Output showing half of the values for minimum steel and clear cover.
Hello, my office is designing a basement wich consists of a slab for foundation, a concrete reinforced wall and beams and pedestals. The program takes hours to run due to the high number of plates it has (around 22000) but even when it did finish the analysis we opened the output only to see that the values for minimum steel are being calculated in such a manner that the result is half of what it should be; for example if there was an element with a thickness of 0,30 m then minimum steel should be 0,0018*30*100 = 5,4 cm2/m but instead the output says the value is 2,70 cm2/m, the same happens with the clear cover values as they should be 38,10 mm by default but the output is showing values of 19,05 mm, this has led us to believe that these are not viable results and we can´t find the reason for this. Wer´e working with STAAD.Pro V8i SS6. Suggestions are welcome, thanks in advance for any help regarding this issue.
The file is attached here.
SOTANO GIS - MODELO 3 AJUSTADO_3 con 750_2.std
