Not sure what or why this error is occurring but it seems to happen when I incorporate steel design parameters into the model. I've looked at recent posts and tried increasing the Memory, along with removing the Load List commands but it does not seem to work. any help is appreciated.
Please attach that STAAD model here if possible. Also, let us know the exact STAAD.Pro version being used.
I am currently using STAAD.Pro CONNECT Edition - Version 21.00.02.43
I built a simple model for reference
STAAD SPACESTART JOB INFORMATIONENGINEER DATE 11-Jan-19END JOB INFORMATIONINPUT WIDTH 79SET ECHO OFFUNIT METER KNJOINT COORDINATES1 0 0 0; 2 6 0 0; 3 0 0 8.00002; 4 6 0 8.00002; 5 0 -4.00001 0; 6 6 -4.00001 0;7 0 -4.00001 8.00002; 8 6 -4.00001 8.00002; 9 8 0 0; 10 8 0 8.00002;MEMBER INCIDENCES1 1 2; 2 3 4; 3 1 3; 4 2 4; 5 6 2; 6 5 1; 7 7 3; 8 8 4; 9 2 9; 10 4 10;START GROUP DEFINITIONFLOOR_FLOOR1 1 TO 4ELEMENTEND GROUP DEFINITIONDEFINE MATERIAL STARTISOTROPIC STEELE 1.99947e+08POISSON 0.3DENSITY 76.8191ALPHA 6.5e-06DAMP 0.03TYPE STEELSTRENGTH FY 248210 FU 399894 RY 1.5 RT 1.2ISOTROPIC CONCRETEE 2.17184e+07POISSON 0.17DENSITY 23.5615ALPHA 5.5e-06DAMP 0.05TYPE CONCRETESTRENGTH FCU 27578.9END DEFINE MATERIALMEMBER PROPERTY CANADIAN1 TO 4 9 10 TABLE ST W310X395 TO 8 TABLE ST W410X54CONSTANTSMATERIAL STEEL MEMB 1 2 2 TO 10SUPPORTS5 TO 8 FIXED BUT MX MZ9 10 FIXED BUT MY MZMEMBER RELEASE1 TO 4 9 10 START MY MZ1 TO 4 END MY MZLOAD 1 LOADTYPE None TITLE SWSELFWEIGHT Y -1 LIST ALLLOAD 2 LOADTYPE None TITLE FLOORONEWAY LOAD_FLOOR1 ONE -10 GYLOAD COMB 3 COMBINATION 11 1.25 2 1.5 PERFORM ANALYSIS*LOAD LIST 3PARAMETER 1CODE CANADIANBEAM 1 MEMB 1 TO 4 9 10TRACK 0 MEMB 1 TO 4 9 10RATIO 1 MEMB 1 TO 4 9 10LAT 1 MEMB 1 TO 4 9 10FYLD 345000 MEMB 1 TO 4 9 10FU 450000 MEMB 1 TO 4 9 10GROUP SZ MEMB 1 TO 4 9 10 FIXED GROUPSELECT MEMB 1 TO 4 9 10PERFORM ANALYSISFINISH
The FIXED GROUP should be located ahead of the GROUP command. Also if you are using FIXED GROUP, you need to use SELECT OPTIMIZED as opposed to SELECT. A modified file is attached for your reference.
1778.Structure1.STD
Answer Verified By: Andrew Dittrick
Thank you Sye
Dear Sir (Sye) , I am facing similar issue but in concrete design ? what could be the reasons . Can help me out . The file is attached here. STRUC_TK.std
