2875 0.917733 1.12121 10.4897;
    2876 0.917733 1.94421 10.4897; 2877 0.917733 2.76721 10.4897;
    2878 0.917733 3.59021 10.4897; 2879 0.917733 4.41321 10.4897;
    2880 0.917733 5.20754 10.4897; 2881 0.917733 6.00187 10.4897;
    2882 0.917733 6.7962 10.4897; 2883 0.917733 7.59053 10.4897;
    2884 0.917733 8.38486 10.4897; 2885 0.917733 9.17919 10.4897;
    2886 0.917733 9.97352 10.4897; 2887 0.917733 10.7678 10.4897;
    2888 0.917733 11.6265 10.4897; 2889 0.917733 12.4851 10.4897;
    2890 0.917733 13.3437 10.4897; 2891 0.917733 14.2024 10.4897;
    2892 0.917733 15.1726 10.4897; 2893 0.917733 16.1428 10.4897;
    2894 0.917733 18.1243 10.4897; 2895 1.82848 1.12121 10.3698;
    2896 1.82848 1.94421 10.3698; 2897 1.82848 2.76721 10.3698;
    2898 1.82848 3.59021 10.3698; 2899 1.82848 4.41321 10.3698;
    2900 1.82848 5.20754 10.3698; 2901 1.82848 6.00187 10.3698;
    2902 1.82848 6.7962 10.3698; 2903 1.82848 7.59053 10.3698;
    2904 1.82848 8.38486 10.3698; 2905 1.82848 9.17919 10.3698;
    2906 1.82848 9.97352 10.3698; 2907 1.82848 10.7678 10.3698;
    2908 1.82848 11.6265 10.3698; 2909 1.82848 12.4851 10.3698;
    2910 1.82848 13.3437 10.3698; 2911 1.82848 14.2024 10.3698;
    2912 1.82848 15.1726 10.3698; 2913 1.82848 16.1428 10.3698;
    2914 1.82848 18.1243 10.3698; 2915 2.72531 1.12121 10.171;
    2916 2.72531 1.94421 10.171; 2917 2.72531 2.76721 10.171;
    2918 2.72531 3.59021 10.171; 2919 2.72531 4.41321 10.171;
    2920 2.72531 5.20754 10.171; 2921 2.72531 6.00187 10.171;
    2922 2.72531 6.7962 10.171; 2923 2.72531 7.59053 10.171;
    2924 2.72531 8.38486 10.171; 2925 2.72531 9.17919 10.171;
    2926 2.72531 9.97352 10.171; 2927 2.72531 10.7678 10.171;
    2928 2.72531 11.6265 10.171; 2929 2.72531 12.4851 10.171;
    2930 2.72531 13.3437 10.171; 2931 2.72531 14.2024 10.171;
    2932 2.72531 15.1726 10.171; 2933 2.72531 16.1428 10.171;
    2934 2.72531 18.1243 10.171; 2935 3.60141 1.12121 9.89478;
    2936 3.60141 1.94421 9.89478; 2937 3.60141 2.76721 9.89478;
    2938 3.60141 3.59021 9.89478; 2939 3.60141 4.41321 9.89478;
    2940 3.60141 5.20754 9.89478; 2941 3.60141 6.00187 9.89478;
    2942 3.60141 6.7962 9.89478; 2943 3.60141 7.59053 9.89478;
    2944 3.60141 8.38486 9.89478; 2945 3.60141 9.17919 9.89478;
    2946 3.60141 9.97352 9.89478; 2947 3.60141 10.7678 9.89478;
    2948 3.60141 11.6265 9.89478; 2949 3.60141 12.4851 9.89478;
    2950 3.60141 13.3437 9.89478; 2951 3.60141 14.2024 9.89478;
    2952 3.60141 15.1726 9.89478; 2953 3.60141 16.1428 9.89478;
    2954 3.60141 18.1243 9.89478; 2955 4.45009 1.12121 9.54325;
    2956 4.45009 1.94421 9.54325; 2957 4.45009 2.76721 9.54325;
    2958 4.45009 3.59021 9.54325; 2959 4.45009 4.41321 9.54325;
    2960 4.45009 5.20754 9.54325; 2961 4.45009 6.00187 9.54325;
    2962 4.45009 6.7962 9.54325; 2963 4.45009 7.59053 9.54325;
    2964 4.45009 8.38486 9.54325; 2965 4.45009 9.17919 9.54325;
    2966 4.45009 9.97352 9.54325; 2967 4.45009 10.7678 9.54325;
    2968 4.45009 11.6265 9.54325; 2969 4.45009 12.4851 9.54325;
    2970 4.45009 13.3437 9.54325; 2971 4.45009 14.2024 9.54325;
    2972 4.45009 15.1726 9.54325; 2973 4.45009 16.1428 9.54325;
    2974 4.45009 18.1243 9.54325; 2975 5.2649 1.12121 9.11908;
    2976 5.2649 1.94421 9.11908; 2977 5.2649 2.76721 9.11908;
    2978 5.2649 3.59021 9.11908; 2979 5.2649 4.41321 9.11908;
    2980 5.2649 5.20754 9.11908; 2981 5.2649 6.00187 9.11908;
    2982 5.2649 6.7962 9.11908; 2983 5.2649 7.59053 9.11908;
    2984 5.2649 8.38486 9.11908; 2985 5.2649 9.17919 9.11908;
    2986 5.2649 9.97352 9.11908; 2987 5.2649 10.7678 9.11908;
    2988 5.2649 11.6265 9.11908; 2989 5.2649 12.4851 9.11908;
    2990 5.2649 13.3437 9.11908; 2991 5.2649 14.2024 9.11908;
    2992 5.2649 15.1726 9.11908; 2993 5.2649 16.1428 9.11908;
    2994 5.2649 18.1243 9.11908; 2995 6.03965 1.12121 8.62551;
    2996 6.03965 1.94421 8.62551; 2997 6.03965 2.76721 8.62551;
    2998 6.03965 3.59021 8.62551; 2999 6.03965 4.41321 8.62551;
    3000 6.03965 5.20754 8.62551; 3001 6.03965 6.00187 8.62551;
    3002 6.03965 6.7962 8.62551; 3003 6.03965 7.59053 8.62551;
    3004 6.03965 8.38486 8.62551; 3005 6.03965 9.17919 8.62551;
    3006 6.03965 9.97352 8.62551; 3007 6.03965 10.7678 8.62551;
    3008 6.03965 11.6265 8.62551; 3009 6.03965 12.4851 8.62551;
    3010 6.03965 13.3437 8.62551; 3011 6.03965 14.2024 8.62551;
    3012 6.03965 15.1726 8.62551; 3013 6.03965 16.1428 8.62551;
    3014 6.03965 18.1243 8.62551; 3015 6.76843 1.12121 8.0663;
    3016 6.76843 1.94421 8.0663; 3017 6.76843 2.76721 8.0663;
    3018 6.76843 3.59021 8.0663; 3019 6.76843 4.41321 8.0663;
    3020 6.76843 5.20754 8.0663; 3021 6.76843 6.00187 8.0663;
    3022 6.76843 6.7962 8.0663; 3023 6.76843 7.59053 8.0663;
    3024 6.76843 8.38486 8.0663; 3025 6.76843 9.17919 8.0663;
    3026 6.76843 9.97352 8.0663; 3027 6.76843 10.7678 8.0663;
    3028 6.76843 11.6265 8.0663; 3029 6.76843 12.4851 8.0663;
    3030 6.76843 13.3437 8.0663; 3031 6.76843 14.2024 8.0663;
    3032 6.76843 15.1726 8.0663; 3033 6.76843 16.1428 8.0663;
    3034 6.76843 18.1243 8.0663; 3035 7.4457 1.12121 7.4457;
    3036 7.4457 1.94421 7.4457; 3037 7.4457 2.76721 7.4457;
    3038 7.4457 3.59021 7.4457; 3039 7.4457 4.41321 7.4457;
    3040 7.4457 5.20754 7.4457; 3041 7.4457 6.00187 7.4457;
    3042 7.4457 6.7962 7.4457; 3043 7.4457 7.59053 7.4457;
    3044 7.4457 8.38486 7.4457; 3045 7.4457 9.17919 7.4457;
    3046 7.4457 9.97352 7.4457; 3047 7.4457 10.7678 7.4457;
    3048 7.4457 11.6265 7.4457; 3049 7.4457 12.4851 7.4457;
    3050 7.4457 13.3437 7.4457; 3051 7.4457 14.2024 7.4457;
    3052 7.4457 15.1726 7.4457; 3053 7.4457 16.1428 7.4457;
    3054 7.4457 18.1243 7.4457; 3055 8.0663 1.12121 6.76843;
    3056 8.0663 1.94421 6.76843; 3057 8.0663 2.76721 6.76843;
    3058 8.0663 3.59021 6.76843; 3059 8.0663 4.41321 6.76843;
    3060 8.0663 5.20754 6.76843; 3061 8.0663 6.00187 6.76843;
    3062 8.0663 6.7962 6.76843; 3063 8.0663 7.59053 6.76843;
    3064 8.0663 8.38486 6.76843; 3065 8.0663 9.17919 6.76843;
    3066 8.0663 9.97352 6.76843; 3067 8.0663 10.7678 6.76843;
    3068 8.0663 11.6265 6.76843; 3069 8.0663 12.4851 6.76843;
    3070 8.0663 13.3437 6.76843; 3071 8.0663 14.2024 6.76843;
    3072 8.0663 15.1726 6.76843; 3073 8.0663 16.1428 6.76843;
    3074 8.0663 18.1243 6.76843; 3075 8.62551 1.12121 6.03965;
    3076 8.62551 1.94421 6.03965; 3077 8.62551 2.76721 6.03965;
    3078 8.62551 3.59021 6.03965; 3079 8.62551 4.41321 6.03965;
    3080 8.62551 5.20754 6.03965; 3081 8.62551 6.00187 6.03965;
    3082 8.62551 6.7962 6.03965; 3083 8.62551 7.59053 6.03965;
    3084 8.62551 8.38486 6.03965; 3085 8.62551 9.17919 6.03965;
    3086 8.62551 9.97352 6.03965; 3087 8.62551 10.7678 6.03965;
    3088 8.62551 11.6265 6.03965; 3089 8.62551 12.4851 6.03965;
    3090 8.62551 13.3437 6.03965; 3091 8.62551 14.2024 6.03965;
    3092 8.62551 15.1726 6.03965; 3093 8.62551 16.1428 6.03965;
    3094 8.62551 18.1243 6.03965; 3095 9.11908 1.12121 5.2649;
    3096 9.11908 1.94421 5.2649; 3097 9.11908 2.76721 5.2649;
    3098 9.11908 3.59021 5.2649; 3099 9.11908 4.41321 5.2649;
    3100 9.11908 5.20754 5.2649; 3101 9.11908 6.00187 5.2649;
    3102 9.11908 6.7962 5.2649; 3103 9.11908 7.59053 5.2649;
    3104 9.11908 8.38486 5.2649; 3105 9.11908 9.17919 5.2649;
    3106 9.11908 9.97352 5.2649; 3107 9.11908 10.7678 5.2649;
    3108 9.11908 11.6265 5.2649; 3109 9.11908 12.4851 5.2649;
    3110 9.11908 13.3437 5.2649; 3111 9.11908 14.2024 5.2649;
    3112 9.11908 15.1726 5.2649; 3113 9.11908 16.1428 5.2649;
    3114 9.11908 18.1243 5.2649; 3115 9.54325 1.12121 4.45009;
    3116 9.54325 1.94421 4.45009; 3117 9.54325 2.76721 4.45009;
    3118 9.54325 3.59021 4.45009; 3119 9.54325 4.41321 4.45009;
    3120 9.54325 5.20754 4.45009; 3121 9.54325 6.00187 4.45009;
    3122 9.54325 6.7962 4.45009; 3123 9.54325 7.59053 4.45009;
    3124 9.54325 8.38486 4.45009; 3125 9.54325 9.17919 4.45009;
    3126 9.54325 9.97352 4.45009; 3127 9.54325 10.7678 4.45009;
    3128 9.54325 11.6265 4.45009; 3129 9.54325 12.4851 4.45009;
    3130 9.54325 13.3437 4.45009; 3131 9.54325 14.2024 4.45009;
    3132 9.54325 15.1726 4.45009; 3133 9.54325 16.1428 4.45009;
    3134 9.54325 18.1243 4.45009; 3135 9.89478 1.12121 3.60141;
    3136 9.89478 1.94421 3.60141; 3137 9.89478 2.76721 3.60141;
    3138 9.89478 3.59021 3.60141; 3139 9.89478 4.41321 3.60141;
    3140 9.89478 5.20754 3.60141; 3141 9.89478 6.00187 3.60141;
    3142 9.89478 6.7962 3.60141; 3143 9.89478 7.59053 3.60141;
    3144 9.89478 8.38486 3.60141; 3145 9.89478 9.17919 3.60141;
    3146 9.89478 9.97352 3.60141; 3147 9.89478 10.7678 3.60141;
    3148 9.89478 11.6265 3.60141; 3149 9.89478 12.4851 3.60141;
    3150 9.89478 13.3437 3.60141; 3151 9.89478 14.2024 3.60141;
    3152 9.89478 15.1726 3.60141; 3153 9.89478 16.1428 3.60141;
    3154 9.89478 18.1243 3.60141; 3155 10.171 1.12121 2.72531;
    3156 10.171 1.94421 2.72531; 3157 10.171 2.76721 2.72531;
    3158 10.171 3.59021 2.72531; 3159 10.171 4.41321 2.72531;
    3160 10.171 5.20754 2.72531; 3161 10.171 6.00187 2.72531;
    3162 10.171 6.7962 2.72531; 3163 10.171 7.59053 2.72531;
    3164 10.171 8.38486 2.72531; 3165 10.171 9.17919 2.72531;
    3166 10.171 9.97352 2.72531; 3167 10.171 10.7678 2.72531;
    3168 10.171 11.6265 2.72531; 3169 10.171 12.4851 2.72531;
    3170 10.171 13.3437 2.72531; 3171 10.171 14.2024 2.72531;
    3172 10.171 15.1726 2.72531; 3173 10.171 16.1428 2.72531;
    3174 10.171 18.1243 2.72531; 3175 10.3698 1.12121 1.82848;
    3176 10.3698 1.94421 1.82848; 3177 10.3698 2.76721 1.82848;
    3178 10.3698 3.59021 1.82848; 3179 10.3698 4.41321 1.82848;
    3180 10.3698 5.20754 1.82848; 3181 10.3698 6.00187 1.82848;
    3182 10.3698 6.7962 1.82848; 3183 10.3698 7.59053 1.82848;
    3184 10.3698 8.38486 1.82848; 3185 10.3698 9.17919 1.82848;
    3186 10.3698 9.97352 1.82848; 3187 10.3698 10.7678 1.82848;
    3188 10.3698 11.6265 1.82848; 3189 10.3698 12.4851 1.82848;
    3190 10.3698 13.3437 1.82848; 3191 10.3698 14.2024 1.82848;
    3192 10.3698 15.1726 1.82848; 3193 10.3698 16.1428 1.82848;
    3194 10.3698 18.1243 1.82848; 3195 10.4897 1.94421 0.917733;
    3196 10.4897 2.76721 0.917733; 3197 10.4897 3.59021 0.917733;
    3198 10.4897 4.41321 0.917733; 3199 10.4897 5.20754 0.917733;
    3200 10.4897 6.00187 0.917733; 3201 10.4897 6.7962 0.917733;
    3202 10.4897 7.59053 0.917733; 3203 10.4897 8.38486 0.917733;
    3204 10.4897 9.17919 0.917733; 3205 10.4897 9.97352 0.917733;
    3206 10.4897 10.7678 0.917733; 3207 10.4897 11.6265 0.917733;
    3208 10.4897 12.4851 0.917733; 3209 10.4897 13.3437 0.917733;
    3210 10.4897 14.2024 0.917733; 3211 10.4897 15.1726 0.917733;
    3212 10.4897 16.1428 0.917733; 3213 10.4897 18.1243 0.917733;
    3222 1.45423 21.8711 0; 3281 10.3058 18.2168 0; 3282 9.85769 18.4018 0;
    3283 9.40961 18.5868 0; 3284 8.96154 18.7718 0; 3285 8.51346 18.9567 0;
    3286 8.06538 19.1417 0; 3287 7.61731 19.3267 0; 3288 7.16923 19.5117 0;
    3289 6.72115 19.6967 0; 3290 6.27308 19.8817 0; 3291 5.825 20.0667 0;
    3292 5.37692 20.2516 0; 3293 4.92885 20.4366 0; 3294 4.48077 20.6216 0;
    3295 4.03269 20.8066 0; 3296 3.58462 20.9916 0; 3297 3.13654 21.1766 0;
    3298 2.68846 21.3616 0; 3299 2.24038 21.5465 0; 3300 1.79231 21.7315 0;
    3301 1.4487 21.8711 -0.126745; 3302 10.2666 18.2168 -0.898207;
    3303 9.82018 18.4018 -0.859154; 3304 9.37381 18.5868 -0.820102;
    3305 8.92744 18.7718 -0.78105; 3306 8.48106 18.9567 -0.741997;
    3307 8.03469 19.1417 -0.702945; 3308 7.58832 19.3267 -0.663892;
    3309 7.14195 19.5117 -0.62484; 3310 6.69558 19.6967 -0.585787;
    3311 6.24921 19.8817 -0.546735; 3312 5.80283 20.0667 -0.507682;
    3313 5.35646 20.2516 -0.46863; 3314 4.91009 20.4366 -0.429577;
    3315 4.46372 20.6216 -0.390525; 3316 4.01735 20.8066 -0.351472;
    3317 3.57097 20.9916 -0.31242; 3318 3.1246 21.1766 -0.273367;
    3319 2.67823 21.3616 -0.234315; 3320 2.23186 21.5465 -0.195262;
    3321 1.78549 21.7315 -0.15621; 3322 1.43214 21.8711 -0.252524;
    3323 10.1492 18.2168 -1.78958; 3324 9.70793 18.4018 -1.71177;
    3325 9.26666 18.5868 -1.63396; 3326 8.82539 18.7718 -1.55615;
    3327 8.38412 18.9567 -1.47835; 3328 7.94285 19.1417 -1.40054;
    3329 7.50158 19.3267 -1.32273; 3330 7.06031 19.5117 -1.24492;
    3331 6.61904 19.6967 -1.16712; 3332 6.17777 19.8817 -1.08931;
    3333 5.7365 20.0667 -1.0115; 3334 5.29524 20.2516 -0.933693;
    3335 4.85397 20.4366 -0.855885; 3336 4.4127 20.6216 -0.778077;
    3337 3.97143 20.8066 -0.70027; 3338 3.53016 20.9916 -0.622462;
    3339 3.08889 21.1766 -0.544654; 3340 2.64762 21.3616 -0.466846;
    3341 2.20635 21.5465 -0.389039; 3342 1.76508 21.7315 -0.311231;
    3343 1.40468 21.8711 -0.376383; 3344 9.95461 18.2168 -2.66733;
    3345 9.5218 18.4018 -2.55136; 3346 9.08899 18.5868 -2.43539;
    3347 8.65618 18.7718 -2.31942; 3348 8.22337 18.9567 -2.20345;
    3349 7.79056 19.1417 -2.08748; 3350 7.35775 19.3267 -1.9715;
    3351 6.92495 19.5117 -1.85553; 3352 6.49214 19.6967 -1.73956;
    3353 6.05933 19.8817 -1.62359; 3354 5.62652 20.0667 -1.50762;
    3355 5.19371 20.2516 -1.39165; 3356 4.7609 20.4366 -1.27568;
    3357 4.32809 20.6216 -1.15971; 3358 3.89528 20.8066 -1.04374;
    3359 3.46247 20.9916 -0.927767; 3360 3.02966 21.1766 -0.811796;
    3361 2.59685 21.3616 -0.695825; 3362 2.16405 21.5465 -0.579854;
    3363 1.73124 21.7315 -0.463883; 3364 1.36653 21.8711 -0.497376;
    3365 9.68426 18.2168 -3.52478; 3366 9.2632 18.4018 -3.37153;
    3367 8.84214 18.5868 -3.21828; 3368 8.42109 18.7718 -3.06503;
    3369 8.00004 18.9567 -2.91178; 3370 7.57898 19.1417 -2.75852;
    3371 7.15793 19.3267 -2.60527; 3372 6.73687 19.5117 -2.45202;
    3373 6.31582 19.6967 -2.29877; 3374 5.89476 19.8817 -2.14552;
    3375 5.47371 20.0667 -1.99227; 3376 5.05265 20.2516 -1.83902;
    3377 4.6316 20.4366 -1.68576; 3378 4.21055 20.6216 -1.53251;
    3379 3.78949 20.8066 -1.37926; 3380 3.36844 20.9916 -1.22601;
    3381 2.94738 21.1766 -1.07276; 3382 2.52633 21.3616 -0.919508;
    3383 2.10527 21.5465 -0.766257; 3384 1.68422 21.7315 -0.613005;
    3385 1.31798 21.8711 -0.614584; 3386 9.3402 18.2168 -4.35541;
    3387 8.9341 18.4018 -4.16604; 3388 8.52801 18.5868 -3.97668;
    3389 8.12191 18.7718 -3.78731; 3390 7.71582 18.9567 -3.59794;
    3391 7.30972 19.1417 -3.40858; 3392 6.90363 19.3267 -3.21921;
    3393 6.49753 19.5117 -3.02985; 3394 6.09143 19.6967 -2.84048;
    3395 5.68534 19.8817 -2.65112; 3396 5.27924 20.0667 -2.46175;
    3397 4.87315 20.2516 -2.27239; 3398 4.46705 20.4366 -2.08302;
    3399 4.06096 20.6216 -1.89365; 3400 3.65486 20.8066 -1.70429;
    3401 3.24877 20.9916 -1.51492; 3402 2.84267 21.1766 -1.32556;
    3403 2.43657 21.3616 -1.13619; 3404 2.03048 21.5465 -0.946827;
    3405 1.62438 21.7315 -0.757462; 3406 1.2594 21.8711 -0.727115;
    3407 8.92506 18.2168 -5.15288; 3408 8.53701 18.4018 -4.92885;
    3409 8.14896 18.5868 -4.70481; 3410 7.76092 18.7718 -4.48077;
    3411 7.37287 18.9567 -4.25673; 3412 6.98483 19.1417 -4.03269;
    3413 6.59678 19.3267 -3.80865; 3414 6.20874 19.5117 -3.58462;
    3415 5.82069 19.6967 -3.36058; 3416 5.43264 19.8817 -3.13654;
    3417 5.0446 20.0667 -2.9125; 3418 4.65655 20.2516 -2.68846;
    3419 4.26851 20.4366 -2.46442; 3420 3.88046 20.6216 -2.24038;
    3421 3.49241 20.8066 -2.01635; 3422 3.10437 20.9916 -1.79231;
    3423 2.71632 21.1766 -1.56827; 3424 2.32828 21.3616 -1.34423;
    3425 1.94023 21.5465 -1.12019; 3426 1.55218 21.7315 -0.896154;
    3427 1.19124 21.8711 -0.834112; 3428 8.44199 18.2168 -5.91115;
    3429 8.07495 18.4018 -5.65414; 3430 7.7079 18.5868 -5.39713;
    3431 7.34086 18.7718 -5.14013; 3432 6.97382 18.9567 -4.88312;
    3433 6.60678 19.1417 -4.62611; 3434 6.23973 19.3267 -4.36911;
    3435 5.87269 19.5117 -4.1121; 3436 5.50565 19.6967 -3.8551;
    3437 5.1386 19.8817 -3.59809; 3438 4.77156 20.0667 -3.34108;
    3439 4.40452 20.2516 -3.08408; 3440 4.03747 20.4366 -2.82707;
    3441 3.67043 20.6216 -2.57006; 3442 3.30339 20.8066 -2.31306;
    3443 2.93635 20.9916 -2.05605; 3444 2.5693 21.1766 -1.79904;
    3445 2.20226 21.3616 -1.54204; 3446 1.83522 21.5465 -1.28503;
    3447 1.46817 21.7315 -1.02803; 3448 1.11401 21.8711 -0.934761;
    3449 7.89468 18.2168 -6.62442; 3450 7.55143 18.4018 -6.3364;
    3451 7.20818 18.5868 -6.04838; 3452 6.86494 18.7718 -5.76037;
    3453 6.52169 18.9567 -5.47235; 3454 6.17844 19.1417 -5.18433;
    3455 5.8352 19.3267 -4.89631; 3456 5.49195 19.5117 -4.60829;
    3457 5.1487 19.6967 -4.32027; 3458 4.80546 19.8817 -4.03226;
    3459 4.46221 20.0667 -3.74424; 3460 4.11896 20.2516 -3.45622;
    3461 3.77572 20.4366 -3.1682; 3462 3.43247 20.6216 -2.88018;
    3463 3.08922 20.8066 -2.59216; 3464 2.74598 20.9916 -2.30415;
    3465 2.40273 21.1766 -2.01613; 3466 2.05948 21.3616 -1.72811;
    3467 1.71623 21.5465 -1.44009; 3468 1.37299 21.7315 -1.15207;
    3469 1.0283 21.8711 -1.0283; 3470 7.28728 18.2168 -7.28728;
    3471 6.97044 18.4018 -6.97044; 3472 6.6536 18.5868 -6.6536;
    3473 6.33676 18.7718 -6.33676; 3474 6.01993 18.9567 -6.01993;
    3475 5.70309 19.1417 -5.70309; 3476 5.38625 19.3267 -5.38625;
    3477 5.06941 19.5117 -5.06941; 3478 4.75257 19.6967 -4.75257;
    3479 4.43574 19.8817 -4.43574; 3480 4.1189 20.0667 -4.1189;
    3481 3.80206 20.2516 -3.80206; 3482 3.48522 20.4366 -3.48522;
    3483 3.16838 20.6216 -3.16838; 3484 2.85154 20.8066 -2.85154;
    3485 2.53471 20.9916 -2.53471; 3486 2.21787 21.1766 -2.21787;
    3487 1.90103 21.3616 -1.90103; 3488 1.58419 21.5465 -1.58419;
    3489 1.26735 21.7315 -1.26735; 3490 0.934761 21.8711 -1.11401;
    3491 6.62442 18.2168 -7.89468; 3492 6.3364 18.4018 -7.55143;
    3493 6.04838 18.5868 -7.20818; 3494 5.76037 18.7718 -6.86494;
    3495 5.47235 18.9567 -6.52169; 3496 5.18433 19.1417 -6.17844;
    3497 4.89631 19.3267 -5.8352; 3498 4.60829 19.5117 -5.49195;
    3499 4.32027 19.6967 -5.1487; 3500 4.03226 19.8817 -4.80546;
    3501 3.74424 20.0667 -4.46221; 3502 3.45622 20.2516 -4.11896;
    3503 3.1682 20.4366 -3.77572; 3504 2.88018 20.6216 -3.43247;
    3505 2.59216 20.8066 -3.08922; 3506 2.30415 20.9916 -2.74598;
    3507 2.01613 21.1766 -2.40273; 3508 1.72811 21.3616 -2.05948;
    3509 1.44009 21.5465 -1.71623; 3510 1.15207 21.7315 -1.37299;
    3511 0.834112 21.8711 -1.19124; 3512 5.91115 18.2168 -8.44199;
    3513 5.65414 18.4018 -8.07495; 3514 5.39713 18.5868 -7.7079;
    3515 5.14013 18.7718 -7.34086; 3516 4.88312 18.9567 -6.97382;
    3517 4.62611 19.1417 -6.60678; 3518 4.36911 19.3267 -6.23973;
    3519 4.1121 19.5117 -5.87269; 3520 3.8551 19.6967 -5.50565;
    3521 3.59809 19.8817 -5.1386; 3522 3.34108 20.0667 -4.77156;
    3523 3.08408 20.2516 -4.40452; 3524 2.82707 20.4366 -4.03747;
    3525 2.57006 20.6216 -3.67043; 3526 2.31306 20.8066 -3.30339;
    3527 2.05605 20.9916 -2.93635; 3528 1.79904 21.1766 -2.5693;
    3529 1.54204 21.3616 -2.20226; 3530 1.28503 21.5465 -1.83522;
    3531 1.02803 21.7315 -1.46817; 3532 0.727115 21.8711 -1.2594;
    3533 5.15288 18.2168 -8.92506; 3534 4.92885 18.4018 -8.53701;
    3535 4.70481 18.5868 -8.14896; 3536 4.48077 18.7718 -7.76092;
    3537 4.25673 18.9567 -7.37287; 3538 4.03269 19.1417 -6.98483;
    3539 3.80865 19.3267 -6.59678; 3540 3.58462 19.5117 -6.20874;
    3541 3.36058 19.6967 -5.82069; 3542 3.13654 19.8817 -5.43264;
    3543 2.9125 20.0667 -5.0446; 3544 2.68846 20.2516 -4.65655;
    3545 2.46442 20.4366 -4.26851; 3546 2.24038 20.6216 -3.88046;
    3547 2.01635 20.8066 -3.49241; 3548 1.79231 20.9916 -3.10437;
    3549 1.56827 21.1766 -2.71632; 3550 1.34423 21.3616 -2.32828;
    3551 1.12019 21.5465 -1.94023; 3552 0.896154 21.7315 -1.55218;
    3553 0.614584 21.8711 -1.31798; 3554 4.35541 18.2168 -9.3402;
    3555 4.16604 18.4018 -8.9341; 3556 3.97668 18.5868 -8.52801;
    3557 3.78731 18.7718 -8.12191; 3558 3.59794 18.9567 -7.71582;
    3559 3.40858 19.1417 -7.30972; 3560 3.21921 19.3267 -6.90363;
    3561 3.02985 19.5117 -6.49753; 3562 2.84048 19.6967 -6.09143;
    3563 2.65112 19.8817 -5.68534; 3564 2.46175 20.0667 -5.27924;
    3565 2.27239 20.2516 -4.87315; 3566 2.08302 20.4366 -4.46705;
    3567 1.89365 20.6216 -4.06096; 3568 1.70429 20.8066 -3.65486;
    3569 1.51492 20.9916 -3.24877; 3570 1.32556 21.1766 -2.84267;
    3571 1.13619 21.3616 -2.43657; 3572 0.946827 21.5465 -2.03048;
    3573 0.757462 21.7315 -1.62438; 3574 0.497376 21.8711 -1.36653;
    3575 3.52478 18.2168 -9.68426; 3576 3.37153 18.4018 -9.2632;
    3577 3.21828 18.5868 -8.84214; 3578 3.06503 18.7718 -8.42109;
    3579 2.91178 18.9567 -8.00004; 3580 2.75852 19.1417 -7.57898;
    3581 2.60527 19.3267 -7.15793; 3582 2.45202 19.5117 -6.73687;
    3583 2.29877 19.6967 -6.31582; 3584 2.14552 19.8817 -5.89476;
    3585 1.99227 20.0667 -5.47371; 3586 1.83902 20.2516 -5.05265;
    3587 1.68576 20.4366 -4.6316; 3588 1.53251 20.6216 -4.21055;
    3589 1.37926 20.8066 -3.78949; 3590 1.22601 20.9916 -3.36844;
    3591 1.07276 21.1766 -2.94738; 3592 0.919508 21.3616 -2.52633;
    3593 0.766257 21.5465 -2.10527; 3594 0.613005 21.7315 -1.68422;
    3595 0.376383 21.8711 -1.40468; 3596 2.66733 18.2168 -9.95461;
    3597 2.55136 18.4018 -9.5218; 3598 2.43539 18.5868 -9.08899;
    3599 2.31942 18.7718 -8.65618; 3600 2.20345 18.9567 -8.22337;
    3601 2.08748 19.1417 -7.79056; 3602 1.9715 19.3267 -7.35775;
    3603 1.85553 19.5117 -6.92495; 3604 1.73956 19.6967 -6.49214;
    3605 1.62359 19.8817 -6.05933; 3606 1.50762 20.0667 -5.62652;
    3607 1.39165 20.2516 -5.19371; 3608 1.27568 20.4366 -4.7609;
    3609 1.15971 20.6216 -4.32809; 3610 1.04374 20.8066 -3.89528;
    3611 0.927767 20.9916 -3.46247; 3612 0.811796 21.1766 -3.02966;
    3613 0.695825 21.3616 -2.59685; 3614 0.579854 21.5465 -2.16405;
    3615 0.463883 21.7315 -1.73124; 3616 0.252524 21.8711 -1.43214;
    3617 1.78958 18.2168 -10.1492; 3618 1.71177 18.4018 -9.70793;
    3619 1.63396 18.5868 -9.26666; 3620 1.55615 18.7718 -8.82539;
    3621 1.47835 18.9567 -8.38412; 3622 1.40054 19.1417 -7.94285;
    3623 1.32273 19.3267 -7.50158; 3624 1.24492 19.5117 -7.06031;
    3625 1.16712 19.6967 -6.61904; 3626 1.08931 19.8817 -6.17777;
    3627 1.0115 20.0667 -5.7365; 3628 0.933693 20.2516 -5.29524;
    3629 0.855885 20.4366 -4.85397; 3630 0.778077 20.6216 -4.4127;
    3631 0.70027 20.8066 -3.97143; 3632 0.622462 20.9916 -3.53016;
    3633 0.544654 21.1766 -3.08889; 3634 0.466846 21.3616 -2.64762;
    3635 0.389039 21.5465 -2.20635; 3636 0.311231 21.7315 -1.76508;
    3637 0.126745 21.8711 -1.4487; 3638 0.898207 18.2168 -10.2666;
    3639 0.859154 18.4018 -9.82018; 3640 0.820102 18.5868 -9.37381;
    3641 0.78105 18.7718 -8.92744; 3642 0.741997 18.9567 -8.48106;
    3643 0.702945 19.1417 -8.03469; 3644 0.663892 19.3267 -7.58832;
    3645 0.62484 19.5117 -7.14195; 3646 0.585787 19.6967 -6.69558;
    3647 0.546735 19.8817 -6.24921; 3648 0.507682 20.0667 -5.80283;
    3649 0.46863 20.2516 -5.35646; 3650 0.429577 20.4366 -4.91009;
    3651 0.390525 20.6216 -4.46372; 3652 0.351472 20.8066 -4.01735;
    3653 0.31242 20.9916 -3.57098; 3654 0.273367 21.1766 -3.1246;
    3655 0.234315 21.3616 -2.67823; 3656 0.195262 21.5465 -2.23186;
    3657 0.15621 21.7315 -1.78549; 3658 2.0958e-009 21.8711 -1.45423;
    3659 2.0958e-009 18.2168 -10.3058; 3660 2.0958e-009 18.4018 -9.85769;
    3661 2.0958e-009 18.5868 -9.40961; 3662 2.0958e-009 18.7718 -8.96154;
    3663 2.0958e-009 18.9567 -8.51346; 3664 2.0958e-009 19.1417 -8.06538;
    3665 2.0958e-009 19.3267 -7.61731; 3666 2.0958e-009 19.5117 -7.16923;
    3667 2.0958e-009 19.6967 -6.72115; 3668 2.0958e-009 19.8817 -6.27308;
    3669 2.0958e-009 20.0667 -5.825; 3670 2.0958e-009 20.2516 -5.37692;
    3671 2.0958e-009 20.4366 -4.92885; 3672 2.0958e-009 20.6216 -4.48077;
    3673 2.0958e-009 20.8066 -4.03269; 3674 2.0958e-009 20.9916 -3.58462;
    3675 2.0958e-009 21.1766 -3.13654; 3676 2.0958e-009 21.3616 -2.68846;
    3677 2.0958e-009 21.5465 -2.24038; 3678 2.0958e-009 21.7315 -1.79231;
    3679 -0.126745 21.8711 -1.4487; 3680 -0.898207 18.2168 -10.2666;
    3681 -0.859154 18.4018 -9.82018; 3682 -0.820102 18.5868 -9.37381;
    3683 -0.78105 18.7718 -8.92744; 3684 -0.741997 18.9567 -8.48106;
    3685 -0.702945 19.1417 -8.03469; 3686 -0.663892 19.3267 -7.58832;
    3687 -0.62484 19.5117 -7.14195; 3688 -0.585787 19.6967 -6.69558;
    3689 -0.546735 19.8817 -6.24921; 3690 -0.507682 20.0667 -5.80283;
    3691 -0.46863 20.2516 -5.35646; 3692 -0.429577 20.4366 -4.91009;
    3693 -0.390525 20.6216 -4.46372; 3694 -0.351472 20.8066 -4.01735;
    3695 -0.31242 20.9916 -3.57098; 3696 -0.273367 21.1766 -3.1246;
    3697 -0.234315 21.3616 -2.67823; 3698 -0.195262 21.5465 -2.23186;
    3699 -0.15621 21.7315 -1.78549; 3700 -0.252524 21.8711 -1.43214;
    3701 -1.78958 18.2168 -10.1492; 3702 -1.71177 18.4018 -9.70793;
    3703 -1.63396 18.5868 -9.26666; 3704 -1.55615 18.7718 -8.82539;
    3705 -1.47835 18.9567 -8.38412; 3706 -1.40054 19.1417 -7.94285;
    3707 -1.32273 19.3267 -7.50158; 3708 -1.24492 19.5117 -7.06031;
    3709 -1.16712 19.6967 -6.61904; 3710 -1.08931 19.8817 -6.17777;
    3711 -1.0115 20.0667 -5.7365; 3712 -0.933693 20.2516 -5.29524;
    3713 -0.855885 20.4366 -4.85397; 3714 -0.778077 20.6216 -4.4127;
    3715 -0.70027 20.8066 -3.97143; 3716 -0.622462 20.9916 -3.53016;
    3717 -0.544654 21.1766 -3.08889; 3718 -0.466846 21.3616 -2.64762;
    3719 -0.389039 21.5465 -2.20635; 3720 -0.311231 21.7315 -1.76508;
    3721 -0.376383 21.8711 -1.40468; 3722 -2.66733 18.2168 -9.95461;
    3723 -2.55136 18.4018 -9.5218; 3724 -2.43539 18.5868 -9.08899;
    3725 -2.31942 18.7718 -8.65618; 3726 -2.20345 18.9567 -8.22337;
    3727 -2.08748 19.1417 -7.79056; 3728 -1.9715 19.3267 -7.35775;
    3729 -1.85553 19.5117 -6.92495; 3730 -1.73956 19.6967 -6.49214;
    3731 -1.62359 19.8817 -6.05933; 3732 -1.50762 20.0667 -5.62652;
    3733 -1.39165 20.2516 -5.19371; 3734 -1.27568 20.4366 -4.7609;
    3735 -1.15971 20.6216 -4.32809; 3736 -1.04374 20.8066 -3.89528;
    3737 -0.927767 20.9916 -3.46247; 3738 -0.811796 21.1766 -3.02966;
    3739 -0.695825 21.3616 -2.59685; 3740 -0.579854 21.5465 -2.16405;
    3741 -0.463883 21.7315 -1.73124; 3742 -0.497376 21.8711 -1.36653;
    3743 -3.52478 18.2168 -9.68426; 3744 -3.37153 18.4018 -9.2632;
    3745 -3.21828 18.5868 -8.84214; 3746 -3.06503 18.7718 -8.42109;
    3747 -2.91178 18.9567 -8.00004; 3748 -2.75852 19.1417 -7.57898;
    3749 -2.60527 19.3267 -7.15793; 3750 -2.45202 19.5117 -6.73687;
    3751 -2.29877 19.6967 -6.31582; 3752 -2.14552 19.8817 -5.89476;
    3753 -1.99227 20.0667 -5.47371; 3754 -1.83902 20.2516 -5.05265;
    3755 -1.68576 20.4366 -4.6316; 3756 -1.53251 20.6216 -4.21055;
    3757 -1.37926 20.8066 -3.78949; 3758 -1.22601 20.9916 -3.36844;
    3759 -1.07276 21.1766 -2.94738; 3760 -0.919508 21.3616 -2.52633;
    3761 -0.766257 21.5465 -2.10527; 3762 -0.613005 21.7315 -1.68422;
    3763 -0.614584 21.8711 -1.31798; 3764 -4.35541 18.2168 -9.3402;
    3765 -4.16604 18.4018 -8.9341; 3766 -3.97668 18.5868 -8.52801;
    3767 -3.78731 18.7718 -8.12191; 3768 -3.59794 18.9567 -7.71582;
    3769 -3.40858 19.1417 -7.30972; 3770 -3.21921 19.3267 -6.90363;
    3771 -3.02985 19.5117 -6.49753; 3772 -2.84048 19.6967 -6.09143;
    3773 -2.65112 19.8817 -5.68534; 3774 -2.46175 20.0667 -5.27924;
    3775 -2.27239 20.2516 -4.87315; 3776 -2.08302 20.4366 -4.46705;
    3777 -1.89365 20.6216 -4.06096; 3778 -1.70429 20.8066 -3.65486;
    3779 -1.51492 20.9916 -3.24877; 3780 -1.32556 21.1766 -2.84267;
    3781 -1.13619 21.3616 -2.43657; 3782 -0.946827 21.5465 -2.03048;
    3783 -0.757462 21.7315 -1.62438; 3784 -0.727115 21.8711 -1.2594;
    3785 -5.15288 18.2168 -8.92506; 3786 -4.92885 18.4018 -8.53701;
    3787 -4.70481 18.5868 -8.14896; 3788 -4.48077 18.7718 -7.76092;
    3789 -4.25673 18.9567 -7.37287; 3790 -4.03269 19.1417 -6.98483;
    3791 -3.80865 19.3267 -6.59678; 3792 -3.58462 19.5117 -6.20874;
    3793 -3.36058 19.6967 -5.82069; 3794 -3.13654 19.8817 -5.43264;
    3795 -2.9125 20.0667 -5.0446; 3796 -2.68846 20.2516 -4.65655;
    3797 -2.46442 20.4366 -4.26851; 3798 -2.24038 20.6216 -3.88046;
    3799 -2.01635 20.8066 -3.49241; 3800 -1.79231 20.9916 -3.10437;
    3801 -1.56827 21.1766 -2.71632; 3802 -1.34423 21.3616 -2.32828;
    3803 -1.12019 21.5465 -1.94023; 3804 -0.896154 21.7315 -1.55218;
    3805 -0.834112 21.8711 -1.19124; 3806 -5.91115 18.2168 -8.44199;
    3807 -5.65414 18.4018 -8.07495; 3808 -5.39713 18.5868 -7.7079;
    3809 -5.14013 18.7718 -7.34086; 3810 -4.88312 18.9567 -6.97382;
    3811 -4.62611 19.1417 -6.60678; 3812 -4.36911 19.3267 -6.23973;
    3813 -4.1121 19.5117 -5.87269; 3814 -3.8551 19.6967 -5.50565;
    3815 -3.59809 19.8817 -5.1386; 3816 -3.34108 20.0667 -4.77156;
    3817 -3.08408 20.2516 -4.40452; 3818 -2.82707 20.4366 -4.03747;
    3819 -2.57006 20.6216 -3.67043; 3820 -2.31306 20.8066 -3.30339;
    3821 -2.05605 20.9916 -2.93635; 3822 -1.79904 21.1766 -2.5693;
    3823 -1.54204 21.3616 -2.20226; 3824 -1.28503 21.5465 -1.83522;
    3825 -1.02803 21.7315 -1.46817; 3826 -0.934761 21.8711 -1.11401;
    3827 -6.62442 18.2168 -7.89468; 3828 -6.3364 18.4018 -7.55143;
    3829 -6.04838 18.5868 -7.20818; 3830 -5.76037 18.7718 -6.86494;
    3831 -5.47235 18.9567 -6.52169; 3832 -5.18433 19.1417 -6.17844;
    3833 -4.89631 19.3267 -5.8352; 3834 -4.60829 19.5117 -5.49195;
    3835 -4.32027 19.6967 -5.1487; 3836 -4.03226 19.8817 -4.80546;
    3837 -3.74424 20.0667 -4.46221; 3838 -3.45622 20.2516 -4.11896;
    3839 -3.1682 20.4366 -3.77572; 3840 -2.88018 20.6216 -3.43247;
    3841 -2.59216 20.8066 -3.08922; 3842 -2.30415 20.9916 -2.74598;
    3843 -2.01613 21.1766 -2.40273; 3844 -1.72811 21.3616 -2.05948;
    3845 -1.44009 21.5465 -1.71623; 3846 -1.15207 21.7315 -1.37299;
    3847 -1.0283 21.8711 -1.0283; 3848 -7.28728 18.2168 -7.28728;
    3849 -6.97044 18.4018 -6.97044; 3850 -6.6536 18.5868 -6.6536;
    3851 -6.33676 18.7718 -6.33676; 3852 -6.01993 18.9567 -6.01993;
    3853 -5.70309 19.1417 -5.70309; 3854 -5.38625 19.3267 -5.38625;
    3855 -5.06941 19.5117 -5.06941; 3856 -4.75257 19.6967 -4.75257;
    3857 -4.43574 19.8817 -4.43574; 3858 -4.1189 20.0667 -4.1189;
    3859 -3.80206 20.2516 -3.80206; 3860 -3.48522 20.4366 -3.48522;
    3861 -3.16838 20.6216 -3.16838; 3862 -2.85154 20.8066 -2.85154;
    3863 -2.53471 20.9916 -2.53471; 3864 -2.21787 21.1766 -2.21787;
    3865 -1.90103 21.3616 -1.90103; 3866 -1.58419 21.5465 -1.58419;
    3867 -1.26735 21.7315 -1.26735; 3868 -1.11401 21.8711 -0.934761;
    3869 -7.89468 18.2168 -6.62442; 3870 -7.55143 18.4018 -6.3364;
    3871 -7.20818 18.5868 -6.04838; 3872 -6.86494 18.7718 -5.76037;
    3873 -6.52169 18.9567 -5.47235; 3874 -6.17844 19.1417 -5.18433;
    3875 -5.8352 19.3267 -4.89631; 3876 -5.49195 19.5117 -4.60829;
    3877 -5.1487 19.6967 -4.32027; 3878 -4.80546 19.8817 -4.03226;
    3879 -4.46221 20.0667 -3.74424; 3880 -4.11896 20.2516 -3.45622;
    3881 -3.77572 20.4366 -3.1682; 3882 -3.43247 20.6216 -2.88018;
    3883 -3.08922 20.8066 -2.59216; 3884 -2.74598 20.9916 -2.30415;
    3885 -2.40273 21.1766 -2.01613; 3886 -2.05948 21.3616 -1.72811;
    3887 -1.71623 21.5465 -1.44009; 3888 -1.37299 21.7315 -1.15207;
    3889 -1.19124 21.8711 -0.834112; 3890 -8.44199 18.2168 -5.91115;
    3891 -8.07495 18.4018 -5.65414; 3892 -7.7079 18.5868 -5.39713;
    3893 -7.34086 18.7718 -5.14013; 3894 -6.97382 18.9567 -4.88312;
    3895 -6.60678 19.1417 -4.62611; 3896 -6.23973 19.3267 -4.36911;
    3897 -5.87269 19.5117 -4.1121; 3898 -5.50565 19.6967 -3.8551;
    3899 -5.1386 19.8817 -3.59809; 3900 -4.77156 20.0667 -3.34108;
    3901 -4.40452 20.2516 -3.08408; 3902 -4.03747 20.4366 -2.82707;
    3903 -3.67043 20.6216 -2.57006; 3904 -3.30339 20.8066 -2.31306;
    3905 -2.93635 20.9916 -2.05605; 3906 -2.5693 21.1766 -1.79904;
    3907 -2.20226 21.3616 -1.54204; 3908 -1.83522 21.5465 -1.28503;
    3909 -1.46817 21.7315 -1.02803; 3910 -1.2594 21.8711 -0.727115;
    3911 -8.92506 18.2168 -5.15288; 3912 -8.53701 18.4018 -4.92885;
    3913 -8.14896 18.5868 -4.70481; 3914 -7.76092 18.7718 -4.48077;
    3915 -7.37287 18.9567 -4.25673; 3916 -6.98483 19.1417 -4.03269;
    3917 -6.59678 19.3267 -3.80865; 3918 -6.20874 19.5117 -3.58462;
    3919 -5.82069 19.6967 -3.36058; 3920 -5.43264 19.8817 -3.13654;
    3921 -5.0446 20.0667 -2.9125; 3922 -4.65655 20.2516 -2.68846;
    3923 -4.26851 20.4366 -2.46442; 3924 -3.88046 20.6216 -2.24038;
    3925 -3.49241 20.8066 -2.01635; 3926 -3.10437 20.9916 -1.79231;
    3927 -2.71632 21.1766 -1.56827; 3928 -2.32828 21.3616 -1.34423;
    3929 -1.94023 21.5465 -1.12019; 3930 -1.55218 21.7315 -0.896154;
    3931 -1.31798 21.8711 -0.614584; 3932 -9.3402 18.2168 -4.35541;
    3933 -8.9341 18.4018 -4.16604; 3934 -8.52801 18.5868 -3.97668;
    3935 -8.12191 18.7718 -3.78731; 3936 -7.71582 18.9567 -3.59794;
    3937 -7.30972 19.1417 -3.40858; 3938 -6.90363 19.3267 -3.21921;
    3939 -6.49753 19.5117 -3.02985; 3940 -6.09143 19.6967 -2.84048;
    3941 -5.68534 19.8817 -2.65112; 3942 -5.27924 20.0667 -2.46175;
    3943 -4.87315 20.2516 -2.27239; 3944 -4.46705 20.4366 -2.08302;
    3945 -4.06096 20.6216 -1.89365; 3946 -3.65486 20.8066 -1.70429;
    3947 -3.24877 20.9916 -1.51492; 3948 -2.84267 21.1766 -1.32556;
    3949 -2.43657 21.3616 -1.13619; 3950 -2.03048 21.5465 -0.946827;
    3951 -1.62438 21.7315 -0.757462; 3952 -1.36653 21.8711 -0.497376;
    3953 -9.68426 18.2168 -3.52478; 3954 -9.2632 18.4018 -3.37153;
    3955 -8.84214 18.5868 -3.21828; 3956 -8.42109 18.7718 -3.06503;
    3957 -8.00004 18.9567 -2.91178; 3958 -7.57898 19.1417 -2.75852;
    3959 -7.15793 19.3267 -2.60527; 3960 -6.73687 19.5117 -2.45202;
    3961 -6.31582 19.6967 -2.29877; 3962 -5.89476 19.8817 -2.14552;
    3963 -5.47371 20.0667 -1.99227; 3964 -5.05265 20.2516 -1.83902;
    3965 -4.6316 20.4366 -1.68576; 3966 -4.21055 20.6216 -1.53251;
    3967 -3.78949 20.8066 -1.37926; 3968 -3.36844 20.9916 -1.22601;
    3969 -2.94738 21.1766 -1.07276; 3970 -2.52633 21.3616 -0.919508;
    3971 -2.10527 21.5465 -0.766257; 3972 -1.68422 21.7315 -0.613005;
    3973 -1.40468 21.8711 -0.376383; 3974 -9.95461 18.2168 -2.66733;
    3975 -9.5218 18.4018 -2.55136; 3976 -9.08899 18.5868 -2.43539;
    3977 -8.65618 18.7718 -2.31942; 3978 -8.22337 18.9567 -2.20345;
    3979 -7.79056 19.1417 -2.08748; 3980 -7.35775 19.3267 -1.9715;
    3981 -6.92495 19.5117 -1.85553; 3982 -6.49214 19.6967 -1.73956;
    3983 -6.05933 19.8817 -1.62359; 3984 -5.62652 20.0667 -1.50762;
    3985 -5.19371 20.2516 -1.39165; 3986 -4.7609 20.4366 -1.27568;
    3987 -4.32809 20.6216 -1.15971; 3988 -3.89528 20.8066 -1.04374;
    3989 -3.46247 20.9916 -0.927767; 3990 -3.02966 21.1766 -0.811796;
    3991 -2.59685 21.3616 -0.695825; 3992 -2.16405 21.5465 -0.579854;
    3993 -1.73124 21.7315 -0.463883; 3994 -1.43214 21.8711 -0.252524;
    3995 -10.1492 18.2168 -1.78958; 3996 -9.70793 18.4018 -1.71177;
    3997 -9.26666 18.5868 -1.63396; 3998 -8.82539 18.7718 -1.55615;
    3999 -8.38412 18.9567 -1.47835; 4000 -7.94285 19.1417 -1.40054;
    4001 -7.50158 19.3267 -1.32273; 4002 -7.06031 19.5117 -1.24492;
    4003 -6.61904 19.6967 -1.16712; 4004 -6.17777 19.8817 -1.08931;
    4005 -5.7365 20.0667 -1.0115; 4006 -5.29524 20.2516 -0.933693;
    4007 -4.85397 20.4366 -0.855885; 4008 -4.4127 20.6216 -0.778077;
    4009 -3.97143 20.8066 -0.70027; 4010 -3.53016 20.9916 -0.622462;
    4011 -3.08889 21.1766 -0.544654; 4012 -2.64762 21.3616 -0.466846;
    4013 -2.20635 21.5465 -0.389039; 4014 -1.76508 21.7315 -0.311231;
    4015 -1.4487 21.8711 -0.126745; 4016 -10.2666 18.2168 -0.898207;
    4017 -9.82018 18.4018 -0.859154; 4018 -9.37381 18.5868 -0.820102;
    4019 -8.92744 18.7718 -0.78105; 4020 -8.48106 18.9567 -0.741997;
    4021 -8.03469 19.1417 -0.702945; 4022 -7.58832 19.3267 -0.663892;
    4023 -7.14195 19.5117 -0.62484; 4024 -6.69558 19.6967 -0.585787;
    4025 -6.24921 19.8817 -0.546735; 4026 -5.80283 20.0667 -0.507682;
    4027 -5.35646 20.2516 -0.46863; 4028 -4.91009 20.4366 -0.429577;
    4029 -4.46372 20.6216 -0.390525; 4030 -4.01735 20.8066 -0.351472;
    4031 -3.57098 20.9916 -0.31242; 4032 -3.1246 21.1766 -0.273367;
    4033 -2.67823 21.3616 -0.234315; 4034 -2.23186 21.5465 -0.195262;
    4035 -1.78549 21.7315 -0.15621; 4036 -1.45423 21.8711 -1.78086e-016;
    4037 -10.3058 18.2168 -1.26205e-015; 4038 -9.85769 18.4018 -1.20718e-015;
    4039 -9.40961 18.5868 -1.15231e-015; 4040 -8.96154 18.7718 -1.09744e-015;
    4041 -8.51346 18.9567 -1.04256e-015; 4042 -8.06538 19.1417 -9.87692e-016;
    4043 -7.61731 19.3267 -9.3282e-016; 4044 -7.16923 19.5117 -8.77949e-016;
    4045 -6.72115 19.6967 -8.23077e-016; 4046 -6.27308 19.8817 -7.68205e-016;
    4047 -5.825 20.0667 -7.13333e-016; 4048 -5.37692 20.2516 -6.58461e-016;
    4049 -4.92885 20.4366 -6.0359e-016; 4050 -4.48077 20.6216 -5.48718e-016;
    4051 -4.03269 20.8066 -4.93846e-016; 4052 -3.58462 20.9916 -4.38974e-016;
    4053 -3.13654 21.1766 -3.84102e-016; 4054 -2.68846 21.3616 -3.29231e-016;
    4055 -2.24038 21.5465 -2.74359e-016; 4056 -1.79231 21.7315 -2.19487e-016;
    4057 -1.4487 21.8711 0.126745; 4058 -10.2666 18.2168 0.898207;
    4059 -9.82018 18.4018 0.859154; 4060 -9.37381 18.5868 0.820102;
    4061 -8.92744 18.7718 0.78105; 4062 -8.48106 18.9567 0.741997;
    4063 -8.03469 19.1417 0.702945; 4064 -7.58832 19.3267 0.663892;
    4065 -7.14195 19.5117 0.62484; 4066 -6.69558 19.6967 0.585787;
    4067 -6.24921 19.8817 0.546735; 4068 -5.80283 20.0667 0.507682;
    4069 -5.35646 20.2516 0.46863; 4070 -4.91009 20.4366 0.429577;
    4071 -4.46372 20.6216 0.390525; 4072 -4.01735 20.8066 0.351472;
    4073 -3.57098 20.9916 0.31242; 4074 -3.1246 21.1766 0.273367;
    4075 -2.67823 21.3616 0.234315; 4076 -2.23186 21.5465 0.195262;
    4077 -1.78549 21.7315 0.15621; 4078 -1.43214 21.8711 0.252524;
    4079 -10.1492 18.2168 1.78958; 4080 -9.70793 18.4018 1.71177;
    4081 -9.26666 18.5868 1.63396; 4082 -8.82539 18.7718 1.55615;
    4083 -8.38412 18.9567 1.47835; 4084 -7.94285 19.1417 1.40054;
    4085 -7.50158 19.3267 1.32273; 4086 -7.06031 19.5117 1.24492;
    4087 -6.61904 19.6967 1.16712; 4088 -6.17777 19.8817 1.08931;
    4089 -5.7365 20.0667 1.0115; 4090 -5.29524 20.2516 0.933693;
    4091 -4.85397 20.4366 0.855885; 4092 -4.4127 20.6216 0.778077;
    4093 -3.97143 20.8066 0.70027; 4094 -3.53016 20.9916 0.622462;
    4095 -3.08889 21.1766 0.544654; 4096 -2.64762 21.3616 0.466846;
    4097 -2.20635 21.5465 0.389039; 4098 -1.76508 21.7315 0.311231;
    4099 -1.40468 21.8711 0.376383; 4100 -9.95461 18.2168 2.66733;
    4101 -9.5218 18.4018 2.55136; 4102 -9.08899 18.5868 2.43539;
    4103 -8.65618 18.7718 2.31942; 4104 -8.22337 18.9567 2.20345;
    4105 -7.79056 19.1417 2.08748; 4106 -7.35775 19.3267 1.9715;
    4107 -6.92495 19.5117 1.85553; 4108 -6.49214 19.6967 1.73956;
    4109 -6.05933 19.8817 1.62359; 4110 -5.62652 20.0667 1.50762;
    4111 -5.19371 20.2516 1.39165; 4112 -4.7609 20.4366 1.27568;
    4113 -4.32809 20.6216 1.15971; 4114 -3.89528 20.8066 1.04374;
    4115 -3.46247 20.9916 0.927767; 4116 -3.02966 21.1766 0.811796;
    4117 -2.59685 21.3616 0.695825; 4118 -2.16405 21.5465 0.579854;
    4119 -1.73124 21.7315 0.463883; 4120 -1.36653 21.8711 0.497376;
    4121 -9.68426 18.2168 3.52478; 4122 -9.2632 18.4018 3.37153;
    4123 -8.84214 18.5868 3.21828; 4124 -8.42109 18.7718 3.06503;
    4125 -8.00004 18.9567 2.91178; 4126 -7.57898 19.1417 2.75852;
    4127 -7.15793 19.3267 2.60527; 4128 -6.73687 19.5117 2.45202;
    4129 -6.31582 19.6967 2.29877; 4130 -5.89476 19.8817 2.14552;
    4131 -5.47371 20.0667 1.99227; 4132 -5.05265 20.2516 1.83902;
    4133 -4.6316 20.4366 1.68576; 4134 -4.21055 20.6216 1.53251;
    4135 -3.78949 20.8066 1.37926; 4136 -3.36844 20.9916 1.22601;
    4137 -2.94738 21.1766 1.07276; 4138 -2.52633 21.3616 0.919508;
    4139 -2.10527 21.5465 0.766257; 4140 -1.68422 21.7315 0.613005;
    4141 -1.31798 21.8711 0.614584; 4142 -9.3402 18.2168 4.35541;
    4143 -8.9341 18.4018 4.16604; 4144 -8.52801 18.5868 3.97668;
    4145 -8.12191 18.7718 3.78731; 4146 -7.71582 18.9567 3.59794;
    4147 -7.30972 19.1417 3.40858; 4148 -6.90363 19.3267 3.21921;
    4149 -6.49753 19.5117 3.02985; 4150 -6.09143 19.6967 2.84048;
    4151 -5.68534 19.8817 2.65112; 4152 -5.27924 20.0667 2.46175;
    4153 -4.87315 20.2516 2.27239; 4154 -4.46705 20.4366 2.08302;
