Hi guys. I am a new user in staad. I tried modeling my file but i can't run it as a whole. Can someone give me tips on how to model this on my staad?
at the same time, i am trying to analyze it part by part, but can't seem quite to run it due to instability errors. Please help me on how to run this structure as a whole. This is my trial partial staad file.
Thank you in advance for those who will help me. God Bless.
STAAD SPACE DXF IMPORT OF ROOFING STADIUM.DXFSTART JOB INFORMATIONENGINEER DATE 08-Sep-18END JOB INFORMATIONINPUT WIDTH 79UNIT MMS KNJOINT COORDINATES1 -81798.6 5080 -10217.5; 2 -90637.8 4699 -6153.49; 3 -81798.6 4699 -6153.49;4 -90638 5194.3 -11437; 5 -90637.8 4965.7 -8998.29;6 -90637.8 4851.41 -7779.15; 7 -90637.8 4737.1 -6559.89;8 -90637.8 4508.5 -4121.49; 9 -90637.8 4622.8 -5340.69;10 -81798.6 5194.31 -11436.7; 11 -81798.6 4965.7 -8998.29;12 -81798.6 4851.41 -7779.15; 13 -81798.6 4737.1 -6559.89;14 -81798.6 4622.8 -5340.69; 15 -81798.6 4508.5 -4121.49;16 -86218 5194.31 -11436.7; 17 -84008.4 4508.5 -4121.49;18 -88428 4508.5 -4121; 19 -90637.8 5080 -10217; 20 -86218.2 4508.5 -4121.49;21 -88427.8 5194.3 -11436.9; 22 -84008.2 5194.31 -11436.8;24 -86218.2 4851.4 -7779.1;MEMBER INCIDENCES2 16 20; 3 19 1; 4 5 11; 5 6 12; 6 7 13; 7 9 14; 8 8 15; 10 21 18; 11 4 8;13 22 17; 14 10 15; 15 4 10;START GROUP DEFINITIONMEMBERFLOOR_ROOF 2 TO 8 10 11 13 TO 15GEOMETRYEND GROUP DEFINITIONDEFINE MATERIAL STARTISOTROPIC STEELE 205POISSON 0.3DENSITY 7.68195e-008ALPHA 1.2e-005DAMP 0.03TYPE STEELSTRENGTH FY 0.2532 FU 0.4078 RY 1.5 RT 1.2END DEFINE MATERIALCONSTANTSMATERIAL STEEL ALLMEMBER PROPERTY AMERICAN2 TO 8 10 11 13 TO 15 TABLE ST W6X8.5SUPPORTS1 19 PINNED2 3 FIXEDMEMBER OFFSET3 TO 8 15 START -1219.2 0 03 TO 8 15 END 1219.2 0 02 10 11 13 14 START 0 114.3 -1219.22 10 11 13 14 END 0 -114.3 1219.49MEMBER RELEASE3 TO 8 15 START MPX 0.993 TO 8 15 END MPX 0.992 10 11 13 14 START MPZ 0.992 10 11 13 14 END MPZ 0.99SLAVE ZX MASTER 24 JOINT 4 TO 18 20 TO 22DEFINE WIND LOADTYPE 1 WIND 1SNIP 1985 PRESSURE 1.27454e-006 TERRAIN A CLASSIFICATION 3EXP 1 JOINT 1 TO 22DEFINE REFERENCE LOADSLOAD R1 LOADTYPE Dead TITLE REF LOAD CASE - DLSELFWEIGHT Y 1 ONEWAY LOAD_ROOF ONE 0.3 GY INCLINEDLOAD R2 LOADTYPE Wind TITLE REF LOAD CASE - WLONEWAY LOAD_ROOF ONE 1.275 GY INCLINEDEND DEFINE REFERENCE LOADSLOAD 3 LOADTYPE Dead TITLE DEADSELFWEIGHT Y -1 REFERENCE LOADR1 1.0 LOAD 5 LOADTYPE Wind TITLE WINDSELFWEIGHT Y -1 REFERENCE LOADR2 1.0 LOAD COMB 1 GENERATED NSCP-2015 AISC/LRFD 13 1.4 LOAD COMB 2 GENERATED NSCP-2015 AISC/LRFD 23 1.2 LOAD COMB 4 GENERATED NSCP-2015 AISC/LRFD 43 0.68 PERFORM ANALYSISPARAMETER 1CODE AISC UNIFIED 2005PERFORM ANALYSISPRINT CGFINISH
Dear user,
There are a lot of training videos in our learn server. You can access those items from below link.
https://learn.bentley.com/app/Public/ViewLearningPathDetails?lpId=112344
Regarding your model, there are some modelling error. The connectivity between the members are not proper. You can check it from Utilites > Structure Tools > Multiple Structure.
