There is an issue on high resolution displays that I am not able to overcome. All of the text in the tables is very small and unreadable.
Close out of STAAD.Pro. In your display settings ( you may right click on your desktop and choose Display Settings ) try setting the resolution and scale as below. Get back into STAAD.Pro and see if you still have the issue.
This does not work. I was able to correct some display issues by adjusting the fonts the Display Options and then adjust the font size where it was possible. There are dialog boxes though where it is not possible to make any changes:
Note the default text size. This problem is not corrected by changing the screen resolution as suggested.
I believe this is a problem with the underlying GUI code that has not changed when it was ported to the new interface.
What is the version of STAAD.Pro that you are using ( 20.07.xx.xx or 21.xx.xx.xx number ) and what is the OS ?
The latest STAAD, just installed on my new computer.
Windows 10
The graphics card is an Nvidia Quadro P4000 running a single monitor at 3140x2160 and 300% scale. Note that changing the settings to 1929x1080 and 100% scaling has not effect.
I have reached out to our development desk and will revert back. When you say that you have the latest STAAD, you mean the version number is 21.03.00.146. Is that correct ?