    4155 -4.06096 20.6216 1.89365; 4156 -3.65486 20.8066 1.70429;
    4157 -3.24877 20.9916 1.51492; 4158 -2.84267 21.1766 1.32556;
    4159 -2.43657 21.3616 1.13619; 4160 -2.03048 21.5465 0.946827;
    4161 -1.62438 21.7315 0.757462; 4162 -1.2594 21.8711 0.727115;
    4163 -8.92506 18.2168 5.15288; 4164 -8.53701 18.4018 4.92885;
    4165 -8.14896 18.5868 4.70481; 4166 -7.76092 18.7718 4.48077;
    4167 -7.37287 18.9567 4.25673; 4168 -6.98483 19.1417 4.03269;
    4169 -6.59678 19.3267 3.80865; 4170 -6.20874 19.5117 3.58462;
    4171 -5.82069 19.6967 3.36058; 4172 -5.43264 19.8817 3.13654;
    4173 -5.0446 20.0667 2.9125; 4174 -4.65655 20.2516 2.68846;
    4175 -4.26851 20.4366 2.46442; 4176 -3.88046 20.6216 2.24038;
    4177 -3.49241 20.8066 2.01635; 4178 -3.10437 20.9916 1.79231;
    4179 -2.71632 21.1766 1.56827; 4180 -2.32828 21.3616 1.34423;
    4181 -1.94023 21.5465 1.12019; 4182 -1.55218 21.7315 0.896154;
    4183 -1.19124 21.8711 0.834112; 4184 -8.44199 18.2168 5.91115;
    4185 -8.07495 18.4018 5.65414; 4186 -7.7079 18.5868 5.39713;
    4187 -7.34086 18.7718 5.14013; 4188 -6.97382 18.9567 4.88312;
    4189 -6.60678 19.1417 4.62611; 4190 -6.23973 19.3267 4.36911;
    4191 -5.87269 19.5117 4.1121; 4192 -5.50565 19.6967 3.8551;
    4193 -5.1386 19.8817 3.59809; 4194 -4.77156 20.0667 3.34108;
    4195 -4.40452 20.2516 3.08408; 4196 -4.03747 20.4366 2.82707;
    4197 -3.67043 20.6216 2.57006; 4198 -3.30339 20.8066 2.31306;
    4199 -2.93635 20.9916 2.05605; 4200 -2.5693 21.1766 1.79904;
    4201 -2.20226 21.3616 1.54204; 4202 -1.83522 21.5465 1.28503;
    4203 -1.46817 21.7315 1.02803; 4204 -1.11401 21.8711 0.934761;
    4205 -7.89468 18.2168 6.62442; 4206 -7.55143 18.4018 6.3364;
    4207 -7.20818 18.5868 6.04838; 4208 -6.86494 18.7718 5.76037;
    4209 -6.52169 18.9567 5.47235; 4210 -6.17844 19.1417 5.18433;
    4211 -5.8352 19.3267 4.89631; 4212 -5.49195 19.5117 4.60829;
    4213 -5.1487 19.6967 4.32027; 4214 -4.80546 19.8817 4.03226;
    4215 -4.46221 20.0667 3.74424; 4216 -4.11896 20.2516 3.45622;
    4217 -3.77572 20.4366 3.1682; 4218 -3.43247 20.6216 2.88018;
    4219 -3.08922 20.8066 2.59216; 4220 -2.74598 20.9916 2.30415;
    4221 -2.40273 21.1766 2.01613; 4222 -2.05948 21.3616 1.72811;
    4223 -1.71623 21.5465 1.44009; 4224 -1.37299 21.7315 1.15207;
    4225 -1.0283 21.8711 1.0283; 4226 -7.28728 18.2168 7.28728;
    4227 -6.97044 18.4018 6.97044; 4228 -6.6536 18.5868 6.6536;
    4229 -6.33676 18.7718 6.33676; 4230 -6.01993 18.9567 6.01993;
    4231 -5.70309 19.1417 5.70309; 4232 -5.38625 19.3267 5.38625;
    4233 -5.06941 19.5117 5.06941; 4234 -4.75257 19.6967 4.75257;
    4235 -4.43574 19.8817 4.43574; 4236 -4.1189 20.0667 4.1189;
    4237 -3.80206 20.2516 3.80206; 4238 -3.48522 20.4366 3.48522;
    4239 -3.16838 20.6216 3.16838; 4240 -2.85154 20.8066 2.85154;
    4241 -2.53471 20.9916 2.53471; 4242 -2.21787 21.1766 2.21787;
    4243 -1.90103 21.3616 1.90103; 4244 -1.58419 21.5465 1.58419;
    4245 -1.26735 21.7315 1.26735; 4246 -0.934761 21.8711 1.11401;
    4247 -6.62442 18.2168 7.89468; 4248 -6.3364 18.4018 7.55143;
    4249 -6.04838 18.5868 7.20818; 4250 -5.76037 18.7718 6.86494;
    4251 -5.47235 18.9567 6.52169; 4252 -5.18433 19.1417 6.17844;
    4253 -4.89631 19.3267 5.8352; 4254 -4.60829 19.5117 5.49195;
    4255 -4.32027 19.6967 5.1487; 4256 -4.03226 19.8817 4.80546;
    4257 -3.74424 20.0667 4.46221; 4258 -3.45622 20.2516 4.11896;
    4259 -3.1682 20.4366 3.77572; 4260 -2.88018 20.6216 3.43247;
    4261 -2.59216 20.8066 3.08922; 4262 -2.30415 20.9916 2.74598;
    4263 -2.01613 21.1766 2.40273; 4264 -1.72811 21.3616 2.05948;
    4265 -1.44009 21.5465 1.71623; 4266 -1.15207 21.7315 1.37299;
    4267 -0.834112 21.8711 1.19124; 4268 -5.91115 18.2168 8.44199;
    4269 -5.65414 18.4018 8.07495; 4270 -5.39713 18.5868 7.7079;
    4271 -5.14013 18.7718 7.34086; 4272 -4.88312 18.9567 6.97382;
    4273 -4.62611 19.1417 6.60678; 4274 -4.36911 19.3267 6.23973;
    4275 -4.1121 19.5117 5.87269; 4276 -3.8551 19.6967 5.50565;
    4277 -3.59809 19.8817 5.1386; 4278 -3.34108 20.0667 4.77156;
    4279 -3.08408 20.2516 4.40452; 4280 -2.82707 20.4366 4.03747;
    4281 -2.57006 20.6216 3.67043; 4282 -2.31306 20.8066 3.30339;
    4283 -2.05605 20.9916 2.93635; 4284 -1.79904 21.1766 2.5693;
    4285 -1.54204 21.3616 2.20226; 4286 -1.28503 21.5465 1.83522;
    4287 -1.02803 21.7315 1.46817; 4288 -0.727115 21.8711 1.2594;
    4289 -5.15288 18.2168 8.92506; 4290 -4.92885 18.4018 8.53701;
    4291 -4.70481 18.5868 8.14896; 4292 -4.48077 18.7718 7.76092;
    4293 -4.25673 18.9567 7.37287; 4294 -4.03269 19.1417 6.98483;
    4295 -3.80865 19.3267 6.59678; 4296 -3.58462 19.5117 6.20874;
    4297 -3.36058 19.6967 5.82069; 4298 -3.13654 19.8817 5.43264;
    4299 -2.9125 20.0667 5.0446; 4300 -2.68846 20.2516 4.65655;
    4301 -2.46442 20.4366 4.26851; 4302 -2.24038 20.6216 3.88046;
    4303 -2.01635 20.8066 3.49241; 4304 -1.79231 20.9916 3.10437;
    4305 -1.56827 21.1766 2.71632; 4306 -1.34423 21.3616 2.32828;
    4307 -1.12019 21.5465 1.94023; 4308 -0.896154 21.7315 1.55218;
    4309 -0.614584 21.8711 1.31798; 4310 -4.35541 18.2168 9.3402;
    4311 -4.16604 18.4018 8.9341; 4312 -3.97668 18.5868 8.52801;
    4313 -3.78731 18.7718 8.12191; 4314 -3.59794 18.9567 7.71582;
    4315 -3.40858 19.1417 7.30972; 4316 -3.21921 19.3267 6.90363;
    4317 -3.02985 19.5117 6.49753; 4318 -2.84048 19.6967 6.09143;
    4319 -2.65112 19.8817 5.68534; 4320 -2.46175 20.0667 5.27924;
    4321 -2.27239 20.2516 4.87315; 4322 -2.08302 20.4366 4.46705;
    4323 -1.89365 20.6216 4.06096; 4324 -1.70429 20.8066 3.65486;
    4325 -1.51492 20.9916 3.24877; 4326 -1.32556 21.1766 2.84267;
    4327 -1.13619 21.3616 2.43657; 4328 -0.946827 21.5465 2.03048;
    4329 -0.757462 21.7315 1.62438; 4330 -0.497376 21.8711 1.36653;
    4331 -3.52478 18.2168 9.68426; 4332 -3.37153 18.4018 9.2632;
    4333 -3.21828 18.5868 8.84214; 4334 -3.06503 18.7718 8.42109;
    4335 -2.91178 18.9567 8.00004; 4336 -2.75852 19.1417 7.57898;
    4337 -2.60527 19.3267 7.15793; 4338 -2.45202 19.5117 6.73687;
    4339 -2.29877 19.6967 6.31582; 4340 -2.14552 19.8817 5.89476;
    4341 -1.99227 20.0667 5.47371; 4342 -1.83902 20.2516 5.05265;
    4343 -1.68576 20.4366 4.6316; 4344 -1.53251 20.6216 4.21055;
    4345 -1.37926 20.8066 3.78949; 4346 -1.22601 20.9916 3.36844;
    4347 -1.07276 21.1766 2.94738; 4348 -0.919508 21.3616 2.52633;
    4349 -0.766257 21.5465 2.10527; 4350 -0.613005 21.7315 1.68422;
    4351 -0.376383 21.8711 1.40468; 4352 -2.66733 18.2168 9.95461;
    4353 -2.55136 18.4018 9.5218; 4354 -2.43539 18.5868 9.08899;
    4355 -2.31942 18.7718 8.65618; 4356 -2.20345 18.9567 8.22337;
    4357 -2.08748 19.1417 7.79056; 4358 -1.9715 19.3267 7.35775;
    4359 -1.85553 19.5117 6.92495; 4360 -1.73956 19.6967 6.49214;
    4361 -1.62359 19.8817 6.05933; 4362 -1.50762 20.0667 5.62652;
    4363 -1.39165 20.2516 5.19371; 4364 -1.27568 20.4366 4.7609;
    4365 -1.15971 20.6216 4.32809; 4366 -1.04374 20.8066 3.89528;
    4367 -0.927767 20.9916 3.46247; 4368 -0.811796 21.1766 3.02966;
    4369 -0.695825 21.3616 2.59685; 4370 -0.579854 21.5465 2.16405;
    4371 -0.463883 21.7315 1.73124; 4372 -0.252524 21.8711 1.43214;
    4373 -1.78958 18.2168 10.1492; 4374 -1.71177 18.4018 9.70793;
    4375 -1.63396 18.5868 9.26666; 4376 -1.55615 18.7718 8.82539;
    4377 -1.47835 18.9567 8.38412; 4378 -1.40054 19.1417 7.94285;
    4379 -1.32273 19.3267 7.50158; 4380 -1.24492 19.5117 7.06031;
    4381 -1.16712 19.6967 6.61904; 4382 -1.08931 19.8817 6.17777;
    4383 -1.0115 20.0667 5.7365; 4384 -0.933693 20.2516 5.29524;
    4385 -0.855885 20.4366 4.85397; 4386 -0.778077 20.6216 4.4127;
    4387 -0.70027 20.8066 3.97143; 4388 -0.622462 20.9916 3.53016;
    4389 -0.544654 21.1766 3.08889; 4390 -0.466846 21.3616 2.64762;
    4391 -0.389039 21.5465 2.20635; 4392 -0.311231 21.7315 1.76508;
    4393 -0.126745 21.8711 1.4487; 4394 -0.898207 18.2168 10.2666;
    4395 -0.859154 18.4018 9.82018; 4396 -0.820102 18.5868 9.37381;
    4397 -0.78105 18.7718 8.92744; 4398 -0.741997 18.9567 8.48106;
    4399 -0.702945 19.1417 8.03469; 4400 -0.663892 19.3267 7.58832;
    4401 -0.62484 19.5117 7.14195; 4402 -0.585787 19.6967 6.69558;
    4403 -0.546735 19.8817 6.24921; 4404 -0.507682 20.0667 5.80283;
    4405 -0.46863 20.2516 5.35646; 4406 -0.429577 20.4366 4.91009;
    4407 -0.390525 20.6216 4.46372; 4408 -0.351472 20.8066 4.01735;
    4409 -0.31242 20.9916 3.57098; 4410 -0.273367 21.1766 3.1246;
    4411 -0.234315 21.3616 2.67823; 4412 -0.195262 21.5465 2.23186;
    4413 -0.15621 21.7315 1.78549; 4414 2.0958e-009 21.8711 1.45423;
    4415 2.0958e-009 18.2168 10.3058; 4416 2.0958e-009 18.4018 9.85769;
    4417 2.0958e-009 18.5868 9.40961; 4418 2.0958e-009 18.7718 8.96154;
    4419 2.0958e-009 18.9567 8.51346; 4420 2.0958e-009 19.1417 8.06538;
    4421 2.0958e-009 19.3267 7.61731; 4422 2.0958e-009 19.5117 7.16923;
    4423 2.0958e-009 19.6967 6.72115; 4424 2.0958e-009 19.8817 6.27308;
    4425 2.0958e-009 20.0667 5.825; 4426 2.0958e-009 20.2516 5.37692;
    4427 2.0958e-009 20.4366 4.92885; 4428 2.0958e-009 20.6216 4.48077;
    4429 2.0958e-009 20.8066 4.03269; 4430 2.0958e-009 20.9916 3.58462;
    4431 2.0958e-009 21.1766 3.13654; 4432 2.0958e-009 21.3616 2.68846;
    4433 2.0958e-009 21.5465 2.24038; 4434 2.0958e-009 21.7315 1.79231;
    4435 0.126745 21.8711 1.4487; 4436 0.898207 18.2168 10.2666;
    4437 0.859154 18.4018 9.82018; 4438 0.820102 18.5868 9.37381;
    4439 0.78105 18.7718 8.92744; 4440 0.741997 18.9567 8.48106;
    4441 0.702945 19.1417 8.03469; 4442 0.663892 19.3267 7.58832;
    4443 0.62484 19.5117 7.14195; 4444 0.585787 19.6967 6.69558;
    4445 0.546735 19.8817 6.24921; 4446 0.507682 20.0667 5.80283;
    4447 0.46863 20.2516 5.35646; 4448 0.429577 20.4366 4.91009;
    4449 0.390525 20.6216 4.46372; 4450 0.351472 20.8066 4.01735;
    4451 0.31242 20.9916 3.57098; 4452 0.273367 21.1766 3.1246;
    4453 0.234315 21.3616 2.67823; 4454 0.195262 21.5465 2.23186;
    4455 0.15621 21.7315 1.78549; 4456 0.252524 21.8711 1.43214;
    4457 1.78958 18.2168 10.1492; 4458 1.71177 18.4018 9.70793;
    4459 1.63396 18.5868 9.26666; 4460 1.55615 18.7718 8.82539;
    4461 1.47835 18.9567 8.38412; 4462 1.40054 19.1417 7.94285;
    4463 1.32273 19.3267 7.50158; 4464 1.24492 19.5117 7.06031;
    4465 1.16712 19.6967 6.61904; 4466 1.08931 19.8817 6.17777;
    4467 1.0115 20.0667 5.7365; 4468 0.933693 20.2516 5.29524;
    4469 0.855885 20.4366 4.85397; 4470 0.778077 20.6216 4.4127;
    4471 0.70027 20.8066 3.97143; 4472 0.622462 20.9916 3.53016;
    4473 0.544654 21.1766 3.08889; 4474 0.466846 21.3616 2.64762;
    4475 0.389039 21.5465 2.20635; 4476 0.311231 21.7315 1.76508;
    4477 0.376383 21.8711 1.40468; 4478 2.66733 18.2168 9.95461;
    4479 2.55136 18.4018 9.5218; 4480 2.43539 18.5868 9.08899;
    4481 2.31942 18.7718 8.65618; 4482 2.20345 18.9567 8.22337;
    4483 2.08748 19.1417 7.79056; 4484 1.9715 19.3267 7.35775;
    4485 1.85553 19.5117 6.92495; 4486 1.73956 19.6967 6.49214;
    4487 1.62359 19.8817 6.05933; 4488 1.50762 20.0667 5.62652;
    4489 1.39165 20.2516 5.19371; 4490 1.27568 20.4366 4.7609;
    4491 1.15971 20.6216 4.32809; 4492 1.04374 20.8066 3.89528;
    4493 0.927767 20.9916 3.46247; 4494 0.811796 21.1766 3.02966;
    4495 0.695825 21.3616 2.59685; 4496 0.579854 21.5465 2.16405;
    4497 0.463883 21.7315 1.73124; 4498 0.497376 21.8711 1.36653;
    4499 3.52478 18.2168 9.68426; 4500 3.37153 18.4018 9.2632;
    4501 3.21828 18.5868 8.84214; 4502 3.06503 18.7718 8.42109;
    4503 2.91178 18.9567 8.00004; 4504 2.75852 19.1417 7.57898;
    4505 2.60527 19.3267 7.15793; 4506 2.45202 19.5117 6.73687;
    4507 2.29877 19.6967 6.31582; 4508 2.14552 19.8817 5.89476;
    4509 1.99227 20.0667 5.47371; 4510 1.83902 20.2516 5.05265;
    4511 1.68576 20.4366 4.6316; 4512 1.53251 20.6216 4.21055;
    4513 1.37926 20.8066 3.78949; 4514 1.22601 20.9916 3.36844;
    4515 1.07276 21.1766 2.94738; 4516 0.919508 21.3616 2.52633;
    4517 0.766257 21.5465 2.10527; 4518 0.613005 21.7315 1.68422;
    4519 0.614584 21.8711 1.31798; 4520 4.35541 18.2168 9.3402;
    4521 4.16604 18.4018 8.9341; 4522 3.97668 18.5868 8.52801;
    4523 3.78731 18.7718 8.12191; 4524 3.59794 18.9567 7.71582;
    4525 3.40858 19.1417 7.30972; 4526 3.21921 19.3267 6.90363;
    4527 3.02985 19.5117 6.49753; 4528 2.84048 19.6967 6.09143;
    4529 2.65112 19.8817 5.68534; 4530 2.46175 20.0667 5.27924;
    4531 2.27239 20.2516 4.87315; 4532 2.08302 20.4366 4.46705;
    4533 1.89365 20.6216 4.06096; 4534 1.70429 20.8066 3.65486;
    4535 1.51492 20.9916 3.24877; 4536 1.32556 21.1766 2.84267;
    4537 1.13619 21.3616 2.43657; 4538 0.946827 21.5465 2.03048;
    4539 0.757462 21.7315 1.62438; 4540 0.727115 21.8711 1.2594;
    4541 5.15288 18.2168 8.92506; 4542 4.92885 18.4018 8.53701;
    4543 4.70481 18.5868 8.14896; 4544 4.48077 18.7718 7.76092;
    4545 4.25673 18.9567 7.37287; 4546 4.03269 19.1417 6.98483;
    4547 3.80865 19.3267 6.59678; 4548 3.58462 19.5117 6.20874;
    4549 3.36058 19.6967 5.82069; 4550 3.13654 19.8817 5.43264;
    4551 2.9125 20.0667 5.0446; 4552 2.68846 20.2516 4.65655;
    4553 2.46442 20.4366 4.26851; 4554 2.24038 20.6216 3.88046;
    4555 2.01635 20.8066 3.49241; 4556 1.79231 20.9916 3.10437;
    4557 1.56827 21.1766 2.71632; 4558 1.34423 21.3616 2.32828;
    4560 0.896154 21.7315 1.55218; 4561 0.834112 21.8711 1.19124;
    4562 5.91115 18.2168 8.44199; 4563 5.65414 18.4018 8.07495;
    4564 5.39713 18.5868 7.7079; 4565 5.14013 18.7718 7.34086;
    4566 4.88312 18.9567 6.97382; 4567 4.62611 19.1417 6.60678;
    4568 4.36911 19.3267 6.23973; 4569 4.1121 19.5117 5.87269;
    4570 3.8551 19.6967 5.50565; 4571 3.59809 19.8817 5.1386;
    4572 3.34108 20.0667 4.77156; 4573 3.08408 20.2516 4.40452;
    4574 2.82707 20.4366 4.03747; 4575 2.57006 20.6216 3.67043;
    4576 2.31306 20.8066 3.30339; 4577 2.05605 20.9916 2.93635;
    4581 1.02803 21.7315 1.46817; 4582 0.934761 21.8711 1.11401;
    4583 6.62442 18.2168 7.89468; 4584 6.3364 18.4018 7.55143;
    4585 6.04838 18.5868 7.20818; 4586 5.76037 18.7718 6.86494;
    4587 5.47235 18.9567 6.52169; 4588 5.18433 19.1417 6.17844;
    4589 4.89631 19.3267 5.8352; 4590 4.60829 19.5117 5.49195;
    4591 4.32027 19.6967 5.1487; 4592 4.03226 19.8817 4.80546;
    4593 3.74424 20.0667 4.46221; 4594 3.45622 20.2516 4.11896;
    4595 3.1682 20.4366 3.77572; 4596 2.88018 20.6216 3.43247;
    4597 2.59216 20.8066 3.08922; 4602 1.15207 21.7315 1.37299;
    4603 1.0283 21.8711 1.0283; 4604 7.28728 18.2168 7.28728;
    4605 6.97044 18.4018 6.97044; 4606 6.6536 18.5868 6.6536;
    4607 6.33676 18.7718 6.33676; 4608 6.01993 18.9567 6.01993;
    4609 5.70309 19.1417 5.70309; 4610 5.38625 19.3267 5.38625;
    4611 5.06941 19.5117 5.06941; 4612 4.75257 19.6967 4.75257;
    4613 4.43574 19.8817 4.43574; 4614 4.1189 20.0667 4.1189;
    4615 3.80206 20.2516 3.80206; 4623 1.26735 21.7315 1.26735;
    4624 1.11401 21.8711 0.934761; 4625 7.89468 18.2168 6.62442;
    4626 7.55143 18.4018 6.3364; 4627 7.20818 18.5868 6.04838;
    4628 6.86494 18.7718 5.76037; 4629 6.52169 18.9567 5.47235;
    4630 6.17844 19.1417 5.18433; 4631 5.8352 19.3267 4.89631;
    4632 5.49195 19.5117 4.60829; 4633 5.1487 19.6967 4.32027;
    4634 4.80546 19.8817 4.03226; 4635 4.46221 20.0667 3.74424;
    4636 4.11896 20.2516 3.45622; 4637 3.77572 20.4366 3.1682;
    4638 3.43247 20.6216 2.88018; 4639 3.08922 20.8066 2.59216;
    4644 1.37299 21.7315 1.15207; 4645 1.19124 21.8711 0.834112;
    4646 8.44199 18.2168 5.91115; 4647 8.07495 18.4018 5.65414;
    4648 7.7079 18.5868 5.39713; 4649 7.34086 18.7718 5.14013;
    4650 6.97382 18.9567 4.88312; 4651 6.60678 19.1417 4.62611;
    4652 6.23973 19.3267 4.36911; 4653 5.87269 19.5117 4.1121;
    4654 5.50565 19.6967 3.8551; 4655 5.1386 19.8817 3.59809;
    4656 4.77156 20.0667 3.34108; 4657 4.40452 20.2516 3.08408;
    4658 4.03747 20.4366 2.82707; 4659 3.67043 20.6216 2.57006;
    4660 3.30339 20.8066 2.31306; 4661 2.93635 20.9916 2.05605;
    4665 1.46817 21.7315 1.02803; 4666 1.2594 21.8711 0.727115;
    4667 8.92506 18.2168 5.15288; 4668 8.53701 18.4018 4.92885;
    4669 8.14896 18.5868 4.70481; 4670 7.76092 18.7718 4.48077;
    4671 7.37287 18.9567 4.25673; 4672 6.98483 19.1417 4.03269;
    4673 6.59678 19.3267 3.80865; 4674 6.20874 19.5117 3.58462;
    4675 5.82069 19.6967 3.36058; 4676 5.43264 19.8817 3.13654;
    4677 5.0446 20.0667 2.9125; 4678 4.65655 20.2516 2.68846;
    4679 4.26851 20.4366 2.46442; 4680 3.88046 20.6216 2.24038;
    4681 3.49241 20.8066 2.01635; 4682 3.10437 20.9916 1.79231;
    4683 2.71632 21.1766 1.56827; 4686 1.55218 21.7315 0.896154;
    4687 1.31798 21.8711 0.614584; 4688 9.3402 18.2168 4.35541;
    4689 8.9341 18.4018 4.16604; 4690 8.52801 18.5868 3.97668;
    4691 8.12191 18.7718 3.78731; 4692 7.71582 18.9567 3.59794;
    4693 7.30972 19.1417 3.40858; 4694 6.90363 19.3267 3.21921;
    4695 6.49753 19.5117 3.02985; 4696 6.09143 19.6967 2.84048;
    4697 5.68534 19.8817 2.65112; 4698 5.27924 20.0667 2.46175;
    4699 4.87315 20.2516 2.27239; 4700 4.46705 20.4366 2.08302;
    4701 4.06096 20.6216 1.89365; 4702 3.65486 20.8066 1.70429;
    4703 3.24877 20.9916 1.51492; 4704 2.84267 21.1766 1.32556;
    4705 2.43657 21.3616 1.13619; 4706 2.03048 21.5465 0.946827;
    4707 1.62438 21.7315 0.757462; 4708 1.36653 21.8711 0.497376;
    4709 9.68426 18.2168 3.52478; 4710 9.2632 18.4018 3.37153;
    4711 8.84214 18.5868 3.21828; 4712 8.42109 18.7718 3.06503;
    4713 8.00004 18.9567 2.91178; 4714 7.57898 19.1417 2.75852;
    4715 7.15793 19.3267 2.60527; 4716 6.73687 19.5117 2.45202;
    4717 6.31582 19.6967 2.29877; 4718 5.89476 19.8817 2.14552;
    4719 5.47371 20.0667 1.99227; 4720 5.05265 20.2516 1.83902;
    4721 4.6316 20.4366 1.68576; 4722 4.21055 20.6216 1.53251;
    4723 3.78949 20.8066 1.37926; 4724 3.36844 20.9916 1.22601;
    4725 2.94738 21.1766 1.07276; 4726 2.52633 21.3616 0.919508;
    4727 2.10527 21.5465 0.766257; 4728 1.68422 21.7315 0.613005;
    4729 1.40468 21.8711 0.376383; 4730 9.95461 18.2168 2.66733;
    4731 9.5218 18.4018 2.55136; 4732 9.08899 18.5868 2.43539;
    4733 8.65618 18.7718 2.31942; 4734 8.22337 18.9567 2.20345;
    4735 7.79056 19.1417 2.08748; 4736 7.35775 19.3267 1.9715;
    4737 6.92495 19.5117 1.85553; 4738 6.49214 19.6967 1.73956;
    4739 6.05933 19.8817 1.62359; 4740 5.62652 20.0667 1.50762;
    4741 5.19371 20.2516 1.39165; 4742 4.7609 20.4366 1.27568;
    4743 4.32809 20.6216 1.15971; 4744 3.89528 20.8066 1.04374;
    4745 3.46247 20.9916 0.927767; 4746 3.02966 21.1766 0.811796;
    4747 2.59685 21.3616 0.695825; 4748 2.16405 21.5465 0.579854;
    4749 1.73124 21.7315 0.463883; 4750 1.43214 21.8711 0.252524;
    4751 10.1492 18.2168 1.78958; 4752 9.70793 18.4018 1.71177;
    4753 9.26666 18.5868 1.63396; 4754 8.82539 18.7718 1.55615;
    4755 8.38412 18.9567 1.47835; 4756 7.94285 19.1417 1.40054;
    4757 7.50158 19.3267 1.32273; 4758 7.06031 19.5117 1.24492;
    4759 6.61904 19.6967 1.16712; 4760 6.17777 19.8817 1.08931;
    4761 5.7365 20.0667 1.0115; 4762 5.29524 20.2516 0.933693;
    4763 4.85397 20.4366 0.855885; 4764 4.4127 20.6216 0.778077;
    4765 3.97143 20.8066 0.70027; 4766 3.53016 20.9916 0.622462;
    4767 3.08889 21.1766 0.544654; 4768 2.64762 21.3616 0.466846;
    4769 2.20635 21.5465 0.389039; 4770 1.76508 21.7315 0.311231;
    4771 1.4487 21.8711 0.126745; 4772 10.2666 18.2168 0.898207;
    4773 9.82018 18.4018 0.859154; 4774 9.37381 18.5868 0.820102;
    4775 8.92744 18.7718 0.78105; 4776 8.48106 18.9567 0.741997;
    4777 8.03469 19.1417 0.702945; 4778 7.58832 19.3267 0.663892;
    4779 7.14195 19.5117 0.62484; 4780 6.69558 19.6967 0.585787;
    4781 6.24921 19.8817 0.546735; 4782 5.80283 20.0667 0.507682;
    4783 5.35646 20.2516 0.46863; 4784 4.91009 20.4366 0.429577;
    4785 4.46372 20.6216 0.390525; 4786 4.01735 20.8066 0.351472;
    4787 3.57098 20.9916 0.31242; 4788 3.1246 21.1766 0.273367;
    4789 2.67823 21.3616 0.234315; 4790 2.23186 21.5465 0.195262;
    4791 1.78549 21.7315 0.15621; 6782 -6.5892e-008 4.36454 10.5298;
    6783 -6.5892e-008 5.18321 10.5298; 6784 6.5892e-008 0.296211 -10.5298;
    6785 -0.917733 0.296211 -10.4897; 6786 -1.82848 0.296211 -10.3698;
    6787 -2.72531 0.296211 -10.171; 6788 -3.6014 0.296211 -9.89478;
    6789 -4.45009 0.296211 -9.54324; 6790 -5.2649 0.296211 -9.11907;
    6791 -6.03965 0.296211 -8.62551; 6792 -6.76842 0.296211 -8.06629;
    6793 -7.44569 0.296211 -7.44569; 6794 -8.06629 0.296211 -6.76843;
    6795 -8.62551 0.296211 -6.03965; 6796 -9.11907 0.296211 -5.2649;
    6797 -9.54324 0.296211 -4.45009; 6798 -9.89478 0.296211 -3.6014;
    6799 -10.171 0.296211 -2.72531; 6800 -10.3698 0.296211 -1.82848;
    6801 -10.4897 0.296211 -0.917733; 6802 -10.5298 0.296211 -6.5892e-008;
    6803 -10.4897 0.296211 0.917733; 6804 -10.3698 0.296211 1.82848;
    6805 -10.171 0.296211 2.72531; 6806 -9.89478 0.296211 3.6014;
    6807 -9.54324 0.296211 4.45009; 6808 -9.11907 0.296211 5.2649;
    6809 -8.62551 0.296211 6.03965; 6810 -8.06629 0.296211 6.76842;
    6811 -7.44569 0.296211 7.44569; 6812 -6.76843 0.296211 8.06629;
    6813 -6.03965 0.296211 8.62551; 6816 -3.6014 0.296211 9.89478;
    6817 -2.72531 0.296211 10.171; 6818 -1.82848 0.296211 10.3698;
    6819 -0.917733 0.296211 10.4897; 6820 -6.5892e-008 0.296211 10.5298;
    6821 0.917733 0.296211 10.4897; 6822 1.82848 0.296211 10.3698;
    6823 2.72531 0.296211 10.171; 6824 3.6014 0.296211 9.89478;
    6825 4.45009 0.296211 9.54324; 6826 5.2649 0.296211 9.11907;
    6827 6.03965 0.296211 8.62551; 6828 6.76842 0.296211 8.06629;
    6829 7.44569 0.296211 7.44569; 6830 8.06629 0.296211 6.76843;
    6831 8.62551 0.296211 6.03965; 6832 9.11907 0.296211 5.2649;
    6833 9.54324 0.296211 4.45009; 6834 9.89478 0.296211 3.6014;
    6835 10.171 0.296211 2.72531; 6836 10.3698 0.296211 1.82848;
    6837 10.4897 0.296211 0.917733; 6838 10.5298 0.296211 6.5892e-008;
    6839 10.4897 0.296211 -0.917733; 6840 10.3698 0.296211 -1.82848;
    6841 10.171 0.296211 -2.72531; 6842 9.89478 0.296211 -3.6014;
    6843 9.54324 0.296211 -4.45009; 6844 9.11907 0.296211 -5.2649;
    6845 8.62551 0.296211 -6.03965; 6846 8.06629 0.296211 -6.76842;
    6847 7.44569 0.296211 -7.44569; 6848 6.76843 0.296211 -8.06629;
    6849 6.03965 0.296211 -8.62551; 6850 5.2649 0.296211 -9.11907;
    6851 4.45009 0.296211 -9.54324; 6852 3.6014 0.296211 -9.89478;
    6853 2.72531 0.296211 -10.171; 6854 1.82848 0.296211 -10.3698;
    6855 0.917733 0.296211 -10.4897; 6928 -5.2649 0.296211 9.11907;
    6929 -4.45008 0.296211 9.54323; 6934 10.718 0 0; 6936 10.6772 0 0.934135;
    6986 10.6772 0 -0.934135; 7002 10.5552 0 -1.86116; 7018 10.3528 0 -2.77402;
    7034 10.0716 0 -3.66577; 7050 9.71381 0 -4.52962; 7066 9.28206 0 -5.359;
    7082 8.77967 0 -6.14759; 7098 8.21046 0 -6.8894; 7114 7.57877 0 -7.57877;
    7130 6.8894 0 -8.21046; 7146 6.14759 0 -8.77967; 7162 5.359 0 -9.28206;
    7178 4.52962 0 -9.71381; 7194 3.66577 0 -10.0716; 7210 2.77402 0 -10.3528;
    7226 1.86116 0 -10.5552; 7242 0.934135 0 -10.6772; 7258 6.56267e-016 0 -10.718;
    7274 -0.934135 0 -10.6772; 7290 -1.86116 0 -10.5552; 7306 -2.77402 0 -10.3528;
    7322 -3.66577 0 -10.0716; 7338 -4.52962 0 -9.71381; 7354 -5.359 0 -9.28206;
    7370 -6.14759 0 -8.77967; 7386 -6.8894 0 -8.21046; 7402 -7.57877 0 -7.57877;
    7418 -8.21046 0 -6.8894; 7434 -8.77967 0 -6.14759; 7450 -9.28206 0 -5.359;
    7466 -9.71381 0 -4.52962; 7482 -10.0716 0 -3.66577; 7498 -10.3528 0 -2.77402;
    7514 -10.5552 0 -1.86116; 7530 -10.6772 0 -0.934135;
    7546 -10.718 0 -1.31253e-015; 7562 -10.6772 0 0.934135;
    7578 -10.5552 0 1.86116; 7594 -10.3528 0 2.77402; 7610 -10.0716 0 3.66577;
    7626 -9.71381 0 4.52962; 7642 -9.28206 0 5.359; 7658 -8.77967 0 6.14759;
    7674 -8.21046 0 6.8894; 7690 -7.57877 0 7.57877; 7706 -6.8894 0 8.21046;
    7722 -6.14759 0 8.77967; 7738 -5.359 0 9.28206; 7754 -4.52962 0 9.71381;
    7770 -3.66577 0 10.0716; 7786 -2.77402 0 10.3528; 7802 -1.86116 0 10.5552;
    7818 -0.934135 0 10.6772; 7834 -1.9688e-015 0 10.718; 7850 0.934135 0 10.6772;
    7866 1.86116 0 10.5552; 7882 2.77402 0 10.3528; 7898 3.66577 0 10.0716;
    7914 4.52962 0 9.71381; 7930 5.359 0 9.28206; 7946 6.14759 0 8.77967;
    7962 6.8894 0 8.21046; 7978 7.57877 0 7.57877; 7994 8.21046 0 6.8894;
    8010 8.77967 0 6.14759; 8026 9.28206 0 5.359; 8042 9.71381 0 4.52962;
    8058 10.0716 0 3.66577; 8074 10.3528 0 2.77402; 8090 10.5552 0 1.86116;
    8445 10.5298 0 0; 8446 10.4897 0 0.91773; 8447 10.4897 0 -0.917733;
    8448 10.3698 0 -1.82848; 8449 10.171 0 -2.72531; 8450 9.89478 0 -3.6014;
    8451 9.54324 0 -4.45009; 8452 9.11907 0 -5.2649; 8453 8.62551 0 -6.03965;
    8454 8.06629 0 -6.76843; 8455 7.44569 0 -7.44569; 8456 6.76843 0 -8.06629;
    8457 6.03965 0 -8.62551; 8458 5.2649 0 -9.11907; 8459 4.45009 0 -9.54324;
    8460 3.6014 0 -9.89478; 8461 2.72531 0 -10.171; 8462 1.82848 0 -10.3698;
    8463 0.917733 0 -10.4897; 8464 6.44743e-016 0 -10.5298;
    8465 -0.917733 0 -10.4897; 8466 -1.82848 0 -10.3698; 8467 -2.72531 0 -10.171;
    8468 -3.6014 0 -9.89478; 8469 -4.45009 0 -9.54324; 8470 -5.2649 0 -9.11907;
    8471 -6.03965 0 -8.62551; 8472 -6.76843 0 -8.06629; 8473 -7.44569 0 -7.44569;
    8474 -8.06629 0 -6.76843; 8475 -8.62551 0 -6.03965; 8476 -9.11907 0 -5.2649;
    8477 -9.54324 0 -4.45009; 8478 -9.89478 0 -3.6014; 8479 -10.171 0 -2.72531;
    8480 -10.3698 0 -1.82848; 8481 -10.4897 0 -0.917733;
    8482 -10.5298 0 -1.28949e-015; 8483 -10.4897 0 0.917733;
    8484 -10.3698 0 1.82848; 8485 -10.171 0 2.72531; 8486 -9.89478 0 3.6014;
    8487 -9.54324 0 4.45009; 8488 -9.11907 0 5.2649; 8489 -8.62551 0 6.03965;
    8490 -8.06629 0 6.76843; 8491 -7.44569 0 7.44569; 8492 -6.76843 0 8.06629;
    8493 -6.03965 0 8.62551; 8494 -5.2649 0 9.11907; 8495 -4.45009 0 9.54324;
    8496 -3.6014 0 9.89478; 8497 -2.72531 0 10.171; 8498 -1.82848 0 10.3698;
    8499 -0.917733 0 10.4897; 8500 -1.93423e-015 0 10.5298;
    8501 0.917733 0 10.4897; 8502 1.82848 0 10.3698; 8503 2.72531 0 10.171;
    8504 3.6014 0 9.89478; 8505 4.45009 0 9.54324; 8506 5.2649 0 9.11907;
    8507 6.03965 0 8.62551; 8508 6.76843 0 8.06629; 8509 7.44569 0 7.44569;
    8510 8.06629 0 6.76843; 8511 8.62551 0 6.03965; 8512 9.11907 0 5.2649;
    8513 9.54324 0 4.45009; 8514 9.89478 0 3.6014; 8515 10.171 0 2.72531;
    8516 10.3698 0 1.82848; 8517 0 0 0; 8518 3.87 0 0; 8519 3.81121 0 0.672018;
    8520 3.38774 0 0.59735; 8521 3.44 0 0; 8522 3.01 0 0; 8523 2.96427 0 0.522681;
    8524 2.5408 0 0.448012; 8525 2.58 0 0; 8526 2.15 0 0; 8527 2.11734 0 0.373344;
    8528 1.69387 0 0.298675; 8529 1.72 0 0; 8530 1.29 0 0; 8531 1.2704 0 0.224006;
    8532 4.28364 0 0.37477; 8533 4.3 0 0; 8534 4.23467 0 0.746687; 8535 8.3 0 0;
    8536 8.26842 0 0.723393; 8537 7.83324 0 0.685319; 8538 7.86316 0 0;
    8539 7.42632 0 0; 8540 7.39806 0 0.647246; 8541 6.96288 0 0.609173;
    8542 6.98947 0 0; 8543 6.55263 0 0; 8544 6.5277 0 0.571099;
    8545 6.09252 0 0.533026; 8546 6.11579 0 0; 8547 5.67895 0 0;
    8548 5.65734 0 0.494953; 8549 5.22216 0 0.45688; 8550 5.24211 0 0;
    8551 4.80526 0 0; 8552 4.78698 0 0.418806; 8553 10.3 0 0;
    8554 10.2608 0 0.897704; 8555 9.85037 0 0.861796; 8556 9.888 0 0;
    8557 9.476 0 0; 8558 9.43994 0 0.825888; 8559 9.02951 0 0.78998;
    8560 9.064 0 0; 8561 8.652 0 0; 8562 8.61908 0 0.754071;
    8563 4.28364 0 -0.37477; 8564 8.26842 0 -0.723393; 8565 7.83324 0 -0.685319;
    8566 7.39806 0 -0.647246; 8567 6.96288 0 -0.609173; 8568 6.5277 0 -0.571099;
    8569 6.09252 0 -0.533026; 8570 5.65734 0 -0.494953; 8571 5.22216 0 -0.45688;
    8572 4.78698 0 -0.418806; 8573 10.2608 0 -0.897704; 8574 9.85037 0 -0.861796;
    8575 9.43994 0 -0.825888; 8576 9.02951 0 -0.78998; 8577 8.61908 0 -0.754072;
    8578 4.23467 0 -0.746687; 8579 8.1739 0 -1.44128; 8580 7.7437 0 -1.36542;
    8581 7.31349 0 -1.28957; 8582 6.88329 0 -1.21371; 8583 6.45308 0 -1.13785;
    8584 6.02288 0 -1.062; 8585 5.59267 0 -0.986139; 8586 5.16247 0 -0.910282;
    8587 4.73226 0 -0.834425; 8588 10.1435 0 -1.78858; 8589 9.73778 0 -1.71703;
    8590 9.33204 0 -1.64549; 8591 8.9263 0 -1.57395; 8592 8.52056 0 -1.5024;
    8593 4.15348 0 -1.11292; 8594 8.01718 0 -2.1482; 8595 7.59523 0 -2.03514;
    8596 7.17327 0 -1.92207; 8597 6.75131 0 -1.80901; 8598 6.32936 0 -1.69595;
    8599 5.9074 0 -1.58288; 8600 5.48544 0 -1.46982; 8601 5.06349 0 -1.35676;
    8602 4.64153 0 -1.24369; 8603 9.94904 0 -2.66584; 8604 9.55107 0 -2.5592;
    8605 9.15311 0 -2.45257; 8606 8.75515 0 -2.34594; 8607 8.35719 0 -2.2393;
    8608 4.04068 0 -1.47069; 8609 7.79945 0 -2.83877; 8610 7.38895 0 -2.68936;
    8611 6.97845 0 -2.53995; 8612 6.56796 0 -2.39054; 8613 6.15746 0 -2.24113;
    8614 5.74696 0 -2.09172; 8615 5.33646 0 -1.94231; 8616 4.92597 0 -1.79291;
    8617 4.51547 0 -1.6435; 8618 9.67883 0 -3.52281; 8619 9.29168 0 -3.3819;
    8620 8.90453 0 -3.24098; 8621 8.51737 0 -3.10007; 8622 8.13022 0 -2.95916;
    8623 3.89712 0 -1.81726; 8624 7.52235 0 -3.50773; 8625 7.12644 0 -3.32311;
    8626 6.73053 0 -3.1385; 8627 6.33461 0 -2.95388; 8628 5.9387 0 -2.76926;
    8629 5.54279 0 -2.58464; 8630 5.14687 0 -2.40003; 8631 4.75096 0 -2.21541;
    8632 4.35505 0 -2.03079; 8633 9.33497 0 -4.35297; 8634 8.96157 0 -4.17885;
    8635 8.58817 0 -4.00473; 8636 8.21477 0 -3.83061; 8637 7.84138 0 -3.65649;
    8638 3.72391 0 -2.15; 8639 7.18801 0 -4.15; 8640 6.80969 0 -3.93158;
    8641 6.43138 0 -3.71316; 8642 6.05306 0 -3.49474; 8643 5.67475 0 -3.27632;
    8644 5.29643 0 -3.05789; 8645 4.91811 0 -2.83947; 8646 4.5398 0 -2.62105;
    8647 4.16148 0 -2.40263; 8648 8.92006 0 -5.15; 8649 8.56326 0 -4.944;
    8650 8.20646 0 -4.738; 8651 7.84965 0 -4.532; 8652 7.49285 0 -4.326;
    8653 3.52235 0 -2.46638; 8654 6.79896 0 -4.76068; 8655 6.44112 0 -4.51012;
    8656 6.08328 0 -4.25956; 8657 5.72544 0 -4.009; 8658 5.3676 0 -3.75844;
    8659 5.00976 0 -3.50787; 8660 4.65192 0 -3.25731; 8661 4.29408 0 -3.00675;
    8662 3.93624 0 -2.75619; 8663 8.43727 0 -5.90784; 8664 8.09978 0 -5.67152;
    8665 7.76228 0 -5.43521; 8666 7.42479 0 -5.1989; 8667 7.0873 0 -4.96258;
    8668 3.29399 0 -2.76399; 8669 6.35817 0 -5.33514; 8670 6.02353 0 -5.05434;
    8671 5.68889 0 -4.77354; 8672 5.35425 0 -4.49275; 8673 5.01961 0 -4.21195;
    8674 4.68497 0 -3.93115; 8675 4.35033 0 -3.65036; 8676 4.01569 0 -3.36956;
    8677 3.68105 0 -3.08876; 8678 7.89026 0 -6.62071; 8679 7.57465 0 -6.35588;
    8680 7.25904 0 -6.09106; 8681 6.94343 0 -5.82623; 8682 6.62782 0 -5.5614;
    8683 3.04056 0 -3.04056; 8684 5.86899 0 -5.86899; 8685 5.56009 0 -5.56009;
    8686 5.2512 0 -5.2512; 8687 4.9423 0 -4.9423; 8688 4.63341 0 -4.63341;
    8689 4.32452 0 -4.32452; 8690 4.01562 0 -4.01562; 8691 3.70673 0 -3.70673;
    8692 3.39783 0 -3.39783; 8693 7.2832 0 -7.2832; 8694 6.99187 0 -6.99187;
    8695 6.70054 0 -6.70054; 8696 6.40922 0 -6.40922; 8697 6.11789 0 -6.11789;
    8698 2.76399 0 -3.29399; 8699 5.33514 0 -6.35817; 8700 5.05434 0 -6.02353;
    8701 4.77354 0 -5.68889; 8702 4.49275 0 -5.35425; 8703 4.21195 0 -5.01961;
    8704 3.93115 0 -4.68497; 8705 3.65036 0 -4.35033; 8706 3.36956 0 -4.01569;
    8707 3.08876 0 -3.68105; 8708 6.62071 0 -7.89026; 8709 6.35588 0 -7.57465;
    8710 6.09106 0 -7.25904; 8711 5.82623 0 -6.94343; 8712 5.5614 0 -6.62782;
    8713 2.46638 0 -3.52235; 8714 4.76068 0 -6.79896; 8715 4.51012 0 -6.44112;
    8716 4.25956 0 -6.08328; 8717 4.009 0 -5.72544; 8718 3.75844 0 -5.3676;
    8719 3.50787 0 -5.00976; 8720 3.25731 0 -4.65192; 8721 3.00675 0 -4.29408;
    8722 2.75619 0 -3.93624; 8723 5.90784 0 -8.43727; 8724 5.67152 0 -8.09978;
    8725 5.43521 0 -7.76228; 8726 5.1989 0 -7.42479; 8727 4.96258 0 -7.0873;
    8728 2.15 0 -3.72391; 8729 4.15 0 -7.18801; 8730 3.93158 0 -6.80969;
    8731 3.71316 0 -6.43138; 8732 3.49474 0 -6.05306; 8733 3.27632 0 -5.67475;
    8734 3.05789 0 -5.29643; 8735 2.83947 0 -4.91811; 8736 2.62105 0 -4.5398;
    8737 2.40263 0 -4.16148; 8738 5.15 0 -8.92006; 8739 4.944 0 -8.56326;
    8740 4.738 0 -8.20646; 8741 4.532 0 -7.84965; 8742 4.326 0 -7.49285;
    8743 1.81726 0 -3.89712; 8744 3.50773 0 -7.52235; 8745 3.32311 0 -7.12644;
    8746 3.1385 0 -6.73053; 8747 2.95388 0 -6.33461; 8748 2.76926 0 -5.9387;
    8749 2.58464 0 -5.54279; 8750 2.40003 0 -5.14687; 8751 2.21541 0 -4.75096;
    8752 2.03079 0 -4.35505; 8753 4.35297 0 -9.33497; 8754 4.17885 0 -8.96157;
    8755 4.00473 0 -8.58817; 8756 3.83061 0 -8.21477; 8757 3.65649 0 -7.84138;
    8758 1.47069 0 -4.04068; 8759 2.83877 0 -7.79945; 8760 2.68936 0 -7.38895;
    8761 2.53995 0 -6.97845; 8762 2.39054 0 -6.56796; 8763 2.24113 0 -6.15746;
    8764 2.09172 0 -5.74696; 8765 1.94231 0 -5.33646; 8766 1.79291 0 -4.92597;
    8767 1.6435 0 -4.51547; 8768 3.52281 0 -9.67883; 8769 3.3819 0 -9.29168;
    8770 3.24098 0 -8.90453; 8771 3.10007 0 -8.51737; 8772 2.95916 0 -8.13022;
    8773 1.11292 0 -4.15348; 8774 2.1482 0 -8.01718; 8775 2.03514 0 -7.59523;
    8776 1.92207 0 -7.17327; 8777 1.80901 0 -6.75131; 8778 1.69595 0 -6.32936;
    8779 1.58288 0 -5.9074; 8780 1.46982 0 -5.48544; 8781 1.35676 0 -5.06349;
    8782 1.24369 0 -4.64153; 8783 2.66584 0 -9.94904; 8784 2.5592 0 -9.55107;
    8785 2.45257 0 -9.15311; 8786 2.34594 0 -8.75515; 8787 2.2393 0 -8.35719;
    8788 0.746687 0 -4.23467; 8789 1.44128 0 -8.1739; 8790 1.36542 0 -7.7437;
    8791 1.28957 0 -7.31349; 8792 1.21371 0 -6.88329; 8793 1.13785 0 -6.45308;
    8794 1.062 0 -6.02288; 8795 0.986139 0 -5.59267; 8796 0.910282 0 -5.16247;
    8797 0.834425 0 -4.73226; 8798 1.78858 0 -10.1435; 8799 1.71703 0 -9.73778;
    8800 1.64549 0 -9.33204; 8801 1.57395 0 -8.9263; 8802 1.5024 0 -8.52056;
    8803 0.37477 0 -4.28364; 8804 0.723393 0 -8.26842; 8805 0.685319 0 -7.83324;
    8806 0.647246 0 -7.39806; 8807 0.609173 0 -6.96288; 8808 0.571099 0 -6.5277;
    8809 0.533026 0 -6.09252; 8810 0.494953 0 -5.65734; 8811 0.45688 0 -5.22216;
    8812 0.418806 0 -4.78698; 8813 0.897704 0 -10.2608; 8814 0.861796 0 -9.85037;
    8815 0.825888 0 -9.43994; 8816 0.78998 0 -9.02951; 8817 0.754072 0 -8.61908;
    8818 2.6329e-016 0 -4.3; 8819 5.08212e-016 0 -8.3;
    8820 4.81464e-016 0 -7.86316; 8821 4.54716e-016 0 -7.42632;
    8822 4.27968e-016 0 -6.98947; 8823 4.0122e-016 0 -6.55263;
    8824 3.74472e-016 0 -6.11579; 8825 3.47724e-016 0 -5.67895;
    8826 3.20976e-016 0 -5.24211; 8827 2.94228e-016 0 -4.80526;
    8828 6.30672e-016 0 -10.3; 8829 6.05445e-016 0 -9.888;
    8830 5.80218e-016 0 -9.476; 8831 5.54992e-016 0 -9.064;
    8832 5.29765e-016 0 -8.652; 8833 -0.37477 0 -4.28364;
    8834 -0.723393 0 -8.26842; 8835 -0.685319 0 -7.83324;
    8836 -0.647246 0 -7.39806; 8837 -0.609173 0 -6.96288; 8838 -0.571099 0 -6.5277;
    8839 -0.533026 0 -6.09252; 8840 -0.494953 0 -5.65734; 8841 -0.45688 0 -5.22216;
    8842 -0.418806 0 -4.78698; 8843 -0.897704 0 -10.2608;
    8844 -0.861796 0 -9.85037; 8845 -0.825888 0 -9.43994; 8846 -0.78998 0 -9.02951;
    8847 -0.754072 0 -8.61908; 8848 -0.746687 0 -4.23467; 8849 -1.44128 0 -8.1739;
    8850 -1.36542 0 -7.7437; 8851 -1.28957 0 -7.31349; 8852 -1.21371 0 -6.88329;
    8853 -1.13785 0 -6.45308; 8854 -1.062 0 -6.02288; 8855 -0.986139 0 -5.59267;
    8856 -0.910282 0 -5.16247; 8857 -0.834425 0 -4.73226; 8858 -1.78858 0 -10.1435;
    8859 -1.71703 0 -9.73778; 8860 -1.64549 0 -9.33204; 8861 -1.57395 0 -8.9263;
    8862 -1.5024 0 -8.52056; 8863 -1.11292 0 -4.15348; 8864 -2.1482 0 -8.01718;
    8865 -2.03514 0 -7.59523; 8866 -1.92207 0 -7.17327; 8867 -1.80901 0 -6.75131;
    8868 -1.69595 0 -6.32936; 8869 -1.58288 0 -5.9074; 8870 -1.46982 0 -5.48544;
    8871 -1.35676 0 -5.06349; 8872 -1.24369 0 -4.64153; 8873 -2.66584 0 -9.94904;
    8874 -2.5592 0 -9.55107; 8875 -2.45257 0 -9.15311; 8876 -2.34594 0 -8.75515;
    8877 -2.2393 0 -8.35719; 8878 -1.47069 0 -4.04068; 8879 -2.83877 0 -7.79945;
    8880 -2.68936 0 -7.38895; 8881 -2.53995 0 -6.97845; 8882 -2.39054 0 -6.56796;
    8883 -2.24113 0 -6.15746; 8884 -2.09172 0 -5.74696; 8885 -1.94231 0 -5.33646;
    8886 -1.79291 0 -4.92597; 8887 -1.6435 0 -4.51547; 8888 -3.52281 0 -9.67883;
    8889 -3.3819 0 -9.29168; 8890 -3.24098 0 -8.90453; 8891 -3.10007 0 -8.51737;
    8892 -2.95916 0 -8.13022; 8893 -1.81726 0 -3.89712; 8894 -3.50773 0 -7.52235;
    8895 -3.32311 0 -7.12644; 8896 -3.1385 0 -6.73053; 8897 -2.95388 0 -6.33461;
    8898 -2.76926 0 -5.9387; 8899 -2.58464 0 -5.54279; 8900 -2.40003 0 -5.14687;
    8901 -2.21541 0 -4.75096; 8902 -2.03079 0 -4.35505; 8903 -4.35297 0 -9.33497;
    8904 -4.17885 0 -8.96157; 8905 -4.00473 0 -8.58817; 8906 -3.83061 0 -8.21477;
    8907 -3.65649 0 -7.84138; 8908 -2.15 0 -3.72391; 8909 -4.15 0 -7.18801;
    8910 -3.93158 0 -6.80969; 8911 -3.71316 0 -6.43138; 8912 -3.49474 0 -6.05306;
    8913 -3.27632 0 -5.67475; 8914 -3.05789 0 -5.29643; 8915 -2.83947 0 -4.91811;
    8916 -2.62105 0 -4.5398; 8917 -2.40263 0 -4.16148; 8918 -5.15 0 -8.92006;
    8919 -4.944 0 -8.56326; 8920 -4.738 0 -8.20646; 8921 -4.532 0 -7.84965;
    8922 -4.326 0 -7.49285; 8923 -2.46638 0 -3.52235; 8924 -4.76068 0 -6.79896;
    8925 -4.51012 0 -6.44112; 8926 -4.25956 0 -6.08328; 8927 -4.009 0 -5.72544;
    8928 -3.75844 0 -5.3676; 8929 -3.50787 0 -5.00976; 8930 -3.25731 0 -4.65192;
    8931 -3.00675 0 -4.29408; 8932 -2.75619 0 -3.93624; 8933 -5.90784 0 -8.43727;
    8934 -5.67152 0 -8.09978; 8935 -5.43521 0 -7.76228; 8936 -5.1989 0 -7.42479;
    8937 -4.96258 0 -7.0873; 8938 -2.76399 0 -3.29399; 8939 -5.33514 0 -6.35817;
    8940 -5.05434 0 -6.02353; 8941 -4.77354 0 -5.68889; 8942 -4.49275 0 -5.35425;
    8943 -4.21195 0 -5.01961; 8944 -3.93115 0 -4.68497; 8945 -3.65036 0 -4.35033;
    8946 -3.36956 0 -4.01569; 8947 -3.08876 0 -3.68105; 8948 -6.62071 0 -7.89026;
    8949 -6.35588 0 -7.57465; 8950 -6.09106 0 -7.25904; 8951 -5.82623 0 -6.94343;
    8952 -5.5614 0 -6.62782; 8953 -3.04056 0 -3.04056; 8954 -5.86899 0 -5.86899;
    8955 -5.56009 0 -5.56009; 8956 -5.2512 0 -5.2512; 8957 -4.9423 0 -4.9423;
    8958 -4.63341 0 -4.63341; 8959 -4.32452 0 -4.32452; 8960 -4.01562 0 -4.01562;
    8961 -3.70673 0 -3.70673; 8962 -3.39783 0 -3.39783; 8963 -7.2832 0 -7.2832;
    8964 -6.99187 0 -6.99187; 8965 -6.70054 0 -6.70054; 8966 -6.40922 0 -6.40922;
    8967 -6.11789 0 -6.11789; 8968 -3.29399 0 -2.76399; 8969 -6.35817 0 -5.33514;
    8970 -6.02353 0 -5.05434; 8971 -5.68889 0 -4.77354; 8972 -5.35425 0 -4.49275;
    8973 -5.01961 0 -4.21195; 8974 -4.68497 0 -3.93115; 8975 -4.35033 0 -3.65036;
    8976 -4.01569 0 -3.36956; 8977 -3.68105 0 -3.08876; 8978 -7.89026 0 -6.62071;
    8979 -7.57465 0 -6.35588; 8980 -7.25904 0 -6.09106; 8981 -6.94343 0 -5.82623;
    8982 -6.62782 0 -5.5614; 8983 -3.52235 0 -2.46638; 8984 -6.79896 0 -4.76068;
    8985 -6.44112 0 -4.51012; 8986 -6.08328 0 -4.25956; 8987 -5.72544 0 -4.009;
    8988 -5.3676 0 -3.75844; 8989 -5.00976 0 -3.50787; 8990 -4.65192 0 -3.25731;
    8991 -4.29408 0 -3.00675; 8992 -3.93624 0 -2.75619; 8993 -8.43727 0 -5.90784;
    8994 -8.09978 0 -5.67152; 8995 -7.76228 0 -5.43521; 8996 -7.42479 0 -5.1989;
    8997 -7.0873 0 -4.96258; 8998 -3.72391 0 -2.15; 8999 -7.18801 0 -4.15;
    9000 -6.80969 0 -3.93158; 9001 -6.43138 0 -3.71316; 9002 -6.05306 0 -3.49474;
    9003 -5.67475 0 -3.27632; 9004 -5.29643 0 -3.05789; 9005 -4.91811 0 -2.83947;
    9006 -4.5398 0 -2.62105; 9007 -4.16148 0 -2.40263; 9008 -8.92006 0 -5.15;
    9009 -8.56326 0 -4.944; 9010 -8.20646 0 -4.738; 9011 -7.84965 0 -4.532;
    9012 -7.49285 0 -4.326; 9013 -3.89712 0 -1.81726; 9014 -7.52235 0 -3.50773;
    9015 -7.12644 0 -3.32311; 9016 -6.73053 0 -3.1385; 9017 -6.33461 0 -2.95388;
    9018 -5.9387 0 -2.76926; 9019 -5.54279 0 -2.58464; 9020 -5.14687 0 -2.40003;
    9021 -4.75096 0 -2.21541; 9022 -4.35505 0 -2.03079; 9023 -9.33497 0 -4.35297;
    9024 -8.96157 0 -4.17885; 9025 -8.58817 0 -4.00473; 9026 -8.21477 0 -3.83061;
    9027 -7.84138 0 -3.65649; 9028 -4.04068 0 -1.47069; 9029 -7.79945 0 -2.83877;
    9030 -7.38895 0 -2.68936; 9031 -6.97845 0 -2.53995; 9032 -6.56796 0 -2.39054;
    9033 -6.15746 0 -2.24113; 9034 -5.74696 0 -2.09172; 9035 -5.33646 0 -1.94231;
    9036 -4.92597 0 -1.79291; 9037 -4.51547 0 -1.6435; 9038 -9.67883 0 -3.52281;
    9039 -9.29168 0 -3.3819; 9040 -8.90453 0 -3.24098; 9041 -8.51737 0 -3.10007;