You can break the beams at selected nodes or intersect the beams as appropriate from geometry tab as shown below.
I would suggest you to view the learn videos from the attached path first and then try to make a model.
Good day. I have already created a structure that has all the beams needed just like on the perspective. But i am really having a hard time analyzing how i can transfer my loads to rafters > purlins > I-beams > Columns > Footing. That is why i created the one i posted because i wanted to transfer the loads part by part. I was just asking how can i use staad on my structure as a whole. I would appreciate if you can tell me how can i do it and it would be a great reference for my future works. This is the file that has all the structural beams. Thank you in advance and God Bless.
STAAD SPACESTART JOB INFORMATIONENGINEER DATE 13-Sep-18END JOB INFORMATIONINPUT WIDTH 79UNIT METER KNJOINT COORDINATES8 3.25121 0 10.0584; 10 7.31501 0 1.2192; 21 0 4.29301 0; 22 9.75362 5.51201 0;23 0 4.29281 10.058; 28 7.31521 0 10.0584; 33 0 4.29301 11.277;42 0 4.29298 1.2192; 43 0 4.29294 3.42901; 44 0 4.2929 5.63881;45 0 4.29285 7.84862; 46 9.75362 5.51201 11.2776; 47 3.25101 4.69901 10.058;51 9.75362 5.51201 1.2192; 52 9.75362 5.51201 3.42901;53 9.75362 5.51201 5.63881; 54 9.75362 5.51201 7.84862;55 9.75362 5.51201 10.0584; 56 1.08374 4.42845 11.2771;57 2.16747 4.56401 11.2772; 58 3.25121 4.69934 11.2772;59 4.33501 4.83479 11.2773; 60 5.41868 4.97023 11.2774;61 6.50241 5.10568 11.2774; 62 7.58615 5.24112 11.2775;63 8.66988 5.37657 11.2776; 104 1.08374 4.42845 0; 105 2.16747 4.5639 0;106 3.25121 4.69934 0; 107 4.33494 4.83479 0; 108 5.41868 4.97023 0;109 6.50241 5.10568 0; 110 7.58615 5.24112 0; 111 8.66988 5.37656 0;112 3.25081 4.69901 1.219; 113 3.25061 0 1.2194; 114 3.51201 4.69901 10.0582;115 1.08374 4.42843 1.2192; 116 2.16747 4.56391 1.2192;118 4.33495 4.83479 1.2192; 119 5.41868 4.97023 1.2192;120 6.50241 5.10568 1.2192; 121 7.58615 5.24112 1.2192;122 8.66988 5.37657 1.2192; 123 1.08375 4.42839 3.42901;124 2.16747 4.56393 3.42901; 125 3.25121 4.69934 3.42901;126 4.33496 4.83479 3.42901; 127 5.41868 4.97023 3.42901;128 6.50241 5.10568 3.42901; 129 7.58615 5.24112 3.42901;130 8.66988 5.37657 3.42901; 131 1.08375 4.42836 5.63881;132 2.16747 4.56395 5.63881; 133 3.25121 4.69934 5.63881;134 4.33497 4.83479 5.63881; 135 5.41868 4.97023 5.63881;136 6.50241 5.10568 5.63881; 137 7.58615 5.24112 5.63881;138 8.66988 5.37657 5.63881; 139 1.08376 4.42831 7.84862;140 2.16747 4.56398 7.84862; 141 3.25121 4.69934 7.84862;142 4.33499 4.83479 7.84862; 143 5.41868 4.97023 7.84862;144 6.50241 5.10568 7.84862; 145 7.58615 5.24112 7.84862;146 8.66988 5.37657 7.84862; 147 1.08376 4.42828 10.058;148 2.16747 4.564 10.0584; 150 4.335 4.83479 10.0584;151 5.41868 4.97023 10.0584; 152 6.50241 5.10568 10.0584;153 7.58615 5.24112 10.0584; 154 8.66988 5.37657 10.0584;155 7.3156 4.97901 