**ERROR - FINISH COMMAND IN LOAD DATA CHECK IF ANALYSIS COMMAND IS OUT OF ORDER OR MISSING IN CASE NO. 3 CHECK DATA ORDER CAREFULLY *** ERROR *** ABOVE LINE CONTAINS ERRONEOUS DATA.
Make sure that PERFORM ANALYSIS command is included in the input file after the entered load cases.