    9042 -8.13022 0 -2.95916; 9043 -4.15348 0 -1.11292; 9044 -8.01718 0 -2.1482;
    9045 -7.59523 0 -2.03514; 9046 -7.17327 0 -1.92207; 9047 -6.75131 0 -1.80901;
    9048 -6.32936 0 -1.69595; 9049 -5.9074 0 -1.58288; 9050 -5.48544 0 -1.46982;
    9051 -5.06349 0 -1.35676; 9052 -4.64153 0 -1.24369; 9053 -9.94904 0 -2.66584;
    9054 -9.55107 0 -2.5592; 9055 -9.15311 0 -2.45257; 9056 -8.75515 0 -2.34594;
    9057 -8.35719 0 -2.2393; 9058 -4.23467 0 -0.746687; 9059 -8.1739 0 -1.44128;
    9060 -7.7437 0 -1.36542; 9061 -7.31349 0 -1.28957; 9062 -6.88329 0 -1.21371;
    9063 -6.45308 0 -1.13785; 9064 -6.02288 0 -1.062; 9065 -5.59267 0 -0.986139;
    9066 -5.16247 0 -0.910282; 9067 -4.73226 0 -0.834425; 9068 -10.1435 0 -1.78858;
    9069 -9.73778 0 -1.71703; 9070 -9.33204 0 -1.64549; 9071 -8.9263 0 -1.57395;
    9072 -8.52056 0 -1.5024; 9073 -4.28364 0 -0.37477; 9074 -8.26842 0 -0.723393;
    9075 -7.83324 0 -0.685319; 9076 -7.39806 0 -0.647246;
    9077 -6.96288 0 -0.609173; 9078 -6.5277 0 -0.571099; 9079 -6.09252 0 -0.533026;
    9080 -5.65734 0 -0.494953; 9081 -5.22216 0 -0.45688; 9082 -4.78698 0 -0.418806;
    9083 -10.2608 0 -0.897704; 9084 -9.85037 0 -0.861796;
    9085 -9.43994 0 -0.825888; 9086 -9.02951 0 -0.78998; 9087 -8.61908 0 -0.754072;
    9088 -4.3 0 -5.26581e-016; 9089 -8.3 0 -1.01642e-015;
    9090 -7.86316 0 -9.62927e-016; 9091 -7.42632 0 -9.09431e-016;
    9092 -6.98947 0 -8.55935e-016; 9093 -6.55263 0 -8.02439e-016;
    9094 -6.11579 0 -7.48943e-016; 9095 -5.67895 0 -6.95448e-016;
    9096 -5.24211 0 -6.41952e-016; 9097 -4.80526 0 -5.88456e-016;
    9098 -10.3 0 -1.26134e-015; 9099 -9.888 0 -1.21089e-015;
    9100 -9.476 0 -1.16044e-015; 9101 -9.064 0 -1.10998e-015;
    9102 -8.652 0 -1.05953e-015; 9103 -4.28364 0 0.37477; 9104 -8.26842 0 0.723393;
    9105 -7.83324 0 0.685319; 9106 -7.39806 0 0.647246; 9107 -6.96288 0 0.609173;
    9108 -6.5277 0 0.571099; 9109 -6.09252 0 0.533026; 9110 -5.65734 0 0.494953;
    9111 -5.22216 0 0.45688; 9112 -4.78698 0 0.418806; 9113 -10.2608 0 0.897704;
    9114 -9.85037 0 0.861796; 9115 -9.43994 0 0.825888; 9116 -9.02951 0 0.78998;
    9117 -8.61908 0 0.754072; 9118 -4.23467 0 0.746687; 9119 -8.1739 0 1.44128;
    9120 -7.7437 0 1.36542; 9121 -7.31349 0 1.28957; 9122 -6.88329 0 1.21371;
    9123 -6.45308 0 1.13785; 9124 -6.02288 0 1.062; 9125 -5.59267 0 0.986139;
    9126 -5.16247 0 0.910282; 9127 -4.73226 0 0.834425; 9128 -10.1435 0 1.78858;
    9129 -9.73778 0 1.71703; 9130 -9.33204 0 1.64549; 9131 -8.9263 0 1.57395;
    9132 -8.52056 0 1.5024; 9133 -4.15348 0 1.11292; 9134 -8.01718 0 2.1482;
    9135 -7.59523 0 2.03514; 9136 -7.17327 0 1.92207; 9137 -6.75131 0 1.80901;
    9138 -6.32936 0 1.69595; 9139 -5.9074 0 1.58288; 9140 -5.48544 0 1.46982;
    9141 -5.06349 0 1.35676; 9142 -4.64153 0 1.24369; 9143 -9.94904 0 2.66584;
    9144 -9.55107 0 2.5592; 9145 -9.15311 0 2.45257; 9146 -8.75515 0 2.34594;
    9147 -8.35719 0 2.2393; 9148 -4.04068 0 1.47069; 9149 -7.79945 0 2.83877;
    9150 -7.38895 0 2.68936; 9151 -6.97845 0 2.53995; 9152 -6.56796 0 2.39054;
    9153 -6.15746 0 2.24113; 9154 -5.74696 0 2.09172; 9155 -5.33646 0 1.94231;
    9156 -4.92597 0 1.79291; 9157 -4.51547 0 1.6435; 9158 -9.67883 0 3.52281;
    9159 -9.29168 0 3.3819; 9160 -8.90453 0 3.24098; 9161 -8.51737 0 3.10007;
    9162 -8.13022 0 2.95916; 9163 -3.89712 0 1.81726; 9164 -7.52235 0 3.50773;
    9165 -7.12644 0 3.32311; 9166 -6.73053 0 3.1385; 9167 -6.33461 0 2.95388;
    9168 -5.9387 0 2.76926; 9169 -5.54279 0 2.58464; 9170 -5.14687 0 2.40003;
    9171 -4.75096 0 2.21541; 9172 -4.35505 0 2.03079; 9173 -9.33497 0 4.35297;
    9174 -8.96157 0 4.17885; 9175 -8.58817 0 4.00473; 9176 -8.21477 0 3.83061;
    9177 -7.84138 0 3.65649; 9178 -3.72391 0 2.15; 9179 -7.18801 0 4.15;
    9180 -6.80969 0 3.93158; 9181 -6.43138 0 3.71316; 9182 -6.05306 0 3.49474;
    9183 -5.67475 0 3.27632; 9184 -5.29643 0 3.05789; 9185 -4.91811 0 2.83947;
    9186 -4.5398 0 2.62105; 9187 -4.16148 0 2.40263; 9188 -8.92006 0 5.15;
    9189 -8.56326 0 4.944; 9190 -8.20646 0 4.738; 9191 -7.84965 0 4.532;
    9192 -7.49285 0 4.326; 9193 -3.52235 0 2.46638; 9194 -6.79896 0 4.76068;
    9195 -6.44112 0 4.51012; 9196 -6.08328 0 4.25956; 9197 -5.72544 0 4.009;
    9198 -5.3676 0 3.75844; 9199 -5.00976 0 3.50787; 9200 -4.65192 0 3.25731;
    9201 -4.29408 0 3.00675; 9202 -3.93624 0 2.75619; 9203 -8.43727 0 5.90784;
    9204 -8.09978 0 5.67152; 9205 -7.76228 0 5.43521; 9206 -7.42479 0 5.1989;
    9207 -7.0873 0 4.96258; 9208 -3.29399 0 2.76399; 9209 -6.35817 0 5.33514;
    9210 -6.02353 0 5.05434; 9211 -5.68889 0 4.77354; 9212 -5.35425 0 4.49275;
    9213 -5.01961 0 4.21195; 9214 -4.68497 0 3.93115; 9215 -4.35033 0 3.65036;
    9216 -4.01569 0 3.36956; 9217 -3.68105 0 3.08876; 9218 -7.89026 0 6.62071;
    9219 -7.57465 0 6.35588; 9220 -7.25904 0 6.09106; 9221 -6.94343 0 5.82623;
    9222 -6.62782 0 5.5614; 9223 -3.04056 0 3.04056; 9224 -5.86899 0 5.86899;
    9225 -5.56009 0 5.56009; 9226 -5.2512 0 5.2512; 9227 -4.9423 0 4.9423;
    9228 -4.63341 0 4.63341; 9229 -4.32452 0 4.32452; 9230 -4.01562 0 4.01562;
    9231 -3.70673 0 3.70673; 9232 -3.39783 0 3.39783; 9233 -7.2832 0 7.2832;
    9234 -6.99187 0 6.99187; 9235 -6.70054 0 6.70054; 9236 -6.40922 0 6.40922;
    9237 -6.11789 0 6.11789; 9238 -2.76399 0 3.29399; 9239 -5.33514 0 6.35817;
    9240 -5.05434 0 6.02353; 9241 -4.77354 0 5.68889; 9242 -4.49275 0 5.35425;
    9243 -4.21195 0 5.01961; 9244 -3.93115 0 4.68497; 9245 -3.65036 0 4.35033;
    9246 -3.36956 0 4.01569; 9247 -3.08876 0 3.68105; 9248 -6.62071 0 7.89026;
    9249 -6.35588 0 7.57465; 9250 -6.09106 0 7.25904; 9251 -5.82623 0 6.94343;
    9252 -5.5614 0 6.62782; 9253 -2.46638 0 3.52235; 9254 -4.76068 0 6.79896;
    9255 -4.51012 0 6.44112; 9256 -4.25956 0 6.08328; 9257 -4.009 0 5.72544;
    9258 -3.75844 0 5.3676; 9259 -3.50787 0 5.00976; 9260 -3.25731 0 4.65192;
    9261 -3.00675 0 4.29408; 9262 -2.75619 0 3.93624; 9263 -5.90784 0 8.43727;
    9264 -5.67152 0 8.09978; 9265 -5.43521 0 7.76228; 9266 -5.1989 0 7.42479;
    9267 -4.96258 0 7.0873; 9268 -2.15 0 3.72391; 9269 -4.15 0 7.18801;
    9270 -3.93158 0 6.80969; 9271 -3.71316 0 6.43138; 9272 -3.49474 0 6.05306;
    9273 -3.27632 0 5.67475; 9274 -3.05789 0 5.29643; 9275 -2.83947 0 4.91811;
    9276 -2.62105 0 4.5398; 9277 -2.40263 0 4.16148; 9278 -5.15 0 8.92006;
    9279 -4.944 0 8.56326; 9280 -4.738 0 8.20646; 9281 -4.532 0 7.84965;
    9282 -4.326 0 7.49285; 9283 -1.81726 0 3.89712; 9284 -3.50773 0 7.52235;
    9285 -3.32311 0 7.12644; 9286 -3.1385 0 6.73053; 9287 -2.95388 0 6.33461;
    9288 -2.76926 0 5.9387; 9289 -2.58464 0 5.54279; 9290 -2.40003 0 5.14687;
    9291 -2.21541 0 4.75096; 9292 -2.03079 0 4.35505; 9293 -4.35297 0 9.33497;
    9294 -4.17885 0 8.96157; 9295 -4.00473 0 8.58817; 9296 -3.83061 0 8.21477;
    9297 -3.65649 0 7.84138; 9298 -1.47069 0 4.04068; 9299 -2.83877 0 7.79945;
    9300 -2.68936 0 7.38895; 9301 -2.53995 0 6.97845; 9302 -2.39054 0 6.56796;
    9303 -2.24113 0 6.15746; 9304 -2.09172 0 5.74696; 9305 -1.94231 0 5.33646;
    9306 -1.79291 0 4.92597; 9307 -1.6435 0 4.51547; 9308 -3.52281 0 9.67883;
    9309 -3.3819 0 9.29168; 9310 -3.24098 0 8.90453; 9311 -3.10007 0 8.51737;
    9312 -2.95916 0 8.13022; 9313 -1.11292 0 4.15348; 9314 -2.1482 0 8.01718;
    9315 -2.03514 0 7.59523; 9316 -1.92207 0 7.17327; 9317 -1.80901 0 6.75131;
    9318 -1.69595 0 6.32936; 9319 -1.58288 0 5.9074; 9320 -1.46982 0 5.48544;
    9321 -1.35676 0 5.06349; 9322 -1.24369 0 4.64153; 9323 -2.66584 0 9.94904;
    9324 -2.5592 0 9.55107; 9325 -2.45257 0 9.15311; 9326 -2.34594 0 8.75515;
    9327 -2.2393 0 8.35719; 9328 -0.746687 0 4.23467; 9329 -1.44128 0 8.1739;
    9330 -1.36542 0 7.7437; 9331 -1.28957 0 7.31349; 9332 -1.21371 0 6.88329;
    9333 -1.13785 0 6.45308; 9334 -1.062 0 6.02288; 9335 -0.986139 0 5.59267;
    9336 -0.910282 0 5.16247; 9337 -0.834425 0 4.73226; 9338 -1.78858 0 10.1435;
    9339 -1.71703 0 9.73778; 9340 -1.64549 0 9.33204; 9341 -1.57395 0 8.9263;
    9342 -1.5024 0 8.52056; 9343 -0.37477 0 4.28364; 9344 -0.723393 0 8.26842;
    9345 -0.685319 0 7.83324; 9346 -0.647246 0 7.39806; 9347 -0.609173 0 6.96288;
    9348 -0.571099 0 6.5277; 9349 -0.533026 0 6.09252; 9350 -0.494953 0 5.65734;
    9351 -0.45688 0 5.22216; 9352 -0.418806 0 4.78698; 9353 -0.897704 0 10.2608;
    9354 -0.861796 0 9.85037; 9355 -0.825888 0 9.43994; 9356 -0.78998 0 9.02951;
    9357 -0.754072 0 8.61908; 9358 -7.89871e-016 0 4.3; 9359 -1.52463e-015 0 8.3;
    9360 -1.44439e-015 0 7.86316; 9361 -1.36415e-015 0 7.42632;
    9362 -1.2839e-015 0 6.98947; 9363 -1.20366e-015 0 6.55263;
    9364 -1.12342e-015 0 6.11579; 9365 -1.04317e-015 0 5.67895;
    9366 -9.62927e-016 0 5.24211; 9367 -8.82683e-016 0 4.80526;
    9368 -1.89202e-015 0 10.3; 9369 -1.81634e-015 0 9.888;
    9370 -1.74066e-015 0 9.476; 9371 -1.66497e-015 0 9.064;
    9372 -1.58929e-015 0 8.652; 9373 0.37477 0 4.28364; 9374 0.723393 0 8.26842;
    9375 0.685319 0 7.83324; 9376 0.647246 0 7.39806; 9377 0.609173 0 6.96288;
    9378 0.571099 0 6.5277; 9379 0.533026 0 6.09252; 9380 0.494953 0 5.65734;
    9381 0.45688 0 5.22216; 9382 0.418806 0 4.78698; 9383 0.897704 0 10.2608;
    9384 0.861796 0 9.85037; 9385 0.825888 0 9.43994; 9386 0.78998 0 9.02951;
    9387 0.754072 0 8.61908; 9388 0.746687 0 4.23467; 9389 1.44128 0 8.1739;
    9390 1.36542 0 7.7437; 9391 1.28957 0 7.31349; 9392 1.21371 0 6.88329;
    9393 1.13785 0 6.45308; 9394 1.062 0 6.02288; 9395 0.986139 0 5.59267;
    9396 0.910282 0 5.16247; 9397 0.834425 0 4.73226; 9398 1.78858 0 10.1435;
    9399 1.71703 0 9.73778; 9400 1.64549 0 9.33204; 9401 1.57395 0 8.9263;
    9402 1.5024 0 8.52056; 9403 1.11292 0 4.15348; 9404 2.1482 0 8.01718;
    9405 2.03514 0 7.59523; 9406 1.92207 0 7.17327; 9407 1.80901 0 6.75131;
    9408 1.69595 0 6.32936; 9409 1.58288 0 5.9074; 9410 1.46982 0 5.48544;
    9411 1.35676 0 5.06349; 9412 1.24369 0 4.64153; 9413 2.66584 0 9.94904;
    9414 2.5592 0 9.55107; 9415 2.45257 0 9.15311; 9416 2.34594 0 8.75515;
    9417 2.2393 0 8.35719; 9418 1.47069 0 4.04068; 9419 2.83877 0 7.79945;
    9420 2.68936 0 7.38895; 9421 2.53995 0 6.97845; 9422 2.39054 0 6.56796;
    9423 2.24113 0 6.15746; 9424 2.09172 0 5.74696; 9425 1.94231 0 5.33646;
    9426 1.79291 0 4.92597; 9427 1.6435 0 4.51547; 9428 3.52281 0 9.67883;
    9429 3.3819 0 9.29168; 9430 3.24098 0 8.90453; 9431 3.10007 0 8.51737;
    9432 2.95916 0 8.13022; 9433 1.81726 0 3.89712; 9434 3.50773 0 7.52235;
    9435 3.32311 0 7.12644; 9436 3.1385 0 6.73053; 9437 2.95388 0 6.33461;
    9438 2.76926 0 5.9387; 9439 2.58464 0 5.54279; 9440 2.40003 0 5.14687;
    9441 2.21541 0 4.75096; 9442 2.03079 0 4.35505; 9443 4.35297 0 9.33497;
    9444 4.17885 0 8.96157; 9445 4.00473 0 8.58817; 9446 3.83061 0 8.21477;
    9447 3.65649 0 7.84138; 9448 2.15 0 3.72391; 9449 4.15 0 7.18801;
    9450 3.93158 0 6.80969; 9451 3.71316 0 6.43138; 9452 3.49474 0 6.05306;
    9453 3.27632 0 5.67475; 9454 3.05789 0 5.29643; 9455 2.83947 0 4.91811;
    9456 2.62105 0 4.5398; 9457 2.40263 0 4.16148; 9458 5.15 0 8.92006;
    9459 4.944 0 8.56326; 9460 4.738 0 8.20646; 9461 4.532 0 7.84965;
    9462 4.326 0 7.49285; 9463 2.46638 0 3.52235; 9464 4.76068 0 6.79896;
    9465 4.51012 0 6.44112; 9466 4.25956 0 6.08328; 9467 4.009 0 5.72544;
    9468 3.75844 0 5.3676; 9469 3.50787 0 5.00976; 9470 3.25731 0 4.65192;
    9471 3.00675 0 4.29408; 9472 2.75619 0 3.93624; 9473 5.90784 0 8.43727;
    9474 5.67152 0 8.09978; 9475 5.43521 0 7.76228; 9476 5.1989 0 7.42479;
    9477 4.96258 0 7.0873; 9478 2.76399 0 3.29399; 9479 5.33514 0 6.35817;
    9480 5.05434 0 6.02353; 9481 4.77354 0 5.68889; 9482 4.49275 0 5.35425;
    9483 4.21195 0 5.01961; 9484 3.93115 0 4.68497; 9485 3.65036 0 4.35033;
    9486 3.36956 0 4.01569; 9487 3.08876 0 3.68105; 9488 6.62071 0 7.89026;
    9489 6.35588 0 7.57465; 9490 6.09106 0 7.25904; 9491 5.82623 0 6.94343;
    9492 5.5614 0 6.62782; 9493 3.04056 0 3.04056; 9494 5.86899 0 5.86899;
    9495 5.56009 0 5.56009; 9496 5.2512 0 5.2512; 9497 4.9423 0 4.9423;
    9498 4.63341 0 4.63341; 9499 4.32452 0 4.32452; 9500 4.01562 0 4.01562;
    9501 3.70673 0 3.70673; 9502 3.39783 0 3.39783; 9503 7.2832 0 7.2832;
    9504 6.99187 0 6.99187; 9505 6.70054 0 6.70054; 9506 6.40922 0 6.40922;
    9507 6.11789 0 6.11789; 9508 3.29399 0 2.76399; 9509 6.35817 0 5.33514;
    9510 6.02353 0 5.05434; 9511 5.68889 0 4.77354; 9512 5.35425 0 4.49275;
    9513 5.01961 0 4.21195; 9514 4.68497 0 3.93115; 9515 4.35033 0 3.65036;
    9516 4.01569 0 3.36956; 9517 3.68105 0 3.08876; 9518 7.89026 0 6.62071;
    9519 7.57465 0 6.35588; 9520 7.25904 0 6.09106; 9521 6.94343 0 5.82623;
    9522 6.62782 0 5.5614; 9523 3.52235 0 2.46638; 9524 6.79896 0 4.76068;
    9525 6.44112 0 4.51012; 9526 6.08328 0 4.25956; 9527 5.72544 0 4.009;
    9528 5.3676 0 3.75844; 9529 5.00976 0 3.50787; 9530 4.65192 0 3.25731;
    9531 4.29408 0 3.00675; 9532 3.93624 0 2.75619; 9533 8.43727 0 5.90784;
    9534 8.09978 0 5.67152; 9535 7.76228 0 5.43521; 9536 7.42479 0 5.1989;
    9537 7.0873 0 4.96258; 9538 3.72391 0 2.15; 9539 7.18801 0 4.15;
    9540 6.80969 0 3.93158; 9541 6.43138 0 3.71316; 9542 6.05306 0 3.49474;
    9543 5.67475 0 3.27632; 9544 5.29643 0 3.05789; 9545 4.91811 0 2.83947;
    9546 4.5398 0 2.62105; 9547 4.16148 0 2.40263; 9548 8.92006 0 5.15;
    9549 8.56326 0 4.944; 9550 8.20646 0 4.738; 9551 7.84965 0 4.532;
    9552 7.49285 0 4.326; 9553 3.89712 0 1.81726; 9554 7.52235 0 3.50773;
    9555 7.12644 0 3.32311; 9556 6.73053 0 3.1385; 9557 6.33461 0 2.95388;
    9558 5.9387 0 2.76926; 9559 5.54279 0 2.58464; 9560 5.14687 0 2.40003;
    9561 4.75096 0 2.21541; 9562 4.35505 0 2.03079; 9563 9.33497 0 4.35297;
    9564 8.96157 0 4.17885; 9565 8.58817 0 4.00473; 9566 8.21477 0 3.83061;
    9567 7.84138 0 3.65649; 9568 4.04068 0 1.47069; 9569 7.79945 0 2.83877;
    9570 7.38895 0 2.68936; 9571 6.97845 0 2.53995; 9572 6.56796 0 2.39054;
    9573 6.15746 0 2.24113; 9574 5.74696 0 2.09172; 9575 5.33646 0 1.94231;
    9576 4.92597 0 1.79291; 9577 4.51547 0 1.6435; 9578 9.67883 0 3.52281;
    9579 9.29168 0 3.3819; 9580 8.90453 0 3.24098; 9581 8.51737 0 3.10007;
    9582 8.13022 0 2.95916; 9583 4.15348 0 1.11292; 9584 8.01718 0 2.1482;
    9585 7.59523 0 2.03514; 9586 7.17327 0 1.92207; 9587 6.75131 0 1.80901;
    9588 6.32936 0 1.69595; 9589 5.9074 0 1.58288; 9590 5.48544 0 1.46982;
    9591 5.06349 0 1.35676; 9592 4.64153 0 1.24369; 9593 9.94904 0 2.66584;
    9594 9.55107 0 2.5592; 9595 9.15311 0 2.45257; 9596 8.75515 0 2.34594;
    9597 8.35719 0 2.2393; 9598 8.1739 0 1.44128; 9599 7.7437 0 1.36542;
    9600 7.31349 0 1.28957; 9601 6.88329 0 1.21371; 9602 6.45308 0 1.13785;
    9603 6.02288 0 1.062; 9604 5.59267 0 0.986139; 9605 5.16247 0 0.910282;
    9606 4.73226 0 0.834425; 9607 10.1435 0 1.78858; 9608 9.73778 0 1.71703;
    9609 9.33204 0 1.64549; 9610 8.9263 0 1.57395; 9611 8.52056 0 1.5024;
    9612 3.81121 0 -0.672018; 9613 3.38774 0 -0.59735; 9614 2.96427 0 -0.522681;
    9615 2.5408 0 -0.448012; 9616 2.11734 0 -0.373344; 9617 1.69387 0 -0.298675;
    9618 1.2704 0 -0.224006; 9619 3.63661 0 -1.32362; 9620 3.23254 0 -1.17655;
    9621 2.82847 0 -1.02948; 9622 2.42441 0 -0.882412; 9623 2.02034 0 -0.735343;
    9624 1.61627 0 -0.588275; 9625 1.2122 0 -0.441206; 9626 3.35152 0 -1.935;
    9627 2.97913 0 -1.72; 9628 2.60674 0 -1.505; 9629 2.23435 0 -1.29;
    9630 1.86195 0 -1.075; 9631 1.48956 0 -0.86; 9632 1.11717 0 -0.645;
    9633 2.96459 0 -2.48759; 9634 2.63519 0 -2.21119; 9635 2.30579 0 -1.93479;
    9636 1.97639 0 -1.65839; 9637 1.647 0 -1.38199; 9638 1.3176 0 -1.10559;
    9639 0.988197 0 -0.829196; 9640 2.48759 0 -2.96459; 9641 2.21119 0 -2.63519;
    9642 1.93479 0 -2.30579; 9643 1.65839 0 -1.97639; 9644 1.38199 0 -1.647;
    9645 1.10559 0 -1.3176; 9646 0.829196 0 -0.988197; 9647 1.935 0 -3.35152;
    9648 1.72 0 -2.97913; 9649 1.505 0 -2.60674; 9650 1.29 0 -2.23435;
    9651 1.075 0 -1.86195; 9652 0.86 0 -1.48956; 9653 0.645 0 -1.11717;
    9654 1.32362 0 -3.63661; 9655 1.17655 0 -3.23254; 9656 1.02948 0 -2.82847;
    9657 0.882412 0 -2.42441; 9658 0.735343 0 -2.02034; 9659 0.588275 0 -1.61627;
    9660 0.441206 0 -1.2122; 9661 0.672018 0 -3.81121; 9662 0.59735 0 -3.38774;
    9663 0.522681 0 -2.96427; 9664 0.448012 0 -2.5408; 9665 0.373344 0 -2.11734;
    9666 0.298675 0 -1.69387; 9667 0.224006 0 -1.2704; 9668 2.36961e-016 0 -3.87;
    9669 2.10632e-016 0 -3.44; 9670 1.84303e-016 0 -3.01;
    9671 1.57974e-016 0 -2.58; 9672 1.31645e-016 0 -2.15;
    9673 1.05316e-016 0 -1.72; 9674 7.89871e-017 0 -1.29;
    9675 -0.672018 0 -3.81121; 9676 -0.59735 0 -3.38774; 9677 -0.522681 0 -2.96427;
    9678 -0.448012 0 -2.5408; 9679 -0.373344 0 -2.11734; 9680 -0.298675 0 -1.69387;
    9681 -0.224006 0 -1.2704; 9682 -1.32362 0 -3.63661; 9683 -1.17655 0 -3.23254;
    9684 -1.02948 0 -2.82847; 9685 -0.882412 0 -2.42441; 9686 -0.735343 0 -2.02034;
    9687 -0.588275 0 -1.61627; 9688 -0.441206 0 -1.2122; 9689 -1.935 0 -3.35152;
    9690 -1.72 0 -2.97913; 9691 -1.505 0 -2.60674; 9692 -1.29 0 -2.23435;
    9693 -1.075 0 -1.86195; 9694 -0.86 0 -1.48956; 9695 -0.645 0 -1.11717;
    9696 -2.48759 0 -2.96459; 9697 -2.21119 0 -2.63519; 9698 -1.93479 0 -2.30579;
    9699 -1.65839 0 -1.97639; 9700 -1.38199 0 -1.647; 9701 -1.10559 0 -1.3176;
    9702 -0.829196 0 -0.988197; 9703 -2.96459 0 -2.48759; 9704 -2.63519 0 -2.21119;
    9705 -2.30579 0 -1.93479; 9706 -1.97639 0 -1.65839; 9707 -1.647 0 -1.38199;
    9708 -1.3176 0 -1.10559; 9709 -0.988197 0 -0.829196; 9710 -3.35152 0 -1.935;
    9711 -2.97913 0 -1.72; 9712 -2.60674 0 -1.505; 9713 -2.23435 0 -1.29;
    9714 -1.86195 0 -1.075; 9715 -1.48956 0 -0.86; 9716 -1.11717 0 -0.645;
    9717 -3.63661 0 -1.32362; 9718 -3.23254 0 -1.17655; 9719 -2.82847 0 -1.02948;
    9720 -2.42441 0 -0.882412; 9721 -2.02034 0 -0.735343;
    9722 -1.61627 0 -0.588275; 9723 -1.2122 0 -0.441206; 9724 -3.81121 0 -0.672018;
    9725 -3.38774 0 -0.59735; 9726 -2.96427 0 -0.522681; 9727 -2.5408 0 -0.448012;
    9728 -2.11734 0 -0.373344; 9729 -1.69387 0 -0.298675; 9730 -1.2704 0 -0.224006;
    9731 -3.87 0 -4.73923e-016; 9732 -3.44 0 -4.21265e-016;
    9733 -3.01 0 -3.68607e-016; 9734 -2.58 0 -3.15948e-016;
    9735 -2.15 0 -2.6329e-016; 9736 -1.72 0 -2.10632e-016;
    9737 -1.29 0 -1.57974e-016; 9738 -3.81121 0 0.672018; 9739 -3.38774 0 0.59735;
    9740 -2.96427 0 0.522681; 9741 -2.5408 0 0.448012; 9742 -2.11734 0 0.373344;
    9743 -1.69387 0 0.298675; 9744 -1.2704 0 0.224006; 9745 -3.63661 0 1.32362;
    9746 -3.23254 0 1.17655; 9747 -2.82847 0 1.02948; 9748 -2.42441 0 0.882412;
    9749 -2.02034 0 0.735343; 9750 -1.61627 0 0.588275; 9751 -1.2122 0 0.441206;
    9752 -3.35152 0 1.935; 9753 -2.97913 0 1.72; 9754 -2.60674 0 1.505;
    9755 -2.23435 0 1.29; 9756 -1.86195 0 1.075; 9757 -1.48956 0 0.86;
    9758 -1.11717 0 0.645; 9759 -2.96459 0 2.48759; 9760 -2.63519 0 2.21119;
    9761 -2.30579 0 1.93479; 9762 -1.97639 0 1.65839; 9763 -1.647 0 1.38199;
    9764 -1.3176 0 1.10559; 9765 -0.988197 0 0.829196; 9766 -2.48759 0 2.96459;
    9767 -2.21119 0 2.63519; 9768 -1.93479 0 2.30579; 9769 -1.65839 0 1.97639;
    9770 -1.38199 0 1.647; 9771 -1.10559 0 1.3176; 9772 -0.829196 0 0.988197;
    9773 -1.935 0 3.35152; 9774 -1.72 0 2.97913; 9775 -1.505 0 2.60674;
    9776 -1.29 0 2.23435; 9777 -1.075 0 1.86195; 9778 -0.86 0 1.48956;
    9779 -0.645 0 1.11717; 9780 -1.32362 0 3.63661; 9781 -1.17655 0 3.23254;
    9782 -1.02948 0 2.82847; 9783 -0.882412 0 2.42441; 9784 -0.735343 0 2.02034;
    9785 -0.588275 0 1.61627; 9786 -0.441206 0 1.2122; 9787 -0.672018 0 3.81121;
    9788 -0.59735 0 3.38774; 9789 -0.522681 0 2.96427; 9790 -0.448012 0 2.5408;
    9791 -0.373344 0 2.11734; 9792 -0.298675 0 1.69387; 9793 -0.224006 0 1.2704;
    9794 -7.10884e-016 0 3.87; 9795 -6.31897e-016 0 3.44; 9796 -5.5291e-016 0 3.01;
    9797 -4.73923e-016 0 2.58; 9798 -3.94936e-016 0 2.15;
    9799 -3.15948e-016 0 1.72; 9800 -2.36961e-016 0 1.29; 9801 0.672018 0 3.81121;
    9802 0.59735 0 3.38774; 9803 0.522681 0 2.96427; 9804 0.448012 0 2.5408;
    9805 0.373344 0 2.11734; 9806 0.298675 0 1.69387; 9807 0.224006 0 1.2704;
    9808 1.32362 0 3.63661; 9809 1.17655 0 3.23254; 9810 1.02948 0 2.82847;
    9811 0.882412 0 2.42441; 9812 0.735343 0 2.02034; 9813 0.588275 0 1.61627;
    9814 0.441206 0 1.2122; 9815 1.935 0 3.35152; 9816 1.72 0 2.97913;
    9817 1.505 0 2.60674; 9818 1.29 0 2.23435; 9819 1.075 0 1.86195;
    9820 0.86 0 1.48956; 9821 0.645 0 1.11717; 9822 2.48759 0 2.96459;
    9823 2.21119 0 2.63519; 9824 1.93479 0 2.30579; 9825 1.65839 0 1.97639;
    9826 1.38199 0 1.647; 9827 1.10559 0 1.3176; 9828 0.829196 0 0.988197;
    9829 2.96459 0 2.48759; 9830 2.63519 0 2.21119; 9831 2.30579 0 1.93479;
    9832 1.97639 0 1.65839; 9833 1.647 0 1.38199; 9834 1.3176 0 1.10559;
    9835 0.988197 0 0.829196; 9836 3.35152 0 1.935; 9837 2.97913 0 1.72;
    9838 2.60674 0 1.505; 9839 2.23435 0 1.29; 9840 1.86195 0 1.075;
    9841 1.48956 0 0.86; 9842 1.11717 0 0.645; 9843 3.63661 0 1.32362;
    9844 3.23254 0 1.17655; 9845 2.82847 0 1.02948; 9846 2.42441 0 0.882412;
    9847 2.02034 0 0.735343; 9848 1.61627 0 0.588275; 9849 1.2122 0 0.441206;
    9850 11.72 0 0; 9851 11.6754 0 1.02147; 9852 11.2584 0 0.984984;
    9853 11.3014 0 0; 9854 11.6754 0 -1.02147; 9855 11.2584 0 -0.984984;
    9856 11.5419 0 -2.03516; 9857 11.1297 0 -1.96247; 9858 11.3207 0 -3.03336;
    9859 10.9163 0 -2.92502; 9860 11.0132 0 -4.00848; 9861 10.6199 0 -3.86532;
    9862 10.6219 0 -4.95309; 9863 10.2426 0 -4.77619; 9864 10.1498 0 -5.86;
    9865 9.78732 0 -5.65071; 9866 9.60046 0 -6.72232; 9867 9.25759 0 -6.48223;
    9868 8.97804 0 -7.53347; 9869 8.6574 0 -7.26442; 9870 8.28729 0 -8.28729;
    9871 7.99132 0 -7.99132; 9872 7.53347 0 -8.97804; 9873 7.26442 0 -8.6574;
    9874 6.72232 0 -9.60046; 9875 6.48223 0 -9.25759; 9876 5.86 0 -10.1498;
    9877 5.65071 0 -9.78732; 9878 4.95309 0 -10.6219; 9879 4.77619 0 -10.2426;
    9880 4.00848 0 -11.0132; 9881 3.86532 0 -10.6199; 9882 3.03336 0 -11.3207;
    9883 2.92502 0 -10.9163; 9884 2.03516 0 -11.5419; 9885 1.96247 0 -11.1297;
    9886 1.02147 0 -11.6754; 9887 0.984984 0 -11.2584; 9888 7.17619e-016 0 -11.72;
    9889 6.9199e-016 0 -11.3014; 9890 -1.02147 0 -11.6754;
    9891 -0.984984 0 -11.2584; 9892 -2.03516 0 -11.5419; 9893 -1.96247 0 -11.1297;
    9894 -3.03336 0 -11.3207; 9895 -2.92502 0 -10.9163; 9896 -4.00848 0 -11.0132;
    9897 -3.86532 0 -10.6199; 9898 -4.95309 0 -10.6219; 9899 -4.77619 0 -10.2426;
    9900 -5.86 0 -10.1498; 9901 -5.65071 0 -9.78732; 9902 -6.72232 0 -9.60046;
    9903 -6.48223 0 -9.25759; 9904 -7.53347 0 -8.97804; 9905 -7.26442 0 -8.6574;
    9906 -8.28729 0 -8.28729; 9907 -7.99132 0 -7.99132; 9908 -8.97804 0 -7.53347;
    9909 -8.6574 0 -7.26442; 9910 -9.60046 0 -6.72232; 9911 -9.25759 0 -6.48223;
    9912 -10.1498 0 -5.86; 9913 -9.78732 0 -5.65071; 9914 -10.6219 0 -4.95309;
    9915 -10.2426 0 -4.77619; 9916 -11.0132 0 -4.00848; 9917 -10.6199 0 -3.86532;
    9918 -11.3207 0 -3.03336; 9919 -10.9163 0 -2.92502; 9920 -11.5419 0 -2.03516;
    9921 -11.1297 0 -1.96247; 9922 -11.6754 0 -1.02147; 9923 -11.2584 0 -0.984984;
    9924 -11.72 0 -1.43524e-015; 9925 -11.3014 0 -1.38398e-015;
    9926 -11.6754 0 1.02147; 9927 -11.2584 0 0.984984; 9928 -11.5419 0 2.03516;
    9929 -11.1297 0 1.96247; 9930 -11.3207 0 3.03336; 9931 -10.9163 0 2.92502;
    9932 -11.0132 0 4.00848; 9933 -10.6199 0 3.86532; 9934 -10.6219 0 4.95309;
    9935 -10.2426 0 4.77619; 9936 -10.1498 0 5.86; 9937 -9.78732 0 5.65071;
    9938 -9.60046 0 6.72232; 9939 -9.25759 0 6.48223; 9940 -8.97804 0 7.53347;
    9941 -8.6574 0 7.26442; 9942 -8.28729 0 8.28729; 9943 -7.99132 0 7.99132;
    9944 -7.53347 0 8.97804; 9945 -7.26442 0 8.6574; 9946 -6.72232 0 9.60046;
    9947 -6.48223 0 9.25759; 9948 -5.86 0 10.1498; 9949 -5.65071 0 9.78732;
    9950 -4.95309 0 10.6219; 9951 -4.77619 0 10.2426; 9952 -4.00848 0 11.0132;
    9953 -3.86532 0 10.6199; 9954 -3.03336 0 11.3207; 9955 -2.92502 0 10.9163;
    9956 -2.03516 0 11.5419; 9957 -1.96247 0 11.1297; 9958 -1.02147 0 11.6754;
    9959 -0.984984 0 11.2584; 9960 -2.15286e-015 0 11.72;
    9961 -2.07597e-015 0 11.3014; 9962 1.02147 0 11.6754; 9963 0.984984 0 11.2584;
    9964 2.03516 0 11.5419; 9965 1.96247 0 11.1297; 9966 3.03336 0 11.3207;
    9967 2.92502 0 10.9163; 9968 4.00848 0 11.0132; 9969 3.86532 0 10.6199;
    9970 4.95309 0 10.6219; 9971 4.77619 0 10.2426; 9972 5.86 0 10.1498;
    9973 5.65071 0 9.78732; 9974 6.72232 0 9.60046; 9975 6.48223 0 9.25759;
    9976 7.53347 0 8.97804; 9977 7.26442 0 8.6574; 9978 8.28729 0 8.28729;
    9979 7.99132 0 7.99132; 9980 8.97804 0 7.53347; 9981 8.6574 0 7.26442;
    9982 9.60046 0 6.72232; 9983 9.25759 0 6.48223; 9984 10.1498 0 5.86;
    9985 9.78732 0 5.65071; 9986 10.6219 0 4.95309; 9987 10.2426 0 4.77619;
    9988 11.0132 0 4.00848; 9989 10.6199 0 3.86532; 9990 11.3207 0 3.03336;
    9991 10.9163 0 2.92502; 9992 11.5419 0 2.03516; 9993 11.1297 0 1.96247;
    9994 10.4897 17.1335 -0.917733; 9995 10.5298 17.1335 0;
    9998 10.3698 17.1335 -1.82848; 10000 10.171 17.1335 -2.72531;
    10002 9.89478 17.1335 -3.60141; 10004 9.54325 17.1335 -4.45009;
    10006 9.11908 17.1335 -5.2649; 10008 8.62551 17.1335 -6.03965;
    10010 8.0663 17.1335 -6.76843; 10012 7.4457 17.1335 -7.4457;
    10014 6.76843 17.1335 -8.0663; 10016 6.03965 17.1335 -8.62551;
    10018 5.2649 17.1335 -9.11908; 10020 4.45009 17.1335 -9.54325;
    10022 3.60141 17.1335 -9.89478; 10024 2.72531 17.1335 -10.171;
    10026 1.82848 17.1335 -10.3698; 10028 0.917733 17.1335 -10.4897;
    10030 6.17004e-008 17.1335 -10.5298; 10032 -0.917733 17.1335 -10.4897;
    10034 -1.82848 17.1335 -10.3698; 10036 -2.72531 17.1335 -10.171;
    10038 -3.60141 17.1335 -9.89478; 10040 -4.45009 17.1335 -9.54325;
    10042 -5.2649 17.1335 -9.11908; 10044 -6.03965 17.1335 -8.62551;
    10046 -6.76843 17.1335 -8.0663; 10048 -7.4457 17.1335 -7.4457;
    10050 -8.0663 17.1335 -6.76843; 10052 -8.62551 17.1335 -6.03965;
    10054 -9.11908 17.1335 -5.2649; 10056 -9.54325 17.1335 -4.45009;
    10058 -9.89478 17.1335 -3.60141; 10060 -10.171 17.1335 -2.72531;
    10062 -10.3698 17.1335 -1.82848; 10064 -10.4897 17.1335 -0.917733;
    10066 -10.5298 17.1335 -6.17004e-008; 10068 -10.4897 17.1335 0.917733;
    10070 -10.3698 17.1335 1.82848; 10072 -10.171 17.1335 2.72531;
    10074 -9.89478 17.1335 3.60141; 10076 -9.54325 17.1335 4.45009;
    10078 -9.11908 17.1335 5.2649; 10080 -8.62551 17.1335 6.03965;
    10082 -8.0663 17.1335 6.76843; 10084 -7.4457 17.1335 7.4457;
    10086 -6.76843 17.1335 8.0663; 10088 -6.03965 17.1335 8.62551;
    10090 -5.2649 17.1335 9.11908; 10092 -4.45009 17.1335 9.54325;
    10094 -3.60141 17.1335 9.89478; 10096 -2.72531 17.1335 10.171;
    10098 -1.82848 17.1335 10.3698; 10100 -0.917733 17.1335 10.4897;
    10102 -6.17004e-008 17.1335 10.5298; 10104 0.917733 17.1335 10.4897;
    10106 1.82848 17.1335 10.3698; 10108 2.72531 17.1335 10.171;
    10110 3.60141 17.1335 9.89478; 10112 4.45009 17.1335 9.54325;
    10114 5.2649 17.1335 9.11908; 10116 6.03965 17.1335 8.62551;
    10118 6.76843 17.1335 8.0663; 10120 7.4457 17.1335 7.4457;
    10122 8.0663 17.1335 6.76843; 10124 8.62551 17.1335 6.03965;
    10126 9.11908 17.1335 5.2649; 10128 9.54325 17.1335 4.45009;
    10130 9.89478 17.1335 3.60141; 10132 10.171 17.1335 2.72531;
    10134 10.3698 17.1335 1.82848; 10136 10.4897 17.1335 0.917733; 10137 12.5 0 0;
    10138 12.4524 0 -1.08945; 10139 12.3101 0 -2.17061; 10140 12.0741 0 -3.23524;
    10141 11.7462 0 -4.27526; 10142 11.3288 0 -5.28273; 10143 10.8253 0 -6.25;
    10144 10.2394 0 -7.16971; 10145 9.57555 0 -8.03485; 10146 8.83883 0 -8.83884;
    10147 8.03484 0 -9.57556; 10148 7.1697 0 -10.2394; 10149 6.24999 0 -10.8253;
    10150 5.28272 0 -11.3288; 10151 4.27525 0 -11.7462; 10152 3.23523 0 -12.0741;
    10153 2.1706 0 -12.3101; 10154 1.08944 0 -12.4524; 10155 -5.1649e-006 0 -12.5;
    10156 -1.08945 0 -12.4524; 10157 -2.17061 0 -12.3101;
    10158 -3.23524 0 -12.0741; 10159 -4.27526 0 -11.7462;
    10160 -5.28273 0 -11.3288; 10161 -6.25 0 -10.8253; 10162 -7.16971 0 -10.2394;
    10163 -8.03485 0 -9.57555; 10164 -8.83884 0 -8.83883;
    10165 -9.57556 0 -8.03484; 10166 -10.2394 0 -7.1697; 10167 -10.8253 0 -6.24999;
    10168 -11.3288 0 -5.28272; 10169 -11.7462 0 -4.27525;
    10170 -12.0741 0 -3.23523; 10171 -12.3101 0 -2.1706; 10172 -12.4524 0 -1.08944;
    10173 -12.5 0 5.1649e-006; 10174 -12.4524 0 1.08945; 10175 -12.3101 0 2.17061;
    10176 -12.0741 0 3.23524; 10177 -11.7462 0 4.27526; 10178 -11.3288 0 5.28273;
    10179 -10.8253 0 6.25; 10180 -10.2394 0 7.16971; 10181 -9.57555 0 8.03485;
    10182 -8.83883 0 8.83884; 10183 -8.03484 0 9.57556; 10184 -7.1697 0 10.2394;
    10185 -6.24999 0 10.8253; 10186 -5.28272 0 11.3288; 10187 -4.27525 0 11.7462;
    10188 -3.23523 0 12.0741; 10189 -2.1706 0 12.3101; 10190 -1.08944 0 12.4524;
    10191 5.1649e-006 0 12.5; 10192 1.08945 0 12.4524; 10193 2.17061 0 12.3101;
    10194 3.23524 0 12.0741; 10195 4.27526 0 11.7462; 10196 5.28273 0 11.3288;
    10197 6.25 0 10.8253; 10198 7.16971 0 10.2394; 10199 8.03485 0 9.57555;
    10200 8.83884 0 8.83883; 10201 9.57556 0 8.03484; 10202 10.2394 0 7.1697;
    10203 10.8253 0 6.24999; 10204 11.3288 0 5.28272; 10205 11.7462 0 4.27525;
    10206 12.0741 0 3.23523; 10207 12.3101 0 2.1706; 10208 12.4524 0 1.08944;
    10209 13.25 0 0; 10210 13.1995 0 -1.15482; 10211 13.0487 0 -2.30084;
    10212 12.7985 0 -3.42935; 10213 12.4509 0 -4.53176; 10214 12.0085 0 -5.59968;
    10215 11.4748 0 -6.62499; 10216 10.8537 0 -7.59987; 10217 10.1501 0 -8.51692;
    10218 9.36914 0 -9.36915; 10219 8.51691 0 -10.1501; 10220 7.59986 0 -10.8537;
    10221 6.62498 0 -11.4748; 10222 5.59967 0 -12.0086; 10223 4.53175 0 -12.4509;
    10224 3.42934 0 -12.7985; 10225 2.30083 0 -13.0487; 10226 1.1548 0 -13.1995;
    10227 -6.57198e-006 0 -13.25; 10228 -1.15482 0 -13.1995;
    10229 -2.30084 0 -13.0487; 10230 -3.42935 0 -12.7985;
    10231 -4.53176 0 -12.4509; 10232 -5.59968 0 -12.0085;
    10233 -6.62499 0 -11.4748; 10234 -7.59987 0 -10.8537;
    10235 -8.51692 0 -10.1501; 10236 -9.36915 0 -9.36914;
    10237 -10.1501 0 -8.51691; 10238 -10.8537 0 -7.59986;
    10239 -11.4748 0 -6.62498; 10240 -12.0086 0 -5.59967;
    10241 -12.4509 0 -4.53175; 10242 -12.7985 0 -3.42934;
    10243 -13.0487 0 -2.30083; 10244 -13.1995 0 -1.1548;
    10245 -13.25 0 6.57198e-006; 10246 -13.1995 0 1.15482;
    10247 -13.0487 0 2.30084; 10248 -12.7985 0 3.42935; 10249 -12.4509 0 4.53176;
    10250 -12.0085 0 5.59968; 10251 -11.4748 0 6.62499; 10252 -10.8537 0 7.59987;
    10253 -10.1501 0 8.51692; 10254 -9.36914 0 9.36915; 10255 -8.51691 0 10.1501;
    10256 -7.59986 0 10.8537; 10257 -6.62498 0 11.4748; 10258 -5.59967 0 12.0086;
    10259 -4.53175 0 12.4509; 10260 -3.42934 0 12.7985; 10261 -2.30083 0 13.0487;
    10262 -1.1548 0 13.1995; 10263 6.57198e-006 0 13.25; 10264 1.15482 0 13.1995;
    10265 2.30084 0 13.0487; 10266 3.42935 0 12.7985; 10267 4.53176 0 12.4509;
    10268 5.59968 0 12.0085; 10269 6.62499 0 11.4748; 10270 7.59987 0 10.8537;
    10271 8.51692 0 10.1501; 10272 9.36915 0 9.36914; 10273 10.1501 0 8.51691;
    10274 10.8537 0 7.59986; 10275 11.4748 0 6.62498; 10276 12.0086 0 5.59967;
    10277 12.4509 0 4.53175; 10278 12.7985 0 3.42934; 10279 13.0487 0 2.30083;
    10280 13.1995 0 1.1548; 10281 6.03965 18.9243 8.62551;
    10282 6.76843 18.9243 8.0663; 10283 7.4457 18.9243 7.4457;
    10284 8.0663 18.9243 6.76843; 10285 6.03965 19.7243 8.62551;
    10286 6.76843 19.7243 8.0663; 10287 7.4457 19.7243 7.4457;
    10288 8.0663 19.7243 6.76843; 10289 6.03965 20.5243 8.62551;
    10290 6.76843 20.5243 8.0663; 10291 7.4457 20.5243 7.4457;
    10292 8.0663 20.5243 6.76843; 10293 6.03965 21.324 8.626;
    10294 6.76843 21.3243 8.0663; 10295 7.4457 21.3243 7.4457;
    10296 8.0663 21.3243 6.76843; 10297 3.08408 21.3236 4.40452;
    10298 4.11896 21.3236 3.45622; 10301 5.91115 19.0168 8.44199;
    10302 7.89468 19.0168 6.62442; 10303 5.91115 19.8168 8.44199;
    10304 7.89468 19.8168 6.62442; 10305 5.91115 20.6168 8.44199;
    10306 7.89468 20.6168 6.62442; 10307 5.91094 21.324 8.44214;
    10308 7.89468 21.3242 6.62442; 10309 5.65414 19.2018 8.07495;
    10310 5.39713 19.3868 7.7079; 10311 5.14013 19.5718 7.34086;
    10312 4.88312 19.7567 6.97382; 10313 7.55143 19.2018 6.3364;
    10314 7.20818 19.3868 6.04838; 10315 6.86494 19.5718 5.76037;
    10316 6.52169 19.7567 5.47235; 10317 5.65414 20.0018 8.07495;
    10318 5.39713 20.1868 7.7079; 10319 5.14013 20.3718 7.34086;
    10320 4.88312 20.5567 6.97382; 10321 5.65414 20.8018 8.07495;
    10322 5.39713 20.9868 7.7079; 10323 5.65398 21.324 8.07506;
    10324 5.39707 21.324 7.70804; 10325 5.14013 21.1718 7.34086;
    10326 5.14013 21.324 7.341; 10327 4.88312 21.324 6.974;
    10328 4.62611 19.9417 6.60678; 10329 4.36911 20.1267 6.23973;
    10330 4.1121 20.3117 5.87269; 10331 4.62611 20.7417 6.60678;
    10332 4.36911 20.9267 6.23973; 10333 4.62611 21.3237 6.60678;
    10334 4.36911 21.3237 6.23973; 10335 4.1121 21.1117 5.87269;
    10336 4.1121 21.3237 5.87269; 10337 3.8551 20.4967 5.50565;
    10338 3.59809 20.6817 5.1386; 10339 3.8551 21.3247 5.50565;
    10340 3.59809 21.3237 5.1386; 10341 3.34108 20.8667 4.77156;
    10342 3.34108 21.3237 4.77156; 10343 3.08408 21.0516 4.40452;
    10344 6.17844 19.9417 5.18433; 10345 5.8352 20.1267 4.89631;
    10346 5.49195 20.3117 4.60829; 10347 5.1487 20.4967 4.32027;
    10348 4.80546 20.6817 4.03226; 10349 4.46221 20.8667 3.74424;
    10350 4.11896 21.0516 3.45622; 10351 4.46221 21.3237 3.74424;
    10352 4.80546 21.3237 4.03226; 10353 5.1487 21.3237 4.32027;
    10354 7.55143 20.0018 6.3364; 10355 7.20818 20.1868 6.04838;
    10356 6.86494 20.3718 5.76037; 10357 6.52169 20.5567 5.47235;
    10358 6.17844 20.7417 5.18433; 10359 5.8352 20.9267 4.89631;
    10360 5.49195 21.1117 4.60829; 10361 5.49195 21.3237 4.60829;
    10362 5.8352 21.3237 4.89631; 10363 6.17844 21.3237 5.18433;
    10364 6.52169 21.3237 5.47235; 10365 7.55143 20.8018 6.3364;
    10366 7.20818 20.9868 6.04838; 10367 6.86494 21.1718 5.76037;
    10368 6.86494 21.3238 5.76037; 10369 7.20818 21.3239 6.04838;
    10370 7.55143 21.3241 6.3364; 10371 2.68846 21.0516 4.65655;
    10372 3.45622 21.0516 4.11896; 10374 2.68846 21.3236 4.65655;
    10375 3.45622 21.3236 4.11896; 10376 2.27239 21.0516 4.87315;
    10377 2.27239 21.3236 4.87315; 10379 1.12258 21.5465 1.93887;
    10380 1.28954 21.5465 1.83209; 10381 1.44642 21.5465 1.71098;
    10382 1.59197 21.5465 1.57647; 10383 1.72507 21.5465 1.42962;
    10384 1.84467 21.5465 1.27158; 10385 1.94984 21.5465 1.1036;
    10386 1.54141 21.3616 2.20272; 10387 1.72694 21.3616 2.0605;
    10388 1.89942 21.3616 1.90271; 10389 2.05753 21.3616 1.73053;
    10390 2.20009 21.3616 1.54526; 10391 2.32602 21.3616 1.34831;
    10392 1.32556 21.3616 2.84267; 10393 2.84267 21.3616 1.32556;
    10394 2.08302 21.3236 4.46705; 10395 1.89365 21.3236 4.06096;
    10396 1.70429 21.3236 3.65486; 10397 1.51492 21.3236 3.24877;
    10398 4.40452 21.0516 3.08408; 10399 4.65655 21.0516 2.68846;
    10400 4.87315 21.0516 2.27239; 10401 4.40452 21.3236 3.08408;
    10402 4.65655 21.3236 2.68846; 10403 4.87315 21.3236 2.27239;
    10404 4.46705 21.3236 2.08302; 10405 4.06096 21.3236 1.89365;
    10406 3.65486 21.3236 1.70429; 10407 3.24877 21.3236 1.51492;
    10409 4.75257 21.3237 -4.75257; 10410 -1.16712 21.3237 -6.61904;
    10411 -3.8551 21.3237 -5.50565; 10412 -5.82069 21.3237 -3.36058;
    10413 -6.69558 21.3237 -0.585787; 10414 -6.31582 21.3237 2.29877;
    10415 -4.75257 21.3237 4.75257; 10416 -2.29877 21.3237 6.31582;
    10417 0.585787 21.3237 6.69558; 10418 6.69558 21.3237 0.585787;
    10420 3.80206 21.3236 -3.80206; 10421 1.83902 21.3236 -5.05265;
    10422 -0.933693 21.3236 -5.29524; 10423 -3.08408 21.3236 -4.40452;
    10424 -4.65655 21.3236 -2.68846; 10425 -5.35646 21.3236 -0.46863;
    10426 -5.05265 21.3236 1.83902; 10427 -3.80206 21.3236 3.80206;
    10428 -1.83902 21.3236 5.05265; 10429 0.46863 21.3236 5.35646;
    10430 5.35646 21.3236 0.46863; 10431 2.84048 21.3237 6.09143;
    10432 6.09143 21.3237 2.84048; 10433 2.29877 21.3237 -6.31582;
    10434 1.37051 21.3236 5.11481; 10435 1.71313 21.3237 6.39351;
    10436 -0.685195 21.3236 5.20456; 10437 -0.856491 21.3237 6.5057;
    10438 -2.82054 21.3236 4.42735; 10439 -3.52567 21.3237 5.53419;
    10440 -4.42735 21.3236 2.82054; 10441 -5.53419 21.3237 3.52567;
    10442 -5.20456 21.3236 0.685195; 10443 -6.5057 21.3237 0.856492;
    10444 -5.00651 21.3236 -1.57854; 10445 -6.25813 21.3237 -1.97318;
    10446 -3.87032 21.3236 -3.54649; 10447 -4.83789 21.3237 -4.43312;
    10448 -2.00889 21.3236 -4.84988; 10449 -2.51111 21.3237 -6.06235;
    10450 0.452663 21.3236 -5.17394; 10451 0.565825 21.3237 -6.46743;
    10452 2.82054 21.3236 -4.42735; 10453 3.52567 21.3237 -5.53419;
    10458 5.11481 21.3236 1.37051; 10459 6.39351 21.3237 1.71313;
    10461 6.31582 21.3237 -2.29877; 10463 5.05265 21.3236 -1.83902;
    10464 4.42735 21.3236 -2.82054; 10465 5.53419 21.3237 -3.52567;
    10466 5.20456 21.3236 -0.685195; 10467 6.5057 21.3237 -0.856492;
    MEMBER INCIDENCES
    3379 2894 2914; 3380 2914 2934; 3381 2934 2954; 3382 2954 2974; 3383 2974 2994;
    3384 2994 3014; 3385 3014 3034; 3386 3034 3054; 3387 3054 3074; 3388 3074 3094;
    3389 3094 3114; 3390 3114 3134; 3391 3134 3154; 3392 3154 3174; 3393 3174 3194;
    3394 3194 3213; 3395 3213 1813; 3396 1813 1814; 3397 1814 1834; 3398 1834 1854;
    3399 1854 1874; 3400 1874 1894; 3401 1894 1914; 3402 1914 1934; 3403 1934 1954;
    3404 1954 1974; 3405 1974 1994; 3406 1994 2014; 3407 2014 2034; 3408 2034 2054;
    3409 2054 2074; 3410 2074 2094; 3411 2094 2114; 3412 2114 2134; 3413 2134 2154;
    3415 2174 2194; 3416 2194 2214; 3417 2214 2234; 3418 2234 2254; 3419 2254 2274;
    3420 2274 2294; 3421 2294 2314; 3422 2314 2334; 3423 2334 2354; 3424 2354 2374;
    3425 2374 2394; 3426 2394 2414; 3427 2414 2434; 3428 2434 2454; 3429 2454 2474;
    3430 2474 2494; 3431 2494 2514; 3433 2534 2554; 3434 2554 2574; 3435 2574 2594;
    3436 2594 2614; 3437 2614 2634; 3438 2634 2654; 3439 2654 2674; 3440 2674 2694;
    3441 2694 2714; 3442 2714 2734; 3443 2734 2754; 3444 2754 2774; 3445 2774 2794;
    3446 2794 2814; 3447 2814 2834; 3448 2834 2854; 3449 2854 2874; 3450 2874 2894;
    6599 4456 4477; 6600 4477 4498; 6601 4498 4519; 6602 4519 4540; 6603 4540 4561;
    6604 4561 4582; 6605 4582 4603; 6606 4603 4624; 6607 4624 4645; 6608 4645 4666;
    6609 4666 4687; 6610 4687 4708; 6611 4708 4729; 6612 4729 4750; 6613 4750 4771;
    6614 4771 3222; 6615 3222 3301; 6616 3301 3322; 6617 3322 3343; 6618 3343 3364;
    6619 3364 3385; 6620 3385 3406; 6621 3406 3427; 6622 3427 3448; 6623 3448 3469;
    6624 3469 3490; 6625 3490 3511; 6626 3511 3532; 6627 3532 3553; 6628 3553 3574;
    6629 3574 3595; 6630 3595 3616; 6631 3616 3637; 6632 3637 3658; 6633 3658 3679;
    6634 3679 3700; 6635 3700 3721; 6636 3721 3742; 6637 3742 3763; 6638 3763 3784;
    6639 3784 3805; 6640 3805 3826; 6641 3826 3847; 6642 3847 3868; 6643 3868 3889;
    6644 3889 3910; 6645 3910 3931; 6646 3931 3952; 6647 3952 3973; 6648 3973 3994;
    6649 3994 4015; 6650 4015 4036; 6651 4036 4057; 6652 4057 4078; 6653 4078 4099;
    6654 4099 4120; 6655 4120 4141; 6656 4141 4162; 6657 4162 4183; 6658 4183 4204;
    6659 4204 4225; 6660 4225 4246; 6661 4246 4267; 6662 4267 4288; 6663 4288 4309;
    6664 4309 4330; 6665 4330 4351; 6666 4351 4372; 6667 4372 4393; 6668 4393 4414;
    6669 4414 4435; 6670 4435 4456; 12528 2154 2174; 12533 2514 2534;
    12894 3373 10461; 12895 3478 10409; 12896 3709 10410; 12897 3814 10411;
    12898 3919 10412; 12899 4024 10413; 12900 4129 10414; 12901 4234 10415;
    12902 4339 10416; 12903 4444 10417; 12904 4780 10418; 12905 3376 10463;
    12906 3481 10420; 12907 3586 10421; 12908 3712 10422; 12909 3817 10423;
    12910 3922 10424; 12911 4027 10425; 12912 4132 10426; 12913 4237 10427;
    12914 4342 10428; 12915 4447 10429; 12916 4783 10430; 12917 4528 10431;
    12918 4696 10432; 12919 3583 10433; 12920 10427 10438; 12921 10428 10436;
    12922 10429 10434; 12923 10417 10435; 12924 10431 10339; 12925 10416 10437;
    12926 10415 10439; 12927 10428 10416; 12928 10429 10417; 12929 10377 10431;
