how to display member utilization in selected range.
why doesnt the display label, design results tab doesn't work
Dear User,
Are you trying to see Utilization ratio only for selected members ? If yes, you can do one thing. After showing all the ratios as per your attached screenshot please select individual beam label cursor as shown below.
Now manually select the members you don's want to show ratio.
The design results tab has been temporarily disabled in GUI. It will be back soon. Regarding display label, the topic is not very clear to me. Can you please explain a bit may be with some screen shots.
I really don't think that manually selecting tens of items to turn on/off is a good recommendation. More if you consider that this turn on/off individual label is not saved, and if we re-run for a check or change, we have to turn on everything again to once more look for the members within our desired range. It is bad practice completely.
Regarding colors, I agree. In G and NG is very easy, green, red or somewhere between. But in detail, to have random not sense colors is not helpful. Why not put somewhat spectrum of colors from red to green by default instead of having the user to configure that manually.
Also, just my opinion as user.
