CAn we export staad model to revit ?
Hi
I installed the structural synchronizer connect edition update 3, as per link provided below. But when I try to create ISM file , it displays error
Can I know why I am not able to generate to generate ISM file?
There should be a Staad.Interop.ISM.config file within the folder C:\Program Files\Bentley\Engineering\STAAD.Pro CONNECT Edition\STAAD\PlugIns\StrucLink.
Copy that file into the folder C:\Users\<User Name>\AppData\Local\Bentley\Engineering\STAAD.Pro CONNECT Edition\Default\Plugins\StrucLink and try re-creating the ISM repository.
verify if you have this family available in Revit
How?
How do I export model from STAAD to Revit. I downloaded items but don't see any add-ins in STAAD?
From within STAAD.Pro, go to File > ISM > Create Repository
On the Revit side of things, make sure that you install the ISM Revit Plugin which would then allow you to import the exported ism model from STAAD.Pro into Revit
after doing the above, I then get this error... please help... thank you.