    12930 10427 10415; 12931 10414 10441; 12932 10426 10440; 12933 10426 10414;
    12934 10413 10443; 12935 10425 10442; 12936 10425 10413; 12937 10434 10377;
    12938 10435 10431; 12939 10434 10435; 12940 10436 10429; 12941 10437 10417;
    12942 10436 10437; 12943 10438 10428; 12944 10439 10416; 12945 10438 10439;
    12946 10440 10427; 12947 10441 10415; 12948 10440 10441; 12949 10442 10426;
    12950 10443 10414; 12951 10442 10443; 12952 10425 10444; 12953 10413 10445;
    12954 10424 10412; 12955 10444 10424; 12956 10445 10412; 12957 10444 10445;
    12958 10424 10446; 12959 10412 10447; 12960 10423 10411; 12961 10446 10423;
    12962 10447 10411; 12963 10446 10447; 12964 10423 10448; 12965 10411 10449;
    12966 10422 10410; 12967 10448 10422; 12968 10449 10410; 12969 10448 10449;
    12970 10422 10450; 12971 10410 10451; 12972 10421 10433; 12973 10450 10421;
    12974 10451 10433; 12975 10450 10451; 12976 10421 10452; 12977 10433 10453;
    12978 10420 10409; 12979 10452 10420; 12980 10453 10409; 12981 10452 10453;
    12984 10463 10461; 12990 10430 10418; 12994 10432 10459; 12995 10403 10458;
    12996 10458 10430; 12997 10459 10418; 12998 10458 10459; 13000 10403 10432;
    13001 10420 10464; 13002 10409 10465; 13003 10464 10463; 13004 10465 10461;
    13005 10464 10465; 13006 10430 10466; 13007 10418 10467; 13008 10466 10463;
    13009 10467 10461; 13010 10466 10467; 13011 4705 10391; 13012 10391 10390;
    13013 10390 10389; 13014 10389 10388; 13015 10388 10387; 13016 10387 10386;
    13017 10386 4558; 13018 4558 4537; 13019 4537 10392; 13020 10392 10397;
    13021 10397 10396; 13025 10377 10374; 13026 10374 10297; 13027 10297 10375;
    13028 10375 10298; 13029 10298 10401; 13030 10401 10402; 13031 10402 10403;
    13032 10403 10404; 13036 10407 10393; 13037 10393 4705; 13038 10298 10351;
    13039 10351 10352; 13040 10352 10353; 13041 10353 10361; 13042 10361 10362;
    13043 10362 10363; 13046 10363 10364; 13047 10364 10368; 13048 10368 10369;
    13054 10294 10293; 13055 10293 10307; 13059 10326 10327; 13060 10327 10333;
    13061 10333 10334; 13062 10334 10336; 13063 10336 10339; 13064 10339 10340;
    13065 10340 10342; 13066 10342 10297; 13067 10353 10339; 13068 10368 10326;
    13069 10294 10295; 13070 10295 10296; 13071 10308 10296; 13072 10369 10370;
    13073 10370 10308; 13074 10307 10323; 13075 10323 10324; 13076 10324 10326;
    13077 10394 10377; 13078 10395 10394; 13079 10396 10395; 13080 10404 10405;
    13081 10405 10406; 13082 10406 10407; 13083 10432 10353;
    ELEMENT INCIDENCES SHELL
    1940 1774 1776 1778 1777; 1941 1777 1778 1780 1779; 1942 1779 1780 1782 1781;
    1943 1781 1782 1784 1783; 1944 1783 1784 1786 1785; 1945 1785 1786 1788 1787;
    1946 1787 1788 1790 1789; 1947 1789 1790 1792 1791; 1948 1791 1792 1794 1793;
    1949 1793 1794 1796 1795; 1950 1795 1796 1798 1797; 1951 1797 1798 1800 1799;
    1952 1799 1800 1802 1801; 1953 1801 1802 1804 1803; 1954 1803 1804 1806 1805;
    1955 1805 1806 1808 1807; 1956 1807 1808 1810 1809; 1957 1809 1810 1812 1811;
    1960 1776 1815 1816 1778; 1961 1778 1816 1817 1780; 1962 1780 1817 1818 1782;
    1963 1782 1818 1819 1784; 1964 1784 1819 1820 1786; 1965 1786 1820 1821 1788;
    1966 1788 1821 1822 1790; 1967 1790 1822 1823 1792; 1968 1792 1823 1824 1794;
    1969 1794 1824 1825 1796; 1970 1796 1825 1826 1798; 1971 1798 1826 1827 1800;
    1972 1800 1827 1828 1802; 1973 1802 1828 1829 1804; 1974 1804 1829 1830 1806;
    1975 1806 1830 1831 1808; 1976 1808 1831 1832 1810; 1977 1810 1832 1833 1812;
    1980 1815 1835 1836 1816; 1981 1816 1836 1837 1817; 1982 1817 1837 1838 1818;
    1983 1818 1838 1839 1819; 1984 1819 1839 1840 1820; 1985 1820 1840 1841 1821;
    1986 1821 1841 1842 1822; 1987 1822 1842 1843 1823; 1988 1823 1843 1844 1824;
    1989 1824 1844 1845 1825; 1990 1825 1845 1846 1826; 1991 1826 1846 1847 1827;
    1992 1827 1847 1848 1828; 1993 1828 1848 1849 1829; 1994 1829 1849 1850 1830;
    1995 1830 1850 1851 1831; 1996 1831 1851 1852 1832; 1997 1832 1852 1853 1833;
    2000 1835 1855 1856 1836; 2001 1836 1856 1857 1837; 2002 1837 1857 1858 1838;
    2003 1838 1858 1859 1839; 2004 1839 1859 1860 1840; 2005 1840 1860 1861 1841;
    2006 1841 1861 1862 1842; 2007 1842 1862 1863 1843; 2008 1843 1863 1864 1844;
    2009 1844 1864 1865 1845; 2010 1845 1865 1866 1846; 2011 1846 1866 1867 1847;
    2012 1847 1867 1868 1848; 2013 1848 1868 1869 1849; 2014 1849 1869 1870 1850;
    2015 1850 1870 1871 1851; 2016 1851 1871 1872 1852; 2017 1852 1872 1873 1853;
    2020 1855 1875 1876 1856; 2021 1856 1876 1877 1857; 2022 1857 1877 1878 1858;
    2023 1858 1878 1879 1859; 2024 1859 1879 1880 1860; 2025 1860 1880 1881 1861;
    2026 1861 1881 1882 1862; 2027 1862 1882 1883 1863; 2028 1863 1883 1884 1864;
    2029 1864 1884 1885 1865; 2030 1865 1885 1886 1866; 2031 1866 1886 1887 1867;
    2032 1867 1887 1888 1868; 2033 1868 1888 1889 1869; 2034 1869 1889 1890 1870;
    2035 1870 1890 1891 1871; 2036 1871 1891 1892 1872; 2037 1872 1892 1893 1873;
    2040 1875 1895 1896 1876; 2041 1876 1896 1897 1877; 2042 1877 1897 1898 1878;
    2043 1878 1898 1899 1879; 2044 1879 1899 1900 1880; 2045 1880 1900 1901 1881;
    2046 1881 1901 1902 1882; 2047 1882 1902 1903 1883; 2048 1883 1903 1904 1884;
    2049 1884 1904 1905 1885; 2050 1885 1905 1906 1886; 2051 1886 1906 1907 1887;
    2052 1887 1907 1908 1888; 2053 1888 1908 1909 1889; 2054 1889 1909 1910 1890;
    2055 1890 1910 1911 1891; 2056 1891 1911 1912 1892; 2057 1892 1912 1913 1893;
    2060 1895 1915 1916 1896; 2061 1896 1916 1917 1897; 2062 1897 1917 1918 1898;
    2063 1898 1918 1919 1899; 2064 1899 1919 1920 1900; 2065 1900 1920 1921 1901;
    2066 1901 1921 1922 1902; 2067 1902 1922 1923 1903; 2068 1903 1923 1924 1904;
    2069 1904 1924 1925 1905; 2070 1905 1925 1926 1906; 2071 1906 1926 1927 1907;
    2072 1907 1927 1928 1908; 2073 1908 1928 1929 1909; 2074 1909 1929 1930 1910;
    2075 1910 1930 1931 1911; 2076 1911 1931 1932 1912; 2077 1912 1932 1933 1913;
    2080 1915 1935 1936 1916; 2081 1916 1936 1937 1917; 2082 1917 1937 1938 1918;
    2083 1918 1938 1939 1919; 2084 1919 1939 1940 1920; 2085 1920 1940 1941 1921;
    2086 1921 1941 1942 1922; 2087 1922 1942 1943 1923; 2088 1923 1943 1944 1924;
    2089 1924 1944 1945 1925; 2090 1925 1945 1946 1926; 2091 1926 1946 1947 1927;
    2092 1927 1947 1948 1928; 2093 1928 1948 1949 1929; 2094 1929 1949 1950 1930;
    2095 1930 1950 1951 1931; 2096 1931 1951 1952 1932; 2097 1932 1952 1953 1933;
    2100 1935 1955 1956 1936; 2101 1936 1956 1957 1937; 2102 1937 1957 1958 1938;
    2103 1938 1958 1959 1939; 2104 1939 1959 1960 1940; 2105 1940 1960 1961 1941;
    2106 1941 1961 1962 1942; 2107 1942 1962 1963 1943; 2108 1943 1963 1964 1944;
    2109 1944 1964 1965 1945; 2110 1945 1965 1966 1946; 2111 1946 1966 1967 1947;
    2112 1947 1967 1968 1948; 2113 1948 1968 1969 1949; 2114 1949 1969 1970 1950;
    2115 1950 1970 1971 1951; 2116 1951 1971 1972 1952; 2117 1952 1972 1973 1953;
    2120 1955 1975 1976 1956; 2121 1956 1976 1977 1957; 2122 1957 1977 1978 1958;
    2123 1958 1978 1979 1959; 2124 1959 1979 1980 1960; 2125 1960 1980 1981 1961;
    2126 1961 1981 1982 1962; 2127 1962 1982 1983 1963; 2128 1963 1983 1984 1964;
    2129 1964 1984 1985 1965; 2130 1965 1985 1986 1966; 2131 1966 1986 1987 1967;
    2132 1967 1987 1988 1968; 2133 1968 1988 1989 1969; 2134 1969 1989 1990 1970;
    2135 1970 1990 1991 1971; 2136 1971 1991 1992 1972; 2137 1972 1992 1993 1973;
    2140 1975 1995 1996 1976; 2141 1976 1996 1997 1977; 2142 1977 1997 1998 1978;
    2143 1978 1998 1999 1979; 2144 1979 1999 2000 1980; 2145 1980 2000 2001 1981;
    2146 1981 2001 2002 1982; 2147 1982 2002 2003 1983; 2148 1983 2003 2004 1984;
    2149 1984 2004 2005 1985; 2150 1985 2005 2006 1986; 2151 1986 2006 2007 1987;
    2152 1987 2007 2008 1988; 2153 1988 2008 2009 1989; 2154 1989 2009 2010 1990;
    2155 1990 2010 2011 1991; 2156 1991 2011 2012 1992; 2157 1992 2012 2013 1993;
    2160 1995 2015 2016 1996; 2161 1996 2016 2017 1997; 2162 1997 2017 2018 1998;
    2163 1998 2018 2019 1999; 2164 1999 2019 2020 2000; 2165 2000 2020 2021 2001;
    2166 2001 2021 2022 2002; 2167 2002 2022 2023 2003; 2168 2003 2023 2024 2004;
    2169 2004 2024 2025 2005; 2170 2005 2025 2026 2006; 2171 2006 2026 2027 2007;
    2172 2007 2027 2028 2008; 2173 2008 2028 2029 2009; 2174 2009 2029 2030 2010;
    2175 2010 2030 2031 2011; 2176 2011 2031 2032 2012; 2177 2012 2032 2033 2013;
    2180 2015 2035 2036 2016; 2181 2016 2036 2037 2017; 2182 2017 2037 2038 2018;
    2183 2018 2038 2039 2019; 2184 2019 2039 2040 2020; 2185 2020 2040 2041 2021;
    2186 2021 2041 2042 2022; 2187 2022 2042 2043 2023; 2188 2023 2043 2044 2024;
    2189 2024 2044 2045 2025; 2190 2025 2045 2046 2026; 2191 2026 2046 2047 2027;
    2192 2027 2047 2048 2028; 2193 2028 2048 2049 2029; 2194 2029 2049 2050 2030;
    2195 2030 2050 2051 2031; 2196 2031 2051 2052 2032; 2197 2032 2052 2053 2033;
    2200 2035 2055 2056 2036; 2201 2036 2056 2057 2037; 2202 2037 2057 2058 2038;
    2203 2038 2058 2059 2039; 2204 2039 2059 2060 2040; 2205 2040 2060 2061 2041;
    2206 2041 2061 2062 2042; 2207 2042 2062 2063 2043; 2208 2043 2063 2064 2044;
    2209 2044 2064 2065 2045; 2210 2045 2065 2066 2046; 2211 2046 2066 2067 2047;
    2212 2047 2067 2068 2048; 2213 2048 2068 2069 2049; 2214 2049 2069 2070 2050;
    2215 2050 2070 2071 2051; 2216 2051 2071 2072 2052; 2217 2052 2072 2073 2053;
    2220 2055 2075 2076 2056; 2221 2056 2076 2077 2057; 2222 2057 2077 2078 2058;
    2223 2058 2078 2079 2059; 2224 2059 2079 2080 2060; 2225 2060 2080 2081 2061;
    2226 2061 2081 2082 2062; 2227 2062 2082 2083 2063; 2228 2063 2083 2084 2064;
    2229 2064 2084 2085 2065; 2230 2065 2085 2086 2066; 2231 2066 2086 2087 2067;
    2232 2067 2087 2088 2068; 2233 2068 2088 2089 2069; 2234 2069 2089 2090 2070;
    2235 2070 2090 2091 2071; 2236 2071 2091 2092 2072; 2237 2072 2092 2093 2073;
    2240 2075 2095 2096 2076; 2241 2076 2096 2097 2077; 2242 2077 2097 2098 2078;
    2243 2078 2098 2099 2079; 2244 2079 2099 2100 2080; 2245 2080 2100 2101 2081;
    2246 2081 2101 2102 2082; 2247 2082 2102 2103 2083; 2248 2083 2103 2104 2084;
    2249 2084 2104 2105 2085; 2250 2085 2105 2106 2086; 2251 2086 2106 2107 2087;
    2252 2087 2107 2108 2088; 2253 2088 2108 2109 2089; 2254 2089 2109 2110 2090;
    2255 2090 2110 2111 2091; 2256 2091 2111 2112 2092; 2257 2092 2112 2113 2093;
    2260 2095 2115 2116 2096; 2261 2096 2116 2117 2097; 2262 2097 2117 2118 2098;
    2263 2098 2118 2119 2099; 2264 2099 2119 2120 2100; 2265 2100 2120 2121 2101;
    2266 2101 2121 2122 2102; 2267 2102 2122 2123 2103; 2268 2103 2123 2124 2104;
    2269 2104 2124 2125 2105; 2270 2105 2125 2126 2106; 2271 2106 2126 2127 2107;
    2272 2107 2127 2128 2108; 2273 2108 2128 2129 2109; 2274 2109 2129 2130 2110;
    2275 2110 2130 2131 2111; 2276 2111 2131 2132 2112; 2277 2112 2132 2133 2113;
    2280 2115 2135 2136 2116; 2281 2116 2136 2137 2117; 2282 2117 2137 2138 2118;
    2283 2118 2138 2139 2119; 2284 2119 2139 2140 2120; 2285 2120 2140 2141 2121;
    2286 2121 2141 2142 2122; 2287 2122 2142 2143 2123; 2288 2123 2143 2144 2124;
    2289 2124 2144 2145 2125; 2290 2125 2145 2146 2126; 2291 2126 2146 2147 2127;
    2292 2127 2147 2148 2128; 2293 2128 2148 2149 2129; 2294 2129 2149 2150 2130;
    2295 2130 2150 2151 2131; 2296 2131 2151 2152 2132; 2297 2132 2152 2153 2133;
    2300 2135 2155 2156 2136; 2301 2136 2156 2157 2137; 2302 2137 2157 2158 2138;
    2303 2138 2158 2159 2139; 2304 2139 2159 2160 2140; 2305 2140 2160 2161 2141;
    2306 2141 2161 2162 2142; 2307 2142 2162 2163 2143; 2308 2143 2163 2164 2144;
    2309 2144 2164 2165 2145; 2310 2145 2165 2166 2146; 2311 2146 2166 2167 2147;
    2312 2147 2167 2168 2148; 2313 2148 2168 2169 2149; 2314 2149 2169 2170 2150;
    2315 2150 2170 2171 2151; 2316 2151 2171 2172 2152; 2317 2152 2172 2173 2153;
    2320 2155 2175 2176 2156; 2321 2156 2176 2177 2157; 2322 2157 2177 2178 2158;
    2323 2158 2178 2179 2159; 2324 2159 2179 2180 2160; 2325 2160 2180 2181 2161;
    2326 2161 2181 2182 2162; 2327 2162 2182 2183 2163; 2328 2163 2183 2184 2164;
    2329 2164 2184 2185 2165; 2330 2165 2185 2186 2166; 2331 2166 2186 2187 2167;
    2332 2167 2187 2188 2168; 2333 2168 2188 2189 2169; 2334 2169 2189 2190 2170;
    2335 2170 2190 2191 2171; 2336 2171 2191 2192 2172; 2337 2172 2192 2193 2173;
    2340 2175 2195 2196 2176; 2341 2176 2196 2197 2177; 2342 2177 2197 2198 2178;
    2343 2178 2198 2199 2179; 2344 2179 2199 2200 2180; 2345 2180 2200 2201 2181;
    2346 2181 2201 2202 2182; 2347 2182 2202 2203 2183; 2348 2183 2203 2204 2184;
    2349 2184 2204 2205 2185; 2350 2185 2205 2206 2186; 2351 2186 2206 2207 2187;
    2352 2187 2207 2208 2188; 2353 2188 2208 2209 2189; 2354 2189 2209 2210 2190;
    2355 2190 2210 2211 2191; 2356 2191 2211 2212 2192; 2357 2192 2212 2213 2193;
    2360 2195 2215 2216 2196; 2361 2196 2216 2217 2197; 2362 2197 2217 2218 2198;
    2363 2198 2218 2219 2199; 2364 2199 2219 2220 2200; 2365 2200 2220 2221 2201;
    2366 2201 2221 2222 2202; 2367 2202 2222 2223 2203; 2368 2203 2223 2224 2204;
    2369 2204 2224 2225 2205; 2370 2205 2225 2226 2206; 2371 2206 2226 2227 2207;
    2372 2207 2227 2228 2208; 2373 2208 2228 2229 2209; 2374 2209 2229 2230 2210;
    2375 2210 2230 2231 2211; 2376 2211 2231 2232 2212; 2377 2212 2232 2233 2213;
    2380 2215 2235 2236 2216; 2381 2216 2236 2237 2217; 2382 2217 2237 2238 2218;
    2383 2218 2238 2239 2219; 2384 2219 2239 2240 2220; 2385 2220 2240 2241 2221;
    2386 2221 2241 2242 2222; 2387 2222 2242 2243 2223; 2388 2223 2243 2244 2224;
    2389 2224 2244 2245 2225; 2390 2225 2245 2246 2226; 2391 2226 2246 2247 2227;
    2392 2227 2247 2248 2228; 2393 2228 2248 2249 2229; 2394 2229 2249 2250 2230;
    2395 2230 2250 2251 2231; 2396 2231 2251 2252 2232; 2397 2232 2252 2253 2233;
    2400 2235 2255 2256 2236; 2401 2236 2256 2257 2237; 2402 2237 2257 2258 2238;
    2403 2238 2258 2259 2239; 2404 2239 2259 2260 2240; 2405 2240 2260 2261 2241;
    2406 2241 2261 2262 2242; 2407 2242 2262 2263 2243; 2408 2243 2263 2264 2244;
    2409 2244 2264 2265 2245; 2410 2245 2265 2266 2246; 2411 2246 2266 2267 2247;
    2412 2247 2267 2268 2248; 2413 2248 2268 2269 2249; 2414 2249 2269 2270 2250;
    2415 2250 2270 2271 2251; 2416 2251 2271 2272 2252; 2417 2252 2272 2273 2253;
    2420 2255 2275 2276 2256; 2421 2256 2276 2277 2257; 2422 2257 2277 2278 2258;
    2423 2258 2278 2279 2259; 2424 2259 2279 2280 2260; 2425 2260 2280 2281 2261;
    2426 2261 2281 2282 2262; 2427 2262 2282 2283 2263; 2428 2263 2283 2284 2264;
    2429 2264 2284 2285 2265; 2430 2265 2285 2286 2266; 2431 2266 2286 2287 2267;
    2432 2267 2287 2288 2268; 2433 2268 2288 2289 2269; 2434 2269 2289 2290 2270;
    2435 2270 2290 2291 2271; 2436 2271 2291 2292 2272; 2437 2272 2292 2293 2273;
    2440 2275 2295 2296 2276; 2441 2276 2296 2297 2277; 2442 2277 2297 2298 2278;
    2443 2278 2298 2299 2279; 2444 2279 2299 2300 2280; 2445 2280 2300 2301 2281;
    2446 2281 2301 2302 2282; 2447 2282 2302 2303 2283; 2448 2283 2303 2304 2284;
    2449 2284 2304 2305 2285; 2450 2285 2305 2306 2286; 2451 2286 2306 2307 2287;
    2452 2287 2307 2308 2288; 2453 2288 2308 2309 2289; 2454 2289 2309 2310 2290;
    2455 2290 2310 2311 2291; 2456 2291 2311 2312 2292; 2457 2292 2312 2313 2293;
    2460 2295 2315 2316 2296; 2461 2296 2316 2317 2297; 2462 2297 2317 2318 2298;
    2463 2298 2318 2319 2299; 2464 2299 2319 2320 2300; 2465 2300 2320 2321 2301;
    2466 2301 2321 2322 2302; 2467 2302 2322 2323 2303; 2468 2303 2323 2324 2304;
    2469 2304 2324 2325 2305; 2470 2305 2325 2326 2306; 2471 2306 2326 2327 2307;
    2472 2307 2327 2328 2308; 2473 2308 2328 2329 2309; 2474 2309 2329 2330 2310;
    2475 2310 2330 2331 2311; 2476 2311 2331 2332 2312; 2477 2312 2332 2333 2313;
    2480 2315 2335 2336 2316; 2481 2316 2336 2337 2317; 2482 2317 2337 2338 2318;
    2483 2318 2338 2339 2319; 2484 2319 2339 2340 2320; 2485 2320 2340 2341 2321;
    2486 2321 2341 2342 2322; 2487 2322 2342 2343 2323; 2488 2323 2343 2344 2324;
    2489 2324 2344 2345 2325; 2490 2325 2345 2346 2326; 2491 2326 2346 2347 2327;
    2492 2327 2347 2348 2328; 2493 2328 2348 2349 2329; 2494 2329 2349 2350 2330;
    2495 2330 2350 2351 2331; 2496 2331 2351 2352 2332; 2497 2332 2352 2353 2333;
    2500 2335 2355 2356 2336; 2501 2336 2356 2357 2337; 2502 2337 2357 2358 2338;
    2503 2338 2358 2359 2339; 2504 2339 2359 2360 2340; 2505 2340 2360 2361 2341;
    2506 2341 2361 2362 2342; 2507 2342 2362 2363 2343; 2508 2343 2363 2364 2344;
    2509 2344 2364 2365 2345; 2510 2345 2365 2366 2346; 2511 2346 2366 2367 2347;
    2512 2347 2367 2368 2348; 2513 2348 2368 2369 2349; 2514 2349 2369 2370 2350;
    2515 2350 2370 2371 2351; 2516 2351 2371 2372 2352; 2517 2352 2372 2373 2353;
    2520 2355 2375 2376 2356; 2521 2356 2376 2377 2357; 2522 2357 2377 2378 2358;
    2523 2358 2378 2379 2359; 2524 2359 2379 2380 2360; 2525 2360 2380 2381 2361;
    2526 2361 2381 2382 2362; 2527 2362 2382 2383 2363; 2528 2363 2383 2384 2364;
    2529 2364 2384 2385 2365; 2530 2365 2385 2386 2366; 2531 2366 2386 2387 2367;
    2532 2367 2387 2388 2368; 2533 2368 2388 2389 2369; 2534 2369 2389 2390 2370;
    2535 2370 2390 2391 2371; 2536 2371 2391 2392 2372; 2537 2372 2392 2393 2373;
    2540 2375 2395 2396 2376; 2541 2376 2396 2397 2377; 2542 2377 2397 2398 2378;
    2543 2378 2398 2399 2379; 2544 2379 2399 2400 2380; 2545 2380 2400 2401 2381;
    2546 2381 2401 2402 2382; 2547 2382 2402 2403 2383; 2548 2383 2403 2404 2384;
    2549 2384 2404 2405 2385; 2550 2385 2405 2406 2386; 2551 2386 2406 2407 2387;
    2552 2387 2407 2408 2388; 2553 2388 2408 2409 2389; 2554 2389 2409 2410 2390;
    2555 2390 2410 2411 2391; 2556 2391 2411 2412 2392; 2557 2392 2412 2413 2393;
    2560 2395 2415 2416 2396; 2561 2396 2416 2417 2397; 2562 2397 2417 2418 2398;
    2563 2398 2418 2419 2399; 2564 2399 2419 2420 2400; 2565 2400 2420 2421 2401;
    2566 2401 2421 2422 2402; 2567 2402 2422 2423 2403; 2568 2403 2423 2424 2404;
    2569 2404 2424 2425 2405; 2570 2405 2425 2426 2406; 2571 2406 2426 2427 2407;
    2572 2407 2427 2428 2408; 2573 2408 2428 2429 2409; 2574 2409 2429 2430 2410;
    2575 2410 2430 2431 2411; 2576 2411 2431 2432 2412; 2577 2412 2432 2433 2413;
    2580 2415 2435 2436 2416; 2581 2416 2436 2437 2417; 2582 2417 2437 2438 2418;
    2583 2418 2438 2439 2419; 2584 2419 2439 2440 2420; 2585 2420 2440 2441 2421;
    2586 2421 2441 2442 2422; 2587 2422 2442 2443 2423; 2588 2423 2443 2444 2424;
    2589 2424 2444 2445 2425; 2590 2425 2445 2446 2426; 2591 2426 2446 2447 2427;
    2592 2427 2447 2448 2428; 2593 2428 2448 2449 2429; 2594 2429 2449 2450 2430;
    2595 2430 2450 2451 2431; 2596 2431 2451 2452 2432; 2597 2432 2452 2453 2433;
    2600 2435 2455 2456 2436; 2601 2436 2456 2457 2437; 2602 2437 2457 2458 2438;
    2603 2438 2458 2459 2439; 2604 2439 2459 2460 2440; 2605 2440 2460 2461 2441;
    2606 2441 2461 2462 2442; 2607 2442 2462 2463 2443; 2608 2443 2463 2464 2444;
    2609 2444 2464 2465 2445; 2610 2445 2465 2466 2446; 2611 2446 2466 2467 2447;
    2612 2447 2467 2468 2448; 2613 2448 2468 2469 2449; 2614 2449 2469 2470 2450;
    2615 2450 2470 2471 2451; 2616 2451 2471 2472 2452; 2617 2452 2472 2473 2453;
    2620 2455 2475 2476 2456; 2621 2456 2476 2477 2457; 2622 2457 2477 2478 2458;
    2623 2458 2478 2479 2459; 2624 2459 2479 2480 2460; 2625 2460 2480 2481 2461;
    2626 2461 2481 2482 2462; 2627 2462 2482 2483 2463; 2628 2463 2483 2484 2464;
    2629 2464 2484 2485 2465; 2630 2465 2485 2486 2466; 2631 2466 2486 2487 2467;
    2632 2467 2487 2488 2468; 2633 2468 2488 2489 2469; 2634 2469 2489 2490 2470;
    2635 2470 2490 2491 2471; 2636 2471 2491 2492 2472; 2637 2472 2492 2493 2473;
    2640 2475 2495 2496 2476; 2641 2476 2496 2497 2477; 2642 2477 2497 2498 2478;
    2643 2478 2498 2499 2479; 2644 2479 2499 2500 2480; 2645 2480 2500 2501 2481;
    2646 2481 2501 2502 2482; 2647 2482 2502 2503 2483; 2648 2483 2503 2504 2484;
    2649 2484 2504 2505 2485; 2650 2485 2505 2506 2486; 2651 2486 2506 2507 2487;
    2652 2487 2507 2508 2488; 2653 2488 2508 2509 2489; 2654 2489 2509 2510 2490;
    2655 2490 2510 2511 2491; 2656 2491 2511 2512 2492; 2657 2492 2512 2513 2493;
    2660 2495 2515 2516 2496; 2661 2496 2516 2517 2497; 2662 2497 2517 2518 2498;
    2663 2498 2518 2519 2499; 2664 2499 2519 2520 2500; 2665 2500 2520 2521 2501;
    2666 2501 2521 2522 2502; 2667 2502 2522 2523 2503; 2668 2503 2523 2524 2504;
    2669 2504 2524 2525 2505; 2670 2505 2525 2526 2506; 2671 2506 2526 2527 2507;
    2672 2507 2527 2528 2508; 2673 2508 2528 2529 2509; 2674 2509 2529 2530 2510;
    2675 2510 2530 2531 2511; 2676 2511 2531 2532 2512; 2677 2512 2532 2533 2513;
    2680 2515 2535 2536 2516; 2681 2516 2536 2537 2517; 2682 2517 2537 2538 2518;
    2683 2518 2538 2539 2519; 2684 2519 2539 2540 2520; 2685 2520 2540 2541 2521;
    2686 2521 2541 2542 2522; 2687 2522 2542 2543 2523; 2688 2523 2543 2544 2524;
    2689 2524 2544 2545 2525; 2690 2525 2545 2546 2526; 2691 2526 2546 2547 2527;
    2692 2527 2547 2548 2528; 2693 2528 2548 2549 2529; 2694 2529 2549 2550 2530;
    2695 2530 2550 2551 2531; 2696 2531 2551 2552 2532; 2697 2532 2552 2553 2533;
    2700 2535 2555 2556 2536; 2701 2536 2556 2557 2537; 2702 2537 2557 2558 2538;
    2703 2538 2558 2559 2539; 2704 2539 2559 2560 2540; 2705 2540 2560 2561 2541;
    2706 2541 2561 2562 2542; 2707 2542 2562 2563 2543; 2708 2543 2563 2564 2544;
    2709 2544 2564 2565 2545; 2710 2545 2565 2566 2546; 2711 2546 2566 2567 2547;
    2712 2547 2567 2568 2548; 2713 2548 2568 2569 2549; 2714 2549 2569 2570 2550;
    2715 2550 2570 2571 2551; 2716 2551 2571 2572 2552; 2717 2552 2572 2573 2553;
    2720 2555 2575 2576 2556; 2721 2556 2576 2577 2557; 2722 2557 2577 2578 2558;
    2723 2558 2578 2579 2559; 2724 2559 2579 2580 2560; 2725 2560 2580 2581 2561;
    2726 2561 2581 2582 2562; 2727 2562 2582 2583 2563; 2728 2563 2583 2584 2564;
    2729 2564 2584 2585 2565; 2730 2565 2585 2586 2566; 2731 2566 2586 2587 2567;
    2732 2567 2587 2588 2568; 2733 2568 2588 2589 2569; 2734 2569 2589 2590 2570;
    2735 2570 2590 2591 2571; 2736 2571 2591 2592 2572; 2737 2572 2592 2593 2573;
    2740 2575 2595 2596 2576; 2741 2576 2596 2597 2577; 2742 2577 2597 2598 2578;
    2743 2578 2598 2599 2579; 2744 2579 2599 2600 2580; 2745 2580 2600 2601 2581;
    2746 2581 2601 2602 2582; 2747 2582 2602 2603 2583; 2748 2583 2603 2604 2584;
    2749 2584 2604 2605 2585; 2750 2585 2605 2606 2586; 2751 2586 2606 2607 2587;
    2752 2587 2607 2608 2588; 2753 2588 2608 2609 2589; 2754 2589 2609 2610 2590;
    2755 2590 2610 2611 2591; 2756 2591 2611 2612 2592; 2757 2592 2612 2613 2593;
    2760 2595 2615 2616 2596; 2761 2596 2616 2617 2597; 2762 2597 2617 2618 2598;
    2763 2598 2618 2619 2599; 2764 2599 2619 2620 2600; 2765 2600 2620 2621 2601;
    2766 2601 2621 2622 2602; 2767 2602 2622 2623 2603; 2768 2603 2623 2624 2604;
    2769 2604 2624 2625 2605; 2770 2605 2625 2626 2606; 2771 2606 2626 2627 2607;
    2772 2607 2627 2628 2608; 2773 2608 2628 2629 2609; 2774 2609 2629 2630 2610;
    2775 2610 2630 2631 2611; 2776 2611 2631 2632 2612; 2777 2612 2632 2633 2613;
    2780 2615 2635 2636 2616; 2781 2616 2636 2637 2617; 2782 2617 2637 2638 2618;
    2783 2618 2638 2639 2619; 2784 2619 2639 2640 2620; 2785 2620 2640 2641 2621;
    2786 2621 2641 2642 2622; 2787 2622 2642 2643 2623; 2788 2623 2643 2644 2624;
    2789 2624 2644 2645 2625; 2790 2625 2645 2646 2626; 2791 2626 2646 2647 2627;
    2792 2627 2647 2648 2628; 2793 2628 2648 2649 2629; 2794 2629 2649 2650 2630;
    2795 2630 2650 2651 2631; 2796 2631 2651 2652 2632; 2797 2632 2652 2653 2633;
    2800 2635 2655 2656 2636; 2801 2636 2656 2657 2637; 2802 2637 2657 2658 2638;
    2803 2638 2658 2659 2639; 2804 2639 2659 2660 2640; 2805 2640 2660 2661 2641;
    2806 2641 2661 2662 2642; 2807 2642 2662 2663 2643; 2808 2643 2663 2664 2644;
    2809 2644 2664 2665 2645; 2810 2645 2665 2666 2646; 2811 2646 2666 2667 2647;
    2812 2647 2667 2668 2648; 2813 2648 2668 2669 2649; 2814 2649 2669 2670 2650;
    2815 2650 2670 2671 2651; 2816 2651 2671 2672 2652; 2817 2652 2672 2673 2653;
    2820 2655 2675 2676 2656; 2821 2656 2676 2677 2657; 2822 2657 2677 2678 2658;
    2823 2658 2678 2679 2659; 2824 2659 2679 2680 2660; 2825 2660 2680 2681 2661;
    2826 2661 2681 2682 2662; 2827 2662 2682 2683 2663; 2828 2663 2683 2684 2664;
    2829 2664 2684 2685 2665; 2830 2665 2685 2686 2666; 2831 2666 2686 2687 2667;
    2832 2667 2687 2688 2668; 2833 2668 2688 2689 2669; 2834 2669 2689 2690 2670;
    2835 2670 2690 2691 2671; 2836 2671 2691 2692 2672; 2837 2672 2692 2693 2673;
    2840 2675 2695 2696 2676; 2841 2676 2696 2697 2677; 2842 2677 2697 2698 2678;
    2843 2678 2698 2699 2679; 2844 2679 2699 2700 2680; 2845 2680 2700 2701 2681;
    2846 2681 2701 2702 2682; 2847 2682 2702 2703 2683; 2848 2683 2703 2704 2684;
    2849 2684 2704 2705 2685; 2850 2685 2705 2706 2686; 2851 2686 2706 2707 2687;
    2852 2687 2707 2708 2688; 2853 2688 2708 2709 2689; 2854 2689 2709 2710 2690;
    2855 2690 2710 2711 2691; 2856 2691 2711 2712 2692; 2857 2692 2712 2713 2693;
    2860 2695 2715 2716 2696; 2861 2696 2716 2717 2697; 2862 2697 2717 2718 2698;
    2863 2698 2718 2719 2699; 2864 2699 2719 2720 2700; 2865 2700 2720 2721 2701;
    2866 2701 2721 2722 2702; 2867 2702 2722 2723 2703; 2868 2703 2723 2724 2704;
    2869 2704 2724 2725 2705; 2870 2705 2725 2726 2706; 2871 2706 2726 2727 2707;
    2872 2707 2727 2728 2708; 2873 2708 2728 2729 2709; 2874 2709 2729 2730 2710;
    2875 2710 2730 2731 2711; 2876 2711 2731 2732 2712; 2877 2712 2732 2733 2713;
    2880 2715 2735 2736 2716; 2881 2716 2736 2737 2717; 2882 2717 2737 2738 2718;
    2883 2718 2738 2739 2719; 2884 2719 2739 2740 2720; 2885 2720 2740 2741 2721;
    2886 2721 2741 2742 2722; 2887 2722 2742 2743 2723; 2888 2723 2743 2744 2724;
    2889 2724 2744 2745 2725; 2890 2725 2745 2746 2726; 2891 2726 2746 2747 2727;
    2892 2727 2747 2748 2728; 2893 2728 2748 2749 2729; 2894 2729 2749 2750 2730;
    2895 2730 2750 2751 2731; 2896 2731 2751 2752 2732; 2897 2732 2752 2753 2733;
    2900 2735 2755 2756 2736; 2901 2736 2756 2757 2737; 2902 2737 2757 2758 2738;
    2903 2738 2758 2759 2739; 2904 2739 2759 2760 2740; 2905 2740 2760 2761 2741;
    2906 2741 2761 2762 2742; 2907 2742 2762 2763 2743; 2908 2743 2763 2764 2744;
    2909 2744 2764 2765 2745; 2910 2745 2765 2766 2746; 2911 2746 2766 2767 2747;
    2912 2747 2767 2768 2748; 2913 2748 2768 2769 2749; 2914 2749 2769 2770 2750;
    2915 2750 2770 2771 2751; 2916 2751 2771 2772 2752; 2917 2752 2772 2773 2753;
    2920 2755 2775 2776 2756; 2921 2756 2776 2777 2757; 2922 2757 2777 2778 2758;
    2923 2758 2778 2779 2759; 2924 2759 2779 2780 2760; 2925 2760 2780 2781 2761;
    2926 2761 2781 2782 2762; 2927 2762 2782 2783 2763; 2928 2763 2783 2784 2764;
    2929 2764 2784 2785 2765; 2930 2765 2785 2786 2766; 2931 2766 2786 2787 2767;
    2932 2767 2787 2788 2768; 2933 2768 2788 2789 2769; 2934 2769 2789 2790 2770;
    2935 2770 2790 2791 2771; 2936 2771 2791 2792 2772; 2937 2772 2792 2793 2773;
    2940 2775 2795 2796 2776; 2941 2776 2796 2797 2777; 2942 2777 2797 2798 2778;
    2943 2778 2798 2799 2779; 2944 2779 2799 2800 2780; 2945 2780 2800 2801 2781;
    2946 2781 2801 2802 2782; 2947 2782 2802 2803 2783; 2948 2783 2803 2804 2784;
    2949 2784 2804 2805 2785; 2950 2785 2805 2806 2786; 2951 2786 2806 2807 2787;
    2952 2787 2807 2808 2788; 2953 2788 2808 2809 2789; 2954 2789 2809 2810 2790;
    2955 2790 2810 2811 2791; 2956 2791 2811 2812 2792; 2957 2792 2812 2813 2793;
    2960 2795 2815 2816 2796; 2961 2796 2816 2817 2797; 2962 2797 2817 2818 2798;
    2963 2798 2818 2819 2799; 2964 2799 2819 2820 2800; 2965 2800 2820 2821 2801;
    2966 2801 2821 2822 2802; 2967 2802 2822 2823 2803; 2968 2803 2823 2824 2804;
    2969 2804 2824 2825 2805; 2970 2805 2825 2826 2806; 2971 2806 2826 2827 2807;
    2972 2807 2827 2828 2808; 2973 2808 2828 2829 2809; 2974 2809 2829 2830 2810;
    2975 2810 2830 2831 2811; 2976 2811 2831 2832 2812; 2977 2812 2832 2833 2813;
    2980 2815 2835 2836 2816; 2981 2816 2836 2837 2817; 2982 2817 2837 2838 2818;
    2983 2818 2838 2839 2819; 2984 2819 2839 2840 2820; 2985 2820 2840 2841 2821;
    2986 2821 2841 2842 2822; 2987 2822 2842 2843 2823; 2988 2823 2843 2844 2824;
    2989 2824 2844 2845 2825; 2990 2825 2845 2846 2826; 2991 2826 2846 2847 2827;
    2992 2827 2847 2848 2828; 2993 2828 2848 2849 2829; 2994 2829 2849 2850 2830;
    2995 2830 2850 2851 2831; 2996 2831 2851 2852 2832; 2997 2832 2852 2853 2833;
    3000 2835 2855 2856 2836; 3001 2836 2856 2857 2837; 3002 2837 2857 2858 2838;
    3006 2841 2861 2862 2842; 3007 2842 2862 2863 2843; 3008 2843 2863 2864 2844;
    3009 2844 2864 2865 2845; 3010 2845 2865 2866 2846; 3011 2846 2866 2867 2847;
    3012 2847 2867 2868 2848; 3013 2848 2868 2869 2849; 3014 2849 2869 2870 2850;
    3015 2850 2870 2871 2851; 3016 2851 2871 2872 2852; 3017 2852 2872 2873 2853;
    3020 2855 2875 2876 2856; 3021 2856 2876 2877 2857; 3022 2857 2877 2878 2858;
    3026 2861 2881 2882 2862; 3027 2862 2882 2883 2863; 3028 2863 2883 2884 2864;
    3029 2864 2884 2885 2865; 3030 2865 2885 2886 2866; 3031 2866 2886 2887 2867;
    3032 2867 2887 2888 2868; 3033 2868 2888 2889 2869; 3034 2869 2889 2890 2870;
    3035 2870 2890 2891 2871; 3036 2871 2891 2892 2872; 3037 2872 2892 2893 2873;
    3040 2875 2895 2896 2876; 3041 2876 2896 2897 2877; 3042 2877 2897 2898 2878;
    3043 2878 2898 2899 2879; 3044 2879 2899 2900 2880; 3045 2880 2900 2901 2881;
    3046 2881 2901 2902 2882; 3047 2882 2902 2903 2883; 3048 2883 2903 2904 2884;
    3049 2884 2904 2905 2885; 3050 2885 2905 2906 2886; 3051 2886 2906 2907 2887;
    3052 2887 2907 2908 2888; 3053 2888 2908 2909 2889; 3054 2889 2909 2910 2890;
    3055 2890 2910 2911 2891; 3056 2891 2911 2912 2892; 3057 2892 2912 2913 2893;
    3060 2895 2915 2916 2896; 3061 2896 2916 2917 2897; 3062 2897 2917 2918 2898;
    3063 2898 2918 2919 2899; 3064 2899 2919 2920 2900; 3065 2900 2920 2921 2901;
    3066 2901 2921 2922 2902; 3067 2902 2922 2923 2903; 3068 2903 2923 2924 2904;
    3069 2904 2924 2925 2905; 3070 2905 2925 2926 2906; 3071 2906 2926 2927 2907;
    3072 2907 2927 2928 2908; 3073 2908 2928 2929 2909; 3074 2909 2929 2930 2910;
    3075 2910 2930 2931 2911; 3076 2911 2931 2932 2912; 3077 2912 2932 2933 2913;
    3080 2915 2935 2936 2916; 3081 2916 2936 2937 2917; 3082 2917 2937 2938 2918;
    3083 2918 2938 2939 2919; 3084 2919 2939 2940 2920; 3085 2920 2940 2941 2921;
    3086 2921 2941 2942 2922; 3087 2922 2942 2943 2923; 3088 2923 2943 2944 2924;
    3089 2924 2944 2945 2925; 3090 2925 2945 2946 2926; 3091 2926 2946 2947 2927;
    3092 2927 2947 2948 2928; 3093 2928 2948 2949 2929; 3094 2929 2949 2950 2930;
    3095 2930 2950 2951 2931; 3096 2931 2951 2952 2932; 3097 2932 2952 2953 2933;
    3100 2935 2955 2956 2936; 3101 2936 2956 2957 2937; 3102 2937 2957 2958 2938;
    3103 2938 2958 2959 2939; 3104 2939 2959 2960 2940; 3105 2940 2960 2961 2941;
    3106 2941 2961 2962 2942; 3107 2942 2962 2963 2943; 3108 2943 2963 2964 2944;
    3109 2944 2964 2965 2945; 3110 2945 2965 2966 2946; 3111 2946 2966 2967 2947;
    3112 2947 2967 2968 2948; 3113 2948 2968 2969 2949; 3114 2949 2969 2970 2950;
    3115 2950 2970 2971 2951; 3116 2951 2971 2972 2952; 3117 2952 2972 2973 2953;
    3120 2955 2975 2976 2956; 3121 2956 2976 2977 2957; 3122 2957 2977 2978 2958;
    3123 2958 2978 2979 2959; 3124 2959 2979 2980 2960; 3125 2960 2980 2981 2961;
    3126 2961 2981 2982 2962; 3127 2962 2982 2983 2963; 3128 2963 2983 2984 2964;
    3129 2964 2984 2985 2965; 3130 2965 2985 2986 2966; 3131 2966 2986 2987 2967;
    3132 2967 2987 2988 2968; 3133 2968 2988 2989 2969; 3134 2969 2989 2990 2970;
    3135 2970 2990 2991 2971; 3136 2971 2991 2992 2972; 3137 2972 2992 2993 2973;
    3140 2975 2995 2996 2976; 3141 2976 2996 2997 2977; 3142 2977 2997 2998 2978;
    3143 2978 2998 2999 2979; 3144 2979 2999 3000 2980; 3145 2980 3000 3001 2981;
    3146 2981 3001 3002 2982; 3147 2982 3002 3003 2983; 3148 2983 3003 3004 2984;
    3149 2984 3004 3005 2985; 3150 2985 3005 3006 2986; 3151 2986 3006 3007 2987;
    3152 2987 3007 3008 2988; 3153 2988 3008 3009 2989; 3154 2989 3009 3010 2990;
    3155 2990 3010 3011 2991; 3156 2991 3011 3012 2992; 3157 2992 3012 3013 2993;
    3160 2995 3015 3016 2996; 3161 2996 3016 3017 2997; 3162 2997 3017 3018 2998;
    3163 2998 3018 3019 2999; 3164 2999 3019 3020 3000; 3165 3000 3020 3021 3001;
    3166 3001 3021 3022 3002; 3167 3002 3022 3023 3003; 3168 3003 3023 3024 3004;
    3169 3004 3024 3025 3005; 3170 3005 3025 3026 3006; 3171 3006 3026 3027 3007;
    3172 3007 3027 3028 3008; 3173 3008 3028 3029 3009; 3174 3009 3029 3030 3010;
    3175 3010 3030 3031 3011; 3176 3011 3031 3032 3012; 3177 3012 3032 3033 3013;
    3180 3015 3035 3036 3016; 3181 3016 3036 3037 3017; 3182 3017 3037 3038 3018;
    3183 3018 3038 3039 3019; 3184 3019 3039 3040 3020; 3185 3020 3040 3041 3021;
    3186 3021 3041 3042 3022; 3187 3022 3042 3043 3023; 3188 3023 3043 3044 3024;
    3189 3024 3044 3045 3025; 3190 3025 3045 3046 3026; 3191 3026 3046 3047 3027;
    3192 3027 3047 3048 3028; 3193 3028 3048 3049 3029; 3194 3029 3049 3050 3030;
    3195 3030 3050 3051 3031; 3196 3031 3051 3052 3032; 3197 3032 3052 3053 3033;
    3200 3035 3055 3056 3036; 3201 3036 3056 3057 3037; 3202 3037 3057 3058 3038;
    3203 3038 3058 3059 3039; 3204 3039 3059 3060 3040; 3205 3040 3060 3061 3041;
    3206 3041 3061 3062 3042; 3207 3042 3062 3063 3043; 3208 3043 3063 3064 3044;
    3209 3044 3064 3065 3045; 3210 3045 3065 3066 3046; 3211 3046 3066 3067 3047;
    3212 3047 3067 3068 3048; 3213 3048 3068 3069 3049; 3214 3049 3069 3070 3050;
    3215 3050 3070 3071 3051; 3216 3051 3071 3072 3052; 3217 3052 3072 3073 3053;
    3220 3055 3075 3076 3056; 3221 3056 3076 3077 3057; 3222 3057 3077 3078 3058;
    3223 3058 3078 3079 3059; 3224 3059 3079 3080 3060; 3225 3060 3080 3081 3061;
    3226 3061 3081 3082 3062; 3227 3062 3082 3083 3063; 3228 3063 3083 3084 3064;
    3229 3064 3084 3085 3065; 3230 3065 3085 3086 3066; 3231 3066 3086 3087 3067;
    3232 3067 3087 3088 3068; 3233 3068 3088 3089 3069; 3234 3069 3089 3090 3070;
    3235 3070 3090 3091 3071; 3236 3071 3091 3092 3072; 3237 3072 3092 3093 3073;
    3240 3075 3095 3096 3076; 3241 3076 3096 3097 3077; 3242 3077 3097 3098 3078;
    3243 3078 3098 3099 3079; 3244 3079 3099 3100 3080; 3245 3080 3100 3101 3081;
    3246 3081 3101 3102 3082; 3247 3082 3102 3103 3083; 3248 3083 3103 3104 3084;
    3249 3084 3104 3105 3085; 3250 3085 3105 3106 3086; 3251 3086 3106 3107 3087;
    3252 3087 3107 3108 3088; 3253 3088 3108 3109 3089; 3254 3089 3109 3110 3090;
    3255 3090 3110 3111 3091; 3256 3091 3111 3112 3092; 3257 3092 3112 3113 3093;
    3260 3095 3115 3116 3096; 3261 3096 3116 3117 3097; 3262 3097 3117 3118 3098;
    3263 3098 3118 3119 3099; 3264 3099 3119 3120 3100; 3265 3100 3120 3121 3101;
    3266 3101 3121 3122 3102; 3267 3102 3122 3123 3103; 3268 3103 3123 3124 3104;
    3269 3104 3124 3125 3105; 3270 3105 3125 3126 3106; 3271 3106 3126 3127 3107;
    3272 3107 3127 3128 3108; 3273 3108 3128 3129 3109; 3274 3109 3129 3130 3110;
    3275 3110 3130 3131 3111; 3276 3111 3131 3132 3112; 3277 3112 3132 3133 3113;
    3280 3115 3135 3136 3116; 3281 3116 3136 3137 3117; 3282 3117 3137 3138 3118;
    3283 3118 3138 3139 3119; 3284 3119 3139 3140 3120; 3285 3120 3140 3141 3121;
    3286 3121 3141 3142 3122; 3287 3122 3142 3143 3123; 3288 3123 3143 3144 3124;
    3289 3124 3144 3145 3125; 3290 3125 3145 3146 3126; 3291 3126 3146 3147 3127;
    3292 3127 3147 3148 3128; 3293 3128 3148 3149 3129; 3294 3129 3149 3150 3130;
    3295 3130 3150 3151 3131; 3296 3131 3151 3152 3132; 3297 3132 3152 3153 3133;
    3300 3135 3155 3156 3136; 3301 3136 3156 3157 3137; 3302 3137 3157 3158 3138;
    3303 3138 3158 3159 3139; 3304 3139 3159 3160 3140; 3305 3140 3160 3161 3141;
    3306 3141 3161 3162 3142; 3307 3142 3162 3163 3143; 3308 3143 3163 3164 3144;
    3309 3144 3164 3165 3145; 3310 3145 3165 3166 3146; 3311 3146 3166 3167 3147;
    3312 3147 3167 3168 3148; 3313 3148 3168 3169 3149; 3314 3149 3169 3170 3150;
    3315 3150 3170 3171 3151; 3316 3151 3171 3172 3152; 3317 3152 3172 3173 3153;
    3320 3155 3175 3176 3156; 3321 3156 3176 3177 3157; 3322 3157 3177 3178 3158;
    3323 3158 3178 3179 3159; 3324 3159 3179 3180 3160; 3325 3160 3180 3181 3161;
    3326 3161 3181 3182 3162; 3327 3162 3182 3183 3163; 3328 3163 3183 3184 3164;
    3329 3164 3184 3185 3165; 3330 3165 3185 3186 3166; 3331 3166 3186 3187 3167;
    3332 3167 3187 3188 3168; 3333 3168 3188 3189 3169; 3334 3169 3189 3190 3170;
    3335 3170 3190 3191 3171; 3336 3171 3191 3192 3172; 3337 3172 3192 3193 3173;
    3340 3175 1775 3195 3176; 3341 3176 3195 3196 3177; 3342 3177 3196 3197 3178;
    3343 3178 3197 3198 3179; 3344 3179 3198 3199 3180; 3345 3180 3199 3200 3181;
    3346 3181 3200 3201 3182; 3347 3182 3201 3202 3183; 3348 3183 3202 3203 3184;
    3349 3184 3203 3204 3185; 3350 3185 3204 3205 3186; 3351 3186 3205 3206 3187;
    3352 3187 3206 3207 3188; 3353 3188 3207 3208 3189; 3354 3189 3208 3209 3190;
    3355 3190 3209 3210 3191; 3356 3191 3210 3211 3192; 3357 3192 3211 3212 3193;
    3360 1775 1774 1777 3195; 3361 3195 1777 1779 3196; 3362 3196 1779 1781 3197;
    3363 3197 1781 1783 3198; 3364 3198 1783 1785 3199; 3365 3199 1785 1787 3200;
    3366 3200 1787 1789 3201; 3367 3201 1789 1791 3202; 3368 3202 1791 1793 3203;
    3369 3203 1793 1795 3204; 3370 3204 1795 1797 3205; 3371 3205 1797 1799 3206;
    3372 3206 1799 1801 3207; 3373 3207 1801 1803 3208; 3374 3208 1803 1805 3209;
    3375 3209 1805 1807 3210; 3376 3210 1807 1809 3211; 3377 3211 1809 1811 3212;
    5087 3281 1813 1814 3302; 5088 3282 3281 3302 3303; 5089 3283 3282 3303 3304;
    5090 3284 3283 3304 3305; 5091 3285 3284 3305 3306; 5092 3286 3285 3306 3307;
    5093 3287 3286 3307 3308; 5094 3288 3287 3308 3309; 5095 3289 3288 3309 3310;
    5096 3290 3289 3310 3311; 5097 3291 3290 3311 3312; 5098 3292 3291 3312 3313;
    5099 3293 3292 3313 3314; 5100 3294 3293 3314 3315; 5101 3295 3294 3315 3316;
    5102 3296 3295 3316 3317; 5103 3297 3296 3317 3318; 5104 3298 3297 3318 3319;
    5105 3299 3298 3319 3320; 5106 3300 3299 3320 3321; 5107 3222 3300 3321 3301;
    5108 3302 1814 1834 3323; 5109 3303 3302 3323 3324; 5110 3304 3303 3324 3325;
    5111 3305 3304 3325 3326; 5112 3306 3305 3326 3327; 5113 3307 3306 3327 3328;
    5114 3308 3307 3328 3329; 5115 3309 3308 3329 3330; 5116 3310 3309 3330 3331;
    5117 3311 3310 3331 3332; 5118 3312 3311 3332 3333; 5119 3313 3312 3333 3334;
    5120 3314 3313 3334 3335; 5121 3315 3314 3335 3336; 5122 3316 3315 3336 3337;
    5123 3317 3316 3337 3338; 5124 3318 3317 3338 3339; 5125 3319 3318 3339 3340;
    5126 3320 3319 3340 3341; 5127 3321 3320 3341 3342; 5128 3301 3321 3342 3322;
    5129 3323 1834 1854 3344; 5130 3324 3323 3344 3345; 5131 3325 3324 3345 3346;
    5132 3326 3325 3346 3347; 5133 3327 3326 3347 3348; 5134 3328 3327 3348 3349;
    5135 3329 3328 3349 3350; 5136 3330 3329 3350 3351; 5137 3331 3330 3351 3352;
    5138 3332 3331 3352 3353; 5139 3333 3332 3353 3354; 5140 3334 3333 3354 3355;
    5141 3335 3334 3355 3356; 5142 3336 3335 3356 3357; 5143 3337 3336 3357 3358;
    5144 3338 3337 3358 3359; 5145 3339 3338 3359 3360; 5146 3340 3339 3360 3361;
    5147 3341 3340 3361 3362; 5148 3342 3341 3362 3363; 5149 3322 3342 3363 3343;
    5150 3344 1854 1874 3365; 5151 3345 3344 3365 3366; 5152 3346 3345 3366 3367;
    5153 3347 3346 3367 3368; 5154 3348 3347 3368 3369; 5155 3349 3348 3369 3370;
    5156 3350 3349 3370 3371; 5157 3351 3350 3371 3372; 5158 3352 3351 3372 3373;
    5159 3353 3352 3373 3374; 5160 3354 3353 3374 3375; 5161 3355 3354 3375 3376;
    5162 3356 3355 3376 3377; 5163 3357 3356 3377 3378; 5164 3358 3357 3378 3379;
    5165 3359 3358 3379 3380; 5166 3360 3359 3380 3381; 5167 3361 3360 3381 3382;
