How to model Connectivity between Raft Footing and Wall in Staad?
Good Everybody,
I am Modeling a Circular Digester tank of 318Million Litters per Day , I have a doubt how to model the connection between the wall and raft footing.
this how I modeled the Raft is 600mm thk and the wall is 350mm thk, I have modeled the walls directly from the raft plate nodes with first layer of the wall to height of 300mm which will be part of raft too how to model this this part of the wall that is inside the raft which type of plate release should i use to simulate the actual behavior.
    Here with i have attached my staad file for reference too.Staad Editor File.rtf
Parents Reply Children
