I have found these OpenSTAAD commands for Physical Member in the OpenSTAAD Documentation.
However, they do not seem to work.
Can you confirm if OpenSTAAD for the Physical model is not yet functional.
Thanks!
I second this request. Of all the "Physical" member commands, only GetPMemberCount seems to work, and oddly enough, GetPhysicalMemberCount doesn't.
I tried GetPhysicalMemberList, GetPhysicalMemberUniqueID, and GetSelectedPhysicalMember - none appear to work. The array is just a bunch of zeros.
Additionally - assuming this functionality gets fixed - will there be a way to extract PHYSICAL member deflections / internal forces using OpenSTAAD? I assume that the none of the .Output.GetMember<xxx> commands will work on Physical members as they carry similar "member numbers".
Any help would be great!
