Shear Capacity of Slab
In RAM concept it shows you a shear plan required for the reinforcing. I understand that these shear bars are shown over columns because of punching shear.
If it is not shown over a column or a concentrated load from above, does this mean the slab is failing in beam shear? and does the capacity of the bars and the slab assume that the designed shear bars are in the slab?
Because in actual fact there are no vertical shear bars in this two way slab. So does the program rely on these shear bars to get the design to work?. I.e. will it tell me that it works when it's actually failing because it assumes the designed shear bars are there?
The generated shear bars look something like this
Many thanks
Parents Reply Children
