Loads Definition is gray out in Staad Pro
Dear friends,
I don't know if it is a bug in the new release of Staad Pro or if I am doing something wrong.
When I send a model from the Physical Model to the Analytical model the Loads Definition tab has its bottom grey out, see:
As you can see the option for "New", "Add" are grey out.
The icons on the top for load are also grey out:
I am running the last version of Staad Pro Connection with windows 10 Pro.
I don't have this problem in project without the physical model, see:
Gustavo
Parents Reply
  • Correct. If you drop the physical model, you will lose the connection between the analytical and the physical model. However at this point of time if generating the loads and adding loads in the analytical modeler is a requirement, then that is the only way out. The version of STAAD.Pro to be released early next year, is going to have the other loading capabilities included in it and at that point you would be able to handle the load generations in the physical modeler and would not need to drop the physical model.
    Answer Verified By: Gustavo Vasconcellos