    5168 3362 3361 3382 3383; 5169 3363 3362 3383 3384; 5170 3343 3363 3384 3364;
    5171 3365 1874 1894 3386; 5172 3366 3365 3386 3387; 5173 3367 3366 3387 3388;
    5174 3368 3367 3388 3389; 5175 3369 3368 3389 3390; 5176 3370 3369 3390 3391;
    5177 3371 3370 3391 3392; 5178 3372 3371 3392 3393; 5179 3373 3372 3393 3394;
    5180 3374 3373 3394 3395; 5181 3375 3374 3395 3396; 5182 3376 3375 3396 3397;
    5183 3377 3376 3397 3398; 5184 3378 3377 3398 3399; 5185 3379 3378 3399 3400;
    5186 3380 3379 3400 3401; 5187 3381 3380 3401 3402; 5188 3382 3381 3402 3403;
    5189 3383 3382 3403 3404; 5190 3384 3383 3404 3405; 5191 3364 3384 3405 3385;
    5192 3386 1894 1914 3407; 5193 3387 3386 3407 3408; 5194 3388 3387 3408 3409;
    5195 3389 3388 3409 3410; 5196 3390 3389 3410 3411; 5197 3391 3390 3411 3412;
    5198 3392 3391 3412 3413; 5199 3393 3392 3413 3414; 5200 3394 3393 3414 3415;
    5201 3395 3394 3415 3416; 5202 3396 3395 3416 3417; 5203 3397 3396 3417 3418;
    5204 3398 3397 3418 3419; 5205 3399 3398 3419 3420; 5206 3400 3399 3420 3421;
    5207 3401 3400 3421 3422; 5208 3402 3401 3422 3423; 5209 3403 3402 3423 3424;
    5210 3404 3403 3424 3425; 5211 3405 3404 3425 3426; 5212 3385 3405 3426 3406;
    5213 3407 1914 1934 3428; 5214 3408 3407 3428 3429; 5215 3409 3408 3429 3430;
    5216 3410 3409 3430 3431; 5217 3411 3410 3431 3432; 5218 3412 3411 3432 3433;
    5219 3413 3412 3433 3434; 5220 3414 3413 3434 3435; 5221 3415 3414 3435 3436;
    5222 3416 3415 3436 3437; 5223 3417 3416 3437 3438; 5224 3418 3417 3438 3439;
    5225 3419 3418 3439 3440; 5226 3420 3419 3440 3441; 5227 3421 3420 3441 3442;
    5228 3422 3421 3442 3443; 5229 3423 3422 3443 3444; 5230 3424 3423 3444 3445;
    5231 3425 3424 3445 3446; 5232 3426 3425 3446 3447; 5233 3406 3426 3447 3427;
    5234 3428 1934 1954 3449; 5235 3429 3428 3449 3450; 5236 3430 3429 3450 3451;
    5237 3431 3430 3451 3452; 5238 3432 3431 3452 3453; 5239 3433 3432 3453 3454;
    5240 3434 3433 3454 3455; 5241 3435 3434 3455 3456; 5242 3436 3435 3456 3457;
    5243 3437 3436 3457 3458; 5244 3438 3437 3458 3459; 5245 3439 3438 3459 3460;
    5246 3440 3439 3460 3461; 5247 3441 3440 3461 3462; 5248 3442 3441 3462 3463;
    5249 3443 3442 3463 3464; 5250 3444 3443 3464 3465; 5251 3445 3444 3465 3466;
    5252 3446 3445 3466 3467; 5253 3447 3446 3467 3468; 5254 3427 3447 3468 3448;
    5255 3449 1954 1974 3470; 5256 3450 3449 3470 3471; 5257 3451 3450 3471 3472;
    5258 3452 3451 3472 3473; 5259 3453 3452 3473 3474; 5260 3454 3453 3474 3475;
    5261 3455 3454 3475 3476; 5262 3456 3455 3476 3477; 5263 3457 3456 3477 3478;
    5264 3458 3457 3478 3479; 5265 3459 3458 3479 3480; 5266 3460 3459 3480 3481;
    5267 3461 3460 3481 3482; 5268 3462 3461 3482 3483; 5269 3463 3462 3483 3484;
    5270 3464 3463 3484 3485; 5271 3465 3464 3485 3486; 5272 3466 3465 3486 3487;
    5273 3467 3466 3487 3488; 5274 3468 3467 3488 3489; 5275 3448 3468 3489 3469;
    5276 3470 1974 1994 3491; 5277 3471 3470 3491 3492; 5278 3472 3471 3492 3493;
    5279 3473 3472 3493 3494; 5280 3474 3473 3494 3495; 5281 3475 3474 3495 3496;
    5282 3476 3475 3496 3497; 5283 3477 3476 3497 3498; 5284 3478 3477 3498 3499;
    5285 3479 3478 3499 3500; 5286 3480 3479 3500 3501; 5287 3481 3480 3501 3502;
    5288 3482 3481 3502 3503; 5289 3483 3482 3503 3504; 5290 3484 3483 3504 3505;
    5291 3485 3484 3505 3506; 5292 3486 3485 3506 3507; 5293 3487 3486 3507 3508;
    5294 3488 3487 3508 3509; 5295 3489 3488 3509 3510; 5296 3469 3489 3510 3490;
    5297 3491 1994 2014 3512; 5298 3492 3491 3512 3513; 5299 3493 3492 3513 3514;
    5300 3494 3493 3514 3515; 5301 3495 3494 3515 3516; 5302 3496 3495 3516 3517;
    5303 3497 3496 3517 3518; 5304 3498 3497 3518 3519; 5305 3499 3498 3519 3520;
    5306 3500 3499 3520 3521; 5307 3501 3500 3521 3522; 5308 3502 3501 3522 3523;
    5309 3503 3502 3523 3524; 5310 3504 3503 3524 3525; 5311 3505 3504 3525 3526;
    5312 3506 3505 3526 3527; 5313 3507 3506 3527 3528; 5314 3508 3507 3528 3529;
    5315 3509 3508 3529 3530; 5316 3510 3509 3530 3531; 5317 3490 3510 3531 3511;
    5318 3512 2014 2034 3533; 5319 3513 3512 3533 3534; 5320 3514 3513 3534 3535;
    5321 3515 3514 3535 3536; 5322 3516 3515 3536 3537; 5323 3517 3516 3537 3538;
    5324 3518 3517 3538 3539; 5325 3519 3518 3539 3540; 5326 3520 3519 3540 3541;
    5327 3521 3520 3541 3542; 5328 3522 3521 3542 3543; 5329 3523 3522 3543 3544;
    5330 3524 3523 3544 3545; 5331 3525 3524 3545 3546; 5332 3526 3525 3546 3547;
    5333 3527 3526 3547 3548; 5334 3528 3527 3548 3549; 5335 3529 3528 3549 3550;
    5336 3530 3529 3550 3551; 5337 3531 3530 3551 3552; 5338 3511 3531 3552 3532;
    5339 3533 2034 2054 3554; 5340 3534 3533 3554 3555; 5341 3535 3534 3555 3556;
    5342 3536 3535 3556 3557; 5343 3537 3536 3557 3558; 5344 3538 3537 3558 3559;
    5345 3539 3538 3559 3560; 5346 3540 3539 3560 3561; 5347 3541 3540 3561 3562;
    5348 3542 3541 3562 3563; 5349 3543 3542 3563 3564; 5350 3544 3543 3564 3565;
    5351 3545 3544 3565 3566; 5352 3546 3545 3566 3567; 5353 3547 3546 3567 3568;
    5354 3548 3547 3568 3569; 5355 3549 3548 3569 3570; 5356 3550 3549 3570 3571;
    5357 3551 3550 3571 3572; 5358 3552 3551 3572 3573; 5359 3532 3552 3573 3553;
    5360 3554 2054 2074 3575; 5361 3555 3554 3575 3576; 5362 3556 3555 3576 3577;
    5363 3557 3556 3577 3578; 5364 3558 3557 3578 3579; 5365 3559 3558 3579 3580;
    5366 3560 3559 3580 3581; 5367 3561 3560 3581 3582; 5368 3562 3561 3582 3583;
    5369 3563 3562 3583 3584; 5370 3564 3563 3584 3585; 5371 3565 3564 3585 3586;
    5372 3566 3565 3586 3587; 5373 3567 3566 3587 3588; 5374 3568 3567 3588 3589;
    5375 3569 3568 3589 3590; 5376 3570 3569 3590 3591; 5377 3571 3570 3591 3592;
    5378 3572 3571 3592 3593; 5379 3573 3572 3593 3594; 5380 3553 3573 3594 3574;
    5381 3575 2074 2094 3596; 5382 3576 3575 3596 3597; 5383 3577 3576 3597 3598;
    5384 3578 3577 3598 3599; 5385 3579 3578 3599 3600; 5386 3580 3579 3600 3601;
    5387 3581 3580 3601 3602; 5388 3582 3581 3602 3603; 5389 3583 3582 3603 3604;
    5390 3584 3583 3604 3605; 5391 3585 3584 3605 3606; 5392 3586 3585 3606 3607;
    5393 3587 3586 3607 3608; 5394 3588 3587 3608 3609; 5395 3589 3588 3609 3610;
    5396 3590 3589 3610 3611; 5397 3591 3590 3611 3612; 5398 3592 3591 3612 3613;
    5399 3593 3592 3613 3614; 5400 3594 3593 3614 3615; 5401 3574 3594 3615 3595;
    5402 3596 2094 2114 3617; 5403 3597 3596 3617 3618; 5404 3598 3597 3618 3619;
    5405 3599 3598 3619 3620; 5406 3600 3599 3620 3621; 5407 3601 3600 3621 3622;
    5408 3602 3601 3622 3623; 5409 3603 3602 3623 3624; 5410 3604 3603 3624 3625;
    5411 3605 3604 3625 3626; 5412 3606 3605 3626 3627; 5413 3607 3606 3627 3628;
    5414 3608 3607 3628 3629; 5415 3609 3608 3629 3630; 5416 3610 3609 3630 3631;
    5417 3611 3610 3631 3632; 5418 3612 3611 3632 3633; 5419 3613 3612 3633 3634;
    5420 3614 3613 3634 3635; 5421 3615 3614 3635 3636; 5422 3595 3615 3636 3616;
    5423 3617 2114 2134 3638; 5424 3618 3617 3638 3639; 5425 3619 3618 3639 3640;
    5426 3620 3619 3640 3641; 5427 3621 3620 3641 3642; 5428 3622 3621 3642 3643;
    5429 3623 3622 3643 3644; 5430 3624 3623 3644 3645; 5431 3625 3624 3645 3646;
    5432 3626 3625 3646 3647; 5433 3627 3626 3647 3648; 5434 3628 3627 3648 3649;
    5435 3629 3628 3649 3650; 5436 3630 3629 3650 3651; 5437 3631 3630 3651 3652;
    5438 3632 3631 3652 3653; 5439 3633 3632 3653 3654; 5440 3634 3633 3654 3655;
    5441 3635 3634 3655 3656; 5442 3636 3635 3656 3657; 5443 3616 3636 3657 3637;
    5444 3638 2134 2154 3659; 5445 3639 3638 3659 3660; 5446 3640 3639 3660 3661;
    5447 3641 3640 3661 3662; 5448 3642 3641 3662 3663; 5449 3643 3642 3663 3664;
    5450 3644 3643 3664 3665; 5451 3645 3644 3665 3666; 5452 3646 3645 3666 3667;
    5453 3647 3646 3667 3668; 5454 3648 3647 3668 3669; 5455 3649 3648 3669 3670;
    5456 3650 3649 3670 3671; 5457 3651 3650 3671 3672; 5458 3652 3651 3672 3673;
    5459 3653 3652 3673 3674; 5460 3654 3653 3674 3675; 5461 3655 3654 3675 3676;
    5462 3656 3655 3676 3677; 5463 3657 3656 3677 3678; 5464 3637 3657 3678 3658;
    5465 3659 2154 2174 3680; 5466 3660 3659 3680 3681; 5467 3661 3660 3681 3682;
    5468 3662 3661 3682 3683; 5469 3663 3662 3683 3684; 5470 3664 3663 3684 3685;
    5471 3665 3664 3685 3686; 5472 3666 3665 3686 3687; 5473 3667 3666 3687 3688;
    5474 3668 3667 3688 3689; 5475 3669 3668 3689 3690; 5476 3670 3669 3690 3691;
    5477 3671 3670 3691 3692; 5478 3672 3671 3692 3693; 5479 3673 3672 3693 3694;
    5480 3674 3673 3694 3695; 5481 3675 3674 3695 3696; 5482 3676 3675 3696 3697;
    5483 3677 3676 3697 3698; 5484 3678 3677 3698 3699; 5485 3658 3678 3699 3679;
    5486 3680 2174 2194 3701; 5487 3681 3680 3701 3702; 5488 3682 3681 3702 3703;
    5489 3683 3682 3703 3704; 5490 3684 3683 3704 3705; 5491 3685 3684 3705 3706;
    5492 3686 3685 3706 3707; 5493 3687 3686 3707 3708; 5494 3688 3687 3708 3709;
    5495 3689 3688 3709 3710; 5496 3690 3689 3710 3711; 5497 3691 3690 3711 3712;
    5498 3692 3691 3712 3713; 5499 3693 3692 3713 3714; 5500 3694 3693 3714 3715;
    5501 3695 3694 3715 3716; 5502 3696 3695 3716 3717; 5503 3697 3696 3717 3718;
    5504 3698 3697 3718 3719; 5505 3699 3698 3719 3720; 5506 3679 3699 3720 3700;
    5507 3701 2194 2214 3722; 5508 3702 3701 3722 3723; 5509 3703 3702 3723 3724;
    5510 3704 3703 3724 3725; 5511 3705 3704 3725 3726; 5512 3706 3705 3726 3727;
    5513 3707 3706 3727 3728; 5514 3708 3707 3728 3729; 5515 3709 3708 3729 3730;
    5516 3710 3709 3730 3731; 5517 3711 3710 3731 3732; 5518 3712 3711 3732 3733;
    5519 3713 3712 3733 3734; 5520 3714 3713 3734 3735; 5521 3715 3714 3735 3736;
    5522 3716 3715 3736 3737; 5523 3717 3716 3737 3738; 5524 3718 3717 3738 3739;
    5525 3719 3718 3739 3740; 5526 3720 3719 3740 3741; 5527 3700 3720 3741 3721;
    5528 3722 2214 2234 3743; 5529 3723 3722 3743 3744; 5530 3724 3723 3744 3745;
    5531 3725 3724 3745 3746; 5532 3726 3725 3746 3747; 5533 3727 3726 3747 3748;
    5534 3728 3727 3748 3749; 5535 3729 3728 3749 3750; 5536 3730 3729 3750 3751;
    5537 3731 3730 3751 3752; 5538 3732 3731 3752 3753; 5539 3733 3732 3753 3754;
    5540 3734 3733 3754 3755; 5541 3735 3734 3755 3756; 5542 3736 3735 3756 3757;
    5543 3737 3736 3757 3758; 5544 3738 3737 3758 3759; 5545 3739 3738 3759 3760;
    5546 3740 3739 3760 3761; 5547 3741 3740 3761 3762; 5548 3721 3741 3762 3742;
    5549 3743 2234 2254 3764; 5550 3744 3743 3764 3765; 5551 3745 3744 3765 3766;
    5552 3746 3745 3766 3767; 5553 3747 3746 3767 3768; 5554 3748 3747 3768 3769;
    5555 3749 3748 3769 3770; 5556 3750 3749 3770 3771; 5557 3751 3750 3771 3772;
    5558 3752 3751 3772 3773; 5559 3753 3752 3773 3774; 5560 3754 3753 3774 3775;
    5561 3755 3754 3775 3776; 5562 3756 3755 3776 3777; 5563 3757 3756 3777 3778;
    5564 3758 3757 3778 3779; 5565 3759 3758 3779 3780; 5566 3760 3759 3780 3781;
    5567 3761 3760 3781 3782; 5568 3762 3761 3782 3783; 5569 3742 3762 3783 3763;
    5570 3764 2254 2274 3785; 5571 3765 3764 3785 3786; 5572 3766 3765 3786 3787;
    5573 3767 3766 3787 3788; 5574 3768 3767 3788 3789; 5575 3769 3768 3789 3790;
    5576 3770 3769 3790 3791; 5577 3771 3770 3791 3792; 5578 3772 3771 3792 3793;
    5579 3773 3772 3793 3794; 5580 3774 3773 3794 3795; 5581 3775 3774 3795 3796;
    5582 3776 3775 3796 3797; 5583 3777 3776 3797 3798; 5584 3778 3777 3798 3799;
    5585 3779 3778 3799 3800; 5586 3780 3779 3800 3801; 5587 3781 3780 3801 3802;
    5588 3782 3781 3802 3803; 5589 3783 3782 3803 3804; 5590 3763 3783 3804 3784;
    5591 3785 2274 2294 3806; 5592 3786 3785 3806 3807; 5593 3787 3786 3807 3808;
    5594 3788 3787 3808 3809; 5595 3789 3788 3809 3810; 5596 3790 3789 3810 3811;
    5597 3791 3790 3811 3812; 5598 3792 3791 3812 3813; 5599 3793 3792 3813 3814;
    5600 3794 3793 3814 3815; 5601 3795 3794 3815 3816; 5602 3796 3795 3816 3817;
    5603 3797 3796 3817 3818; 5604 3798 3797 3818 3819; 5605 3799 3798 3819 3820;
    5606 3800 3799 3820 3821; 5607 3801 3800 3821 3822; 5608 3802 3801 3822 3823;
    5609 3803 3802 3823 3824; 5610 3804 3803 3824 3825; 5611 3784 3804 3825 3805;
    5612 3806 2294 2314 3827; 5613 3807 3806 3827 3828; 5614 3808 3807 3828 3829;
    5615 3809 3808 3829 3830; 5616 3810 3809 3830 3831; 5617 3811 3810 3831 3832;
    5618 3812 3811 3832 3833; 5619 3813 3812 3833 3834; 5620 3814 3813 3834 3835;
    5621 3815 3814 3835 3836; 5622 3816 3815 3836 3837; 5623 3817 3816 3837 3838;
    5624 3818 3817 3838 3839; 5625 3819 3818 3839 3840; 5626 3820 3819 3840 3841;
    5627 3821 3820 3841 3842; 5628 3822 3821 3842 3843; 5629 3823 3822 3843 3844;
    5630 3824 3823 3844 3845; 5631 3825 3824 3845 3846; 5632 3805 3825 3846 3826;
    5633 3827 2314 2334 3848; 5634 3828 3827 3848 3849; 5635 3829 3828 3849 3850;
    5636 3830 3829 3850 3851; 5637 3831 3830 3851 3852; 5638 3832 3831 3852 3853;
    5639 3833 3832 3853 3854; 5640 3834 3833 3854 3855; 5641 3835 3834 3855 3856;
    5642 3836 3835 3856 3857; 5643 3837 3836 3857 3858; 5644 3838 3837 3858 3859;
    5645 3839 3838 3859 3860; 5646 3840 3839 3860 3861; 5647 3841 3840 3861 3862;
    5648 3842 3841 3862 3863; 5649 3843 3842 3863 3864; 5650 3844 3843 3864 3865;
    5651 3845 3844 3865 3866; 5652 3846 3845 3866 3867; 5653 3826 3846 3867 3847;
    5654 3848 2334 2354 3869; 5655 3849 3848 3869 3870; 5656 3850 3849 3870 3871;
    5657 3851 3850 3871 3872; 5658 3852 3851 3872 3873; 5659 3853 3852 3873 3874;
    5660 3854 3853 3874 3875; 5661 3855 3854 3875 3876; 5662 3856 3855 3876 3877;
    5663 3857 3856 3877 3878; 5664 3858 3857 3878 3879; 5665 3859 3858 3879 3880;
    5666 3860 3859 3880 3881; 5667 3861 3860 3881 3882; 5668 3862 3861 3882 3883;
    5669 3863 3862 3883 3884; 5670 3864 3863 3884 3885; 5671 3865 3864 3885 3886;
    5672 3866 3865 3886 3887; 5673 3867 3866 3887 3888; 5674 3847 3867 3888 3868;
    5675 3869 2354 2374 3890; 5676 3870 3869 3890 3891; 5677 3871 3870 3891 3892;
    5678 3872 3871 3892 3893; 5679 3873 3872 3893 3894; 5680 3874 3873 3894 3895;
    5681 3875 3874 3895 3896; 5682 3876 3875 3896 3897; 5683 3877 3876 3897 3898;
    5684 3878 3877 3898 3899; 5685 3879 3878 3899 3900; 5686 3880 3879 3900 3901;
    5687 3881 3880 3901 3902; 5688 3882 3881 3902 3903; 5689 3883 3882 3903 3904;
    5690 3884 3883 3904 3905; 5691 3885 3884 3905 3906; 5692 3886 3885 3906 3907;
    5693 3887 3886 3907 3908; 5694 3888 3887 3908 3909; 5695 3868 3888 3909 3889;
    5696 3890 2374 2394 3911; 5697 3891 3890 3911 3912; 5698 3892 3891 3912 3913;
    5699 3893 3892 3913 3914; 5700 3894 3893 3914 3915; 5701 3895 3894 3915 3916;
    5702 3896 3895 3916 3917; 5703 3897 3896 3917 3918; 5704 3898 3897 3918 3919;
    5705 3899 3898 3919 3920; 5706 3900 3899 3920 3921; 5707 3901 3900 3921 3922;
    5708 3902 3901 3922 3923; 5709 3903 3902 3923 3924; 5710 3904 3903 3924 3925;
    5711 3905 3904 3925 3926; 5712 3906 3905 3926 3927; 5713 3907 3906 3927 3928;
    5714 3908 3907 3928 3929; 5715 3909 3908 3929 3930; 5716 3889 3909 3930 3910;
    5717 3911 2394 2414 3932; 5718 3912 3911 3932 3933; 5719 3913 3912 3933 3934;
    5720 3914 3913 3934 3935; 5721 3915 3914 3935 3936; 5722 3916 3915 3936 3937;
    5723 3917 3916 3937 3938; 5724 3918 3917 3938 3939; 5725 3919 3918 3939 3940;
    5726 3920 3919 3940 3941; 5727 3921 3920 3941 3942; 5728 3922 3921 3942 3943;
    5729 3923 3922 3943 3944; 5730 3924 3923 3944 3945; 5731 3925 3924 3945 3946;
    5732 3926 3925 3946 3947; 5733 3927 3926 3947 3948; 5734 3928 3927 3948 3949;
    5735 3929 3928 3949 3950; 5736 3930 3929 3950 3951; 5737 3910 3930 3951 3931;
    5738 3932 2414 2434 3953; 5739 3933 3932 3953 3954; 5740 3934 3933 3954 3955;
    5741 3935 3934 3955 3956; 5742 3936 3935 3956 3957; 5743 3937 3936 3957 3958;
    5744 3938 3937 3958 3959; 5745 3939 3938 3959 3960; 5746 3940 3939 3960 3961;
    5747 3941 3940 3961 3962; 5748 3942 3941 3962 3963; 5749 3943 3942 3963 3964;
    5750 3944 3943 3964 3965; 5751 3945 3944 3965 3966; 5752 3946 3945 3966 3967;
    5753 3947 3946 3967 3968; 5754 3948 3947 3968 3969; 5755 3949 3948 3969 3970;
    5756 3950 3949 3970 3971; 5757 3951 3950 3971 3972; 5758 3931 3951 3972 3952;
    5759 3953 2434 2454 3974; 5760 3954 3953 3974 3975; 5761 3955 3954 3975 3976;
    5762 3956 3955 3976 3977; 5763 3957 3956 3977 3978; 5764 3958 3957 3978 3979;
    5765 3959 3958 3979 3980; 5766 3960 3959 3980 3981; 5767 3961 3960 3981 3982;
    5768 3962 3961 3982 3983; 5769 3963 3962 3983 3984; 5770 3964 3963 3984 3985;
    5771 3965 3964 3985 3986; 5772 3966 3965 3986 3987; 5773 3967 3966 3987 3988;
    5774 3968 3967 3988 3989; 5775 3969 3968 3989 3990; 5776 3970 3969 3990 3991;
    5777 3971 3970 3991 3992; 5778 3972 3971 3992 3993; 5779 3952 3972 3993 3973;
    5780 3974 2454 2474 3995; 5781 3975 3974 3995 3996; 5782 3976 3975 3996 3997;
    5783 3977 3976 3997 3998; 5784 3978 3977 3998 3999; 5785 3979 3978 3999 4000;
    5786 3980 3979 4000 4001; 5787 3981 3980 4001 4002; 5788 3982 3981 4002 4003;
    5789 3983 3982 4003 4004; 5790 3984 3983 4004 4005; 5791 3985 3984 4005 4006;
    5792 3986 3985 4006 4007; 5793 3987 3986 4007 4008; 5794 3988 3987 4008 4009;
    5795 3989 3988 4009 4010; 5796 3990 3989 4010 4011; 5797 3991 3990 4011 4012;
    5798 3992 3991 4012 4013; 5799 3993 3992 4013 4014; 5800 3973 3993 4014 3994;
    5801 3995 2474 2494 4016; 5802 3996 3995 4016 4017; 5803 3997 3996 4017 4018;
    5804 3998 3997 4018 4019; 5805 3999 3998 4019 4020; 5806 4000 3999 4020 4021;
    5807 4001 4000 4021 4022; 5808 4002 4001 4022 4023; 5809 4003 4002 4023 4024;
    5810 4004 4003 4024 4025; 5811 4005 4004 4025 4026; 5812 4006 4005 4026 4027;
    5813 4007 4006 4027 4028; 5814 4008 4007 4028 4029; 5815 4009 4008 4029 4030;
    5816 4010 4009 4030 4031; 5817 4011 4010 4031 4032; 5818 4012 4011 4032 4033;
    5819 4013 4012 4033 4034; 5820 4014 4013 4034 4035; 5821 3994 4014 4035 4015;
    5822 4016 2494 2514 4037; 5823 4017 4016 4037 4038; 5824 4018 4017 4038 4039;
    5825 4019 4018 4039 4040; 5826 4020 4019 4040 4041; 5827 4021 4020 4041 4042;
    5828 4022 4021 4042 4043; 5829 4023 4022 4043 4044; 5830 4024 4023 4044 4045;
    5831 4025 4024 4045 4046; 5832 4026 4025 4046 4047; 5833 4027 4026 4047 4048;
    5834 4028 4027 4048 4049; 5835 4029 4028 4049 4050; 5836 4030 4029 4050 4051;
    5837 4031 4030 4051 4052; 5838 4032 4031 4052 4053; 5839 4033 4032 4053 4054;
    5840 4034 4033 4054 4055; 5841 4035 4034 4055 4056; 5842 4015 4035 4056 4036;
    5843 4037 2514 2534 4058; 5844 4038 4037 4058 4059; 5845 4039 4038 4059 4060;
    5846 4040 4039 4060 4061; 5847 4041 4040 4061 4062; 5848 4042 4041 4062 4063;
    5849 4043 4042 4063 4064; 5850 4044 4043 4064 4065; 5851 4045 4044 4065 4066;
    5852 4046 4045 4066 4067; 5853 4047 4046 4067 4068; 5854 4048 4047 4068 4069;
    5855 4049 4048 4069 4070; 5856 4050 4049 4070 4071; 5857 4051 4050 4071 4072;
    5858 4052 4051 4072 4073; 5859 4053 4052 4073 4074; 5860 4054 4053 4074 4075;
    5861 4055 4054 4075 4076; 5862 4056 4055 4076 4077; 5863 4036 4056 4077 4057;
    5864 4058 2534 2554 4079; 5865 4059 4058 4079 4080; 5866 4060 4059 4080 4081;
    5867 4061 4060 4081 4082; 5868 4062 4061 4082 4083; 5869 4063 4062 4083 4084;
    5870 4064 4063 4084 4085; 5871 4065 4064 4085 4086; 5872 4066 4065 4086 4087;
    5873 4067 4066 4087 4088; 5874 4068 4067 4088 4089; 5875 4069 4068 4089 4090;
    5876 4070 4069 4090 4091; 5877 4071 4070 4091 4092; 5878 4072 4071 4092 4093;
    5879 4073 4072 4093 4094; 5880 4074 4073 4094 4095; 5881 4075 4074 4095 4096;
    5882 4076 4075 4096 4097; 5883 4077 4076 4097 4098; 5884 4057 4077 4098 4078;
    5885 4079 2554 2574 4100; 5886 4080 4079 4100 4101; 5887 4081 4080 4101 4102;
    5888 4082 4081 4102 4103; 5889 4083 4082 4103 4104; 5890 4084 4083 4104 4105;
    5891 4085 4084 4105 4106; 5892 4086 4085 4106 4107; 5893 4087 4086 4107 4108;
    5894 4088 4087 4108 4109; 5895 4089 4088 4109 4110; 5896 4090 4089 4110 4111;
    5897 4091 4090 4111 4112; 5898 4092 4091 4112 4113; 5899 4093 4092 4113 4114;
    5900 4094 4093 4114 4115; 5901 4095 4094 4115 4116; 5902 4096 4095 4116 4117;
    5903 4097 4096 4117 4118; 5904 4098 4097 4118 4119; 5905 4078 4098 4119 4099;
    5906 4100 2574 2594 4121; 5907 4101 4100 4121 4122; 5908 4102 4101 4122 4123;
    5909 4103 4102 4123 4124; 5910 4104 4103 4124 4125; 5911 4105 4104 4125 4126;
    5912 4106 4105 4126 4127; 5913 4107 4106 4127 4128; 5914 4108 4107 4128 4129;
    5915 4109 4108 4129 4130; 5916 4110 4109 4130 4131; 5917 4111 4110 4131 4132;
    5918 4112 4111 4132 4133; 5919 4113 4112 4133 4134; 5920 4114 4113 4134 4135;
    5921 4115 4114 4135 4136; 5922 4116 4115 4136 4137; 5923 4117 4116 4137 4138;
    5924 4118 4117 4138 4139; 5925 4119 4118 4139 4140; 5926 4099 4119 4140 4120;
    5927 4121 2594 2614 4142; 5928 4122 4121 4142 4143; 5929 4123 4122 4143 4144;
    5930 4124 4123 4144 4145; 5931 4125 4124 4145 4146; 5932 4126 4125 4146 4147;
    5933 4127 4126 4147 4148; 5934 4128 4127 4148 4149; 5935 4129 4128 4149 4150;
    5936 4130 4129 4150 4151; 5937 4131 4130 4151 4152; 5938 4132 4131 4152 4153;
    5939 4133 4132 4153 4154; 5940 4134 4133 4154 4155; 5941 4135 4134 4155 4156;
    5942 4136 4135 4156 4157; 5943 4137 4136 4157 4158; 5944 4138 4137 4158 4159;
    5945 4139 4138 4159 4160; 5946 4140 4139 4160 4161; 5947 4120 4140 4161 4141;
    5948 4142 2614 2634 4163; 5949 4143 4142 4163 4164; 5950 4144 4143 4164 4165;
    5951 4145 4144 4165 4166; 5952 4146 4145 4166 4167; 5953 4147 4146 4167 4168;
    5954 4148 4147 4168 4169; 5955 4149 4148 4169 4170; 5956 4150 4149 4170 4171;
    5957 4151 4150 4171 4172; 5958 4152 4151 4172 4173; 5959 4153 4152 4173 4174;
    5960 4154 4153 4174 4175; 5961 4155 4154 4175 4176; 5962 4156 4155 4176 4177;
    5963 4157 4156 4177 4178; 5964 4158 4157 4178 4179; 5965 4159 4158 4179 4180;
    5966 4160 4159 4180 4181; 5967 4161 4160 4181 4182; 5968 4141 4161 4182 4162;
    5969 4163 2634 2654 4184; 5970 4164 4163 4184 4185; 5971 4165 4164 4185 4186;
    5972 4166 4165 4186 4187; 5973 4167 4166 4187 4188; 5974 4168 4167 4188 4189;
    5975 4169 4168 4189 4190; 5976 4170 4169 4190 4191; 5977 4171 4170 4191 4192;
    5978 4172 4171 4192 4193; 5979 4173 4172 4193 4194; 5980 4174 4173 4194 4195;
    5981 4175 4174 4195 4196; 5982 4176 4175 4196 4197; 5983 4177 4176 4197 4198;
    5984 4178 4177 4198 4199; 5985 4179 4178 4199 4200; 5986 4180 4179 4200 4201;
    5987 4181 4180 4201 4202; 5988 4182 4181 4202 4203; 5989 4162 4182 4203 4183;
    5990 4184 2654 2674 4205; 5991 4185 4184 4205 4206; 5992 4186 4185 4206 4207;
    5993 4187 4186 4207 4208; 5994 4188 4187 4208 4209; 5995 4189 4188 4209 4210;
    5996 4190 4189 4210 4211; 5997 4191 4190 4211 4212; 5998 4192 4191 4212 4213;
    5999 4193 4192 4213 4214; 6000 4194 4193 4214 4215; 6001 4195 4194 4215 4216;
    6002 4196 4195 4216 4217; 6003 4197 4196 4217 4218; 6004 4198 4197 4218 4219;
    6005 4199 4198 4219 4220; 6006 4200 4199 4220 4221; 6007 4201 4200 4221 4222;
    6008 4202 4201 4222 4223; 6009 4203 4202 4223 4224; 6010 4183 4203 4224 4204;
    6011 4205 2674 2694 4226; 6012 4206 4205 4226 4227; 6013 4207 4206 4227 4228;
    6014 4208 4207 4228 4229; 6015 4209 4208 4229 4230; 6016 4210 4209 4230 4231;
    6017 4211 4210 4231 4232; 6018 4212 4211 4232 4233; 6019 4213 4212 4233 4234;
    6020 4214 4213 4234 4235; 6021 4215 4214 4235 4236; 6022 4216 4215 4236 4237;
    6023 4217 4216 4237 4238; 6024 4218 4217 4238 4239; 6025 4219 4218 4239 4240;
    6026 4220 4219 4240 4241; 6027 4221 4220 4241 4242; 6028 4222 4221 4242 4243;
    6029 4223 4222 4243 4244; 6030 4224 4223 4244 4245; 6031 4204 4224 4245 4225;
    6032 4226 2694 2714 4247; 6033 4227 4226 4247 4248; 6034 4228 4227 4248 4249;
    6035 4229 4228 4249 4250; 6036 4230 4229 4250 4251; 6037 4231 4230 4251 4252;
    6038 4232 4231 4252 4253; 6039 4233 4232 4253 4254; 6040 4234 4233 4254 4255;
    6041 4235 4234 4255 4256; 6042 4236 4235 4256 4257; 6043 4237 4236 4257 4258;
    6044 4238 4237 4258 4259; 6045 4239 4238 4259 4260; 6046 4240 4239 4260 4261;
    6047 4241 4240 4261 4262; 6048 4242 4241 4262 4263; 6049 4243 4242 4263 4264;
    6050 4244 4243 4264 4265; 6051 4245 4244 4265 4266; 6052 4225 4245 4266 4246;
    6053 4247 2714 2734 4268; 6054 4248 4247 4268 4269; 6055 4249 4248 4269 4270;
    6056 4250 4249 4270 4271; 6057 4251 4250 4271 4272; 6058 4252 4251 4272 4273;
    6059 4253 4252 4273 4274; 6060 4254 4253 4274 4275; 6061 4255 4254 4275 4276;
    6062 4256 4255 4276 4277; 6063 4257 4256 4277 4278; 6064 4258 4257 4278 4279;
    6065 4259 4258 4279 4280; 6066 4260 4259 4280 4281; 6067 4261 4260 4281 4282;
    6068 4262 4261 4282 4283; 6069 4263 4262 4283 4284; 6070 4264 4263 4284 4285;
    6071 4265 4264 4285 4286; 6072 4266 4265 4286 4287; 6073 4246 4266 4287 4267;
    6074 4268 2734 2754 4289; 6075 4269 4268 4289 4290; 6076 4270 4269 4290 4291;
    6077 4271 4270 4291 4292; 6078 4272 4271 4292 4293; 6079 4273 4272 4293 4294;
    6080 4274 4273 4294 4295; 6081 4275 4274 4295 4296; 6082 4276 4275 4296 4297;
    6083 4277 4276 4297 4298; 6084 4278 4277 4298 4299; 6085 4279 4278 4299 4300;
    6086 4280 4279 4300 4301; 6087 4281 4280 4301 4302; 6088 4282 4281 4302 4303;
    6089 4283 4282 4303 4304; 6090 4284 4283 4304 4305; 6091 4285 4284 4305 4306;
    6092 4286 4285 4306 4307; 6093 4287 4286 4307 4308; 6094 4267 4287 4308 4288;
    6095 4289 2754 2774 4310; 6096 4290 4289 4310 4311; 6097 4291 4290 4311 4312;
    6098 4292 4291 4312 4313; 6099 4293 4292 4313 4314; 6100 4294 4293 4314 4315;
    6101 4295 4294 4315 4316; 6102 4296 4295 4316 4317; 6103 4297 4296 4317 4318;
    6104 4298 4297 4318 4319; 6105 4299 4298 4319 4320; 6106 4300 4299 4320 4321;
    6107 4301 4300 4321 4322; 6108 4302 4301 4322 4323; 6109 4303 4302 4323 4324;
    6110 4304 4303 4324 4325; 6111 4305 4304 4325 4326; 6112 4306 4305 4326 4327;
    6113 4307 4306 4327 4328; 6114 4308 4307 4328 4329; 6115 4288 4308 4329 4309;
    6116 4310 2774 2794 4331; 6117 4311 4310 4331 4332; 6118 4312 4311 4332 4333;
    6119 4313 4312 4333 4334; 6120 4314 4313 4334 4335; 6121 4315 4314 4335 4336;
    6122 4316 4315 4336 4337; 6123 4317 4316 4337 4338; 6124 4318 4317 4338 4339;
    6125 4319 4318 4339 4340; 6126 4320 4319 4340 4341; 6127 4321 4320 4341 4342;
    6128 4322 4321 4342 4343; 6129 4323 4322 4343 4344; 6130 4324 4323 4344 4345;
    6131 4325 4324 4345 4346; 6132 4326 4325 4346 4347; 6133 4327 4326 4347 4348;
    6134 4328 4327 4348 4349; 6135 4329 4328 4349 4350; 6136 4309 4329 4350 4330;
    6137 4331 2794 2814 4352; 6138 4332 4331 4352 4353; 6139 4333 4332 4353 4354;
    6140 4334 4333 4354 4355; 6141 4335 4334 4355 4356; 6142 4336 4335 4356 4357;
    6143 4337 4336 4357 4358; 6144 4338 4337 4358 4359; 6145 4339 4338 4359 4360;
    6146 4340 4339 4360 4361; 6147 4341 4340 4361 4362; 6148 4342 4341 4362 4363;
    6149 4343 4342 4363 4364; 6150 4344 4343 4364 4365; 6151 4345 4344 4365 4366;
    6152 4346 4345 4366 4367; 6153 4347 4346 4367 4368; 6154 4348 4347 4368 4369;
    6155 4349 4348 4369 4370; 6156 4350 4349 4370 4371; 6157 4330 4350 4371 4351;
    6158 4352 2814 2834 4373; 6159 4353 4352 4373 4374; 6160 4354 4353 4374 4375;
    6161 4355 4354 4375 4376; 6162 4356 4355 4376 4377; 6163 4357 4356 4377 4378;
    6164 4358 4357 4378 4379; 6165 4359 4358 4379 4380; 6166 4360 4359 4380 4381;
    6167 4361 4360 4381 4382; 6168 4362 4361 4382 4383; 6169 4363 4362 4383 4384;
    6170 4364 4363 4384 4385; 6171 4365 4364 4385 4386; 6172 4366 4365 4386 4387;
    6173 4367 4366 4387 4388; 6174 4368 4367 4388 4389; 6175 4369 4368 4389 4390;
    6176 4370 4369 4390 4391; 6177 4371 4370 4391 4392; 6178 4351 4371 4392 4372;
    6179 4373 2834 2854 4394; 6180 4374 4373 4394 4395; 6181 4375 4374 4395 4396;
    6182 4376 4375 4396 4397; 6183 4377 4376 4397 4398; 6184 4378 4377 4398 4399;
    6185 4379 4378 4399 4400; 6186 4380 4379 4400 4401; 6187 4381 4380 4401 4402;
    6188 4382 4381 4402 4403; 6189 4383 4382 4403 4404; 6190 4384 4383 4404 4405;
    6191 4385 4384 4405 4406; 6192 4386 4385 4406 4407; 6193 4387 4386 4407 4408;
    6194 4388 4387 4408 4409; 6195 4389 4388 4409 4410; 6196 4390 4389 4410 4411;
    6197 4391 4390 4411 4412; 6198 4392 4391 4412 4413; 6199 4372 4392 4413 4393;
    6200 4394 2854 2874 4415; 6201 4395 4394 4415 4416; 6202 4396 4395 4416 4417;
    6203 4397 4396 4417 4418; 6204 4398 4397 4418 4419; 6205 4399 4398 4419 4420;
    6206 4400 4399 4420 4421; 6207 4401 4400 4421 4422; 6208 4402 4401 4422 4423;
    6209 4403 4402 4423 4424; 6210 4404 4403 4424 4425; 6211 4405 4404 4425 4426;
    6212 4406 4405 4426 4427; 6213 4407 4406 4427 4428; 6214 4408 4407 4428 4429;
    6215 4409 4408 4429 4430; 6216 4410 4409 4430 4431; 6217 4411 4410 4431 4432;
    6218 4412 4411 4432 4433; 6219 4413 4412 4433 4434; 6220 4393 4413 4434 4414;
    6221 4415 2874 2894 4436; 6222 4416 4415 4436 4437; 6223 4417 4416 4437 4438;
    6224 4418 4417 4438 4439; 6225 4419 4418 4439 4440; 6226 4420 4419 4440 4441;
    6227 4421 4420 4441 4442; 6228 4422 4421 4442 4443; 6229 4423 4422 4443 4444;
    6230 4424 4423 4444 4445; 6231 4425 4424 4445 4446; 6232 4426 4425 4446 4447;
    6233 4427 4426 4447 4448; 6234 4428 4427 4448 4449; 6235 4429 4428 4449 4450;
    6236 4430 4429 4450 4451; 6237 4431 4430 4451 4452; 6238 4432 4431 4452 4453;
    6239 4433 4432 4453 4454; 6240 4434 4433 4454 4455; 6241 4414 4434 4455 4435;
    6242 4436 2894 2914 4457; 6243 4437 4436 4457 4458; 6244 4438 4437 4458 4459;
    6245 4439 4438 4459 4460; 6246 4440 4439 4460 4461; 6247 4441 4440 4461 4462;
    6248 4442 4441 4462 4463; 6249 4443 4442 4463 4464; 6250 4444 4443 4464 4465;
    6251 4445 4444 4465 4466; 6252 4446 4445 4466 4467; 6253 4447 4446 4467 4468;
    6254 4448 4447 4468 4469; 6255 4449 4448 4469 4470; 6256 4450 4449 4470 4471;
    6257 4451 4450 4471 4472; 6258 4452 4451 4472 4473; 6259 4453 4452 4473 4474;
    6260 4454 4453 4474 4475; 6261 4455 4454 4475 4476; 6262 4435 4455 4476 4456;
    6263 4457 2914 2934 4478; 6264 4458 4457 4478 4479; 6265 4459 4458 4479 4480;
    6266 4460 4459 4480 4481; 6267 4461 4460 4481 4482; 6268 4462 4461 4482 4483;
    6269 4463 4462 4483 4484; 6270 4464 4463 4484 4485; 6271 4465 4464 4485 4486;
    6272 4466 4465 4486 4487; 6273 4467 4466 4487 4488; 6274 4468 4467 4488 4489;
    6275 4469 4468 4489 4490; 6276 4470 4469 4490 4491; 6277 4471 4470 4491 4492;
    6278 4472 4471 4492 4493; 6279 4473 4472 4493 4494; 6280 4474 4473 4494 4495;
    6281 4475 4474 4495 4496; 6282 4476 4475 4496 4497; 6283 4456 4476 4497 4477;
    6284 4478 2934 2954 4499; 6285 4479 4478 4499 4500; 6286 4480 4479 4500 4501;
    6287 4481 4480 4501 4502; 6288 4482 4481 4502 4503; 6289 4483 4482 4503 4504;
    6290 4484 4483 4504 4505; 6291 4485 4484 4505 4506; 6292 4486 4485 4506 4507;
    6293 4487 4486 4507 4508; 6294 4488 4487 4508 4509; 6295 4489 4488 4509 4510;
    6296 4490 4489 4510 4511; 6297 4491 4490 4511 4512; 6298 4492 4491 4512 4513;
    6299 4493 4492 4513 4514; 6300 4494 4493 4514 4515; 6301 4495 4494 4515 4516;
    6302 4496 4495 4516 4517; 6303 4497 4496 4517 4518; 6304 4477 4497 4518 4498;
    6305 4499 2954 2974 4520; 6306 4500 4499 4520 4521; 6307 4501 4500 4521 4522;
    6308 4502 4501 4522 4523; 6309 4503 4502 4523 4524; 6310 4504 4503 4524 4525;
    6311 4505 4504 4525 4526; 6312 4506 4505 4526 4527; 6313 4507 4506 4527 4528;
    6314 4508 4507 4528 4529; 6315 4509 4508 4529 4530; 6316 4510 4509 4530 4531;
    6317 4511 4510 4531 4532; 6318 4512 4511 4532 4533; 6319 4513 4512 4533 4534;
    6320 4514 4513 4534 4535; 6321 4515 4514 4535 4536; 6322 4516 4515 4536 4537;
    6323 4517 4516 4537 4538; 6325 4498 4518 4539 4519; 6326 4520 2974 2994 4541;
    6327 4521 4520 4541 4542; 6328 4522 4521 4542 4543; 6329 4523 4522 4543 4544;
    6330 4524 4523 4544 4545; 6331 4525 4524 4545 4546; 6332 4526 4525 4546 4547;
    6333 4527 4526 4547 4548; 6334 4528 4527 4548 4549; 6335 4529 4528 4549 4550;
    6336 4530 4529 4550 4551; 6337 4531 4530 4551 4552; 6338 4532 4531 4552 4553;
    6339 4533 4532 4553 4554; 6340 4534 4533 4554 4555; 6341 4535 4534 4555 4556;
    6342 4536 4535 4556 4557; 6346 4519 4539 4560 4540; 6347 4541 2994 3014 4562;
    6348 4542 4541 4562 4563; 6349 4543 4542 4563 4564; 6350 4544 4543 4564 4565;
    6351 4545 4544 4565 4566; 6352 4546 4545 4566 4567; 6353 4547 4546 4567 4568;
    6354 4548 4547 4568 4569; 6355 4549 4548 4569 4570; 6356 4550 4549 4570 4571;
    6357 4551 4550 4571 4572; 6358 4552 4551 4572 4573; 6359 4553 4552 4573 4574;
    6360 4554 4553 4574 4575; 6361 4555 4554 4575 4576; 6362 4556 4555 4576 4577;
    6367 4540 4560 4581 4561; 6368 4562 3014 3034 4583; 6369 4563 4562 4583 4584;
    6370 4564 4563 4584 4585; 6371 4565 4564 4585 4586; 6372 4566 4565 4586 4587;
    6373 4567 4566 4587 4588; 6374 4568 4567 4588 4589; 6375 4569 4568 4589 4590;
    6376 4570 4569 4590 4591; 6377 4571 4570 4591 4592; 6378 4572 4571 4592 4593;
    6379 4573 4572 4593 4594; 6380 4574 4573 4594 4595; 6381 4575 4574 4595 4596;
    6382 4576 4575 4596 4597; 6388 4561 4581 4602 4582; 6389 4583 3034 3054 4604;
    6390 4584 4583 4604 4605; 6391 4585 4584 4605 4606; 6392 4586 4585 4606 4607;
    6393 4587 4586 4607 4608; 6394 4588 4587 4608 4609; 6395 4589 4588 4609 4610;
    6396 4590 4589 4610 4611; 6397 4591 4590 4611 4612; 6398 4592 4591 4612 4613;
    6399 4593 4592 4613 4614; 6400 4594 4593 4614 4615; 6409 4582 4602 4623 4603;
    6410 4604 3054 3074 4625; 6411 4605 4604 4625 4626; 6412 4606 4605 4626 4627;
    6413 4607 4606 4627 4628; 6414 4608 4607 4628 4629; 6415 4609 4608 4629 4630;
    6416 4610 4609 4630 4631; 6417 4611 4610 4631 4632; 6418 4612 4611 4632 4633;
    6419 4613 4612 4633 4634; 6420 4614 4613 4634 4635; 6421 4615 4614 4635 4636;
    6430 4603 4623 4644 4624; 6431 4625 3074 3094 4646; 6432 4626 4625 4646 4647;
    6433 4627 4626 4647 4648; 6434 4628 4627 4648 4649; 6435 4629 4628 4649 4650;
    6436 4630 4629 4650 4651; 6437 4631 4630 4651 4652; 6438 4632 4631 4652 4653;
    6439 4633 4632 4653 4654; 6440 4634 4633 4654 4655; 6441 4635 4634 4655 4656;
    6442 4636 4635 4656 4657; 6443 4637 4636 4657 4658; 6444 4638 4637 4658 4659;
    6445 4639 4638 4659 4660; 6451 4624 4644 4665 4645; 6452 4646 3094 3114 4667;
    6453 4647 4646 4667 4668; 6454 4648 4647 4668 4669; 6455 4649 4648 4669 4670;
    6456 4650 4649 4670 4671; 6457 4651 4650 4671 4672; 6458 4652 4651 4672 4673;
    6459 4653 4652 4673 4674; 6460 4654 4653 4674 4675; 6461 4655 4654 4675 4676;
    6462 4656 4655 4676 4677; 6463 4657 4656 4677 4678; 6464 4658 4657 4678 4679;
    6465 4659 4658 4679 4680; 6466 4660 4659 4680 4681; 6467 4661 4660 4681 4682;
    6472 4645 4665 4686 4666; 6473 4667 3114 3134 4688; 6474 4668 4667 4688 4689;
    6475 4669 4668 4689 4690; 6476 4670 4669 4690 4691; 6477 4671 4670 4691 4692;
    6478 4672 4671 4692 4693; 6479 4673 4672 4693 4694; 6480 4674 4673 4694 4695;
    6481 4675 4674 4695 4696; 6482 4676 4675 4696 4697; 6483 4677 4676 4697 4698;
    6484 4678 4677 4698 4699; 6485 4679 4678 4699 4700; 6486 4680 4679 4700 4701;
    6487 4681 4680 4701 4702; 6488 4682 4681 4702 4703; 6489 4683 4682 4703 4704;
    6493 4666 4686 4707 4687; 6494 4688 3134 3154 4709; 6495 4689 4688 4709 4710;
    6496 4690 4689 4710 4711; 6497 4691 4690 4711 4712; 6498 4692 4691 4712 4713;
    6499 4693 4692 4713 4714; 6500 4694 4693 4714 4715; 6501 4695 4694 4715 4716;
    6502 4696 4695 4716 4717; 6503 4697 4696 4717 4718; 6504 4698 4697 4718 4719;
    6505 4699 4698 4719 4720; 6506 4700 4699 4720 4721; 6507 4701 4700 4721 4722;
    6508 4702 4701 4722 4723; 6509 4703 4702 4723 4724; 6510 4704 4703 4724 4725;
    6511 4705 4704 4725 4726; 6512 4706 4705 4726 4727; 6514 4687 4707 4728 4708;
    6515 4709 3154 3174 4730; 6516 4710 4709 4730 4731; 6517 4711 4710 4731 4732;
    6518 4712 4711 4732 4733; 6519 4713 4712 4733 4734; 6520 4714 4713 4734 4735;
    6521 4715 4714 4735 4736; 6522 4716 4715 4736 4737; 6523 4717 4716 4737 4738;
    6524 4718 4717 4738 4739; 6525 4719 4718 4739 4740; 6526 4720 4719 4740 4741;
    6527 4721 4720 4741 4742; 6528 4722 4721 4742 4743; 6529 4723 4722 4743 4744;
    6530 4724 4723 4744 4745; 6531 4725 4724 4745 4746; 6532 4726 4725 4746 4747;
    6533 4727 4726 4747 4748; 6534 4728 4727 4748 4749; 6535 4708 4728 4749 4729;
    6536 4730 3174 3194 4751; 6537 4731 4730 4751 4752; 6538 4732 4731 4752 4753;
    6539 4733 4732 4753 4754; 6540 4734 4733 4754 4755; 6541 4735 4734 4755 4756;
    6542 4736 4735 4756 4757; 6543 4737 4736 4757 4758; 6544 4738 4737 4758 4759;
    6545 4739 4738 4759 4760; 6546 4740 4739 4760 4761; 6547 4741 4740 4761 4762;
    6548 4742 4741 4762 4763; 6549 4743 4742 4763 4764; 6550 4744 4743 4764 4765;
    6551 4745 4744 4765 4766; 6552 4746 4745 4766 4767; 6553 4747 4746 4767 4768;
    6554 4748 4747 4768 4769; 6555 4749 4748 4769 4770; 6556 4729 4749 4770 4750;
    6557 4751 3194 3213 4772; 6558 4752 4751 4772 4773; 6559 4753 4752 4773 4774;
    6560 4754 4753 4774 4775; 6561 4755 4754 4775 4776; 6562 4756 4755 4776 4777;
    6563 4757 4756 4777 4778; 6564 4758 4757 4778 4779; 6565 4759 4758 4779 4780;
    6566 4760 4759 4780 4781; 6567 4761 4760 4781 4782; 6568 4762 4761 4782 4783;
    6569 4763 4762 4783 4784; 6570 4764 4763 4784 4785; 6571 4765 4764 4785 4786;
    6572 4766 4765 4786 4787; 6573 4767 4766 4787 4788; 6574 4768 4767 4788 4789;
    6575 4769 4768 4789 4790; 6576 4770 4769 4790 4791; 6577 4750 4770 4791 4771;
    6578 4772 3213 1813 3281; 6579 4773 4772 3281 3282; 6580 4774 4773 3282 3283;
    6581 4775 4774 3283 3284; 6582 4776 4775 3284 3285; 6583 4777 4776 3285 3286;
    6584 4778 4777 3286 3287; 6585 4779 4778 3287 3288; 6586 4780 4779 3288 3289;
    6587 4781 4780 3289 3290; 6588 4782 4781 3290 3291; 6589 4783 4782 3291 3292;
    6590 4784 4783 3292 3293; 6591 4785 4784 3293 3294; 6592 4786 4785 3294 3295;
    6593 4787 4786 3295 3296; 6594 4788 4787 3296 3297; 6595 4789 4788 3297 3298;
    6596 4790 4789 3298 3299; 6597 4791 4790 3299 3300; 6598 4771 4791 3300 3222;
    8631 2840 6783 2861 2841; 8632 6783 2880 2881 2861; 8633 2839 6782 6783 2840;
    8634 2838 2858 6782 2839; 8635 2858 2878 2879 6782; 8779 6817 6818 2815 2795;
    10317 8446 8445 6838 6837; 10318 8445 8447 6839 6838;
    10319 8447 8448 6840 6839; 10320 8448 8449 6841 6840;
    10321 8449 8450 6842 6841; 10322 8450 8451 6843 6842;
    10323 8451 8452 6844 6843; 10324 8452 8453 6845 6844;
    10325 8453 8454 6846 6845; 10326 8454 8455 6847 6846;
    10327 8455 8456 6848 6847; 10328 8456 8457 6849 6848;
    10329 8457 8458 6850 6849; 10330 8458 8459 6851 6850;
    10331 8459 8460 6852 6851; 10332 8460 8461 6853 6852;
    10333 8461 8462 6854 6853; 10334 8462 8463 6855 6854;
    10335 8463 8464 6784 6855; 10336 8464 8465 6785 6784;
    10337 8465 8466 6786 6785; 10338 8466 8467 6787 6786;
    10339 8467 8468 6788 6787; 10340 8468 8469 6789 6788;
    10341 8469 8470 6790 6789; 10342 8470 8471 6791 6790;
    10343 8471 8472 6792 6791; 10344 8472 8473 6793 6792;
    10345 8473 8474 6794 6793; 10346 8474 8475 6795 6794;
    10347 8475 8476 6796 6795; 10348 8476 8477 6797 6796;
    10349 8477 8478 6798 6797; 10350 8478 8479 6799 6798;
    10351 8479 8480 6800 6799; 10352 8480 8481 6801 6800;
    10353 8481 8482 6802 6801; 10354 8482 8483 6803 6802;
    10355 8483 8484 6804 6803; 10356 8484 8485 6805 6804;
    10357 8485 8486 6806 6805; 10358 8486 8487 6807 6806;
    10359 8487 8488 6808 6807; 10360 8488 8489 6809 6808;
    10361 8489 8490 6810 6809; 10362 8490 8491 6811 6810;
    10363 8491 8492 6812 6811; 10364 8492 8493 6813 6812;
    10365 8493 8494 6928 6813; 10366 8494 8495 6929 6928;
    10367 8495 8496 6816 6929; 10368 8496 8497 6817 6816;
    10369 8497 8498 6818 6817; 10370 8498 8499 6819 6818;
    10371 8499 8500 6820 6819; 10372 8500 8501 6821 6820;
    10373 8501 8502 6822 6821; 10374 8502 8503 6823 6822;
    10375 8503 8504 6824 6823; 10376 8504 8505 6825 6824;
    10377 8505 8506 6826 6825; 10378 8506 8507 6827 6826;
    10379 8507 8508 6828 6827; 10380 8508 8509 6829 6828;
    10381 8509 8510 6830 6829; 10382 8510 8511 6831 6830;
    10383 8511 8512 6832 6831; 10384 8512 8513 6833 6832;