10.058; 159 7.31521 4.97901 1.219;MEMBER INCIDENCES3 10 159; 8 21 104; 11 21 42; 24 42 43; 25 43 44; 26 44 45; 27 45 23; 28 22 51;29 33 46; 32 47 8; 35 28 155; 36 23 33; 38 155 159; 39 51 52; 40 52 53;41 51 52; 42 53 54; 43 52 53; 44 54 55; 45 53 54; 46 55 46; 47 54 55;48 42 115; 49 43 123; 50 44 131; 51 45 139; 52 23 147; 157 111 122; 158 62 153;159 109 120; 160 60 151; 161 107 118; 162 58 47; 163 105 116; 164 56 147;165 47 141; 166 113 112; 167 104 105; 168 105 106; 169 106 107; 170 107 108;171 108 109; 172 109 110; 173 110 111; 174 111 22; 175 115 116; 176 115 104;177 42 115; 178 116 124; 179 116 112; 180 115 116; 181 112 106; 182 112 118;183 116 112; 184 118 126; 185 118 119; 186 112 118; 187 119 108; 188 119 120;189 118 119; 190 120 128; 191 120 121; 192 119 120; 193 121 110; 194 121 122;195 120 121; 196 122 130; 197 122 51; 198 121 122; 199 123 124; 200 123 115;201 43 123; 202 124 132; 203 124 125; 204 123 124; 205 125 112; 206 125 126;207 124 125; 208 126 134; 209 126 127; 210 125 126; 211 127 119; 212 127 128;213 126 127; 214 128 136; 215 128 129; 216 127 128; 217 129 121; 218 129 130;219 128 129; 220 130 138; 221 130 52; 222 129 130; 223 131 132; 224 131 123;225 44 131; 226 132 140; 227 132 133; 228 131 132; 229 133 125; 230 133 134;231 132 133; 232 134 142; 233 134 135; 234 133 134; 235 135 127; 236 135 136;237 134 135; 238 136 144; 239 136 137; 240 135 136; 241 137 129; 242 137 138;243 136 137; 244 138 146; 245 138 53; 246 137 138; 247 139 140; 248 139 131;249 45 139; 250 140 148; 251 140 141; 252 139 140; 253 141 133; 254 141 142;255 140 141; 256 142 150; 257 142 143; 258 141 142; 259 143 135; 260 143 144;261 142 143; 262 144 152; 263 144 145; 264 143 144; 265 145 137; 266 145 146;267 144 145; 268 146 154; 269 146 54; 270 145 146; 271 147 148; 272 147 139;273 23 147; 274 148 57; 275 148 47; 276 147 148; 277 47 141; 278 47 150;279 148 47; 280 150 59; 281 150 151; 282 47 150; 283 151 143; 284 151 152;285 150 151; 286 152 61; 287 152 153; 288 151 152; 289 153 145; 290 153 154;291 152 153; 292 154 63; 293 154 55; 294 153 154; 299 125 112; 300 133 125;301 141 133;START GROUP DEFINITIONFLOOR_ROOF 8 11 24 TO 29 36 39 TO 52 157 TO 164 167 TO 294MEMBER_W 38 165 299 TO 301_COL 3 32 35 166END GROUP DEFINITIONSUPPORTS8 10 28 113 FIXEDUNIT METER KGDEFINE REFERENCE LOADSLOAD R1 LOADTYPE Dead TITLE REF LOAD CASE 1 - DLSELFWEIGHT Y -1 SELFWEIGHT Y -1 LIST 8SELFWEIGHT Y -1 LIST 29SELFWEIGHT Y -1 LIST 52SELFWEIGHT Y -1 LIST 51SELFWEIGHT Y -1 LIST 50SELFWEIGHT Y -1 LIST 49SELFWEIGHT Y -1 LIST 48FLOOR LOAD_ROOF FLOAD 0.3 GY INCLINED_ROOF FLOAD 1.275 GY INCLINEDEND DEFINE REFERENCE LOADSUNIT METER KNPARAMETER 1CODE AISCRATIO 0.88 MEMB 3 11 24 TO 28 32 35 36 38 TO 47 157 TO 166 176 178 181 184 -187 190 193 196 200 202 205 208 211 214 217 220 224 226 229 232 235 238 241 -244 248 250 253 256 259 262 265 268 272 274 277 280 283 286 289 292 -299 TO 301TRACK 0 MEMB 