Is it possible to import 'other lines' (center lines marking the location of shafts), which are not Grid lines from REVIT to RAM SS using the ISM repository? I am aware of the process of importing the lines marked as GLs from REVIT to RAM SS. But I am unable to import the 'other lines'. Any solutions is much appreciated!
Thank You!
No, Grid Lines are the only non-physical line objects supported in ISM. DXF importing might help. https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/10314/ram-ss---using-dxf-as-a-reference-layout
Thanks Seth!