    10385 8513 8514 6834 6833; 10386 8514 8515 6835 6834;
    10387 8515 8516 6836 6835; 10388 8516 8446 6837 6836;
    10531 8446 8516 8090 6936; 10533 6818 6819 2835 2815;
    10534 6819 6820 2855 2835; 10535 6820 6821 2875 2855;
    10536 6821 6822 2895 2875; 10537 6822 6823 2915 2895;
    10538 6823 6824 2935 2915; 10539 6824 6825 2955 2935;
    10540 6825 6826 2975 2955; 10541 6826 6827 2995 2975;
    10542 6827 6828 3015 2995; 10543 6828 6829 3035 3015;
    10544 6829 6830 3055 3035; 10545 6830 6831 3075 3055;
    10546 6831 6832 3095 3075; 10547 6832 6833 3115 3095;
    10548 6833 6834 3135 3115; 10549 6834 6835 3155 3135;
    10550 6835 6836 3175 3155; 10551 6836 6837 1775 3175;
    10552 6837 6838 1774 1775; 10553 6838 6839 1776 1774;
    10554 6839 6840 1815 1776; 10555 6840 6841 1835 1815;
    10556 6841 6842 1855 1835; 10557 6842 6843 1875 1855;
    10558 6843 6844 1895 1875; 10559 6844 6845 1915 1895;
    10560 6845 6846 1935 1915; 10561 6846 6847 1955 1935;
    10562 6847 6848 1975 1955; 10563 6848 6849 1995 1975;
    10564 6849 6850 2015 1995; 10565 6850 6851 2035 2015;
    10566 6851 6852 2055 2035; 10567 6852 6853 2075 2055;
    10568 6853 6854 2095 2075; 10569 6854 6855 2115 2095;
    10570 6855 6784 2135 2115; 10571 6784 6785 2155 2135;
    10572 6785 6786 2175 2155; 10573 6786 6787 2195 2175;
    10574 6787 6788 2215 2195; 10575 6788 6789 2235 2215;
    10576 6789 6790 2255 2235; 10577 6790 6791 2275 2255;
    10578 6791 6792 2295 2275; 10579 6792 6793 2315 2295;
    10580 6793 6794 2335 2315; 10581 6794 6795 2355 2335;
    10582 6795 6796 2375 2355; 10583 6796 6797 2395 2375;
    10584 6797 6798 2415 2395; 10585 6798 6799 2435 2415;
    10586 6799 6800 2455 2435; 10587 6800 6801 2475 2455;
    10588 6801 6802 2495 2475; 10589 6802 6803 2515 2495;
    10590 6803 6804 2535 2515; 10591 6804 6805 2555 2535;
    10592 6805 6806 2575 2555; 10593 6806 6807 2595 2575;
    10594 6807 6808 2615 2595; 10595 6808 6809 2635 2615;
    10596 6809 6810 2655 2635; 10597 6810 6811 2675 2655;
    10598 6811 6812 2695 2675; 10599 6812 6813 2715 2695;
    10600 6813 6928 2735 2715; 10601 6928 6929 2755 2735;
    10602 6929 6816 2775 2755; 10603 6816 6817 2795 2775;
    10650 8553 8554 8446 8445; 10651 8556 8555 8554 8553;
    10652 8557 8558 8555 8556; 10653 8560 8559 8558 8557;
    10654 8561 8562 8559 8560; 10655 8535 8536 8562 8561;
    10657 8538 8537 8536 8535; 10658 8539 8540 8537 8538;
    10659 8542 8541 8540 8539; 10660 8543 8544 8541 8542;
    10661 8546 8545 8544 8543; 10662 8547 8548 8545 8546;
    10663 8550 8549 8548 8547; 10664 8551 8552 8549 8550;
    10665 8533 8532 8552 8551; 10666 8521 8520 8519 8518;
    10667 8522 8523 8520 8521; 10668 8525 8524 8523 8522;
    10669 8526 8527 8524 8525; 10670 8529 8528 8527 8526;
    10671 8530 8531 8528 8529; 10672 8517 8531 8530; 10673 8519 8532 8518;
    10674 8518 8532 8533; 10675 8519 8534 8532; 10676 8573 8553 8445 8447;
    10677 8574 8556 8553 8573; 10678 8575 8557 8556 8574;
    10679 8576 8560 8557 8575; 10680 8577 8561 8560 8576;
    10681 8564 8535 8561 8577; 10682 8565 8538 8535 8564;
    10683 8566 8539 8538 8565; 10684 8567 8542 8539 8566;
    10685 8568 8543 8542 8567; 10686 8569 8546 8543 8568;
    10687 8570 8547 8546 8569; 10688 8571 8550 8547 8570;
    10689 8572 8551 8550 8571; 10690 8563 8533 8551 8572;
    10691 8588 8573 8447 8448; 10692 8589 8574 8573 8588;
    10693 8590 8575 8574 8589; 10694 8591 8576 8575 8590;
    10695 8592 8577 8576 8591; 10696 8579 8564 8577 8592;
    10697 8580 8565 8564 8579; 10698 8581 8566 8565 8580;
    10699 8582 8567 8566 8581; 10700 8583 8568 8567 8582;
    10701 8584 8569 8568 8583; 10702 8585 8570 8569 8584;
    10703 8586 8571 8570 8585; 10704 8587 8572 8571 8586;
    10705 8578 8563 8572 8587; 10706 8603 8588 8448 8449;
    10707 8604 8589 8588 8603; 10708 8605 8590 8589 8604;
    10709 8606 8591 8590 8605; 10710 8607 8592 8591 8606;
    10711 8594 8579 8592 8607; 10712 8595 8580 8579 8594;
    10713 8596 8581 8580 8595; 10714 8597 8582 8581 8596;
    10715 8598 8583 8582 8597; 10716 8599 8584 8583 8598;
    10717 8600 8585 8584 8599; 10718 8601 8586 8585 8600;
    10719 8602 8587 8586 8601; 10720 8593 8578 8587 8602;
    10721 8618 8603 8449 8450; 10722 8619 8604 8603 8618;
    10723 8620 8605 8604 8619; 10724 8621 8606 8605 8620;
    10725 8622 8607 8606 8621; 10726 8609 8594 8607 8622;
    10727 8610 8595 8594 8609; 10728 8611 8596 8595 8610;
    10729 8612 8597 8596 8611; 10730 8613 8598 8597 8612;
    10731 8614 8599 8598 8613; 10732 8615 8600 8599 8614;
    10733 8616 8601 8600 8615; 10734 8617 8602 8601 8616;
    10735 8608 8593 8602 8617; 10736 8633 8618 8450 8451;
    10737 8634 8619 8618 8633; 10738 8635 8620 8619 8634;
    10739 8636 8621 8620 8635; 10740 8637 8622 8621 8636;
    10741 8624 8609 8622 8637; 10742 8625 8610 8609 8624;
    10743 8626 8611 8610 8625; 10744 8627 8612 8611 8626;
    10745 8628 8613 8612 8627; 10746 8629 8614 8613 8628;
    10747 8630 8615 8614 8629; 10748 8631 8616 8615 8630;
    10749 8632 8617 8616 8631; 10750 8623 8608 8617 8632;
    10751 8648 8633 8451 8452; 10752 8649 8634 8633 8648;
    10753 8650 8635 8634 8649; 10754 8651 8636 8635 8650;
    10755 8652 8637 8636 8651; 10756 8639 8624 8637 8652;
    10757 8640 8625 8624 8639; 10758 8641 8626 8625 8640;
    10759 8642 8627 8626 8641; 10760 8643 8628 8627 8642;
    10761 8644 8629 8628 8643; 10762 8645 8630 8629 8644;
    10763 8646 8631 8630 8645; 10764 8647 8632 8631 8646;
    10765 8638 8623 8632 8647; 10766 8663 8648 8452 8453;
    10767 8664 8649 8648 8663; 10768 8665 8650 8649 8664;
    10769 8666 8651 8650 8665; 10770 8667 8652 8651 8666;
    10771 8654 8639 8652 8667; 10772 8655 8640 8639 8654;
    10773 8656 8641 8640 8655; 10774 8657 8642 8641 8656;
    10775 8658 8643 8642 8657; 10776 8659 8644 8643 8658;
    10777 8660 8645 8644 8659; 10778 8661 8646 8645 8660;
    10779 8662 8647 8646 8661; 10780 8653 8638 8647 8662;
    10781 8678 8663 8453 8454; 10782 8679 8664 8663 8678;
    10783 8680 8665 8664 8679; 10784 8681 8666 8665 8680;
    10785 8682 8667 8666 8681; 10786 8669 8654 8667 8682;
    10787 8670 8655 8654 8669; 10788 8671 8656 8655 8670;
    10789 8672 8657 8656 8671; 10790 8673 8658 8657 8672;
    10791 8674 8659 8658 8673; 10792 8675 8660 8659 8674;
    10793 8676 8661 8660 8675; 10794 8677 8662 8661 8676;
    10795 8668 8653 8662 8677; 10796 8693 8678 8454 8455;
    10797 8694 8679 8678 8693; 10798 8695 8680 8679 8694;
    10799 8696 8681 8680 8695; 10800 8697 8682 8681 8696;
    10801 8684 8669 8682 8697; 10802 8685 8670 8669 8684;
    10803 8686 8671 8670 8685; 10804 8687 8672 8671 8686;
    10805 8688 8673 8672 8687; 10806 8689 8674 8673 8688;
    10807 8690 8675 8674 8689; 10808 8691 8676 8675 8690;
    10809 8692 8677 8676 8691; 10810 8683 8668 8677 8692;
    10811 8708 8693 8455 8456; 10812 8709 8694 8693 8708;
    10813 8710 8695 8694 8709; 10814 8711 8696 8695 8710;
    10815 8712 8697 8696 8711; 10816 8699 8684 8697 8712;
    10817 8700 8685 8684 8699; 10818 8701 8686 8685 8700;
    10819 8702 8687 8686 8701; 10820 8703 8688 8687 8702;
    10821 8704 8689 8688 8703; 10822 8705 8690 8689 8704;
    10823 8706 8691 8690 8705; 10824 8707 8692 8691 8706;
    10825 8698 8683 8692 8707; 10826 8723 8708 8456 8457;
    10827 8724 8709 8708 8723; 10828 8725 8710 8709 8724;
    10829 8726 8711 8710 8725; 10830 8727 8712 8711 8726;
    10831 8714 8699 8712 8727; 10832 8715 8700 8699 8714;
    10833 8716 8701 8700 8715; 10834 8717 8702 8701 8716;
    10835 8718 8703 8702 8717; 10836 8719 8704 8703 8718;
    10837 8720 8705 8704 8719; 10838 8721 8706 8705 8720;
    10839 8722 8707 8706 8721; 10840 8713 8698 8707 8722;
    10841 8738 8723 8457 8458; 10842 8739 8724 8723 8738;
    10843 8740 8725 8724 8739; 10844 8741 8726 8725 8740;
    10845 8742 8727 8726 8741; 10846 8729 8714 8727 8742;
    10847 8730 8715 8714 8729; 10848 8731 8716 8715 8730;
    10849 8732 8717 8716 8731; 10850 8733 8718 8717 8732;
    10851 8734 8719 8718 8733; 10852 8735 8720 8719 8734;
    10853 8736 8721 8720 8735; 10854 8737 8722 8721 8736;
    10855 8728 8713 8722 8737; 10856 8753 8738 8458 8459;
    10857 8754 8739 8738 8753; 10858 8755 8740 8739 8754;
    10859 8756 8741 8740 8755; 10860 8757 8742 8741 8756;
    10861 8744 8729 8742 8757; 10862 8745 8730 8729 8744;
    10863 8746 8731 8730 8745; 10864 8747 8732 8731 8746;
    10865 8748 8733 8732 8747; 10866 8749 8734 8733 8748;
    10867 8750 8735 8734 8749; 10868 8751 8736 8735 8750;
    10869 8752 8737 8736 8751; 10870 8743 8728 8737 8752;
    10871 8768 8753 8459 8460; 10872 8769 8754 8753 8768;
    10873 8770 8755 8754 8769; 10874 8771 8756 8755 8770;
    10875 8772 8757 8756 8771; 10876 8759 8744 8757 8772;
    10877 8760 8745 8744 8759; 10878 8761 8746 8745 8760;
    10879 8762 8747 8746 8761; 10880 8763 8748 8747 8762;
    10881 8764 8749 8748 8763; 10882 8765 8750 8749 8764;
    10883 8766 8751 8750 8765; 10884 8767 8752 8751 8766;
    10885 8758 8743 8752 8767; 10886 8783 8768 8460 8461;
    10887 8784 8769 8768 8783; 10888 8785 8770 8769 8784;
    10889 8786 8771 8770 8785; 10890 8787 8772 8771 8786;
    10891 8774 8759 8772 8787; 10892 8775 8760 8759 8774;
    10893 8776 8761 8760 8775; 10894 8777 8762 8761 8776;
    10895 8778 8763 8762 8777; 10896 8779 8764 8763 8778;
    10897 8780 8765 8764 8779; 10898 8781 8766 8765 8780;
    10899 8782 8767 8766 8781; 10900 8773 8758 8767 8782;
    10901 8798 8783 8461 8462; 10902 8799 8784 8783 8798;
    10903 8800 8785 8784 8799; 10904 8801 8786 8785 8800;
    10905 8802 8787 8786 8801; 10906 8789 8774 8787 8802;
    10907 8790 8775 8774 8789; 10908 8791 8776 8775 8790;
    10909 8792 8777 8776 8791; 10910 8793 8778 8777 8792;
    10911 8794 8779 8778 8793; 10912 8795 8780 8779 8794;
    10913 8796 8781 8780 8795; 10914 8797 8782 8781 8796;
    10915 8788 8773 8782 8797; 10916 8813 8798 8462 8463;
    10917 8814 8799 8798 8813; 10918 8815 8800 8799 8814;
    10919 8816 8801 8800 8815; 10920 8817 8802 8801 8816;
    10921 8804 8789 8802 8817; 10922 8805 8790 8789 8804;
    10923 8806 8791 8790 8805; 10924 8807 8792 8791 8806;
    10925 8808 8793 8792 8807; 10926 8809 8794 8793 8808;
    10927 8810 8795 8794 8809; 10928 8811 8796 8795 8810;
    10929 8812 8797 8796 8811; 10930 8803 8788 8797 8812;
    10931 8828 8813 8463 8464; 10932 8829 8814 8813 8828;
    10933 8830 8815 8814 8829; 10934 8831 8816 8815 8830;
    10935 8832 8817 8816 8831; 10936 8819 8804 8817 8832;
    10937 8820 8805 8804 8819; 10938 8821 8806 8805 8820;
    10939 8822 8807 8806 8821; 10940 8823 8808 8807 8822;
    10941 8824 8809 8808 8823; 10942 8825 8810 8809 8824;
    10943 8826 8811 8810 8825; 10944 8827 8812 8811 8826;
    10945 8818 8803 8812 8827; 10946 8843 8828 8464 8465;
    10947 8844 8829 8828 8843; 10948 8845 8830 8829 8844;
    10949 8846 8831 8830 8845; 10950 8847 8832 8831 8846;
    10951 8834 8819 8832 8847; 10952 8835 8820 8819 8834;
    10953 8836 8821 8820 8835; 10954 8837 8822 8821 8836;
    10955 8838 8823 8822 8837; 10956 8839 8824 8823 8838;
    10957 8840 8825 8824 8839; 10958 8841 8826 8825 8840;
    10959 8842 8827 8826 8841; 10960 8833 8818 8827 8842;
    10961 8858 8843 8465 8466; 10962 8859 8844 8843 8858;
    10963 8860 8845 8844 8859; 10964 8861 8846 8845 8860;
    10965 8862 8847 8846 8861; 10966 8849 8834 8847 8862;
    10967 8850 8835 8834 8849; 10968 8851 8836 8835 8850;
    10969 8852 8837 8836 8851; 10970 8853 8838 8837 8852;
    10971 8854 8839 8838 8853; 10972 8855 8840 8839 8854;
    10973 8856 8841 8840 8855; 10974 8857 8842 8841 8856;
    10975 8848 8833 8842 8857; 10976 8873 8858 8466 8467;
    10977 8874 8859 8858 8873; 10978 8875 8860 8859 8874;
    10979 8876 8861 8860 8875; 10980 8877 8862 8861 8876;
    10981 8864 8849 8862 8877; 10982 8865 8850 8849 8864;
    10983 8866 8851 8850 8865; 10984 8867 8852 8851 8866;
    10985 8868 8853 8852 8867; 10986 8869 8854 8853 8868;
    10987 8870 8855 8854 8869; 10988 8871 8856 8855 8870;
    10989 8872 8857 8856 8871; 10990 8863 8848 8857 8872;
    10991 8888 8873 8467 8468; 10992 8889 8874 8873 8888;
    10993 8890 8875 8874 8889; 10994 8891 8876 8875 8890;
    10995 8892 8877 8876 8891; 10996 8879 8864 8877 8892;
    10997 8880 8865 8864 8879; 10998 8881 8866 8865 8880;
    10999 8882 8867 8866 8881; 11000 8883 8868 8867 8882;
    11001 8884 8869 8868 8883; 11002 8885 8870 8869 8884;
    11003 8886 8871 8870 8885; 11004 8887 8872 8871 8886;
    11005 8878 8863 8872 8887; 11006 8903 8888 8468 8469;
    11007 8904 8889 8888 8903; 11008 8905 8890 8889 8904;
    11009 8906 8891 8890 8905; 11010 8907 8892 8891 8906;
    11011 8894 8879 8892 8907; 11012 8895 8880 8879 8894;
    11013 8896 8881 8880 8895; 11014 8897 8882 8881 8896;
    11015 8898 8883 8882 8897; 11016 8899 8884 8883 8898;
    11017 8900 8885 8884 8899; 11018 8901 8886 8885 8900;
    11019 8902 8887 8886 8901; 11020 8893 8878 8887 8902;
    11021 8918 8903 8469 8470; 11022 8919 8904 8903 8918;
    11023 8920 8905 8904 8919; 11024 8921 8906 8905 8920;
    11025 8922 8907 8906 8921; 11026 8909 8894 8907 8922;
    11027 8910 8895 8894 8909; 11028 8911 8896 8895 8910;
    11029 8912 8897 8896 8911; 11030 8913 8898 8897 8912;
    11031 8914 8899 8898 8913; 11032 8915 8900 8899 8914;
    11033 8916 8901 8900 8915; 11034 8917 8902 8901 8916;
    11035 8908 8893 8902 8917; 11036 8933 8918 8470 8471;
    11037 8934 8919 8918 8933; 11038 8935 8920 8919 8934;
    11039 8936 8921 8920 8935; 11040 8937 8922 8921 8936;
    11041 8924 8909 8922 8937; 11042 8925 8910 8909 8924;
    11043 8926 8911 8910 8925; 11044 8927 8912 8911 8926;
    11045 8928 8913 8912 8927; 11046 8929 8914 8913 8928;
    11047 8930 8915 8914 8929; 11048 8931 8916 8915 8930;
    11049 8932 8917 8916 8931; 11050 8923 8908 8917 8932;
    11051 8948 8933 8471 8472; 11052 8949 8934 8933 8948;
    11053 8950 8935 8934 8949; 11054 8951 8936 8935 8950;
    11055 8952 8937 8936 8951; 11056 8939 8924 8937 8952;
    11057 8940 8925 8924 8939; 11058 8941 8926 8925 8940;
    11059 8942 8927 8926 8941; 11060 8943 8928 8927 8942;
    11061 8944 8929 8928 8943; 11062 8945 8930 8929 8944;
    11063 8946 8931 8930 8945; 11064 8947 8932 8931 8946;
    11065 8938 8923 8932 8947; 11066 8963 8948 8472 8473;
    11067 8964 8949 8948 8963; 11068 8965 8950 8949 8964;
    11069 8966 8951 8950 8965; 11070 8967 8952 8951 8966;
    11071 8954 8939 8952 8967; 11072 8955 8940 8939 8954;
    11073 8956 8941 8940 8955; 11074 8957 8942 8941 8956;
    11075 8958 8943 8942 8957; 11076 8959 8944 8943 8958;
    11077 8960 8945 8944 8959; 11078 8961 8946 8945 8960;
    11079 8962 8947 8946 8961; 11080 8953 8938 8947 8962;
    11081 8978 8963 8473 8474; 11082 8979 8964 8963 8978;
    11083 8980 8965 8964 8979; 11084 8981 8966 8965 8980;
    11085 8982 8967 8966 8981; 11086 8969 8954 8967 8982;
    11087 8970 8955 8954 8969; 11088 8971 8956 8955 8970;
    11089 8972 8957 8956 8971; 11090 8973 8958 8957 8972;
    11091 8974 8959 8958 8973; 11092 8975 8960 8959 8974;
    11093 8976 8961 8960 8975; 11094 8977 8962 8961 8976;
    11095 8968 8953 8962 8977; 11096 8993 8978 8474 8475;
    11097 8994 8979 8978 8993; 11098 8995 8980 8979 8994;
    11099 8996 8981 8980 8995; 11100 8997 8982 8981 8996;
    11101 8984 8969 8982 8997; 11102 8985 8970 8969 8984;
    11103 8986 8971 8970 8985; 11104 8987 8972 8971 8986;
    11105 8988 8973 8972 8987; 11106 8989 8974 8973 8988;
    11107 8990 8975 8974 8989; 11108 8991 8976 8975 8990;
    11109 8992 8977 8976 8991; 11110 8983 8968 8977 8992;
    11111 9008 8993 8475 8476; 11112 9009 8994 8993 9008;
    11113 9010 8995 8994 9009; 11114 9011 8996 8995 9010;
    11115 9012 8997 8996 9011; 11116 8999 8984 8997 9012;
    11117 9000 8985 8984 8999; 11118 9001 8986 8985 9000;
    11119 9002 8987 8986 9001; 11120 9003 8988 8987 9002;
    11121 9004 8989 8988 9003; 11122 9005 8990 8989 9004;
    11123 9006 8991 8990 9005; 11124 9007 8992 8991 9006;
    11125 8998 8983 8992 9007; 11126 9023 9008 8476 8477;
    11127 9024 9009 9008 9023; 11128 9025 9010 9009 9024;
    11129 9026 9011 9010 9025; 11130 9027 9012 9011 9026;
    11131 9014 8999 9012 9027; 11132 9015 9000 8999 9014;
    11133 9016 9001 9000 9015; 11134 9017 9002 9001 9016;
    11135 9018 9003 9002 9017; 11136 9019 9004 9003 9018;
    11137 9020 9005 9004 9019; 11138 9021 9006 9005 9020;
    11139 9022 9007 9006 9021; 11140 9013 8998 9007 9022;
    11141 9038 9023 8477 8478; 11142 9039 9024 9023 9038;
    11143 9040 9025 9024 9039; 11144 9041 9026 9025 9040;
    11145 9042 9027 9026 9041; 11146 9029 9014 9027 9042;
    11147 9030 9015 9014 9029; 11148 9031 9016 9015 9030;
    11149 9032 9017 9016 9031; 11150 9033 9018 9017 9032;
    11151 9034 9019 9018 9033; 11152 9035 9020 9019 9034;
    11153 9036 9021 9020 9035; 11154 9037 9022 9021 9036;
    11155 9028 9013 9022 9037; 11156 9053 9038 8478 8479;
    11157 9054 9039 9038 9053; 11158 9055 9040 9039 9054;
    11159 9056 9041 9040 9055; 11160 9057 9042 9041 9056;
    11161 9044 9029 9042 9057; 11162 9045 9030 9029 9044;
    11163 9046 9031 9030 9045; 11164 9047 9032 9031 9046;
    11165 9048 9033 9032 9047; 11166 9049 9034 9033 9048;
    11167 9050 9035 9034 9049; 11168 9051 9036 9035 9050;
    11169 9052 9037 9036 9051; 11170 9043 9028 9037 9052;
    11171 9068 9053 8479 8480; 11172 9069 9054 9053 9068;
    11173 9070 9055 9054 9069; 11174 9071 9056 9055 9070;
    11175 9072 9057 9056 9071; 11176 9059 9044 9057 9072;
    11177 9060 9045 9044 9059; 11178 9061 9046 9045 9060;
    11179 9062 9047 9046 9061; 11180 9063 9048 9047 9062;
    11181 9064 9049 9048 9063; 11182 9065 9050 9049 9064;
    11183 9066 9051 9050 9065; 11184 9067 9052 9051 9066;
    11185 9058 9043 9052 9067; 11186 9083 9068 8480 8481;
    11187 9084 9069 9068 9083; 11188 9085 9070 9069 9084;
    11189 9086 9071 9070 9085; 11190 9087 9072 9071 9086;
    11191 9074 9059 9072 9087; 11192 9075 9060 9059 9074;
    11193 9076 9061 9060 9075; 11194 9077 9062 9061 9076;
    11195 9078 9063 9062 9077; 11196 9079 9064 9063 9078;
    11197 9080 9065 9064 9079; 11198 9081 9066 9065 9080;
    11199 9082 9067 9066 9081; 11200 9073 9058 9067 9082;
    11201 9098 9083 8481 8482; 11202 9099 9084 9083 9098;
    11203 9100 9085 9084 9099; 11204 9101 9086 9085 9100;
    11205 9102 9087 9086 9101; 11206 9089 9074 9087 9102;
    11207 9090 9075 9074 9089; 11208 9091 9076 9075 9090;
    11209 9092 9077 9076 9091; 11210 9093 9078 9077 9092;
    11211 9094 9079 9078 9093; 11212 9095 9080 9079 9094;
    11213 9096 9081 9080 9095; 11214 9097 9082 9081 9096;
    11215 9088 9073 9082 9097; 11216 9113 9098 8482 8483;
    11217 9114 9099 9098 9113; 11218 9115 9100 9099 9114;
    11219 9116 9101 9100 9115; 11220 9117 9102 9101 9116;
    11221 9104 9089 9102 9117; 11222 9105 9090 9089 9104;
    11223 9106 9091 9090 9105; 11224 9107 9092 9091 9106;
    11225 9108 9093 9092 9107; 11226 9109 9094 9093 9108;
    11227 9110 9095 9094 9109; 11228 9111 9096 9095 9110;
    11229 9112 9097 9096 9111; 11230 9103 9088 9097 9112;
    11231 9128 9113 8483 8484; 11232 9129 9114 9113 9128;
    11233 9130 9115 9114 9129; 11234 9131 9116 9115 9130;
    11235 9132 9117 9116 9131; 11236 9119 9104 9117 9132;
    11237 9120 9105 9104 9119; 11238 9121 9106 9105 9120;
    11239 9122 9107 9106 9121; 11240 9123 9108 9107 9122;
    11241 9124 9109 9108 9123; 11242 9125 9110 9109 9124;
    11243 9126 9111 9110 9125; 11244 9127 9112 9111 9126;
    11245 9118 9103 9112 9127; 11246 9143 9128 8484 8485;
    11247 9144 9129 9128 9143; 11248 9145 9130 9129 9144;
    11249 9146 9131 9130 9145; 11250 9147 9132 9131 9146;
    11251 9134 9119 9132 9147; 11252 9135 9120 9119 9134;
    11253 9136 9121 9120 9135; 11254 9137 9122 9121 9136;
    11255 9138 9123 9122 9137; 11256 9139 9124 9123 9138;
    11257 9140 9125 9124 9139; 11258 9141 9126 9125 9140;
    11259 9142 9127 9126 9141; 11260 9133 9118 9127 9142;
    11261 9158 9143 8485 8486; 11262 9159 9144 9143 9158;
    11263 9160 9145 9144 9159; 11264 9161 9146 9145 9160;
    11265 9162 9147 9146 9161; 11266 9149 9134 9147 9162;
    11267 9150 9135 9134 9149; 11268 9151 9136 9135 9150;
    11269 9152 9137 9136 9151; 11270 9153 9138 9137 9152;
    11271 9154 9139 9138 9153; 11272 9155 9140 9139 9154;
    11273 9156 9141 9140 9155; 11274 9157 9142 9141 9156;
    11275 9148 9133 9142 9157; 11276 9173 9158 8486 8487;
    11277 9174 9159 9158 9173; 11278 9175 9160 9159 9174;
    11279 9176 9161 9160 9175; 11280 9177 9162 9161 9176;
    11281 9164 9149 9162 9177; 11282 9165 9150 9149 9164;
    11283 9166 9151 9150 9165; 11284 9167 9152 9151 9166;
    11285 9168 9153 9152 9167; 11286 9169 9154 9153 9168;
    11287 9170 9155 9154 9169; 11288 9171 9156 9155 9170;
    11289 9172 9157 9156 9171; 11290 9163 9148 9157 9172;
    11291 9188 9173 8487 8488; 11292 9189 9174 9173 9188;
    11293 9190 9175 9174 9189; 11294 9191 9176 9175 9190;
    11295 9192 9177 9176 9191; 11296 9179 9164 9177 9192;
    11297 9180 9165 9164 9179; 11298 9181 9166 9165 9180;
    11299 9182 9167 9166 9181; 11300 9183 9168 9167 9182;
    11301 9184 9169 9168 9183; 11302 9185 9170 9169 9184;
    11303 9186 9171 9170 9185; 11304 9187 9172 9171 9186;
    11305 9178 9163 9172 9187; 11306 9203 9188 8488 8489;
    11307 9204 9189 9188 9203; 11308 9205 9190 9189 9204;
    11309 9206 9191 9190 9205; 11310 9207 9192 9191 9206;
    11311 9194 9179 9192 9207; 11312 9195 9180 9179 9194;
    11313 9196 9181 9180 9195; 11314 9197 9182 9181 9196;
    11315 9198 9183 9182 9197; 11316 9199 9184 9183 9198;
    11317 9200 9185 9184 9199; 11318 9201 9186 9185 9200;
    11319 9202 9187 9186 9201; 11320 9193 9178 9187 9202;
    11321 9218 9203 8489 8490; 11322 9219 9204 9203 9218;
    11323 9220 9205 9204 9219; 11324 9221 9206 9205 9220;
    11325 9222 9207 9206 9221; 11326 9209 9194 9207 9222;
    11327 9210 9195 9194 9209; 11328 9211 9196 9195 9210;
    11329 9212 9197 9196 9211; 11330 9213 9198 9197 9212;
    11331 9214 9199 9198 9213; 11332 9215 9200 9199 9214;
    11333 9216 9201 9200 9215; 11334 9217 9202 9201 9216;
    11335 9208 9193 9202 9217; 11336 9233 9218 8490 8491;
    11337 9234 9219 9218 9233; 11338 9235 9220 9219 9234;
    11339 9236 9221 9220 9235; 11340 9237 9222 9221 9236;
    11341 9224 9209 9222 9237; 11342 9225 9210 9209 9224;
    11343 9226 9211 9210 9225; 11344 9227 9212 9211 9226;
    11345 9228 9213 9212 9227; 11346 9229 9214 9213 9228;
    11347 9230 9215 9214 9229; 11348 9231 9216 9215 9230;
    11349 9232 9217 9216 9231; 11350 9223 9208 9217 9232;
    11351 9248 9233 8491 8492; 11352 9249 9234 9233 9248;
    11353 9250 9235 9234 9249; 11354 9251 9236 9235 9250;
    11355 9252 9237 9236 9251; 11356 9239 9224 9237 9252;
    11357 9240 9225 9224 9239; 11358 9241 9226 9225 9240;
    11359 9242 9227 9226 9241; 11360 9243 9228 9227 9242;
    11361 9244 9229 9228 9243; 11362 9245 9230 9229 9244;
    11363 9246 9231 9230 9245; 11364 9247 9232 9231 9246;
    11365 9238 9223 9232 9247; 11366 9263 9248 8492 8493;
    11367 9264 9249 9248 9263; 11368 9265 9250 9249 9264;
    11369 9266 9251 9250 9265; 11370 9267 9252 9251 9266;
    11371 9254 9239 9252 9267; 11372 9255 9240 9239 9254;
    11373 9256 9241 9240 9255; 11374 9257 9242 9241 9256;
    11375 9258 9243 9242 9257; 11376 9259 9244 9243 9258;
    11377 9260 9245 9244 9259; 11378 9261 9246 9245 9260;
    11379 9262 9247 9246 9261; 11380 9253 9238 9247 9262;
    11381 9278 9263 8493 8494; 11382 9279 9264 9263 9278;
    11383 9280 9265 9264 9279; 11384 9281 9266 9265 9280;
    11385 9282 9267 9266 9281; 11386 9269 9254 9267 9282;
    11387 9270 9255 9254 9269; 11388 9271 9256 9255 9270;
    11389 9272 9257 9256 9271; 11390 9273 9258 9257 9272;
    11391 9274 9259 9258 9273; 11392 9275 9260 9259 9274;
    11393 9276 9261 9260 9275; 11394 9277 9262 9261 9276;
    11395 9268 9253 9262 9277; 11396 9293 9278 8494 8495;
    11397 9294 9279 9278 9293; 11398 9295 9280 9279 9294;
    11399 9296 9281 9280 9295; 11400 9297 9282 9281 9296;
    11401 9284 9269 9282 9297; 11402 9285 9270 9269 9284;
    11403 9286 9271 9270 9285; 11404 9287 9272 9271 9286;
    11405 9288 9273 9272 9287; 11406 9289 9274 9273 9288;
    11407 9290 9275 9274 9289; 11408 9291 9276 9275 9290;
    11409 9292 9277 9276 9291; 11410 9283 9268 9277 9292;
    11411 9308 9293 8495 8496; 11412 9309 9294 9293 9308;
    11413 9310 9295 9294 9309; 11414 9311 9296 9295 9310;
    11415 9312 9297 9296 9311; 11416 9299 9284 9297 9312;
    11417 9300 9285 9284 9299; 11418 9301 9286 9285 9300;
    11419 9302 9287 9286 9301; 11420 9303 9288 9287 9302;
    11421 9304 9289 9288 9303; 11422 9305 9290 9289 9304;
    11423 9306 9291 9290 9305; 11424 9307 9292 9291 9306;
    11425 9298 9283 9292 9307; 11426 9323 9308 8496 8497;
    11427 9324 9309 9308 9323; 11428 9325 9310 9309 9324;
    11429 9326 9311 9310 9325; 11430 9327 9312 9311 9326;
    11431 9314 9299 9312 9327; 11432 9315 9300 9299 9314;
    11433 9316 9301 9300 9315; 11434 9317 9302 9301 9316;
    11435 9318 9303 9302 9317; 11436 9319 9304 9303 9318;
    11437 9320 9305 9304 9319; 11438 9321 9306 9305 9320;
    11439 9322 9307 9306 9321; 11440 9313 9298 9307 9322;
    11441 9338 9323 8497 8498; 11442 9339 9324 9323 9338;
    11443 9340 9325 9324 9339; 11444 9341 9326 9325 9340;
    11445 9342 9327 9326 9341; 11446 9329 9314 9327 9342;
    11447 9330 9315 9314 9329; 11448 9331 9316 9315 9330;
    11449 9332 9317 9316 9331; 11450 9333 9318 9317 9332;
    11451 9334 9319 9318 9333; 11452 9335 9320 9319 9334;
    11453 9336 9321 9320 9335; 11454 9337 9322 9321 9336;
    11455 9328 9313 9322 9337; 11456 9353 9338 8498 8499;
    11457 9354 9339 9338 9353; 11458 9355 9340 9339 9354;
    11459 9356 9341 9340 9355; 11460 9357 9342 9341 9356;
    11461 9344 9329 9342 9357; 11462 9345 9330 9329 9344;
    11463 9346 9331 9330 9345; 11464 9347 9332 9331 9346;
    11465 9348 9333 9332 9347; 11466 9349 9334 9333 9348;
    11467 9350 9335 9334 9349; 11468 9351 9336 9335 9350;
    11469 9352 9337 9336 9351; 11470 9343 9328 9337 9352;
    11471 9368 9353 8499 8500; 11472 9369 9354 9353 9368;
    11473 9370 9355 9354 9369; 11474 9371 9356 9355 9370;
    11475 9372 9357 9356 9371; 11476 9359 9344 9357 9372;
    11477 9360 9345 9344 9359; 11478 9361 9346 9345 9360;
    11479 9362 9347 9346 9361; 11480 9363 9348 9347 9362;
    11481 9364 9349 9348 9363; 11482 9365 9350 9349 9364;
    11483 9366 9351 9350 9365; 11484 9367 9352 9351 9366;
    11485 9358 9343 9352 9367; 11486 9383 9368 8500 8501;
    11487 9384 9369 9368 9383; 11488 9385 9370 9369 9384;
    11489 9386 9371 9370 9385; 11490 9387 9372 9371 9386;
    11491 9374 9359 9372 9387; 11492 9375 9360 9359 9374;
    11493 9376 9361 9360 9375; 11494 9377 9362 9361 9376;
    11495 9378 9363 9362 9377; 11496 9379 9364 9363 9378;
    11497 9380 9365 9364 9379; 11498 9381 9366 9365 9380;
    11499 9382 9367 9366 9381; 11500 9373 9358 9367 9382;
    11501 9398 9383 8501 8502; 11502 9399 9384 9383 9398;
    11503 9400 9385 9384 9399; 11504 9401 9386 9385 9400;
    11505 9402 9387 9386 9401; 11506 9389 9374 9387 9402;
    11507 9390 9375 9374 9389; 11508 9391 9376 9375 9390;
    11509 9392 9377 9376 9391; 11510 9393 9378 9377 9392;
    11511 9394 9379 9378 9393; 11512 9395 9380 9379 9394;
    11513 9396 9381 9380 9395; 11514 9397 9382 9381 9396;
    11515 9388 9373 9382 9397; 11516 9413 9398 8502 8503;
    11517 9414 9399 9398 9413; 11518 9415 9400 9399 9414;
    11519 9416 9401 9400 9415; 11520 9417 9402 9401 9416;
    11521 9404 9389 9402 9417; 11522 9405 9390 9389 9404;
    11523 9406 9391 9390 9405; 11524 9407 9392 9391 9406;
    11525 9408 9393 9392 9407; 11526 9409 9394 9393 9408;
    11527 9410 9395 9394 9409; 11528 9411 9396 9395 9410;
    11529 9412 9397 9396 9411; 11530 9403 9388 9397 9412;
    11531 9428 9413 8503 8504; 11532 9429 9414 9413 9428;
    11533 9430 9415 9414 9429; 11534 9431 9416 9415 9430;
    11535 9432 9417 9416 9431; 11536 9419 9404 9417 9432;
    11537 9420 9405 9404 9419; 11538 9421 9406 9405 9420;
    11539 9422 9407 9406 9421; 11540 9423 9408 9407 9422;
    11541 9424 9409 9408 9423; 11542 9425 9410 9409 9424;
    11543 9426 9411 9410 9425; 11544 9427 9412 9411 9426;
    11545 9418 9403 9412 9427; 11546 9443 9428 8504 8505;
    11547 9444 9429 9428 9443; 11548 9445 9430 9429 9444;
    11549 9446 9431 9430 9445; 11550 9447 9432 9431 9446;
    11551 9434 9419 9432 9447; 11552 9435 9420 9419 9434;
    11553 9436 9421 9420 9435; 11554 9437 9422 9421 9436;
    11555 9438 9423 9422 9437; 11556 9439 9424 9423 9438;
    11557 9440 9425 9424 9439; 11558 9441 9426 9425 9440;
    11559 9442 9427 9426 9441; 11560 9433 9418 9427 9442;
    11561 9458 9443 8505 8506; 11562 9459 9444 9443 9458;
    11563 9460 9445 9444 9459; 11564 9461 9446 9445 9460;
    11565 9462 9447 9446 9461; 11566 9449 9434 9447 9462;
    11567 9450 9435 9434 9449; 11568 9451 9436 9435 9450;
    11569 9452 9437 9436 9451; 11570 9453 9438 9437 9452;
    11571 9454 9439 9438 9453; 11572 9455 9440 9439 9454;
    11573 9456 9441 9440 9455; 11574 9457 9442 9441 9456;
    11575 9448 9433 9442 9457; 11576 9473 9458 8506 8507;
    11577 9474 9459 9458 9473; 11578 9475 9460 9459 9474;
    11579 9476 9461 9460 9475; 11580 9477 9462 9461 9476;
    11581 9464 9449 9462 9477; 11582 9465 9450 9449 9464;
    11583 9466 9451 9450 9465; 11584 9467 9452 9451 9466;
    11585 9468 9453 9452 9467; 11586 9469 9454 9453 9468;
    11587 9470 9455 9454 9469; 11588 9471 9456 9455 9470;
    11589 9472 9457 9456 9471; 11590 9463 9448 9457 9472;
    11591 9488 9473 8507 8508; 11592 9489 9474 9473 9488;
    11593 9490 9475 9474 9489; 11594 9491 9476 9475 9490;
    11595 9492 9477 9476 9491; 11596 9479 9464 9477 9492;
    11597 9480 9465 9464 9479; 11598 9481 9466 9465 9480;
    11599 9482 9467 9466 9481; 11600 9483 9468 9467 9482;
    11601 9484 9469 9468 9483; 11602 9485 9470 9469 9484;
    11603 9486 9471 9470 9485; 11604 9487 9472 9471 9486;
    11605 9478 9463 9472 9487; 11606 9503 9488 8508 8509;
    11607 9504 9489 9488 9503; 11608 9505 9490 9489 9504;
    11609 9506 9491 9490 9505; 11610 9507 9492 9491 9506;
    11611 9494 9479 9492 9507; 11612 9495 9480 9479 9494;
    11613 9496 9481 9480 9495; 11614 9497 9482 9481 9496;
    11615 9498 9483 9482 9497; 11616 9499 9484 9483 9498;
    11617 9500 9485 9484 9499; 11618 9501 9486 9485 9500;
    11619 9502 9487 9486 9501; 11620 9493 9478 9487 9502;
    11621 9518 9503 8509 8510; 11622 9519 9504 9503 9518;
    11623 9520 9505 9504 9519; 11624 9521 9506 9505 9520;
    11625 9522 9507 9506 9521; 11626 9509 9494 9507 9522;
    11627 9510 9495 9494 9509; 11628 9511 9496 9495 9510;
    11629 9512 9497 9496 9511; 11630 9513 9498 9497 9512;
    11631 9514 9499 9498 9513; 11632 9515 9500 9499 9514;
    11633 9516 9501 9500 9515; 11634 9517 9502 9501 9516;
    11635 9508 9493 9502 9517; 11636 9533 9518 8510 8511;
    11637 9534 9519 9518 9533; 11638 9535 9520 9519 9534;
    11639 9536 9521 9520 9535; 11640 9537 9522 9521 9536;
    11641 9524 9509 9522 9537; 11642 9525 9510 9509 9524;
    11643 9526 9511 9510 9525; 11644 9527 9512 9511 9526;
    11645 9528 9513 9512 9527; 11646 9529 9514 9513 9528;
    11647 9530 9515 9514 9529; 11648 9531 9516 9515 9530;
    11649 9532 9517 9516 9531; 11650 9523 9508 9517 9532;
    11651 9548 9533 8511 8512; 11652 9549 9534 9533 9548;
    11653 9550 9535 9534 9549; 11654 9551 9536 9535 9550;
    11655 9552 9537 9536 9551; 11656 9539 9524 9537 9552;
    11657 9540 9525 9524 9539; 11658 9541 9526 9525 9540;
    11659 9542 9527 9526 9541; 11660 9543 9528 9527 9542;
    11661 9544 9529 9528 9543; 11662 9545 9530 9529 9544;
    11663 9546 9531 9530 9545; 11664 9547 9532 9531 9546;
    11665 9538 9523 9532 9547; 11666 9563 9548 8512 8513;
    11667 9564 9549 9548 9563; 11668 9565 9550 9549 9564;
    11669 9566 9551 9550 9565; 11670 9567 9552 9551 9566;
    11671 9554 9539 9552 9567; 11672 9555 9540 9539 9554;
    11673 9556 9541 9540 9555; 11674 9557 9542 9541 9556;
    11675 9558 9543 9542 9557; 11676 9559 9544 9543 9558;
    11677 9560 9545 9544 9559; 11678 9561 9546 9545 9560;
    11679 9562 9547 9546 9561; 11680 9553 9538 9547 9562;
    11681 9578 9563 8513 8514; 11682 9579 9564 9563 9578;
    11683 9580 9565 9564 9579; 11684 9581 9566 9565 9580;
    11685 9582 9567 9566 9581; 11686 9569 9554 9567 9582;
    11687 9570 9555 9554 9569; 11688 9571 9556 9555 9570;
    11689 9572 9557 9556 9571; 11690 9573 9558 9557 9572;
    11691 9574 9559 9558 9573; 11692 9575 9560 9559 9574;
    11693 9576 9561 9560 9575; 11694 9577 9562 9561 9576;
    11695 9568 9553 9562 9577; 11696 9593 9578 8514 8515;
    11697 9594 9579 9578 9593; 11698 9595 9580 9579 9594;
    11699 9596 9581 9580 9595; 11700 9597 9582 9581 9596;
    11701 9584 9569 9582 9597; 11702 9585 9570 9569 9584;
    11703 9586 9571 9570 9585; 11704 9587 9572 9571 9586;
    11705 9588 9573 9572 9587; 11706 9589 9574 9573 9588;
    11707 9590 9575 9574 9589; 11708 9591 9576 9575 9590;
    11709 9592 9577 9576 9591; 11710 9583 9568 9577 9592;
    11711 9607 9593 8515 8516; 11712 9608 9594 9593 9607;
    11713 9609 9595 9594 9608; 11714 9610 9596 9595 9609;
    11715 9611 9597 9596 9610; 11716 9598 9584 9597 9611;
    11717 9599 9585 9584 9598; 11718 9600 9586 9585 9599;
    11719 9601 9587 9586 9600; 11720 9602 9588 9587 9601;
    11721 9603 9589 9588 9602; 11722 9604 9590 9589 9603;
    11723 9605 9591 9590 9604; 11724 9606 9592 9591 9605;
    11725 8534 9583 9592 9606; 11726 8554 9607 8516 8446;
    11727 8555 9608 9607 8554; 11728 8558 9609 9608 8555;
    11729 8559 9610 9609 8558; 11730 8562 9611 9610 8559;
    11731 8536 9598 9611 8562; 11732 8537 9599 9598 8536;
    11733 8540 9600 9599 8537; 11734 8541 9601 9600 8540;
    11735 8544 9602 9601 8541; 11736 8545 9603 9602 8544;
    11737 8548 9604 9603 8545; 11738 8549 9605 9604 8548;
    11739 8552 9606 9605 8549; 11740 8532 8534 9606 8552;
    11741 9613 8521 8518 9612; 11742 9614 8522 8521 9613;
    11743 9615 8525 8522 9614; 11744 9616 8526 8525 9615;
    11745 9617 8529 8526 9616; 11746 9618 8530 8529 9617; 11747 8517 8530 9618;
    11748 8518 8563 9612; 11749 9612 8563 8578; 11750 8518 8533 8563;
    11751 9620 9613 9612 9619; 11752 9621 9614 9613 9620;
    11753 9622 9615 9614 9621; 11754 9623 9616 9615 9622;
    11755 9624 9617 9616 9623; 11756 9625 9618 9617 9624; 11757 8517 9618 9625;
    11758 9612 8593 9619; 11759 9619 8593 8608; 11760 9612 8578 8593;
    11761 9627 9620 9619 9626; 11762 9628 9621 9620 9627;
    11763 9629 9622 9621 9628; 11764 9630 9623 9622 9629;
    11765 9631 9624 9623 9630; 11766 9632 9625 9624 9631; 11767 8517 9625 9632;
    11768 9619 8623 9626; 11769 9626 8623 8638; 11770 9619 8608 8623;
    11771 9634 9627 9626 9633; 11772 9635 9628 9627 9634;
    11773 9636 9629 9628 9635; 11774 9637 9630 9629 9636;
    11775 9638 9631 9630 9637; 11776 9639 9632 9631 9638; 11777 8517 9632 9639;
    11778 9626 8653 9633; 11779 9633 8653 8668; 11780 9626 8638 8653;
    11781 9641 9634 9633 9640; 11782 9642 9635 9634 9641;
    11783 9643 9636 9635 9642; 11784 9644 9637 9636 9643;
    11785 9645 9638 9637 9644; 11786 9646 9639 9638 9645; 11787 8517 9639 9646;
    11788 9633 8683 9640; 11789 9640 8683 8698; 11790 9633 8668 8683;
    11791 9648 9641 9640 9647; 11792 9649 9642 9641 9648;
    11793 9650 9643 9642 9649; 11794 9651 9644 9643 9650;
    11795 9652 9645 9644 9651; 11796 9653 9646 9645 9652; 11797 8517 9646 9653;
    11798 9640 8713 9647; 11799 9647 8713 8728; 11800 9640 8698 8713;
    11801 9655 9648 9647 9654; 11802 9656 9649 9648 9655;
    11803 9657 9650 9649 9656; 11804 9658 9651 9650 9657;
    11805 9659 9652 9651 9658; 11806 9660 9653 9652 9659; 11807 8517 9653 9660;
    11808 9647 8743 9654; 11809 9654 8743 8758; 11810 9647 8728 8743;
    11811 9662 9655 9654 9661; 11812 9663 9656 9655 9662;
    11813 9664 9657 9656 9663; 11814 9665 9658 9657 9664;
    11815 9666 9659 9658 9665; 11816 9667 9660 9659 9666; 11817 8517 9660 9667;
    11818 9654 8773 9661; 11819 9661 8773 8788; 11820 9654 8758 8773;
    11821 9669 9662 9661 9668; 11822 9670 9663 9662 9669;
    11823 9671 9664 9663 9670; 11824 9672 9665 9664 9671;
    11825 9673 9666 9665 9672; 11826 9674 9667 9666 9673; 11827 8517 9667 9674;
    11828 9661 8803 9668; 11829 9668 8803 8818; 11830 9661 8788 8803;
    11831 9676 9669 9668 9675; 11832 9677 9670 9669 9676;
    11833 9678 9671 9670 9677; 11834 9679 9672 9671 9678;
    11835 9680 9673 9672 9679; 11836 9681 9674 9673 9680; 11837 8517 9674 9681;
    11838 9668 8833 9675; 11839 9675 8833 8848; 11840 9668 8818 8833;
    11841 9683 9676 9675 9682; 11842 9684 9677 9676 9683;
    11843 9685 9678 9677 9684; 11844 9686 9679 9678 9685;
    11845 9687 9680 9679 9686; 11846 9688 9681 9680 9687; 11847 8517 9681 9688;
    11848 9675 8863 9682; 11849 9682 8863 8878; 11850 9675 8848 8863;
    11851 9690 9683 9682 9689; 11852 9691 9684 9683 9690;
    11853 9692 9685 9684 9691; 11854 9693 9686 9685 9692;
    11855 9694 9687 9686 9693; 11856 9695 9688 9687 9694; 11857 8517 9688 9695;
    11858 9682 8893 9689; 11859 9689 8893 8908; 11860 9682 8878 8893;
    11861 9697 9690 9689 9696; 11862 9698 9691 9690 9697;
    11863 9699 9692 9691 9698; 11864 9700 9693 9692 9699;
    11865 9701 9694 9693 9700; 11866 9702 9695 9694 9701; 11867 8517 9695 9702;
    11868 9689 8923 9696; 11869 9696 8923 8938; 11870 9689 8908 8923;
    11871 9704 9697 9696 9703; 11872 9705 9698 9697 9704;
    11873 9706 9699 9698 9705; 11874 9707 9700 9699 9706;
    11875 9708 9701 9700 9707; 11876 9709 9702 9701 9708; 11877 8517 9702 9709;
    11878 9696 8953 9703; 11879 9703 8953 8968; 11880 9696 8938 8953;
    11881 9711 9704 9703 9710; 11882 9712 9705 9704 9711;
    11883 9713 9706 9705 9712; 11884 9714 9707 9706 9713;
    11885 9715 9708 9707 9714; 11886 9716 9709 9708 9715; 11887 8517 9709 9716;
    11888 9703 8983 9710; 11889 9710 8983 8998; 11890 9703 8968 8983;
    11891 9718 9711 9710 9717; 11892 9719 9712 9711 9718;
    11893 9720 9713 9712 9719; 11894 9721 9714 9713 9720;
    11895 9722 9715 9714 9721; 11896 9723 9716 9715 9722; 11897 8517 9716 9723;
    11898 9710 9013 9717; 11899 9717 9013 9028; 11900 9710 8998 9013;
    11901 9725 9718 9717 9724; 11902 9726 9719 9718 9725;
    11903 9727 9720 9719 9726; 11904 9728 9721 9720 9727;
    11905 9729 9722 9721 9728; 11906 9730 9723 9722 9729; 11907 8517 9723 9730;
    11908 9717 9043 9724; 11909 9724 9043 9058; 11910 9717 9028 9043;
    11911 9732 9725 9724 9731; 11912 9733 9726 9725 9732;
    11913 9734 9727 9726 9733; 11914 9735 9728 9727 9734;
    11915 9736 9729 9728 9735; 11916 9737 9730 9729 9736; 11917 8517 9730 9737;
    11918 9724 9073 9731; 11919 9731 9073 9088; 11920 9724 9058 9073;
    11921 9739 9732 9731 9738; 11922 9740 9733 9732 9739;
    11923 9741 9734 9733 9740; 11924 9742 9735 9734 9741;
    11925 9743 9736 9735 9742; 11926 9744 9737 9736 9743; 11927 8517 9737 9744;
    11928 9731 9103 9738; 11929 9738 9103 9118; 11930 9731 9088 9103;
    11931 9746 9739 9738 9745; 11932 9747 9740 9739 9746;
    11933 9748 9741 9740 9747; 11934 9749 9742 9741 9748;
    11935 9750 9743 9742 9749; 11936 9751 9744 9743 9750; 11937 8517 9744 9751;
    11938 9738 9133 9745; 11939 9745 9133 9148; 11940 9738 9118 9133;
    11941 9753 9746 9745 9752; 11942 9754 9747 9746 9753;
    11943 9755 9748 9747 9754; 11944 9756 9749 9748 9755;
    11945 9757 9750 9749 9756; 11946 9758 9751 9750 9757; 11947 8517 9751 9758;
    11948 9745 9163 9752; 11949 9752 9163 9178; 11950 9745 9148 9163;
    11951 9760 9753 9752 9759; 11952 9761 9754 9753 9760;
    11953 9762 9755 9754 9761; 11954 9763 9756 9755 9762;
    11955 9764 9757 9756 9763; 11956 9765 9758 9757 9764; 11957 8517 9758 9765;
    11958 9752 9193 9759; 11959 9759 9193 9208; 11960 9752 9178 9193;
    11961 9767 9760 9759 9766; 11962 9768 9761 9760 9767;
    11963 9769 9762 9761 9768; 11964 9770 9763 9762 9769;
    11965 9771 9764 9763 9770; 11966 9772 9765 9764 9771; 11967 8517 9765 9772;
    11968 9759 9223 9766; 11969 9766 9223 9238; 11970 9759 9208 9223;
    11971 9774 9767 9766 9773; 11972 9775 9768 9767 9774;
    11973 9776 9769 9768 9775; 11974 9777 9770 9769 9776;
    11975 9778 9771 9770 9777; 11976 9779 9772 9771 9778; 11977 8517 9772 9779;