3 11 24 TO 28 32 35 36 38 TO 47 157 TO 166 176 178 181 184 187 -190 193 196 200 202 205 208 211 214 217 220 224 226 229 232 235 238 241 244 -248 250 253 256 259 262 265 268 272 274 277 280 283 286 289 292 299 TO 301SELECT OPTIMIZEDGROUP MEMB 8 11 24 TO 29 36 39 TO 52 157 TO 164 167 TO 294 GROUP MEMB 3 32 35 166 GROUP MEMB 38 165 299 TO 301 PERFORM ANALYSISPARAMETER 2CODE AISCFYLD 250000 MEMB 3 11 24 TO 28 32 35 36 38 TO 47 157 TO 166 176 178 181 184 -187 190 193 196 200 202 205 208 211 214 217 220 224 226 229 232 235 238 241 -244 248 250 253 256 259 262 265 268 272 274 277 280 283 286 289 292 -299 TO 301RATIO 0.9 MEMB 3 11 24 TO 28 32 35 36 38 TO 47 157 TO 166 176 178 181 184 -187 190 193 196 200 202 205 208 211 214 217 220 224 226 229 232 235 238 241 -244 248 250 253 256 259 262 265 268 272 274 277 280 283 286 289 292 -299 TO 301TRACK 0 MEMB 3 11 24 TO 28 32 35 36 38 TO 47 157 TO 166 176 178 181 184 187 -190 193 196 200 202 205 208 211 214 217 220 224 226 229 232 235 238 241 244 -248 250 253 256 259 262 265 268 272 274 277 280 283 286 289 292 299 TO 301CHECK CODE MEMB 3 11 24 TO 28 32 35 36 38 TO 47 157 TO 166 176 178 181 184 -187 190 193 196 200 202 205 208 211 214 217 220 224 226 229 232 235 238 241 -244 248 250 253 256 259 262 265 268 272 274 277 280 283 286 289 292 -299 TO 301UNIT METER KGLOAD 1 LOADTYPE Dead TITLE DLREFERENCE LOADR1 1.0 LOAD 2 LOADTYPE Wind TITLE WLFLOOR LOAD_ROOF FLOAD 0.3 GY INCLINED_ROOF FLOAD 1.275 GY INCLINEDLOAD COMB 3 GENERATED UBC-1997 TABLE1 11 1.4 LOAD COMB 4 GENERATED UBC-1997 TABLE1 21 1.2 LOAD COMB 5 GENERATED UBC-1997 TABLE1 31 1.2 2 0.8 LOAD COMB 6 GENERATED UBC-1997 TABLE1 41 1.2 2 1.3 LOAD COMB 7 GENERATED UBC-1997 TABLE1 51 0.9 LOAD COMB 8 GENERATED UBC-1997 TABLE1 61 0.9 2 1.3 LOAD COMB 9 GENERATED UBC-1997 TABLE1 71 0.9 2 -1.3 STEEL TAKE OFF LIST 3 11 24 TO 28 32 35 36 38 TO 47 157 TO 166 176 178 181 -184 187 190 193 196 200 202 205 208 211 214 217 220 224 226 229 232 235 238 -241 244 248 250 253 256 259 262 265 268 272 274 277 280 283 286 289 292 299 -300 TO 301FINISH
A modified file is attached for your reference
8623.Structure1.STD
List of issues addressed in the modified modelorphan node 114 deletedlot of duplicate members merged ( Utilities > Beam Tools > Duplicate Beams > Merge)analysis command added after load combinationmember properties missing in your original model- some arbitrary property has been assigned, you can make changes as neededmaterial definition and assignment were out of place and moveddesign commands were out of place and moved portal frame (formed by the members 3 38 35 in your original model) was not connected to the rest of the structure. Top level beam moved up and members intersected to establish connectivity
I would also highly recommend that you go through the learn server videos or go through a STAAD.Pro training which should clear all doubts that you are having now.
Thank you.
