Default file saving location
Is there a way to define the default location to save my work files? The program is default to a network location as of currently.
  • By default, files are saved within the current working directory. So every time you do a manual save or an automatic save, a backup file gets created in the same folder where your model is. However if you want this backup to be made in a different folder, you can set that up from inside the Backup Manager. In the STAAD.Pro Connect Edition you need to go to File > Tools > Open Backup Manager and use the option highlighted below to make the change.
    In older versions of STAAD.Pro like the v8i, the option is available within File > Open Backup Manager
    Also I would like to add that when you work with a file on a particular directory and close out of the software, it remembers that path and so next time if you try to create a new file, the Location would be the last directory you worked on. You can always change the location using the Browse button as shown below
  • STAAD Foundation Advanced saves the data in the same folder in which the model is. To save to a different folder you have to use Save As.
    Like STAAD.Pro it does remember the path location in which the last work was done. So next time when you create a New file or try to Open a file you will be taken to that folder by default. Of course you can change it if required.
