OpenStaad Macro using VB.NET
Hi Guys,
I Have tried to create OpenStaad macro using VB.NET.  This program can generate geometry of 2D or 3D Single Span or Multi Span Pitched roof Frame(Portal Type) without any edit.
This helps to save time. Few additional optional features are added like Support conditions, Support Group, Adding Exterior/Interior/Ridge ties. Output is fine in my computer. But when trying to run my program in different computer The StaadPro is closed. But after reopening StaadPro I found geometry was generated perfectly.
If anyone have come across this problem please help. Some previews as below:
  • Hi Vivek
    VBA has limited functions and buttons. Also, by using VB.net you can use stand alone file which does not require MSExcel. This program is for many users. So chance of modification accidentally or intentionally is nil. As I know OpenStaad functions can be used in .NET environment.
    Anyway Now My program is running well in different PCs. This problem is solved.
    Thanks.
Reply
  • Hi Vivek
    Thanks.