    11978 9766 9253 9773; 11979 9773 9253 9268; 11980 9766 9238 9253;
    11981 9781 9774 9773 9780; 11982 9782 9775 9774 9781;
    11983 9783 9776 9775 9782; 11984 9784 9777 9776 9783;
    11985 9785 9778 9777 9784; 11986 9786 9779 9778 9785; 11987 8517 9779 9786;
    11988 9773 9283 9780; 11989 9780 9283 9298; 11990 9773 9268 9283;
    11991 9788 9781 9780 9787; 11992 9789 9782 9781 9788;
    11993 9790 9783 9782 9789; 11994 9791 9784 9783 9790;
    11995 9792 9785 9784 9791; 11996 9793 9786 9785 9792; 11997 8517 9786 9793;
    11998 9780 9313 9787; 11999 9787 9313 9328; 12000 9780 9298 9313;
    12001 9795 9788 9787 9794; 12002 9796 9789 9788 9795;
    12003 9797 9790 9789 9796; 12004 9798 9791 9790 9797;
    12005 9799 9792 9791 9798; 12006 9800 9793 9792 9799; 12007 8517 9793 9800;
    12008 9787 9343 9794; 12009 9794 9343 9358; 12010 9787 9328 9343;
    12011 9802 9795 9794 9801; 12012 9803 9796 9795 9802;
    12013 9804 9797 9796 9803; 12014 9805 9798 9797 9804;
    12015 9806 9799 9798 9805; 12016 9807 9800 9799 9806; 12017 8517 9800 9807;
    12018 9794 9373 9801; 12019 9801 9373 9388; 12020 9794 9358 9373;
    12021 9809 9802 9801 9808; 12022 9810 9803 9802 9809;
    12023 9811 9804 9803 9810; 12024 9812 9805 9804 9811;
    12025 9813 9806 9805 9812; 12026 9814 9807 9806 9813; 12027 8517 9807 9814;
    12028 9801 9403 9808; 12029 9808 9403 9418; 12030 9801 9388 9403;
    12031 9816 9809 9808 9815; 12032 9817 9810 9809 9816;
    12033 9818 9811 9810 9817; 12034 9819 9812 9811 9818;
    12035 9820 9813 9812 9819; 12036 9821 9814 9813 9820; 12037 8517 9814 9821;
    12038 9808 9433 9815; 12039 9815 9433 9448; 12040 9808 9418 9433;
    12041 9823 9816 9815 9822; 12042 9824 9817 9816 9823;
    12043 9825 9818 9817 9824; 12044 9826 9819 9818 9825;
    12045 9827 9820 9819 9826; 12046 9828 9821 9820 9827; 12047 8517 9821 9828;
    12048 9815 9463 9822; 12049 9822 9463 9478; 12050 9815 9448 9463;
    12051 9830 9823 9822 9829; 12052 9831 9824 9823 9830;
    12053 9832 9825 9824 9831; 12054 9833 9826 9825 9832;
    12055 9834 9827 9826 9833; 12056 9835 9828 9827 9834; 12057 8517 9828 9835;
    12058 9822 9493 9829; 12059 9829 9493 9508; 12060 9822 9478 9493;
    12061 9837 9830 9829 9836; 12062 9838 9831 9830 9837;
    12063 9839 9832 9831 9838; 12064 9840 9833 9832 9839;
    12065 9841 9834 9833 9840; 12066 9842 9835 9834 9841; 12067 8517 9835 9842;
    12068 9829 9523 9836; 12069 9836 9523 9538; 12070 9829 9508 9523;
    12071 9844 9837 9836 9843; 12072 9845 9838 9837 9844;
    12073 9846 9839 9838 9845; 12074 9847 9840 9839 9846;
    12075 9848 9841 9840 9847; 12076 9849 9842 9841 9848; 12077 8517 9842 9849;
    12078 9836 9553 9843; 12079 9843 9553 9568; 12080 9836 9538 9553;
    12081 8520 9844 9843 8519; 12082 8523 9845 9844 8520;
    12083 8524 9846 9845 8523; 12084 8527 9847 9846 8524;
    12085 8528 9848 9847 8527; 12086 8531 9849 9848 8528; 12087 8517 9849 8531;
    12088 9843 9583 8519; 12089 8519 9583 8534; 12090 9843 9568 9583;
    12094 6934 6936 9852 9853; 12095 9853 9852 9851 9850;
    12096 6986 6934 9853 9855; 12097 9855 9853 9850 9854;
    12098 7002 6986 9855 9857; 12099 9857 9855 9854 9856;
    12100 7018 7002 9857 9859; 12101 9859 9857 9856 9858;
    12102 7034 7018 9859 9861; 12103 9861 9859 9858 9860;
    12104 7050 7034 9861 9863; 12105 9863 9861 9860 9862;
    12106 7066 7050 9863 9865; 12107 9865 9863 9862 9864;
    12108 7082 7066 9865 9867; 12109 9867 9865 9864 9866;
    12110 7098 7082 9867 9869; 12111 9869 9867 9866 9868;
    12112 7114 7098 9869 9871; 12113 9871 9869 9868 9870;
    12114 7130 7114 9871 9873; 12115 9873 9871 9870 9872;
    12116 7146 7130 9873 9875; 12117 9875 9873 9872 9874;
    12118 7162 7146 9875 9877; 12119 9877 9875 9874 9876;
    12120 7178 7162 9877 9879; 12121 9879 9877 9876 9878;
    12122 7194 7178 9879 9881; 12123 9881 9879 9878 9880;
    12124 7210 7194 9881 9883; 12125 9883 9881 9880 9882;
    12126 7226 7210 9883 9885; 12127 9885 9883 9882 9884;
    12128 7242 7226 9885 9887; 12129 9887 9885 9884 9886;
    12130 7258 7242 9887 9889; 12131 9889 9887 9886 9888;
    12132 7274 7258 9889 9891; 12133 9891 9889 9888 9890;
    12134 7290 7274 9891 9893; 12135 9893 9891 9890 9892;
    12136 7306 7290 9893 9895; 12137 9895 9893 9892 9894;
    12138 7322 7306 9895 9897; 12139 9897 9895 9894 9896;
    12140 7338 7322 9897 9899; 12141 9899 9897 9896 9898;
    12142 7354 7338 9899 9901; 12143 9901 9899 9898 9900;
    12144 7370 7354 9901 9903; 12145 9903 9901 9900 9902;
    12146 7386 7370 9903 9905; 12147 9905 9903 9902 9904;
    12148 7402 7386 9905 9907; 12149 9907 9905 9904 9906;
    12150 7418 7402 9907 9909; 12151 9909 9907 9906 9908;
    12152 7434 7418 9909 9911; 12153 9911 9909 9908 9910;
    12154 7450 7434 9911 9913; 12155 9913 9911 9910 9912;
    12156 7466 7450 9913 9915; 12157 9915 9913 9912 9914;
    12158 7482 7466 9915 9917; 12159 9917 9915 9914 9916;
    12160 7498 7482 9917 9919; 12161 9919 9917 9916 9918;
    12162 7514 7498 9919 9921; 12163 9921 9919 9918 9920;
    12164 7530 7514 9921 9923; 12165 9923 9921 9920 9922;
    12166 7546 7530 9923 9925; 12167 9925 9923 9922 9924;
    12168 7562 7546 9925 9927; 12169 9927 9925 9924 9926;
    12170 7578 7562 9927 9929; 12171 9929 9927 9926 9928;
    12172 7594 7578 9929 9931; 12173 9931 9929 9928 9930;
    12174 7610 7594 9931 9933; 12175 9933 9931 9930 9932;
    12176 7626 7610 9933 9935; 12177 9935 9933 9932 9934;
    12178 7642 7626 9935 9937; 12179 9937 9935 9934 9936;
    12180 7658 7642 9937 9939; 12181 9939 9937 9936 9938;
    12182 7674 7658 9939 9941; 12183 9941 9939 9938 9940;
    12184 7690 7674 9941 9943; 12185 9943 9941 9940 9942;
    12186 7706 7690 9943 9945; 12187 9945 9943 9942 9944;
    12188 7722 7706 9945 9947; 12189 9947 9945 9944 9946;
    12190 7738 7722 9947 9949; 12191 9949 9947 9946 9948;
    12192 7754 7738 9949 9951; 12193 9951 9949 9948 9950;
    12194 7770 7754 9951 9953; 12195 9953 9951 9950 9952;
    12196 7786 7770 9953 9955; 12197 9955 9953 9952 9954;
    12198 7802 7786 9955 9957; 12199 9957 9955 9954 9956;
    12200 7818 7802 9957 9959; 12201 9959 9957 9956 9958;
    12202 7834 7818 9959 9961; 12203 9961 9959 9958 9960;
    12204 7850 7834 9961 9963; 12205 9963 9961 9960 9962;
    12206 7866 7850 9963 9965; 12207 9965 9963 9962 9964;
    12208 7882 7866 9965 9967; 12209 9967 9965 9964 9966;
    12210 7898 7882 9967 9969; 12211 9969 9967 9966 9968;
    12212 7914 7898 9969 9971; 12213 9971 9969 9968 9970;
    12214 7930 7914 9971 9973; 12215 9973 9971 9970 9972;
    12216 7946 7930 9973 9975; 12217 9975 9973 9972 9974;
    12218 7962 7946 9975 9977; 12219 9977 9975 9974 9976;
    12220 7978 7962 9977 9979; 12221 9979 9977 9976 9978;
    12222 7994 7978 9979 9981; 12223 9981 9979 9978 9980;
    12224 8010 7994 9981 9983; 12225 9983 9981 9980 9982;
    12226 8026 8010 9983 9985; 12227 9985 9983 9982 9984;
    12228 8042 8026 9985 9987; 12229 9987 9985 9984 9986;
    12230 8058 8042 9987 9989; 12231 9989 9987 9986 9988;
    12232 8074 8058 9989 9991; 12233 9991 9989 9988 9990;
    12234 8090 8074 9991 9993; 12235 9993 9991 9990 9992;
    12236 6936 8090 9993 9852; 12237 9852 9993 9992 9851;
    12238 8445 8446 6936 6934; 12239 8447 8445 6934 6986;
    12240 8448 8447 6986 7002; 12241 8449 8448 7002 7018;
    12242 8450 8449 7018 7034; 12243 8451 8450 7034 7050;
    12244 8452 8451 7050 7066; 12245 8453 8452 7066 7082;
    12246 8454 8453 7082 7098; 12247 8455 8454 7098 7114;
    12248 8456 8455 7114 7130; 12249 8457 8456 7130 7146;
    12250 8458 8457 7146 7162; 12251 8459 8458 7162 7178;
    12252 8460 8459 7178 7194; 12253 8461 8460 7194 7210;
    12254 8462 8461 7210 7226; 12255 8463 8462 7226 7242;
    12256 8464 8463 7242 7258; 12257 8465 8464 7258 7274;
    12258 8466 8465 7274 7290; 12259 8467 8466 7290 7306;
    12260 8468 8467 7306 7322; 12261 8469 8468 7322 7338;
    12262 8470 8469 7338 7354; 12263 8471 8470 7354 7370;
    12264 8472 8471 7370 7386; 12265 8473 8472 7386 7402;
    12266 8474 8473 7402 7418; 12267 8475 8474 7418 7434;
    12268 8476 8475 7434 7450; 12269 8477 8476 7450 7466;
    12270 8478 8477 7466 7482; 12271 8479 8478 7482 7498;
    12272 8480 8479 7498 7514; 12273 8481 8480 7514 7530;
    12274 8482 8481 7530 7546; 12275 8483 8482 7546 7562;
    12276 8484 8483 7562 7578; 12277 8485 8484 7578 7594;
    12278 8486 8485 7594 7610; 12279 8487 8486 7610 7626;
    12280 8488 8487 7626 7642; 12281 8489 8488 7642 7658;
    12282 8490 8489 7658 7674; 12283 8491 8490 7674 7690;
    12284 8492 8491 7690 7706; 12285 8493 8492 7706 7722;
    12286 8494 8493 7722 7738; 12287 8495 8494 7738 7754;
    12288 8496 8495 7754 7770; 12289 8497 8496 7770 7786;
    12290 8498 8497 7786 7802; 12291 8499 8498 7802 7818;
    12292 8500 8499 7818 7834; 12293 8501 8500 7834 7850;
    12294 8502 8501 7850 7866; 12295 8503 8502 7866 7882;
    12296 8504 8503 7882 7898; 12297 8505 8504 7898 7914;
    12298 8506 8505 7914 7930; 12299 8507 8506 7930 7946;
    12300 8508 8507 7946 7962; 12301 8509 8508 7962 7978;
    12302 8510 8509 7978 7994; 12303 8511 8510 7994 8010;
    12304 8512 8511 8010 8026; 12305 8513 8512 8026 8042;
    12306 8514 8513 8042 8058; 12307 8515 8514 8058 8074;
    12308 8516 8515 8074 8090; 12309 1811 1812 9994 9995;
    12310 9995 9994 1814 1813; 12312 1812 1833 9998 9994;
    12313 9994 9998 1834 1814; 12315 1833 1853 10000 9998;
    12316 9998 10000 1854 1834; 12318 1853 1873 10002 10000;
    12319 10000 10002 1874 1854; 12321 1873 1893 10004 10002;
    12322 10002 10004 1894 1874; 12324 1893 1913 10006 10004;
    12325 10004 10006 1914 1894; 12327 1913 1933 10008 10006;
    12328 10006 10008 1934 1914; 12330 1933 1953 10010 10008;
    12331 10008 10010 1954 1934; 12333 1953 1973 10012 10010;
    12334 10010 10012 1974 1954; 12336 1973 1993 10014 10012;
    12337 10012 10014 1994 1974; 12339 1993 2013 10016 10014;
    12340 10014 10016 2014 1994; 12342 2013 2033 10018 10016;
    12343 10016 10018 2034 2014; 12345 2033 2053 10020 10018;
    12346 10018 10020 2054 2034; 12348 2053 2073 10022 10020;
    12349 10020 10022 2074 2054; 12351 2073 2093 10024 10022;
    12352 10022 10024 2094 2074; 12354 2093 2113 10026 10024;
    12355 10024 10026 2114 2094; 12357 2113 2133 10028 10026;
    12358 10026 10028 2134 2114; 12360 2133 2153 10030 10028;
    12361 10028 10030 2154 2134; 12363 2153 2173 10032 10030;
    12364 10030 10032 2174 2154; 12366 2173 2193 10034 10032;
    12367 10032 10034 2194 2174; 12369 2193 2213 10036 10034;
    12370 10034 10036 2214 2194; 12372 2213 2233 10038 10036;
    12373 10036 10038 2234 2214; 12375 2233 2253 10040 10038;
    12376 10038 10040 2254 2234; 12378 2253 2273 10042 10040;
    12379 10040 10042 2274 2254; 12381 2273 2293 10044 10042;
    12382 10042 10044 2294 2274; 12384 2293 2313 10046 10044;
    12385 10044 10046 2314 2294; 12387 2313 2333 10048 10046;
    12388 10046 10048 2334 2314; 12390 2333 2353 10050 10048;
    12391 10048 10050 2354 2334; 12393 2353 2373 10052 10050;
    12394 10050 10052 2374 2354; 12396 2373 2393 10054 10052;
    12397 10052 10054 2394 2374; 12399 2393 2413 10056 10054;
    12400 10054 10056 2414 2394; 12402 2413 2433 10058 10056;
    12403 10056 10058 2434 2414; 12405 2433 2453 10060 10058;
    12406 10058 10060 2454 2434; 12408 2453 2473 10062 10060;
    12409 10060 10062 2474 2454; 12411 2473 2493 10064 10062;
    12412 10062 10064 2494 2474; 12414 2493 2513 10066 10064;
    12415 10064 10066 2514 2494; 12417 2513 2533 10068 10066;
    12418 10066 10068 2534 2514; 12420 2533 2553 10070 10068;
    12421 10068 10070 2554 2534; 12423 2553 2573 10072 10070;
    12424 10070 10072 2574 2554; 12426 2573 2593 10074 10072;
    12427 10072 10074 2594 2574; 12429 2593 2613 10076 10074;
    12430 10074 10076 2614 2594; 12432 2613 2633 10078 10076;
    12433 10076 10078 2634 2614; 12435 2633 2653 10080 10078;
    12436 10078 10080 2654 2634; 12438 2653 2673 10082 10080;
    12439 10080 10082 2674 2654; 12441 2673 2693 10084 10082;
    12442 10082 10084 2694 2674; 12444 2693 2713 10086 10084;
    12445 10084 10086 2714 2694; 12447 2713 2733 10088 10086;
    12448 10086 10088 2734 2714; 12450 2733 2753 10090 10088;
    12451 10088 10090 2754 2734; 12453 2753 2773 10092 10090;
    12454 10090 10092 2774 2754; 12456 2773 2793 10094 10092;
    12457 10092 10094 2794 2774; 12459 2793 2813 10096 10094;
    12460 10094 10096 2814 2794; 12462 2813 2833 10098 10096;
    12463 10096 10098 2834 2814; 12465 2833 2853 10100 10098;
    12466 10098 10100 2854 2834; 12468 2853 2873 10102 10100;
    12469 10100 10102 2874 2854; 12471 2873 2893 10104 10102;
    12472 10102 10104 2894 2874; 12474 2893 2913 10106 10104;
    12475 10104 10106 2914 2894; 12477 2913 2933 10108 10106;
    12478 10106 10108 2934 2914; 12480 2933 2953 10110 10108;
    12481 10108 10110 2954 2934; 12483 2953 2973 10112 10110;
    12484 10110 10112 2974 2954; 12486 2973 2993 10114 10112;
    12487 10112 10114 2994 2974; 12489 2993 3013 10116 10114;
    12490 10114 10116 3014 2994; 12492 3013 3033 10118 10116;
    12493 10116 10118 3034 3014; 12495 3033 3053 10120 10118;
    12496 10118 10120 3054 3034; 12498 3053 3073 10122 10120;
    12499 10120 10122 3074 3054; 12501 3073 3093 10124 10122;
    12502 10122 10124 3094 3074; 12504 3093 3113 10126 10124;
    12505 10124 10126 3114 3094; 12507 3113 3133 10128 10126;
    12508 10126 10128 3134 3114; 12510 3133 3153 10130 10128;
    12511 10128 10130 3154 3134; 12513 3153 3173 10132 10130;
    12514 10130 10132 3174 3154; 12516 3173 3193 10134 10132;
    12517 10132 10134 3194 3174; 12519 3193 3212 10136 10134;
    12520 10134 10136 3213 3194; 12522 3212 1811 9995 10136;
    12523 10136 9995 1813 3213; 12538 9854 9850 10137 10138;
    12539 9856 9854 10138 10139; 12540 9858 9856 10139 10140;
    12541 9860 9858 10140 10141; 12542 9862 9860 10141 10142;
    12543 9864 9862 10142 10143; 12544 9866 9864 10143 10144;
    12545 9868 9866 10144 10145; 12546 9870 9868 10145 10146;
    12547 9872 9870 10146 10147; 12548 9874 9872 10147 10148;
    12549 9876 9874 10148 10149; 12550 9878 9876 10149 10150;
    12551 9880 9878 10150 10151; 12552 9882 9880 10151 10152;
    12553 9884 9882 10152 10153; 12554 9886 9884 10153 10154;
    12555 9888 9886 10154 10155; 12556 9890 9888 10155 10156;
    12557 9892 9890 10156 10157; 12558 9894 9892 10157 10158;
    12559 9896 9894 10158 10159; 12560 9898 9896 10159 10160;
    12561 9900 9898 10160 10161; 12562 9902 9900 10161 10162;
    12563 9904 9902 10162 10163; 12564 9906 9904 10163 10164;
    12565 9908 9906 10164 10165; 12566 9910 9908 10165 10166;
    12567 9912 9910 10166 10167; 12568 9914 9912 10167 10168;
    12569 9916 9914 10168 10169; 12570 9918 9916 10169 10170;
    12571 9920 9918 10170 10171; 12572 9922 9920 10171 10172;
    12573 9924 9922 10172 10173; 12574 9926 9924 10173 10174;
    12575 9928 9926 10174 10175; 12576 9930 9928 10175 10176;
    12577 9932 9930 10176 10177; 12578 9934 9932 10177 10178;
    12579 9936 9934 10178 10179; 12580 9938 9936 10179 10180;
    12581 9940 9938 10180 10181; 12582 9942 9940 10181 10182;
    12583 9944 9942 10182 10183; 12584 9946 9944 10183 10184;
    12585 9948 9946 10184 10185; 12586 9950 9948 10185 10186;
    12587 9952 9950 10186 10187; 12588 9954 9952 10187 10188;
    12589 9956 9954 10188 10189; 12590 9958 9956 10189 10190;
    12591 9960 9958 10190 10191; 12592 9962 9960 10191 10192;
    12593 9964 9962 10192 10193; 12594 9966 9964 10193 10194;
    12595 9968 9966 10194 10195; 12596 9970 9968 10195 10196;
    12597 9972 9970 10196 10197; 12598 9974 9972 10197 10198;
    12599 9976 9974 10198 10199; 12600 9978 9976 10199 10200;
    12601 9980 9978 10200 10201; 12602 9982 9980 10201 10202;
    12603 9984 9982 10202 10203; 12604 9986 9984 10203 10204;
    12605 9988 9986 10204 10205; 12606 9990 9988 10205 10206;
    12607 9992 9990 10206 10207; 12608 9851 9992 10207 10208;
    12609 9850 9851 10208 10137; 12614 10138 10137 10209 10210;
    12615 10139 10138 10210 10211; 12616 10140 10139 10211 10212;
    12617 10141 10140 10212 10213; 12618 10142 10141 10213 10214;
    12619 10143 10142 10214 10215; 12620 10144 10143 10215 10216;
    12621 10145 10144 10216 10217; 12622 10146 10145 10217 10218;
    12623 10147 10146 10218 10219; 12624 10148 10147 10219 10220;
    12625 10149 10148 10220 10221; 12626 10150 10149 10221 10222;
    12627 10151 10150 10222 10223; 12628 10152 10151 10223 10224;
    12629 10153 10152 10224 10225; 12630 10154 10153 10225 10226;
    12631 10155 10154 10226 10227; 12632 10156 10155 10227 10228;
    12633 10157 10156 10228 10229; 12634 10158 10157 10229 10230;
    12635 10159 10158 10230 10231; 12636 10160 10159 10231 10232;
    12637 10161 10160 10232 10233; 12638 10162 10161 10233 10234;
    12639 10163 10162 10234 10235; 12640 10164 10163 10235 10236;
    12641 10165 10164 10236 10237; 12642 10166 10165 10237 10238;
    12643 10167 10166 10238 10239; 12644 10168 10167 10239 10240;
    12645 10169 10168 10240 10241; 12646 10170 10169 10241 10242;
    12647 10171 10170 10242 10243; 12648 10172 10171 10243 10244;
    12649 10173 10172 10244 10245; 12650 10174 10173 10245 10246;
    12651 10175 10174 10246 10247; 12652 10176 10175 10247 10248;
    12653 10177 10176 10248 10249; 12654 10178 10177 10249 10250;
    12655 10179 10178 10250 10251; 12656 10180 10179 10251 10252;
    12657 10181 10180 10252 10253; 12658 10182 10181 10253 10254;
    12659 10183 10182 10254 10255; 12660 10184 10183 10255 10256;
    12661 10185 10184 10256 10257; 12662 10186 10185 10257 10258;
    12663 10187 10186 10258 10259; 12664 10188 10187 10259 10260;
    12665 10189 10188 10260 10261; 12666 10190 10189 10261 10262;
    12667 10191 10190 10262 10263; 12668 10192 10191 10263 10264;
    12669 10193 10192 10264 10265; 12670 10194 10193 10265 10266;
    12671 10195 10194 10266 10267; 12672 10196 10195 10267 10268;
    12673 10197 10196 10268 10269; 12674 10198 10197 10269 10270;
    12675 10199 10198 10270 10271; 12676 10200 10199 10271 10272;
    12677 10201 10200 10272 10273; 12678 10202 10201 10273 10274;
    12679 10203 10202 10274 10275; 12680 10204 10203 10275 10276;
    12681 10205 10204 10276 10277; 12682 10206 10205 10277 10278;
    12683 10207 10206 10278 10279; 12684 10208 10207 10279 10280;
    12685 10137 10208 10280 10209; 12686 3014 3034 10282 10281;
    12687 3034 3054 10283 10282; 12688 3054 3074 10284 10283;
    12689 10281 10282 10286 10285; 12690 10282 10283 10287 10286;
    12691 10283 10284 10288 10287; 12692 10285 10286 10290 10289;
    12693 10286 10287 10291 10290; 12694 10287 10288 10292 10291;
    12695 10289 10290 10294 10293; 12696 10290 10291 10295 10294;
    12697 10291 10292 10296 10295; 12704 4562 3014 10281 10301;
    12705 4625 10302 10284 3074; 12706 10301 10281 10285 10303;
    12707 10302 10304 10288 10284; 12708 10303 10285 10289 10305;
    12709 10304 10306 10292 10288; 12712 10305 10289 10293 10307;
    12713 10292 10306 10308 10296; 12722 4563 4562 10301 10309;
    12723 4564 4563 10309 10310; 12724 4565 4564 10310 10311;
    12725 4566 4565 10311 10312; 12726 10309 10301 10303 10317;
    12727 10310 10309 10317 10318; 12728 10311 10310 10318 10319;
    12729 10312 10311 10319 10320; 12730 10317 10303 10305 10321;
    12731 10318 10317 10321 10322; 12733 10321 10305 10307 10323;
    12735 10322 10321 10323 10324; 12736 10319 10318 10322 10325;
    12738 10325 10322 10324 10326; 12740 10320 10319 10325 10327;
    12741 10327 10325 10326; 12745 4567 4566 10312 10328;
    12746 4568 4567 10328 10329; 12747 4569 4568 10329 10330;
    12748 10328 10312 10320 10331; 12749 10329 10328 10331 10332;
    12751 10331 10320 10327 10333; 12753 10332 10331 10333 10334;
    12754 10330 10329 10332 10335; 12756 10335 10332 10334 10336;
    12760 4570 4569 10330 10337; 12761 4571 4570 10337 10338;
    12763 10337 10330 10335 10339; 12764 10339 10335 10336;
    12766 10338 10337 10339 10340; 12768 4572 4571 10338 10341;
    12770 10341 10338 10340 10342; 12772 4573 4572 10341 10343;
    12773 10343 10341 10342 10297; 12774 4625 4626 10313 10302;
    12775 4626 4627 10314 10313; 12776 4627 4628 10315 10314;
    12777 4628 4629 10316 10315; 12785 4629 4630 10344 10316;
    12786 4630 4631 10345 10344; 12787 4631 4632 10346 10345;
    12788 4632 4633 10347 10346; 12789 4633 4634 10348 10347;
    12790 4634 4635 10349 10348; 12791 4635 4636 10350 10349;
    12793 10349 10350 10298 10351; 12795 10348 10349 10351 10352;
    12797 10347 10348 10352 10353; 12799 10302 10313 10354 10304;
    12800 10313 10314 10355 10354; 12801 10314 10315 10356 10355;
    12802 10315 10316 10357 10356; 12803 10316 10344 10358 10357;
    12804 10344 10345 10359 10358; 12805 10345 10346 10360 10359;
    12806 10346 10347 10353 10360; 12808 10360 10353 10361;
    12810 10359 10360 10361 10362; 12812 10358 10359 10362 10363;
    12814 10357 10358 10363 10364; 12815 10304 10354 10365 10306;
    12816 10354 10355 10366 10365; 12817 10355 10356 10367 10366;
    12818 10356 10357 10364 10367; 12820 10367 10364 10368;
    12822 10366 10367 10368 10369; 12824 10365 10366 10369 10370;
    12825 10306 10365 10370 10308; 12828 4573 4594 10372 10343;
    12829 4552 4573 10343 10371; 12833 10371 10343 10297 10374;
    12834 10343 10372 10375 10297; 12836 4531 4552 10371 10376;
    12838 10376 10371 10374 10377; 12840 4518 4517 4538 4539;
    12841 4539 4538 10379 4560; 12842 4560 10379 10380 4581;
    12843 4581 10380 10381 4602; 12844 4602 10381 10382 4623;
    12845 4623 10382 10383 4644; 12846 4644 10383 10384 4665;
    12847 4665 10384 10385 4686; 12848 4686 10385 4706 4707;
    12849 4707 4706 4727 4728; 12850 4538 4537 4558 10379;
    12851 10379 4558 10386 10380; 12852 10380 10386 10387 10381;
    12853 10381 10387 10388 10382; 12854 10382 10388 10389 10383;
    12855 10383 10389 10390 10384; 12856 10384 10390 10391 10385;
    12857 10385 10391 4705 4706; 12860 4537 4536 10392; 12861 4705 4704 10393;
    12866 4532 4531 10376 10394; 12867 4533 4532 10394 10395;
    12868 4534 4533 10395 10396; 12869 4535 4534 10396 10397;
    12870 4536 4535 10397 10392; 12871 10394 10376 10377;
    12878 10350 4636 4657 10398; 12879 10298 10350 10398 10401;
    12880 10398 4657 4678 10399; 12881 10401 10398 10399 10402;
    12882 10399 4678 4699 10400; 12883 10402 10399 10400 10403;
    12885 10400 4699 4700 10404; 12889 10404 4700 4701 10405;
    12890 10405 4701 4702 10406; 12891 10406 4702 4703 10407;
    12892 4703 4704 10393 10407; 12893 10403 10400 10404;
    START GROUP DEFINITION
    ELEMENT
    _INNER-PLATE 10651 TO 10655 10657 TO 10675 10677 TO 10690 10692 TO 10705 -
    10707 TO 10720 10722 TO 10735 10737 TO 10750 10752 TO 10765 10767 TO 10780 -
    10782 TO 10795 10797 TO 10810 10812 TO 10825 10827 TO 10840 10842 TO 10855 -
    10857 TO 10870 10872 TO 10885 10887 TO 10900 10902 TO 10915 10917 TO 10930 -
    10932 TO 10945 10947 TO 10960 10962 TO 10975 10977 TO 10990 10992 TO 11005 -
    11007 TO 11020 11022 TO 11035 11037 TO 11050 11052 TO 11065 11067 TO 11080 -
    11082 TO 11095 11097 TO 11110 11112 TO 11125 11127 TO 11140 11142 TO 11155 -
    11157 TO 11170 11172 TO 11185 11187 TO 11200 11202 TO 11215 11217 TO 11230 -
    11232 TO 11245 11247 TO 11260 11262 TO 11275 11277 TO 11290 11292 TO 11305 -
    11307 TO 11320 11322 TO 11335 11337 TO 11350 11352 TO 11365 11367 TO 11380 -
    11382 TO 11395 11397 TO 11410 11412 TO 11425 11427 TO 11440 11442 TO 11455 -
    11457 TO 11470 11472 TO 11485 11487 TO 11500 11502 TO 11515 11517 TO 11530 -
    11532 TO 11545 11547 TO 11560 11562 TO 11575 11577 TO 11590 11592 TO 11605 -
    11607 TO 11620 11622 TO 11635 11637 TO 11650 11652 TO 11665 11667 TO 11680 -
    11682 TO 11695 11697 TO 11710 11712 TO 11725 11727 TO 12090
    _PROJECTION 12094 TO 12237
    _1 8779 10533 TO 10603
    _2 1940 1960 1980 2000 2020 2040 2060 2080 2100 2120 2140 2160 2180 2200 2220 -
    2240 2260 2280 2300 2320 2340 2360 2380 2400 2420 2440 2460 2480 2500 2520 -
    2540 2560 2580 2600 2620 2640 2660 2680 2700 2720 2740 2760 2780 2800 2820 -
    2840 2860 2880 2900 2920 2940 2960 2980 3000 3020 3040 3060 3080 3100 3120 -
    3140 3160 3180 3200 3220 3240 3260 3280 3300 3320 3340 3360
    _3 1941 1961 1981 2001 2021 2041 2061 2081 2101 2121 2141 2161 2181 2201 2221 -
    2241 2261 2281 2301 2321 2341 2361 2381 2401 2421 2441 2461 2481 2501 2521 -
    2541 2561 2581 2601 2621 2641 2661 2681 2701 2721 2741 2761 2781 2801 2821 -
    2841 2861 2881 2901 2921 2941 2961 2981 3001 3021 3041 3061 3081 3101 3121 -
    3141 3161 3181 3201 3221 3241 3261 3281 3301 3321 3341 3361
    _4 1942 1962 1982 2002 2022 2042 2062 2082 2102 2122 2142 2162 2182 2202 2222 -
    2242 2262 2282 2302 2322 2342 2362 2382 2402 2422 2442 2462 2482 2502 2522 -
    2542 2562 2582 2602 2622 2642 2662 2682 2702 2722 2742 2762 2782 2802 2822 -
    2842 2862 2882 2902 2922 2942 2962 2982 3002 3022 3042 3062 3082 3102 3122 -
    3142 3162 3182 3202 3222 3242 3262 3282 3302 3322 3342 3362
    _5 1943 1963 1983 2003 2023 2043 2063 2083 2103 2123 2143 2163 2183 2203 2223 -
    2243 2263 2283 2303 2323 2343 2363 2383 2403 2423 2443 2463 2483 2503 2523 -
    2543 2563 2583 2603 2623 2643 2663 2683 2703 2723 2743 2763 2783 2803 2823 -
    2843 2863 2883 2903 2923 2943 2963 2983 3063 3083 3103 3123 3143 3163 3183 -
    3203 3223 3243 3263 3283 3303 3323 3343 3363
    _6 1944 1964 1984 2004 2024 2044 2064 2084 2104 2124 2144 2164 2184 2204 2224 -
    2244 2264 2284 2304 2324 2344 2364 2384 2404 2424 2444 2464 2484 2504 2524 -
    2544 2564 2584 2604 2624 2644 2664 2684 2704 2724 2744 2764 2784 2804 2824 -
    2844 2864 2884 2904 2924 2944 2964 2984 3064 3084 3104 3124 3144 3164 3184 -
    3204 3224 3244 3264 3284 3304 3324 3344 3364
    _7 1945 1965 1985 2005 2025 2045 2065 2085 2105 2125 2145 2165 2185 2205 2225 -
    2245 2265 2285 2305 2325 2345 2365 2385 2405 2425 2445 2465 2485 2505 2525 -
    2545 2565 2585 2605 2625 2645 2665 2685 2705 2725 2745 2765 2785 2805 2825 -
    2845 2865 2885 2905 2925 2945 2965 2985 3065 3085 3105 3125 3145 3165 3185 -
    3205 3225 3245 3265 3285 3305 3325 3345 3365
    _8 1946 1966 1986 2006 2026 2046 2066 2086 2106 2126 2146 2166 2186 2206 2226 -
    2246 2266 2286 2306 2326 2346 2366 2386 2406 2426 2446 2466 2486 2506 2526 -
    2546 2566 2586 2606 2626 2646 2666 2686 2706 2726 2746 2766 2786 2806 2826 -
    2846 2866 2886 2906 2926 2946 2966 2986 3006 3026 3046 3066 3086 3106 3126 -
    3146 3166 3186 3206 3226 3246 3266 3286 3306 3326 3346 3366
    _9 1947 1967 1987 2007 2027 2047 2067 2087 2107 2127 2147 2167 2187 2207 2227 -
    2247 2267 2287 2307 2327 2347 2367 2387 2407 2427 2447 2467 2487 2507 2527 -
    2547 2567 2587 2607 2627 2647 2667 2687 2707 2727 2747 2767 2787 2807 2827 -
    2847 2867 2887 2907 2927 2947 2967 2987 3007 3027 3047 3067 3087 3107 3127 -
    3147 3167 3187 3207 3227 3247 3267 3287 3307 3327 3347 3367
    _10 1948 1968 1988 2008 2028 2048 2068 2088 2108 2128 2148 2168 2188 2208 -
    2228 2248 2268 2288 2308 2328 2348 2368 2388 2408 2428 2448 2468 2488 2508 -
    2528 2548 2568 2588 2608 2628 2648 2668 2688 2708 2728 2748 2768 2788 2808 -
    2828 2848 2868 2888 2908 2928 2948 2968 2988 3008 3028 3048 3068 3088 3108 -
    3128 3148 3168 3188 3208 3228 3248 3268 3288 3308 3328 3348 3368
    _11 1949 1969 1989 2009 2029 2049 2069 2089 2109 2129 2149 2169 2189 2209 -
    2229 2249 2269 2289 2309 2329 2349 2369 2389 2409 2429 2449 2469 2489 2509 -
    2529 2549 2569 2589 2609 2629 2649 2669 2689 2709 2729 2749 2769 2789 2809 -
    2829 2849 2869 2889 2909 2929 2949 2969 2989 3009 3029 3049 3069 3089 3109 -
    3129 3149 3169 3189 3209 3229 3249 3269 3289 3309 3329 3349 3369
    _12 1950 1970 1990 2010 2030 2050 2070 2090 2110 2130 2150 2170 2190 2210 -
    2230 2250 2270 2290 2310 2330 2350 2370 2390 2410 2430 2450 2470 2490 2510 -
    2530 2550 2570 2590 2610 2630 2650 2670 2690 2710 2730 2750 2770 2790 2810 -
    2830 2850 2870 2890 2910 2930 2950 2970 2990 3010 3030 3050 3070 3090 3110 -
    3130 3150 3170 3190 3210 3230 3250 3270 3290 3310 3330 3350 3370
    _13 1951 1971 1991 2011 2031 2051 2071 2091 2111 2131 2151 2171 2191 2211 -
    2231 2251 2271 2291 2311 2331 2351 2371 2391 2411 2431 2451 2471 2491 2511 -
    2531 2551 2571 2591 2611 2631 2651 2671 2691 2711 2731 2751 2771 2791 2811 -
    2831 2851 2871 2891 2911 2931 2951 2971 2991 3011 3031 3051 3071 3091 3111 -
    3131 3151 3171 3191 3211 3231 3251 3271 3291 3311 3331 3351 3371
    _14 1952 1972 1992 2012 2032 2052 2072 2092 2112 2132 2152 2172 2192 2212 -
    2232 2252 2272 2292 2312 2332 2352 2372 2392 2412 2432 2452 2472 2492 2512 -
    2532 2552 2572 2592 2612 2632 2652 2672 2692 2712 2732 2752 2772 2792 2812 -
    2832 2852 2872 2892 2912 2932 2952 2972 2992 3012 3032 3052 3072 3092 3112 -
    3132 3152 3172 3192 3212 3232 3252 3272 3292 3312 3332 3352 3372
    _15 1953 1973 1993 2013 2033 2053 2073 2093 2113 2133 2153 2173 2193 2213 -
    2233 2253 2273 2293 2313 2333 2353 2373 2393 2413 2433 2453 2473 2493 2513 -
    2533 2553 2573 2593 2613 2633 2653 2673 2693 2713 2733 2753 2773 2793 2813 -
    2833 2853 2873 2893 2913 2933 2953 2973 2993 3013 3033 3053 3073 3093 3113 -
    3133 3153 3173 3193 3213 3233 3253 3273 3293 3313 3333 3353 3373
    _16 1954 1974 1994 2014 2034 2054 2074 2094 2114 2134 2154 2174 2194 2214 -
    2234 2254 2274 2294 2314 2334 2354 2374 2394 2414 2434 2454 2474 2494 2514 -
    2534 2554 2574 2594 2614 2634 2654 2674 2694 2714 2734 2754 2774 2794 2814 -
    2834 2854 2874 2894 2914 2934 2954 2974 2994 3014 3034 3054 3074 3094 3114 -
    3134 3154 3174 3194 3214 3234 3254 3274 3294 3314 3334 3354 3374
    _17 1955 1975 1995 2015 2035 2055 2075 2095 2115 2135 2155 2175 2195 2215 -
    2235 2255 2275 2295 2315 2335 2355 2375 2395 2415 2435 2455 2475 2495 2515 -
    2535 2555 2575 2595 2615 2635 2655 2675 2695 2715 2735 2755 2775 2795 2815 -
    2835 2855 2875 2895 2915 2935 2955 2975 2995 3015 3035 3055 3075 3095 3115 -
    3135 3155 3175 3195 3215 3235 3255 3275 3295 3315 3335 3355 3375
    _18 1956 1976 1996 2016 2036 2056 2076 2096 2116 2136 2156 2176 2196 2216 -
    2236 2256 2276 2296 2316 2336 2356 2376 2396 2416 2436 2456 2476 2496 2516 -
    2536 2556 2576 2596 2616 2636 2656 2676 2696 2716 2736 2756 2776 2796 2816 -
    2836 2856 2876 2896 2916 2936 2956 2976 2996 3016 3036 3056 3076 3096 3116 -
    3136 3156 3176 3196 3216 3236 3256 3276 3296 3316 3336 3356 3376
    _19 1957 1977 1997 2017 2037 2057 2077 2097 2117 2137 2157 2177 2197 2217 -
    2237 2257 2277 2297 2317 2337 2357 2377 2397 2417 2437 2457 2477 2497 2517 -
    2537 2557 2577 2597 2617 2637 2657 2677 2697 2717 2737 2757 2777 2797 2817 -
    2837 2857 2877 2897 2917 2937 2957 2977 2997 3017 3037 3057 3077 3097 3117 -
    3137 3157 3177 3197 3217 3237 3257 3277 3297 3317 3337 3357 3377
    _20 12309 12312 12315 12318 12321 12324 12327 12330 12333 12336 12339 12342 -
    12345 12348 12351 12354 12357 12360 12363 12366 12369 12372 12375 12378 -
    12381 12384 12387 12390 12393 12396 12399 12402 12405 12408 12411 12414 -
    12417 12420 12423 12426 12429 12432 12435 12438 12441 12444 12447 12450 -
    12453 12456 12459 12462 12465 12468 12471 12474 12477 12480 12483 12486 -
    12489 12492 12495 12498 12501 12504 12507 12510 12513 12516 12519 12522
    _DOME 5091 TO 5106 5112 TO 5127 5133 TO 5148 5154 TO 5169 5175 TO 5190 5196 -
    5197 TO 5211 5217 TO 5232 5238 TO 5253 5259 TO 5274 5280 TO 5295 5301 TO 5316 -
    5322 TO 5337 5343 TO 5358 5364 TO 5379 5385 TO 5400 5406 TO 5421 -
    5427 TO 5442 5448 TO 5463 5469 TO 5484 5490 TO 5505 5511 TO 5526 -
    5532 TO 5547 5553 TO 5568 5574 TO 5589 5595 TO 5610 5616 TO 5631 -
    5637 TO 5652 5658 TO 5673 5679 TO 5694 5700 TO 5715 5721 TO 5736 -
    5742 TO 5757 5763 TO 5778 5784 TO 5799 5805 TO 5820 5826 TO 5841 -
    5847 TO 5862 5868 TO 5883 5889 TO 5904 5910 TO 5925 5931 TO 5946 -
    5952 TO 5967 5973 TO 5988 5994 TO 6009 6015 TO 6030 6036 TO 6051 -
    6057 TO 6072 6078 TO 6093 6099 TO 6114 6120 TO 6135 6141 TO 6156 -
    6162 TO 6177 6183 TO 6198 6204 TO 6219 6225 TO 6240 6246 TO 6261 -
    6267 TO 6282 6288 TO 6302 6309 TO 6322 6330 TO 6342 6351 TO 6362 -
    6372 TO 6379 6393 TO 6400 6414 TO 6421 6435 TO 6442 6456 TO 6467 -
    6477 TO 6489 6498 TO 6511 6519 TO 6533 6540 TO 6555 6561 TO 6576 -
    6582 TO 6597
    _DOME-300THK 5087 TO 5091 5108 TO 5112 5129 TO 5133 5150 TO 5154 5171 TO 5175 -
    5192 TO 5196 5213 TO 5217 5234 TO 5238 5255 TO 5259 5276 TO 5280 -
    5297 TO 5301 5318 TO 5322 5339 TO 5343 5360 TO 5364 5381 TO 5385 -
    5402 TO 5406 5423 TO 5427 5444 TO 5448 5465 TO 5469 5486 TO 5490 -
    5507 TO 5511 5528 TO 5532 5549 TO 5553 5570 TO 5574 5591 TO 5595 -
    5612 TO 5616 5633 TO 5637 5654 TO 5658 5675 TO 5679 5696 TO 5700 -
    5717 TO 5721 5738 TO 5742 5759 TO 5763 5780 TO 5784 5801 TO 5805 -
    5822 TO 5826 5843 TO 5847 5864 TO 5868 5885 TO 5889 5906 TO 5910 -
    5927 TO 5931 5948 TO 5952 5969 TO 5973 5990 TO 5994 6011 TO 6015 -
    6032 TO 6036 6053 TO 6057 6074 TO 6078 6095 TO 6099 6116 TO 6120 -
    6137 TO 6141 6158 TO 6162 6179 TO 6183 6200 TO 6204 6221 TO 6225 -
    6242 TO 6246 6263 TO 6267 6284 TO 6288 6305 TO 6309 6326 TO 6330 -
    6347 TO 6351 6368 TO 6372 6389 TO 6393 6410 TO 6414 6431 TO 6435 -
    6452 TO 6456 6473 TO 6477 6494 TO 6498 6515 TO 6519 6536 TO 6540 -
    6557 TO 6561 6578 TO 6582
    _WALL-1STLAYER 1940 TO 1944 1960 TO 1964 1980 TO 1984 2000 TO 2004 -
    2020 TO 2024 2040 TO 2044 2060 TO 2064 2080 TO 2084 2100 TO 2104 -
    2120 TO 2124 2140 TO 2144 2160 TO 2164 2180 TO 2184 2200 TO 2204 -
    2220 TO 2224 2240 TO 2244 2260 TO 2264 2280 TO 2284 2300 TO 2304 -
    2320 TO 2324 2340 TO 2344 2360 TO 2364 2380 TO 2384 2400 TO 2404 -
    2420 TO 2424 2440 TO 2444 2460 TO 2464 2480 TO 2484 2500 TO 2504 -
    2520 TO 2524 2540 TO 2544 2560 TO 2564 2580 TO 2584 2600 TO 2604 -
    2620 TO 2624 2640 TO 2644 2660 TO 2664 2680 TO 2684 2700 TO 2704 -
    2720 TO 2724 2740 TO 2744 2760 TO 2764 2780 TO 2784 2800 TO 2804 -
    2820 TO 2824 2840 TO 2844 2860 TO 2864 2880 TO 2884 2900 TO 2904 -
    2920 TO 2924 2940 TO 2944 2960 TO 2964 2980 TO 2984 3000 TO 3002 -
    3020 TO 3022 3040 TO 3042 3060 TO 3064 3080 TO 3084 3100 TO 3104 -
    3120 TO 3124 3140 TO 3144 3160 TO 3164 3180 TO 3184 3200 TO 3204 -
    3220 TO 3224 3240 TO 3244 3260 TO 3264 3280 TO 3284 3300 TO 3304 -
    3320 TO 3324 3340 TO 3344 3360 TO 3364 8779 10533 TO 10603
    _WALL-2NDLAYER 1945 TO 1951 1965 TO 1971 1985 TO 1991 2005 TO 2011 -
    2025 TO 2031 2045 TO 2051 2065 TO 2071 2085 TO 2091 2105 TO 2111 -
    2125 TO 2131 2145 TO 2151 2165 TO 2171 2185 TO 2191 2205 TO 2211 -
    2225 TO 2231 2245 TO 2251 2265 TO 2271 2285 TO 2291 2305 TO 2311 -
    2325 TO 2331 2345 TO 2351 2365 TO 2371 2385 TO 2391 2405 TO 2411 -
    2425 TO 2431 2445 TO 2451 2465 TO 2471 2485 TO 2491 2505 TO 2511 -
    2525 TO 2531 2545 TO 2551 2565 TO 2571 2585 TO 2591 2605 TO 2611 -
    2625 TO 2631 2645 TO 2651 2665 TO 2671 2685 TO 2691 2705 TO 2711 -
    2725 TO 2731 2745 TO 2751 2765 TO 2771 2785 TO 2791 2805 TO 2811 -
    2825 TO 2831 2845 TO 2851 2865 TO 2871 2885 TO 2891 2905 TO 2911 -
    2925 TO 2931 2945 TO 2951 2965 TO 2971 2985 TO 2991 3006 TO 3011 -
    3026 TO 3031 3046 TO 3051 3065 TO 3071 3085 TO 3091 3105 TO 3111 -
    3125 TO 3131 3145 TO 3151 3165 TO 3171 3185 TO 3191 3205 TO 3211 -
    3225 TO 3231 3245 TO 3251 3265 TO 3271 3285 TO 3291 3305 TO 3311 -
    3325 TO 3331 3345 TO 3351 3365 TO 3371
    _WALL-3RDLAYER 1952 TO 1957 1972 TO 1977 1992 TO 1997 2012 TO 2017 -
    2032 TO 2037 2052 TO 2057 2072 TO 2077 2092 TO 2097 2112 TO 2117 -
    2132 TO 2137 2152 TO 2157 2172 TO 2177 2192 TO 2197 2212 TO 2217 -
    2232 TO 2237 2252 TO 2257 2272 TO 2277 2292 TO 2297 2312 TO 2317 -
    2332 TO 2337 2352 TO 2357 2372 TO 2377 2392 TO 2397 2412 TO 2417 -
    2432 TO 2437 2452 TO 2457 2472 TO 2477 2492 TO 2497 2512 TO 2517 -
    2532 TO 2537 2552 TO 2557 2572 TO 2577 2592 TO 2597 2612 TO 2617 -
    2632 TO 2637 2652 TO 2657 2672 TO 2677 2692 TO 2697 2712 TO 2717 -
    2732 TO 2737 2752 TO 2757 2772 TO 2777 2792 TO 2797 2812 TO 2817 -
    2832 TO 2837 2852 TO 2857 2872 TO 2877 2892 TO 2897 2912 TO 2917 -
    2932 TO 2937 2952 TO 2957 2972 TO 2977 2992 TO 2997 3012 TO 3017 -
    3032 TO 3037 3052 TO 3057 3072 TO 3077 3092 TO 3097 3112 TO 3117 -
    3132 TO 3137 3152 TO 3157 3172 TO 3177 3192 TO 3197 3212 TO 3217 -
    3232 TO 3237 3252 TO 3257 3272 TO 3277 3292 TO 3297 3312 TO 3317 -
    3332 TO 3337 3352 TO 3357 3372 TO 3377 12309 12310 12312 12313 12315 12316 -
    12318 12319 12321 12322 12324 12325 12327 12328 12330 12331 12333 12334 -
    12336 12337 12339 12340 12342 12343 12345 12346 12348 12349 12351 12352 -
    12354 12355 12357 12358 12360 12361 12363 12364 12366 12367 12369 12370 -
    12372 12373 12375 12376 12378 12379 12381 12382 12384 12385 12387 12388 -
    12390 12391 12393 12394 12396 12397 12399 12400 12402 12403
    _WALL-3RDLAYER 12405 12406 12408 12409 12411 12412 12414 12415 12417 12418 -
    12420 12421 12423 12424 12426 12427 12429 12430 12432 12433 12435 12436 -
    12438 12439 12441 12442 12444 12445 12447 12448 12450 12451 12453 12454 -
    12456 12457 12459 12460 12462 12463 12465 12466 12468 12469 12471 12472 -
    12474 12475 12477 12478 12480 12481 12483 12484 12486 12487 12489 12490 -
    12492 12493 12495 12496 12498 12499 12501 12502 12504 12505 12507 12508 -
    12510 12511 12513 12514 12516 12517 12519 12520 12522 12523
    _RAFT-1STLAYER 10651 TO 10655 10677 TO 10681 10692 TO 10696 10707 TO 10711 -
    10722 TO 10726 10737 TO 10741 10752 TO 10756 10767 TO 10771 10782 TO 10786 -
    10797 TO 10801 10812 TO 10816 10827 TO 10831 10842 TO 10846 10857 TO 10861 -
    10872 TO 10876 10887 TO 10891 10902 TO 10906 10917 TO 10921 10932 TO 10936 -
    10947 TO 10951 10962 TO 10966 10977 TO 10981 10992 TO 10996 11007 TO 11011 -
    11022 TO 11026 11037 TO 11041 11052 TO 11056 11067 TO 11071 11082 TO 11086 -
    11097 TO 11101 11112 TO 11116 11127 TO 11131 11142 TO 11146 11157 TO 11161 -
    11172 TO 11176 11187 TO 11191 11202 TO 11206 11217 TO 11221 11232 TO 11236 -
    11247 TO 11251 11262 TO 11266 11277 TO 11281 11292 TO 11296 11307 TO 11311 -
    11322 TO 11326 11337 TO 11341 11352 TO 11356 11367 TO 11371 11382 TO 11386 -
    11397 TO 11401 11412 TO 11416 11427 TO 11431 11442 TO 11446 11457 TO 11461 -
    11472 TO 11476 11487 TO 11491 11502 TO 11506 11517 TO 11521 11532 TO 11536 -
    11547 TO 11551 11562 TO 11566 11577 TO 11581 11592 TO 11596 11607 TO 11611 -
    11622 TO 11626 11637 TO 11641 11652 TO 11656 11667 TO 11671 11682 TO 11686 -
    11697 TO 11701 11712 TO 11716 11727 TO 11731 12094 TO 12237 12538 TO 12609 -
    12614 TO 12685
    _RAFT-2NDLAYER 10657 TO 10665 10682 TO 10690 10697 TO 10705 10712 TO 10720 -
    10727 TO 10735 10742 TO 10750 10757 TO 10765 10772 TO 10780 10787 TO 10795 -
    10802 TO 10810 10817 TO 10825 10832 TO 10840 10847 TO 10855 10862 TO 10870 -
    10877 TO 10885 10892 TO 10900 10907 TO 10915 10922 TO 10930 10937 TO 10945 -
    10952 TO 10960 10967 TO 10975 10982 TO 10990 10997 TO 11005 11012 TO 11020 -
    11027 TO 11035 11042 TO 11050 11057 TO 11065 11072 TO 11080 11087 TO 11095 -
    11102 TO 11110 11117 TO 11125 11132 TO 11140 11147 TO 11155 11162 TO 11170 -
    11177 TO 11185 11192 TO 11200 11207 TO 11215 11222 TO 11230 11237 TO 11245 -
    11252 TO 11260 11267 TO 11275 11282 TO 11290 11297 TO 11305 11312 TO 11320 -
    11327 TO 11335 11342 TO 11350 11357 TO 11365 11372 TO 11380 11387 TO 11395 -
    11402 TO 11410 11417 TO 11425 11432 TO 11440 11447 TO 11455 11462 TO 11470 -
    11477 TO 11485 11492 TO 11500 11507 TO 11515 11522 TO 11530 11537 TO 11545 -
    11552 TO 11560 11567 TO 11575 11582 TO 11590 11597 TO 11605 11612 TO 11620 -
    11627 TO 11635 11642 TO 11650 11657 TO 11665 11672 TO 11680 11687 TO 11695 -
    11702 TO 11710 11717 TO 11725 11732 TO 11740
    _RAFT-3RDLAYER 10666 TO 10675 11741 TO 12090
    _21 12310 12313 12316 12319 12322 12325 12328 12331 12334 12337 12340 12343 -
    12346 12349 12352 12355 12358 12361 12364 12367 12370 12373 12376 12379 -
    12382 12385 12388 12391 12394 12397 12400 12403 12406 12409 12412 12415 -
