PRINT ANALYSIS RESULTS - List / Limit Load Cases?
When Print result information to the analysis results file (*.ANL), you can limit the output to certain nodes or members (LIST...):
PERFORM ANALYSIS
PRINT MEMBER FORCES LIST ALL
PRINT JOINT DISPLACEMENTS LIST 7 11
FINISH
...but is there a way / command that can LIMIT THE NUMBER OF LOAD CASES PRINTED?...similar to...
(the below commands do not actually do what I want)
PERFORM ANALYSIS
PRINT MEMBER FORCES LIST ALL LOAD 100 TO 133
PRINT JOINT DISPLACEMENTS LIST 7 11 LOAD 100 TO 133
FINISH
(the Loads I'm concerned with are combinations, so the LOAD LIST command is not achieving this)
