I am modeling shear walls in STAAD using shell elements, how to get the moment and shear values at certain levels?
Please refer to the wiki below
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/23103/modeling-shear-walls-using-plates
It would be helpful in future versions to be able to see the forces at the section cut (Results Along Line) for all the load cases/combinations at the same time in the same table similar to beam forces or or be able to export all this data to Excel using OpenSTAAD. This would be make this feature a much better feature and lot more user friendly and much better for design. Without this it is a very cumbersome tool to use.