    12418 12421 12424 12427 12430 12433 12436 12439 12442 12445 12448 12451 -
    12454 12457 12460 12463 12466 12469 12472 12475 12478 12481 12484 12487 -
    12490 12493 12496 12499 12502 12505 12508 12511 12514 12517 12520 12523
    _WALL 1940 TO 1957 1960 TO 1977 1980 TO 1997 2000 TO 2017 2020 TO 2037 2040 -
    2041 TO 2057 2060 TO 2077 2080 TO 2097 2100 TO 2117 2120 TO 2137 2140 TO 2157 -
    2160 TO 2177 2180 TO 2197 2200 TO 2217 2220 TO 2237 2240 TO 2257 -
    2260 TO 2277 2280 TO 2297 2300 TO 2317 2320 TO 2337 2340 TO 2357 -
    2360 TO 2377 2380 TO 2397 2400 TO 2417 2420 TO 2437 2440 TO 2457 -
    2460 TO 2477 2480 TO 2497 2500 TO 2517 2520 TO 2537 2540 TO 2557 -
    2560 TO 2577 2580 TO 2597 2600 TO 2617 2620 TO 2637 2640 TO 2657 -
    2660 TO 2677 2680 TO 2697 2700 TO 2717 2720 TO 2737 2740 TO 2757 -
    2760 TO 2777 2780 TO 2797 2800 TO 2817 2820 TO 2837 2840 TO 2857 -
    2860 TO 2877 2880 TO 2897 2900 TO 2917 2920 TO 2937 2940 TO 2957 -
    2960 TO 2977 2980 TO 2997 3000 TO 3002 3006 TO 3017 3020 TO 3022 -
    3026 TO 3037 3040 TO 3042 3046 TO 3057 3060 TO 3077 3080 TO 3097 -
    3100 TO 3117 3120 TO 3137 3140 TO 3157 3160 TO 3177 3180 TO 3197 -
    3200 TO 3217 3220 TO 3237 3240 TO 3257 3260 TO 3277 3280 TO 3297 -
    3300 TO 3317 3320 TO 3337 3340 TO 3357 3360 TO 3377 8779 10533 TO 10603 -
    12309 12310 12312 12313 12315 12316 12318 12319 12321 12322 12324 12325 -
    12327 12328 12330 12331 12333 12334 12336 12337 12339 12340 12342 12343 -
    12345 12346 12348 12349 12351 12352 12354 12355 12357 12358 12360 12361 -
    12363 12364 12366 12367 12369 12370 12372 12373 12375 12376 12378 12379 -
    12381 12382 12384
    _WALL 12385 12387 12388 12390 12391 12393 12394 12396 12397 12399 12400 12402 -
    12403 12405 12406 12408 12409 12411 12412 12414 12415 12417 12418 12420 -
    12421 12423 12424 12426 12427 12429 12430 12432 12433 12435 12436 12438 -
    12439 12441 12442 12444 12445 12447 12448 12450 12451 12453 12454 12456 -
    12457 12459 12460 12462 12463 12465 12466 12468 12469 12471 12472 12474 -
    12475 12477 12478 12480 12481 12483 12484 12486 12487 12489 12490 12492 -
    12493 12495 12496 12498 12499 12501 12502 12504 12505 12507 12508 12510 -
    _RAFT 10651 TO 10655 10657 TO 10675 10677 TO 10690 10692 TO 10705 -
    11682 TO 11695 11697 TO 11710 11712 TO 11725 11727 TO 12090 12094 TO 12237 -
    12538 TO 12609 12614 TO 12685
    _DOME-FULL 5087 TO 6323 6325 TO 6342 6346 TO 6362 6367 TO 6382 6388 TO 6400 -
    6409 TO 6421 6430 TO 6445 6451 TO 6467 6472 TO 6489 6493 TO 6512 -
    6514 TO 6598
    _WALL0-2.5 1940 1941 1960 1961 1980 1981 2000 2001 2020 2021 2040 2041 2060 -
    2061 2080 2081 2100 2101 2120 2121 2140 2141 2160 2161 2180 2181 2200 2201 -
    2220 2221 2240 2241 2260 2261 2280 2281 2300 2301 2320 2321 2340 2341 2360 -
    2361 2380 2381 2400 2401 2420 2421 2440 2441 2460 2461 2480 2481 2500 2501 -
    2520 2521 2540 2541 2560 2561 2580 2581 2600 2601 2620 2621 2640 2641 2660 -
    2661 2680 2681 2700 2701 2720 2721 2740 2741 2760 2761 2780 2781 2800 2801 -
    2820 2821 2840 2841 2860 2861 2880 2881 2900 2901 2920 2921 2940 2941 2960 -
    2961 2980 2981 3000 3001 3020 3021 3040 3041 3060 3061 3080 3081 3100 3101 -
    3120 3121 3140 3141 3160 3161 3180 3181 3200 3201 3220 3221 3240 3241 3260 -
    3261 3280 3281 3300 3301 3320 3321 3340 3341 3360 3361 8779 10533 TO 10603
    _WALL2.5-10 1942 TO 1950 1962 TO 1970 1982 TO 1990 2002 TO 2010 2022 TO 2030 -
    2042 TO 2050 2062 TO 2070 2082 TO 2090 2102 TO 2110 2122 TO 2130 -
    2142 TO 2150 2162 TO 2170 2182 TO 2190 2202 TO 2210 2222 TO 2230 -
    2242 TO 2250 2262 TO 2270 2282 TO 2290 2302 TO 2310 2322 TO 2330 -
    2342 TO 2350 2362 TO 2370 2382 TO 2390 2402 TO 2410 2422 TO 2430 -
    2442 TO 2450 2462 TO 2470 2482 TO 2490 2502 TO 2510 2522 TO 2530 -
    2542 TO 2550 2562 TO 2570 2582 TO 2590 2602 TO 2610 2622 TO 2630 -
    2642 TO 2650 2662 TO 2670 2682 TO 2690 2702 TO 2710 2722 TO 2730 -
    2742 TO 2750 2762 TO 2770 2782 TO 2790 2802 TO 2810 2822 TO 2830 -
    2842 TO 2850 2862 TO 2870 2882 TO 2890 2902 TO 2910 2922 TO 2930 -
    2942 TO 2950 2962 TO 2970 2982 TO 2990 3002 3007 TO 3010 3022 3027 TO 3030 -
    3042 3047 TO 3050 3062 TO 3070 3082 TO 3090 3102 TO 3110 3122 TO 3130 3142 -
    3143 TO 3150 3162 TO 3170 3182 TO 3190 3202 TO 3210 3222 TO 3230 3242 TO 3250 -
    3262 TO 3270 3282 TO 3290 3302 TO 3310 3322 TO 3330 3342 TO 3350 -
    3362 TO 3370
    _WALL10-18.5 1951 TO 1957 1971 TO 1977 1991 TO 1997 2011 TO 2017 2031 TO 2037 -
    2051 TO 2057 2071 TO 2077 2091 TO 2097 2111 TO 2117 2131 TO 2137 -
    2151 TO 2157 2171 TO 2177 2191 TO 2197 2211 TO 2217 2231 TO 2237 -
    2251 TO 2257 2271 TO 2277 2291 TO 2297 2311 TO 2317 2331 TO 2337 -
    2351 TO 2357 2371 TO 2377 2391 TO 2397 2411 TO 2417 2431 TO 2437 -
    2451 TO 2457 2471 TO 2477 2491 TO 2497 2511 TO 2517 2531 TO 2537 -
    2551 TO 2557 2571 TO 2577 2591 TO 2597 2611 TO 2617 2631 TO 2637 -
    2651 TO 2657 2671 TO 2677 2691 TO 2697 2711 TO 2717 2731 TO 2737 -
    2751 TO 2757 2771 TO 2777 2791 TO 2797 2811 TO 2817 2831 TO 2837 -
    2851 TO 2857 2871 TO 2877 2891 TO 2897 2911 TO 2917 2931 TO 2937 -
    2951 TO 2957 2971 TO 2977 2991 TO 2997 3011 TO 3017 3031 TO 3037 -
    3051 TO 3057 3071 TO 3077 3091 TO 3097 3111 TO 3117 3131 TO 3137 -
    3151 TO 3157 3171 TO 3177 3191 TO 3197 3211 TO 3217 3231 TO 3237 -
    3251 TO 3257 3271 TO 3277 3291 TO 3297 3311 TO 3317 3331 TO 3337 -
    3351 TO 3357 3371 TO 3377 12309 12310 12312 12313 12315 12316 12318 12319 -
    12321 12322 12324 12325 12327 12328 12330 12331 12333 12334 12336 12337 -
    12339 12340 12342 12343 12345 12346 12348 12349 12351 12352 12354 12355 -
    12357 12358 12360 12361 12363 12364 12366 12367 12369 12370 12372 12373 -
    12375 12376 12378 12379 12381 12382 12384 12385 12387 12388 12390 12391 -
    _WALL10-18.5 12405 12406 12408 12409 12411 12412 12414 12415 12417 12418 -
    _RAFT-WALL-JUNC 10317 TO 10388 10531 10650 10676 10691 10706 10721 10736 -
    10751 10766 10781 10796 10811 10826 10841 10856 10871 10886 10901 10916 -
    10931 10946 10961 10976 10991 11006 11021 11036 11051 11066 11081 11096 -
    11111 11126 11141 11156 11171 11186 11201 11216 11231 11246 11261 11276 -
    11291 11306 11321 11336 11351 11366 11381 11396 11411 11426 11441 11456 -
    11471 11486 11501 11516 11531 11546 11561 11576 11591 11606 11621 11636 -
    11651 11666 11681 11696 11711 11726 12238 TO 12308
    _WALL-SHEAR 1940 TO 1957 1960 TO 1977 1980 TO 1997 2000 TO 2017 2020 TO 2037 -
    2040 TO 2057 2060 TO 2077 2080 TO 2097 2100 TO 2117 2120 TO 2137 -
    2140 TO 2157 2160 TO 2177 2180 TO 2197 2200 TO 2217 2220 TO 2237 -
    2240 TO 2257 2260 TO 2277 2280 TO 2297 2300 TO 2317 2320 TO 2337 -
    2340 TO 2357 2360 TO 2377 2380 TO 2397 2400 TO 2417 2420 TO 2437 -
    2440 TO 2457 2460 TO 2477 2480 TO 2497 2500 TO 2517 2520 TO 2537 -
    2540 TO 2557 2560 TO 2577 2580 TO 2597 2600 TO 2617 2620 TO 2637 -
    2640 TO 2657 2660 TO 2677 2680 TO 2697 2700 TO 2717 2720 TO 2737 -
    2740 TO 2757 2760 TO 2777 2780 TO 2797 2800 TO 2817 2820 TO 2837 -
    2840 TO 2857 2860 TO 2877 2880 TO 2897 2900 TO 2917 2920 TO 2937 -
    2940 TO 2957 2960 TO 2977 2980 TO 2997 3000 TO 3002 3006 TO 3017 -
    3020 TO 3022 3026 TO 3037 3040 TO 3042 3046 TO 3057 3060 TO 3077 -
    3080 TO 3097 3100 TO 3117 3120 TO 3137 3140 TO 3157 3160 TO 3177 -
    3180 TO 3197 3200 TO 3217 3220 TO 3237 3240 TO 3257 3260 TO 3277 -
    3280 TO 3297 3300 TO 3317 3320 TO 3337 3340 TO 3357 3360 TO 3377 8779 10317 -
    10318 TO 10388 10533 TO 10603 12309 12310 12312 12313 12315 12316 12318 12319 -
    _WALL-SHEAR 12381 12382 12384 12385 12387 12388 12390 12391 12393 12394 12396 -
    12397 12399 12400 12402 12403 12405 12406 12408 12409 12411 12412 12414 -
    12415 12417 12418 12420 12421 12423 12424 12426 12427 12429 12430 12432 -
    12433 12435 12436 12438 12439 12441 12442 12444 12445 12447 12448 12450 -
    12451 12453 12454 12456 12457 12459 12460 12462 12463 12465 12466 12468 -
    12469 12471 12472 12474 12475 12477 12478 12480 12481 12483 12484 12486 -
    12487 12489 12490 12492 12493 12495 12496 12498 12499 12501 12502 12504 -
    12505 12507 12508 12510 12511 12513 12514 12516 12517 12519 12520 12522 -
    12523
    _MX-MOMENT-CHECK 1946 1966 1986 2006 2026 2046 2066 2086 2106 2126 2146 2166 -
    2186 2206 2226 2246 2266 2286 2306 2326 2346 2366 2386 2406 2426 2446 2466 -
    2486 2506 2526 2546 2566 2586 2606 2626 2646 2666 2686 2706 2726 2746 2766 -
    2786 2806 2826 2846 2866 2886 2906 2926 2946 2966 2986 3006 3026 3046 3066 -
    3086 3106 3126 3146 3166 3186 3206 3226 3246 3266 3286 3306 3326 3346 3366
    MEMBER
    _RINGBEAM 3379 TO 3413 3415 TO 3431 3433 TO 3450 12528 12533
    _RINGBEAM-2 6599 TO 6670
    JOINT
    FLOOR
    _WALKWAY 12920 TO 12938 12940 12941 12943 12944 12946 12947 12949 12950 12952 -
    12953 TO 12956 12958 TO 12962 12964 TO 12968 12970 TO 12974 12976 TO 12980 -
    12984 12990 12994 TO 12997 13000 TO 13004 13006 TO 13009 13025 13026 13029 -
    13030 TO 13031 13038 TO 13040 13064 TO 13066 13083
    _DOMEWALL-RCC 13011 TO 13021 13025 TO 13032 13036 13037
    _DOMEWALL-STEEL 13027 13028 13038 TO 13043 13046 13047 13059 TO 13068
    _DOMEWALL-STEEL2 13048 13054 13055 13068 TO 13076
    END GROUP DEFINITION
    ELEMENT PROPERTY
    10531 10650 TO 10655 10657 TO 12090 12094 TO 12308 THICKNESS 0.6
    1940 TO 1957 1960 TO 1977 1980 TO 1997 2000 TO 2017 2020 TO 2037 2040 TO 2057 -
    3026 TO 3037 3040 TO 3057 3060 TO 3077 3080 TO 3097 3100 TO 3117 -
    3120 TO 3137 3140 TO 3157 3160 TO 3177 3180 TO 3197 3200 TO 3217 -
    3220 TO 3237 3240 TO 3257 3260 TO 3277 3280 TO 3297 3300 TO 3317 -
    3320 TO 3337 3340 TO 3357 3360 TO 3377 8631 TO 8635 8779 10317 TO 10388 -
    10533 TO 10603 12309 12310 12312 12313 12315 12316 12318 12319 12321 12322 -
    12324 12325 12327 12328 12330 12331 12333 12334 12336 12337 12339 12340 -
    12342 12343 12345 12346 12348 12349 12351 12352 12354 12355 12357 12358 -
    12360 12361 12363 12364 12366 12367 12369 12370 12372 12373 12375 12376 -
    12378 12379 THICKNESS 0.35
    12381 12382 12384 12385 12387 12388 12390 12391 12393 12394 12396 12397 12399 -
    12400 12402 12403 12405 12406 12408 12409 12411 12412 12414 12415 12417 -
    12418 12420 12421 12423 12424 12426 12427 12429 12430 12432 12433 12435 -
    12436 12438 12439 12441 12442 12444 12445 12447 12448 12450 12451 12453 -
    12454 12456 12457 12459 12460 12462 12463 12465 12466 12468 12469 12471 -
    12472 12474 12475 12477 12478 12480 12481 12483 12484 12486 12487 12489 -
    12490 12492 12493 12495 12496 12498 12499 12501 12502 12504 12505 12507 -
    12523 THICKNESS 0.35
    5087 TO 6323 6325 TO 6342 6346 TO 6362 6367 TO 6382 6388 TO 6400 6409 TO 6421 -
    6430 TO 6445 6451 TO 6467 6472 TO 6489 6493 TO 6512 6514 TO 6598 -
    12840 TO 12857 THICKNESS 0.15
    12538 TO 12609 THICKNESS 0.6
    12614 TO 12685 THICKNESS 0.6
    12686 TO 12697 12704 TO 12709 12712 12713 12722 TO 12731 12733 12735 12736 -
    12738 12740 12741 12745 TO 12749 12751 12753 12754 12756 12760 12761 12763 -
    12764 12766 12768 12770 12772 TO 12777 12785 TO 12791 12793 12795 12797 -
    12799 TO 12806 12808 12810 12812 12814 TO 12818 12820 12822 12824 12825 -
    12828 12829 12833 12834 12836 12838 12860 12861 12866 TO 12871 -
    12878 TO 12883 12885 12889 TO 12893 THICKNESS 0.2
    DEFINE MATERIAL START
    ISOTROPIC CONCRETE
    E 2.17185e+007
    POISSON 0.17
    DENSITY 25
    ALPHA 1e-005
    DAMP 0.05
    ISOTROPIC STEEL
    E 2.05e+008
    POISSON 0.3
    DENSITY 76.8195
    ALPHA 1.2e-005
    DAMP 0.03
    TYPE STEEL
    STRENGTH FY 253200 FU 407800 RY 1.5 RT 1.2
    ISOTROPIC DUMMY
    E 2.17185e+007
    POISSON 0.17
    ALPHA 1e-005
    DAMP 0.05
    G 9.28139e+006
    TYPE CONCRETE
    STRENGTH FCU 27579
    END DEFINE MATERIAL
    MEMBER PROPERTY AMERICAN
    3379 TO 3413 3415 TO 3431 3433 TO 3450 12528 12533 PRIS YD 0.5 ZD 0.6
    6599 TO 6670 PRIS YD 0.45 ZD 0.45
    MEMBER PROPERTY INDIAN
    12894 TO 12919 12927 TO 12930 12933 12936 12954 12960 12966 12972 12978 12984 -
    12990 13000 TABLE FR ISMC75
    12939 12942 12945 12948 12951 12957 12963 12969 12975 12981 12998 13005 -
    13010 TABLE ST ISMC75
    12920 TO 12926 12931 12932 12934 12935 12937 12938 12940 12941 12943 12944 -
    12946 12947 12949 12950 12952 12953 12955 12956 12958 12959 12961 12962 -
    12964 12965 12967 12968 12970 12971 12973 12974 12976 12977 12979 12980 -
    12994 TO 12997 13001 TO 13004 13006 TO 13009 13083 TABLE ST ISMC125
    13067 13068 TABLE ST ISMC150
    13011 TO 13021 13025 TO 13032 13036 TO 13043 13046 TO 13048 13054 13055 13059 -
    13060 TO 13066 13069 TO 13082 PRIS YD 0.01 ZD 0.01
    CONSTANTS
    MATERIAL CONCRETE MEMB 1940 TO 1957 1960 TO 1977 1980 TO 1997 2000 TO 2017 -
    2020 TO 2037 2040 TO 2057 2060 TO 2077 2080 TO 2097 2100 TO 2117 -
    2120 TO 2137 2140 TO 2157 2160 TO 2177 2180 TO 2197 2200 TO 2217 -
    2220 TO 2237 2240 TO 2257 2260 TO 2277 2280 TO 2297 2300 TO 2317 -
    2320 TO 2337 2340 TO 2357 2360 TO 2377 2380 TO 2397 2400 TO 2417 -
    2420 TO 2437 2440 TO 2457 2460 TO 2477 2480 TO 2497 2500 TO 2517 -
    2520 TO 2537 2540 TO 2557 2560 TO 2577 2580 TO 2597 2600 TO 2617 -
    2620 TO 2637 2640 TO 2657 2660 TO 2677 2680 TO 2697 2700 TO 2717 -
    2720 TO 2737 2740 TO 2757 2760 TO 2777 2780 TO 2797 2800 TO 2817 -
    2820 TO 2837 2840 TO 2857 2860 TO 2877 2880 TO 2897 2900 TO 2917 -
    2920 TO 2937 2940 TO 2957 2960 TO 2977 2980 TO 2997 3000 TO 3002 -
    3006 TO 3017 3020 TO 3022 3026 TO 3037 3040 TO 3057 3060 TO 3077 -
    3280 TO 3297 3300 TO 3317 3320 TO 3337 3340 TO 3357 3360 TO 3377 -
    3379 TO 3413 3415 TO 3431 3433 TO 3450 5087 TO 6323 6325 TO 6342 -
    6346 TO 6362 6367 TO 6382 6388 TO 6400 6409 TO 6421 6430 TO 6445 -
    6451 TO 6467 6472 TO 6489 6493 TO 6512 6514 TO 6670 8631 TO 8635 8779 10317 -
    10318 TO 10388 10531 10533 TO 10603 10650 TO 10655 10657
    MATERIAL CONCRETE MEMB 10658 TO 12090 12094 TO 12310 12312 12313 12315 12316 -
    12390 12391 12393 12394 12396 12397 12399 12400 12402 12403 12405 12406 -
    12408 12409 12411 12412 12414 12415 12417 12418 12420 12421 12423 12424 -
    12426 12427 12429 12430 12432 12433 12435 12436 12438 12439 12441 12442 -
    12444 12445 12447 12448 12450 12451 12453 12454 12456 12457 12459 12460 -
    12462 12463 12465 12466 12468 12469 12471 12472 12474 12475 12477 12478 -
    12480 12481 12483 12484 12486 12487 12489 12490 12492 12493 12495 12496 -
    12498 12499 12501 12502 12504 12505 12507 12508 12510 12511 12513 12514 -
    12516 12517 12519 12520 12522 12523 12528 12533 12538 TO 12609 -
    12614 TO 12697 12704 TO 12709 12712 12713 12722 TO 12731 12733 12735 12736 -
    12828 12829 12833 12834 12836 12838 12840 TO 12857 12860 12861 -
    12866 TO 12871 12878 TO 12883 12885 12889 TO 12893
    MATERIAL DUMMY MEMB 13011 TO 13021 13025 TO 13032 13036 TO 13043 -
    13046 TO 13048 13054 13055 13059 TO 13066 13069 TO 13082
    MATERIAL STEEL MEMB 12894 TO 12981 12984 12990 12994 TO 12998 13000 TO 13010 -
    13067 13068 13083
    SUPPORTS
    10531 10650 TO 10655 10657 TO 12090 12094 TO 12308 12538 TO 12609 -
    12614 TO 12685 PLATE MAT DIRECT Y SUBGRADE 12254 PRINT
    LOAD 1 LOADTYPE Dead TITLE DEAD LOAD & PCC LOAD
    SELFWEIGHT Y -1
    ELEMENT LOAD
    12840 TO 12857 PR GY -1.5
    10651 TO 10655 10657 TO 10675 10677 TO 10690 10692 TO 10705 10707 TO 10720 -
    10722 TO 10735 10737 TO 10750 10752 TO 10765 10767 TO 10780 10782 TO 10795 -
    10797 TO 10810 10812 TO 10825 10827 TO 10840 10842 TO 10855 10857 TO 10870 -
    10872 TO 10885 10887 TO 10900 10902 TO 10915 10917 TO 10930 10932 TO 10945 -
    10947 TO 10960 10962 TO 10975 10977 TO 10990 10992 TO 11005 11007 TO 11020 -
    11022 TO 11035 11037 TO 11050 11052 TO 11065 11067 TO 11080 11082 TO 11095 -
    11097 TO 11110 11112 TO 11125 11127 TO 11140 11142 TO 11155 11157 TO 11170 -
    11172 TO 11185 11187 TO 11200 11202 TO 11215 11217 TO 11230 11232 TO 11245 -
    11247 TO 11260 11262 TO 11275 11277 TO 11290 11292 TO 11305 11307 TO 11320 -
    11322 TO 11335 11337 TO 11350 11352 TO 11365 11367 TO 11380 11382 TO 11395 -
    11397 TO 11410 11412 TO 11425 11427 TO 11440 11442 TO 11455 11457 TO 11470 -
    11472 TO 11485 11487 TO 11500 11502 TO 11515 11517 TO 11530 11532 TO 11545 -
    11547 TO 11560 11562 TO 11575 11577 TO 11590 11592 TO 11605 11607 TO 11620 -
    11622 TO 11635 11637 TO 11650 11652 TO 11665 11667 TO 11680 11682 TO 11695 -
    11697 TO 11710 11712 TO 11725 11727 TO 12090 PR -17.66
    MEMBER LOAD
    6599 TO 6670 UNI GY -8.75
    3379 TO 3413 3415 TO 3431 3433 TO 3450 12528 12533 UNI GY -4.3
    6599 TO 6670 UNI GY -2.77
    ELEMENT LOAD
    5650 TO 5653 5665 TO 5716 5728 TO 5737 5755 TO 5758 PR -4.8
    FLOOR LOAD
    _WALKWAY FLOAD -0.3 GY
    MEMBER LOAD
    12994 TO 12997 13001 TO 13004 13006 TO 13009 13011 TO 13021 13025 TO 13032 -
    13036 TO 13043 13046 TO 13048 13054 13055 13059 TO 13066 13069 TO 13081 -
    13082 UNI GY -1.5
    FLOOR LOAD
    _DOMEWALL-STEEL FLOAD -0.3 GY
    FLOOR LOAD
    _DOMEWALL-STEEL2 FLOAD -0.3 GY
    MEMBER LOAD
    13011 TO 13018 13025 TO 13031 UNI GY -4.506
    13019 TO 13021 13032 13036 13037 13077 TO 13082 UNI GY -4.46
    LOAD 2 LOADTYPE Live TITLE LIVE LOAD
    ELEMENT LOAD
    12840 TO 12857 PR GY -5
    5101 TO 5107 5122 TO 5128 5143 TO 5149 5164 TO 5170 5185 TO 5191 5206 TO 5212 -
    5227 TO 5233 5248 TO 5254 5269 TO 5275 5290 TO 5296 5311 TO 5317 -
    5332 TO 5338 5353 TO 5359 5374 TO 5380 5395 TO 5401 5416 TO 5422 -
    5437 TO 5443 5458 TO 5464 5479 TO 5485 5500 TO 5506 5521 TO 5527 -
    5542 TO 5548 5563 TO 5569 5584 TO 5590 5605 TO 5611 5626 TO 5632 -
    5647 TO 5653 5668 TO 5674 5689 TO 5695 5710 TO 5716 5731 TO 5737 -
    5752 TO 5758 5773 TO 5779 5794 TO 5800 5815 TO 5821 5836 TO 5842 -
    5857 TO 5863 5878 TO 5884 5899 TO 5905 5920 TO 5926 5941 TO 5947 -
    5962 TO 5968 5983 TO 5989 6004 TO 6010 6025 TO 6031 6046 TO 6052 -
    6067 TO 6073 6088 TO 6094 6109 TO 6115 6130 TO 6136 6151 TO 6157 -
    6172 TO 6178 6193 TO 6199 6214 TO 6220 6235 TO 6241 6256 TO 6262 -
    6277 TO 6283 6298 TO 6304 6319 TO 6323 6325 6340 TO 6342 6346 6361 6362 6367 -
    6382 6388 6409 6430 6445 6451 6466 6467 6472 6487 TO 6489 6493 6508 TO 6512 -
    6514 6529 TO 6535 6550 TO 6556 6571 TO 6577 6592 TO 6598 12840 TO 12856 -
    12857 PR 5
    FLOOR LOAD
    _WALKWAY FLOAD -2.5 GY
    FLOOR LOAD
    _DOMEWALL-STEEL2 FLOAD -2.5 GY
    _DOMEWALL-STEEL FLOAD -2.5 GY
    MEMBER LOAD
    13011 TO 13021 13025 TO 13032 13036 13037 13077 TO 13082 UNI GY -3
    LOAD 3 LOADTYPE Soil TITLE SOIL PRESSURE LOAD ON PROJECTION
    ELEMENT LOAD
    12094 TO 12237 12538 TO 12609 12614 TO 12685 PR -82
    LOAD 4 LOADTYPE Soil TITLE SURCHARGE LOAD
    ELEMENT LOAD
    1940 TO 1942 1960 TO 1962 1980 TO 1982 2000 TO 2002 2020 TO 2022 2040 TO 2042 -
    2060 TO 2062 2080 TO 2082 2100 TO 2102 2120 TO 2122 2140 TO 2142 -
    2160 TO 2162 2180 TO 2182 2200 TO 2202 2220 TO 2222 2240 TO 2242 -
    2260 TO 2262 2280 TO 2282 2300 TO 2302 2320 TO 2322 2340 TO 2342 -
    2360 TO 2362 2380 TO 2382 2400 TO 2402 2420 TO 2422 2440 TO 2442 -
    2460 TO 2462 2480 TO 2482 2500 TO 2502 2520 TO 2522 2540 TO 2542 -
    2560 TO 2562 2580 TO 2582 2600 TO 2602 2620 TO 2622 2640 TO 2642 -
    2660 TO 2662 2680 TO 2682 2700 TO 2702 2720 TO 2722 2740 TO 2742 -
    2760 TO 2762 2780 TO 2782 2800 TO 2802 2820 TO 2822 2840 TO 2842 -
    2860 TO 2862 2880 TO 2882 2900 TO 2902 2920 TO 2922 2940 TO 2942 -
    2960 TO 2962 2980 TO 2982 3000 TO 3002 3020 TO 3022 3040 TO 3042 -
    3060 TO 3062 3080 TO 3082 3100 TO 3102 3120 TO 3122 3140 TO 3142 -
    3160 TO 3162 3180 TO 3182 3200 TO 3202 3220 TO 3222 3240 TO 3242 -
    3260 TO 3262 3280 TO 3282 3300 TO 3302 3320 TO 3322 3340 TO 3342 -
    3360 TO 3362 8779 10533 TO 10603 PR -3.4
    LOAD 5 LOADTYPE Fluids TITLE LIQUID & GAS PRESSURE INSIDE DIGESTER
    ELEMENT LOAD
    *5087 TO 5091 5108 TO 5112 5129 TO 5133 5150 TO 5154 5171 TO 5175 5192 TO 5196 -
    *5213 TO 5217 5234 TO 5238 5255 TO 5259 5276 TO 5280 5297 TO 5301 -
    *5318 TO 5322 5339 TO 5343 5360 TO 5364 5381 TO 5385 5402 TO 5406 -
    *5423 TO 5427 5444 TO 5448 6221 TO 6225 6242 TO 6246 6263 TO 6267 -
    *6284 TO 6288 6305 TO 6309 6326 TO 6330 6347 TO 6351 6368 TO 6372 -
    *6389 TO 6393 6410 TO 6414 6431 TO 6435 6452 TO 6456 6473 TO 6477 -
    *6494 TO 6498 6515 TO 6519 6536 TO 6540 6557 TO 6561 6578 TO 6581 -
    *6582 TRAP GX Y 41.526 31.866
    *5092 TO 5095 5113 TO 5116 5134 TO 5137 5155 TO 5158 5176 TO 5179 5197 TO 5200 -
    *5218 TO 5221 5239 TO 5242 5260 TO 5263 5281 TO 5284 5302 TO 5305 -
    *5323 TO 5326 5344 TO 5347 5365 TO 5368 5386 TO 5389 5407 TO 5410 -
    *5428 TO 5431 5449 TO 5452 6226 TO 6229 6247 TO 6250 6268 TO 6271 -
    *6289 TO 6292 6310 TO 6313 6331 TO 6334 6352 TO 6355 6373 TO 6376 -
    *6394 TO 6397 6415 TO 6418 6436 TO 6439 6457 TO 6460 6478 TO 6481 -
    *6499 TO 6502 6520 TO 6523 6541 TO 6544 6562 TO 6565 6583 TO 6585 -
    *6586 TRAP GX Y 31.866 23.9
    *5096 TO 5099 5117 TO 5120 5138 TO 5141 5159 TO 5162 5180 TO 5183 5201 TO 5204 -
    *5222 TO 5225 5243 TO 5246 5264 TO 5267 5285 TO 5288 5306 TO 5309 -
    *5327 TO 5330 5348 TO 5351 5369 TO 5372 5390 TO 5393 5411 TO 5414 -
    *5432 TO 5435 5453 TO 5456 6230 TO 6233 6251 TO 6254 6272 TO 6275 -
    *6293 TO 6296 6314 TO 6317 6335 TO 6338 6356 TO 6359 6377 TO 6380 -
    *6398 TO 6401 6419 TO 6422 6440 TO 6443 6461 TO 6464 6482 TO 6485 -
    *6503 TO 6506 6524 TO 6527 6545 TO 6548 6566 TO 6569 6587 TO 6589 -
    *6590 TRAP GX Y 23.9 15.933
    *5100 TO 5103 5121 TO 5124 5142 TO 5145 5163 TO 5166 5184 TO 5187 5205 TO 5208 -
    *5226 TO 5229 5247 TO 5250 5268 TO 5271 5289 TO 5292 5310 TO 5313 -
    *5331 TO 5334 5352 TO 5355 5373 TO 5376 5394 TO 5397 5415 TO 5418 -
    *5436 TO 5439 5457 TO 5460 6234 TO 6237 6255 TO 6258 6276 TO 6279 -
    *6297 TO 6300 6318 TO 6321 6339 TO 6342 6360 TO 6363 6381 TO 6383 -
    *6444 TO 6446 6465 TO 6468 6486 TO 6489 6507 TO 6510 6528 TO 6531 -
    *6549 TO 6552 6570 TO 6573 6591 TO 6594 TRAP GX Y 15.933 7.967
    *5104 TO 5106 5125 TO 5127 5146 TO 5148 5167 TO 5169 5188 TO 5190 5209 TO 5211 -
    *5230 TO 5232 5251 TO 5253 5272 TO 5274 5293 TO 5295 5314 TO 5316 -
    *5335 TO 5337 5356 TO 5358 5377 TO 5379 5398 TO 5400 5419 TO 5421 -
    *5440 TO 5442 5461 TO 5463 6238 TO 6240 6259 TO 6261 6280 TO 6282 -
    *6301 TO 6303 6322 6323 6343 6490 6511 6512 6532 TO 6534 6553 TO 6555 6574 -
    *6575 TO 6576 6595 TO 6597 TRAP GX Y 7.967 0
    *5465 TO 5469 5486 TO 5490 5507 TO 5511 5528 TO 5532 5549 TO 5553 5570 TO 5574 -
    *5591 TO 5595 5612 TO 5616 5633 TO 5637 5654 TO 5658 5675 TO 5679 -
    *5696 TO 5700 5717 TO 5721 5738 TO 5742 5759 TO 5763 5780 TO 5784 -
    *5801 TO 5805 5822 TO 5826 5843 TO 5847 5864 TO 5868 5885 TO 5889 -
    *5906 TO 5910 5927 TO 5931 5948 TO 5952 5969 TO 5973 5990 TO 5994 -
    *6011 TO 6015 6032 TO 6036 6053 TO 6057 6074 TO 6078 6095 TO 6099 -
    *6116 TO 6120 6137 TO 6141 6158 TO 6162 6179 TO 6183 6200 TO 6203 -
    *6204 TRAP GX Y -41.526 -31.866
    *5470 TO 5473 5491 TO 5494 5512 TO 5515 5533 TO 5536 5554 TO 5557 5575 TO 5578 -
    *5596 TO 5599 5617 TO 5620 5638 TO 5641 5659 TO 5662 5680 TO 5683 -
    *5701 TO 5704 5722 TO 5725 5743 TO 5746 5764 TO 5767 5785 TO 5788 -
    *5806 TO 5809 5827 TO 5830 5848 TO 5851 5869 TO 5872 5890 TO 5893 -
    *5911 TO 5914 5932 TO 5935 5953 TO 5956 5974 TO 5977 5995 TO 5998 -
    *6016 TO 6019 6037 TO 6040 6058 TO 6061 6079 TO 6082 6100 TO 6103 -
    *6121 TO 6124 6142 TO 6145 6163 TO 6166 6184 TO 6187 6205 TO 6207 -
    *6208 TRAP GX Y -31.866 -23.9
    *5474 TO 5477 5495 TO 5498 5516 TO 5519 5537 TO 5540 5558 TO 5561 5579 TO 5582 -
    *5600 TO 5603 5621 TO 5624 5642 TO 5645 5663 TO 5666 5684 TO 5687 -
    *5705 TO 5708 5726 TO 5729 5747 TO 5750 5768 TO 5771 5789 TO 5792 -
    *5810 TO 5813 5831 TO 5834 5852 TO 5855 5873 TO 5876 5894 TO 5897 -
    *5915 TO 5918 5936 TO 5939 5957 TO 5960 5978 TO 5981 5999 TO 6002 -
    *6020 TO 6023 6041 TO 6044 6062 TO 6065 6083 TO 6086 6104 TO 6107 -
    *6125 TO 6128 6146 TO 6149 6167 TO 6170 6188 TO 6191 6209 TO 6211 -
    *6212 TRAP GX Y -23.9 -15.933
    *5478 TO 5481 5499 TO 5502 5520 TO 5523 5541 TO 5544 5562 TO 5565 5583 TO 5586 -
    *5604 TO 5607 5625 TO 5628 5646 TO 5649 5667 TO 5670 5688 TO 5691 -
    *5709 TO 5712 5730 TO 5733 5751 TO 5754 5772 TO 5775 5793 TO 5796 -
    *5814 TO 5817 5835 TO 5838 5856 TO 5859 5877 TO 5880 5898 TO 5901 -
    *5919 TO 5922 5940 TO 5943 5961 TO 5964 5982 TO 5985 6003 TO 6006 -
    *6024 TO 6027 6045 TO 6048 6066 TO 6069 6087 TO 6090 6108 TO 6111 -
    *6129 TO 6132 6150 TO 6153 6171 TO 6174 6192 TO 6195 6213 TO 6215 -
    *6216 TRAP GX Y -15.933 -7.967
    *5482 TO 5484 5503 TO 5505 5524 TO 5526 5545 TO 5547 5566 TO 5568 5587 TO 5589 -
    *5608 TO 5610 5629 TO 5631 5650 TO 5652 5671 TO 5673 5692 TO 5694 -
    *5713 TO 5715 5734 TO 5736 5755 TO 5757 5776 TO 5778 5797 TO 5799 -
    *5818 TO 5820 5839 TO 5841 5860 TO 5862 5881 TO 5883 5902 TO 5904 -
    *5923 TO 5925 5944 TO 5946 5965 TO 5967 5986 TO 5988 6007 TO 6009 -
    *6028 TO 6030 6049 TO 6051 6070 TO 6072 6091 TO 6093 6112 TO 6114 -
    *6133 TO 6135 6154 TO 6156 6175 TO 6177 6196 TO 6198 6217 TO 6218 -
    *6219 TRAP GX Y -7.967 0
    11697 TO 11710 11712 TO 11725 11727 TO 12090 PR -202.5
    10317 TO 10388 PR 220.73
    8779 10533 TO 10603 TRAP Y 220.73 213.65
    3140 3160 3180 3200 3220 3240 3260 3280 3300 3320 3340 -
    3360 TRAP Y 213.65 206.22
    3141 3161 3181 3201 3221 3241 3261 3281 3301 3321 3341 -
    3361 TRAP Y 206.22 197.78
    3142 3162 3182 3202 3222 3242 3262 3282 3302 3322 3342 -
    3362 TRAP Y 197.78 189.33
    3203 3223 3243 3263 3283 3303 3323 3343 3363 TRAP Y 189.33 180.89
    3204 3224 3244 3264 3284 3304 3324 3344 3364 TRAP Y 180.89 172.71
    3205 3225 3245 3265 3285 3305 3325 3345 3365 TRAP Y 172.71 164.53
    3146 3166 3186 3206 3226 3246 3266 3286 3306 3326 3346 -
    3366 TRAP Y 164.53 156.35
    3147 3167 3187 3207 3227 3247 3267 3287 3307 3327 3347 -
    3367 TRAP Y 156.35 148.18
    1948 1968 1988 2008 2028 2048 2068 2088 2108 2128 2148 2168 2188 2208 2228 -
    2248 2268 2288 2308 2328 2348 2368 2388 2408 2428 2448 2468 2488 2508 2528 -
    2548 2568 2588 2608 2628 2648 2668 2688 2708 2728 2748 2768 2788 2808 2828 -
    2848 2868 2888 2908 2928 2948 2968 2988 3008 3028 3048 3068 3088 3108 3128 -
    3148 3168 3188 3208 3228 3248 3268 3288 3308 3328 3348 -
    3368 TRAP Y 148.18 140
    1949 1969 1989 2009 2029 2049 2069 2089 2109 2129 2149 2169 2189 2209 2229 -
    2249 2269 2289 2309 2329 2349 2369 2389 2409 2429 2449 2469 2489 2509 2529 -
    2549 2569 2589 2609 2629 2649 2669 2689 2709 2729 2749 2769 2789 2809 2829 -
    2849 2869 2889 2909 2929 2949 2969 2989 3009 3029 3049 3069 3089 3109 3129 -
    3149 3169 3189 3209 3229 3249 3269 3289 3309 3329 3349 -
    3369 TRAP Y 140 131.82
    1950 1970 1990 2010 2030 2050 2070 2090 2110 2130 2150 2170 2190 2210 2230 -
    2250 2270 2290 2310 2330 2350 2370 2390 2410 2430 2450 2470 2490 2510 2530 -
    2550 2570 2590 2610 2630 2650 2670 2690 2710 2730 2750 2770 2790 2810 2830 -
    2850 2870 2890 2910 2930 2950 2970 2990 3010 3030 3050 3070 3090 3110 3130 -
    3150 3170 3190 3210 3230 3250 3270 3290 3310 3330 3350 -
    3370 TRAP Y 131.82 123.64
    1951 1971 1991 2011 2031 2051 2071 2091 2111 2131 2151 2171 2191 2211 2231 -
    2251 2271 2291 2311 2331 2351 2371 2391 2411 2431 2451 2471 2491 2511 2531 -
    2551 2571 2591 2611 2631 2651 2671 2691 2711 2731 2751 2771 2791 2811 2831 -
    2851 2871 2891 2911 2931 2951 2971 2991 3011 3031 3051 3071 3091 3111 3131 -
    3151 3171 3191 3211 3231 3251 3271 3291 3311 3331 3351 -
    3371 TRAP Y 123.64 115.5
    1952 1972 1992 2012 2032 2052 2072 2092 2112 2132 2152 2172 2192 2212 2232 -
    2252 2272 2292 2312 2332 2352 2372 2392 2412 2432 2452 2472 2492 2512 2532 -
    2552 2572 2592 2612 2632 2652 2672 2692 2712 2732 2752 2772 2792 2812 2832 -
    2852 2872 2892 2912 2932 2952 2972 2992 3012 3032 3052 3072 3092 3112 3132 -
    3152 3172 3192 3212 3232 3252 3272 3292 3312 3332 3352 -
    3372 TRAP Y 115.5 106.6
    1953 1973 1993 2013 2033 2053 2073 2093 2113 2133 2153 2173 2193 2213 2233 -
    2253 2273 2293 2313 2333 2353 2373 2393 2413 2433 2453 2473 2493 2513 2533 -
    2553 2573 2593 2613 2633 2653 2673 2693 2713 2733 2753 2773 2793 2813 2833 -
    2853 2873 2893 2913 2933 2953 2973 2993 3013 3033 3053 3073 3093 3113 3133 -
    3153 3173 3193 3213 3233 3253 3273 3293 3313 3333 3353 -
    3373 TRAP Y 106.6 97.75
    1954 1974 1994 2014 2034 2054 2074 2094 2114 2134 2154 2174 2194 2214 2234 -
    2254 2274 2294 2314 2334 2354 2374 2394 2414 2434 2454 2474 2494 2514 2534 -
    2554 2574 2594 2614 2634 2654 2674 2694 2714 2734 2754 2774 2794 2814 2834 -
    2854 2874 2894 2914 2934 2954 2974 2994 3014 3034 3054 3074 3094 3114 3134 -
    3154 3174 3194 3214 3234 3254 3274 3294 3314 3334 3354 -
    3374 TRAP Y 97.75 88.89
    1955 1975 1995 2015 2035 2055 2075 2095 2115 2135 2155 2175 2195 2215 2235 -
    2255 2275 2295 2315 2335 2355 2375 2395 2415 2435 2455 2475 2495 2515 2535 -
    2555 2575 2595 2615 2635 2655 2675 2695 2715 2735 2755 2775 2795 2815 2835 -
    2855 2875 2895 2915 2935 2955 2975 2995 3015 3035 3055 3075 3095 3115 3135 -
    3155 3175 3195 3215 3235 3255 3275 3295 3315 3335 3355 -
    3375 TRAP Y 88.89 80.03
    1956 1976 1996 2016 2036 2056 2076 2096 2116 2136 2156 2176 2196 2216 2236 -
    2256 2276 2296 2316 2336 2356 2376 2396 2416 2436 2456 2476 2496 2516 2536 -
    2556 2576 2596 2616 2636 2656 2676 2696 2716 2736 2756 2776 2796 2816 2836 -
    2856 2876 2896 2916 2936 2956 2976 2996 3016 3036 3056 3076 3096 3116 3136 -
    3156 3176 3196 3216 3236 3256 3276 3296 3316 3336 3356 -
    3376 TRAP Y 80.03 70.04
    1957 1977 1997 2017 2037 2057 2077 2097 2117 2137 2157 2177 2197 2217 2237 -
    2257 2277 2297 2317 2337 2357 2377 2397 2417 2437 2457 2477 2497 2517 2537 -
    2557 2577 2597 2617 2637 2657 2677 2697 2717 2737 2757 2777 2797 2817 2837 -
    2857 2877 2897 2917 2937 2957 2977 2997 3017 3037 3057 3077 3097 3117 3137 -
    3157 3177 3197 3217 3237 3257 3277 3297 3317 3337 3357 -
    3377 TRAP Y 70.04 59.84
    12309 12312 12315 12318 12321 12324 12327 12330 12333 12336 12339 12342 12345 -
    12348 12351 12354 12357 12360 12363 12366 12369 12372 12375 12378 12381 -
    12384 12387 12390 12393 12396 12399 12402 12405 12408 12411 12414 12417 -
    12420 12423 12426 12429 12432 12435 12438 12441 12444 12447 12450 12453 -
    12456 12459 12462 12465 12468 12471 12474 12477 12480 12483 12486 12489 -
    12492 12495 12498 12501 12504 12507 12510 12513 12516 12519 -
    12522 TRAP Y 59.84 49.65
    12310 12313 12316 12319 12322 12325 12328 12331 12334 12337 12340 12343 12346 -
    12349 12352 12355 12358 12361 12364 12367 12370 12373 12376 12379 12382 -
    12385 12388 12391 12394 12397 12400 12403 12406 12409 12412 12415 12418 -
    12421 12424 12427 12430 12433 12436 12439 12442 12445 12448 12451 12454 -
    12457 12460 12463 12466 12469 12472 12475 12478 12481 12484 12487 12490 -
    12493 12496 12499 12502 12505 12508 12511 12514 12517 12520 -
    12523 TRAP Y 49.65 39.45
    5103 TO 5105 5124 TO 5126 5145 TO 5147 5166 TO 5168 5187 TO 5189 5208 TO 5210 -
    5229 TO 5231 5250 TO 5252 5271 TO 5273 5292 TO 5294 5313 TO 5315 -
    5334 TO 5336 5355 TO 5357 5376 TO 5378 5397 TO 5399 5418 TO 5420 -
    5439 TO 5441 5460 TO 5462 5481 TO 5483 5502 TO 5504 5523 TO 5525 -
    5544 TO 5546 5565 TO 5567 5586 TO 5588 5607 TO 5609 5628 TO 5630 -
    5649 TO 5651 5670 TO 5672 5691 TO 5693 5712 TO 5714 5733 TO 5735 -
    5754 TO 5756 5775 TO 5777 5796 TO 5798 5817 TO 5819 5838 TO 5840 -
    5859 TO 5861 5880 TO 5882 5901 TO 5903 5922 TO 5924 5943 TO 5945 -
    5964 TO 5966 5985 TO 5987 6006 TO 6008 6027 TO 6029 6048 TO 6050 -
    6069 TO 6071 6090 TO 6092 6111 TO 6113 6132 TO 6134 6153 TO 6155 -
    6174 TO 6176 6195 TO 6197 6216 TO 6218 6237 TO 6239 6258 TO 6260 -
    6279 TO 6281 6300 TO 6302 6321 6322 6342 6489 6510 6511 6531 TO 6533 6552 -
    6553 TO 6554 6573 TO 6575 6594 TO 6596 TRAP Y 2.63 0
    5100 TO 5102 5121 TO 5123 5142 TO 5144 5163 TO 5165 5184 TO 5186 5205 TO 5207 -
    5226 TO 5228 5247 TO 5249 5268 TO 5270 5289 TO 5291 5310 TO 5312 -
    5331 TO 5333 5352 TO 5354 5373 TO 5375 5394 TO 5396 5415 TO 5417 -
    5436 TO 5438 5457 TO 5459 5478 TO 5480 5499 TO 5501 5520 TO 5522 -
    5541 TO 5543 5562 TO 5564 5583 TO 5585 5604 TO 5606 5625 TO 5627 -
    5646 TO 5648 5667 TO 5669 5688 TO 5690 5709 TO 5711 5730 TO 5732 -
    5751 TO 5753 5772 TO 5774 5793 TO 5795 5814 TO 5816 5835 TO 5837 -
    5856 TO 5858 5877 TO 5879 5898 TO 5900 5919 TO 5921 5940 TO 5942 -
    5961 TO 5963 5982 TO 5984 6003 TO 6005 6024 TO 6026 6045 TO 6047 -
    6066 TO 6068 6087 TO 6089 6108 TO 6110 6129 TO 6131 6150 TO 6152 -
    6171 TO 6173 6192 TO 6194 6213 TO 6215 6234 TO 6236 6255 TO 6257 -
    6276 TO 6278 6297 TO 6299 6318 TO 6320 6339 TO 6341 6360 TO 6362 -
    6465 TO 6467 6486 TO 6488 6507 TO 6509 6528 TO 6530 6549 TO 6551 -
    6570 TO 6572 6591 TO 6593 TRAP Y 5.3 2.63
    5432 TO 5435 5453 TO 5456 5474 TO 5477 5495 TO 5498 5516 TO 5519 -
    5537 TO 5540 5558 TO 5561 5579 TO 5582 5600 TO 5603 5621 TO 5624 -
    5642 TO 5645 5663 TO 5666 5684 TO 5687 5705 TO 5708 5726 TO 5729 -
    5747 TO 5750 5768 TO 5771 5789 TO 5792 5810 TO 5813 5831 TO 5834 -
    5852 TO 5855 5873 TO 5876 5894 TO 5897 5915 TO 5918 5936 TO 5939 -
    5957 TO 5960 5978 TO 5981 5999 TO 6002 6020 TO 6023 6041 TO 6044 -
    6062 TO 6065 6083 TO 6086 6104 TO 6107 6125 TO 6128 6146 TO 6149 -
    6167 TO 6170 6188 TO 6191 6209 TO 6212 6230 TO 6233 6251 TO 6254 -
    6272 TO 6275 6293 TO 6296 6314 TO 6317 6335 TO 6338 6356 TO 6359 -
    6377 TO 6379 6398 TO 6400 6419 TO 6421 6440 TO 6442 6461 TO 6464 -
    6482 TO 6485 6503 TO 6506 6524 TO 6527 6545 TO 6548 6566 TO 6569 -
    6587 TO 6590 TRAP Y 8 5.3
    5428 TO 5431 5449 TO 5452 5470 TO 5473 5491 TO 5494 5512 TO 5515 -
    5533 TO 5536 5554 TO 5557 5575 TO 5578 5596 TO 5599 5617 TO 5620 -
    5638 TO 5641 5659 TO 5662 5680 TO 5683 5701 TO 5704 5722 TO 5725 -
    5743 TO 5746 5764 TO 5767 5785 TO 5788 5806 TO 5809 5827 TO 5830 -
    5848 TO 5851 5869 TO 5872 5890 TO 5893 5911 TO 5914 5932 TO 5935 -
    5953 TO 5956 5974 TO 5977 5995 TO 5998 6016 TO 6019 6037 TO 6040 -
    6058 TO 6061 6079 TO 6082 6100 TO 6103 6121 TO 6124 6142 TO 6145 -
    6163 TO 6166 6184 TO 6187 6205 TO 6208 6226 TO 6229 6247 TO 6250 -
    6268 TO 6271 6289 TO 6292 6310 TO 6313 6331 TO 6334 6352 TO 6355 -
    6373 TO 6376 6394 TO 6397 6415 TO 6418 6436 TO 6439 6457 TO 6460 -
    6478 TO 6481 6499 TO 6502 6520 TO 6523 6541 TO 6544 6562 TO 6565 -
    6583 TO 6586 TRAP Y 10.6 8
    5423 TO 5427 5444 TO 5448 5465 TO 5469 5486 TO 5490 5507 TO 5511 -
    5528 TO 5532 5549 TO 5553 5570 TO 5574 5591 TO 5595 5612 TO 5616 -
    5633 TO 5637 5654 TO 5658 5675 TO 5679 5696 TO 5700 5717 TO 5721 -
    5738 TO 5742 5759 TO 5763 5780 TO 5784 5801 TO 5805 5822 TO 5826 -
    5843 TO 5847 5864 TO 5868 5885 TO 5889 5906 TO 5910 5927 TO 5931 -
    5948 TO 5952 5969 TO 5973 5990 TO 5994 6011 TO 6015 6032 TO 6036 -
    6053 TO 6057 6074 TO 6078 6095 TO 6099 6116 TO 6120 6137 TO 6141 -
    6158 TO 6162 6179 TO 6183 6200 TO 6204 6221 TO 6225 6242 TO 6246 -
    6263 TO 6267 6284 TO 6288 6305 TO 6309 6326 TO 6330 6347 TO 6351 -
    6368 TO 6372 6389 TO 6393 6410 TO 6414 6431 TO 6435 6452 TO 6456 -
    6473 TO 6477 6494 TO 6498 6515 TO 6519 6536 TO 6540 6557 TO 6561 -
    6578 TO 6582 TRAP Y 13.1 10.6
    LOAD 6 LOADTYPE Soil TITLE OUTISDE SOIL & WATER TABLE IN DIGESTER
    ELEMENT LOAD
    1940 1941 1960 1961 1980 1981 2000 2001 2020 2021 2040 2041 2060 2061 2080 -
    2081 2100 2101 2120 2121 2140 2141 2160 2161 2180 2181 2200 2201 2220 2221 -
    2240 2241 2260 2261 2280 2281 2300 2301 2320 2321 2340 2341 2360 2361 2380 -
    2381 2400 2401 2420 2421 2440 2441 2460 2461 2480 2481 2500 2501 2520 2521 -
    2540 2541 2560 2561 2580 2581 2600 2601 2620 2621 2640 2641 2660 2661 2680 -
    2681 2700 2701 2720 2721 2740 2741 2760 2761 2780 2781 2800 2801 2820 2821 -
    2840 2841 2860 2861 2880 2881 2900 2901 2920 2921 2940 2941 2960 2961 2980 -
    2981 3000 3001 3020 3021 3040 3041 3060 3061 3080 3081 3100 3101 3120 3121 -
    3140 3141 3160 3161 3180 3181 3200 3201 3220 3221 3240 3241 3260 3261 3280 -
    3281 3300 3301 3320 3321 3340 3341 3360 3361 8779 10317 TO 10388 -
    10533 TO 10603 PR -10.2
    3142 3162 3182 3202 3222 3242 3262 3282 3302 3322 3342 3362 TRAP Y -10.2 0
    10317 TO 10388 TRAP Y -34.84 -24.12
    8779 10533 TO 10603 TRAP Y -24.12 -16.08
    3360 TRAP Y -16.08 -8.04
    3141 3161 3181 3201 3221 3241 3261 3281 3301 3321 3341 3361 TRAP Y -8.04 0
    LOAD 7 LOADTYPE Temperature TITLE TEMPERATURE LOAD
    TEMPERATURE LOAD
    3320 TO 3337 3340 TO 3357 3360 TO 3377 3379 TO 3413 3415 TO 3431 -
    3433 TO 3450 5087 TO 6323 6325 TO 6342 6346 TO 6362 6367 TO 6382 -
    6388 TO 6400 6409 TO 6421 6430 TO 6445 6451 TO 6467 6472 TO 6489 -
    6493 TO 6512 6514 TO 6670 8631 TO 8635 8779 10317 TO 10388 10531 -
    10533 TO 10603 10650 TO 10655 10657 TEMP 7.5
    10658 TO 12090 12094 TO 12310 12312 12313 12315 12316 12318 12319 12321 12322 -
    12378 12379 12381 12382 12384 12385 12387 12388 12390 12391 12393 12394 -
    12396 12397 12399 12400 12402 12403 12405 12406 12408 12409 12411 12412 -
    12414 12415 12417 12418 12420 12421 12423 12424 12426 12427 12429 12430 -
    12432 12433 12435 12436 12438 12439 12441 12442 12444 12445 12447 12448 -
    12450 12451 12453 12454 12456 12457 12459 12460 12462 12463 12465 12466 -
    12468 12469 12471 12472 12474 12475 12477 12478 12480 12481 12483 12484 -
    12486 12487 12489 12490 12492 12493 12495 12496 12498 12499 12501 12502 -
    12504 12505 12507 12508 12510 12511 12513 12514 12516 12517 12519 12520 -
    12522 12523 12528 12533 12538 TO 12609 12614 TO 12697 12704 TO 12709 12712 -
    12713 12722 TO 12731 12733 12735 12736 12738 12740 12741 12745 TO 12749 -
    12751 12753 12754 12756 12760 12761 12763 12764 12766 12768 12770 -
    12772 TO 12777 12785 TO 12791 12793 12795 12797 12799 TO 12806 12808 12810 -
    12812 12814 TO 12818 12820 12822 12824 12825 12828 12829 12833 12834 12836 -
    12838 12840 TO 12857 12860 12861 12866 TO 12871 12878 TO 12883 12885 12889 -
    12890 TO 12981 12984 12990 12994 TO 12998 13000 TO 13021 13025 TO 13032 13036 -
    13037 TO 13043 13046 TO 13048 13054 13055 13059 TO 13083 TEMP 7.5
    LOAD 8 LOADTYPE Accidental TITLE EXPLOSION LOAD
    ELEMENT LOAD
    6514 6529 TO 6535 6550 TO 6556 6571 TO 6577 6592 TO 6598 PR 3
    LOAD COMB 101 TANK FULL(DL + LL + WATER INSIDE + TEMP)
    1 1.0 2 1.0 5 1.0 7 1.0
    LOAD COMB 102 TANK FULL(DL + LL + WATER INSIDE - TEMP)
    1 1.0 2 1.0 5 1.0 7 -1.0
    LOAD COMB 103 TANK EMPTY(DL + LL + SURCHARGE + OUTSIDE SOIL & WATER TABLE + TEMP)
    1 1.0 2 1.0 3 1.0 4 1.0 6 1.0 7 1.0
    LOAD COMB 104 TANK EMPTY(DL + LL + SURCHARGE + OUTSIDE SOIL & WATER TABLE - TEMP)
    1 1.0 2 1.0 3 1.0 4 1.0 6 1.0 7 -1.0
    LOAD COMB 105 OPERATING CONDITION(DL + LL + SURCHARGE + WATER INSIDE + OUTSIDE SOIL & WATER TABLE + TEMP)
    1 1.0 2 1.0 3 1.0 4 1.0 5 1.0 6 1.0 7 1.0
    LOAD COMB 106 OPERATING CONDITION(DL + LL + SURCHARGE + WATER INSIDE + OUTSIDE SOIL & WATER TABLE - TEMP)
    1 1.0 2 1.0 3 1.0 4 1.0 5 1.0 6 1.0 7 -1.0
    LOAD COMB 302 GROSS SBC CHECK (OPERATING CONDITION WITH SOIL + TEMP)
    LOAD COMB 303 GROSS SBC CHECK (OPERATING CONDITION WITH SOIL - TEMP)
    PERFORM ANALYSIS
    DEFINE ENVELOPE
    101 TO 106 ENVELOPE 1 TYPE SERVICEABILITY
    END DEFINE ENVELOPE
    FINISH
  • Whereas the floor load generation would work for most of the panels but there are a few as marked below where the angles formed by the adjacent sides exceed 180 degree which is not suitable for a floor load generation. Instead of applying the load as floor load on these panels, I would suggest that you calculate the loads on the members and apply it using member loads for these panels. The floor load should work for the rest.
Reply Children
