RAM Frame- Steel Moment Frame Joint Stiffness
How does RAM frame handle joint stiffness reduction when analyzing a steel moment frame? I have a structure with steel moment frames and would like to explore the option of using flexible moment connections. What is the process of reducing joint stiffness in the RAM Frame model and how much does it needs to be reduced?
Thank you.
Parents Reply Children
