Hi All,
is there a way to permanently change the way RAM Concept presents the reinforcing descriptions? As far as I can tell the only way to do it is by right-clicking on a bar callout in a reinforcing layer, going to the reinforcing properties and changing it in the 'Presentation' tab, and that doesn't stick, can't be saved to a template, reverts back next time you hit 'run', etc.
Thanks!
Alex
Make the presentation changes on the Reinforcement layer in some file, then save that file as a template (File - Save Template...). When starting New files, choose the "Copy File..." option and select that template. This should preserve your formatting preferences, but does not work for models created directly from Ram Structural System or ISM.
Answer Verified By: Alex McHugh
Hi Seth,
I see my mistake, I was modifying the rebar presentation by right clicking on the generated yellow program reinforcement in the main screen, not by double-clicking on the rebar buttons on the right ribbon. Saving the formatting to a template works for me now.
