Response spectrum in staad connect edition
Hello ,
I had applied the loading for response spectrum analysis as per IS 1893 2016 ..i received some warnings regarding the eigen solutions please give me some guidance for response spectrum analysis .i have done the right procedure as per new code IS1893-2016  or not i am little bit confused so  please guide me . and also i want to know the reason behind the warnings .
the staad file is attached ..
Thank you
For DL + LL+EQ (with stiffness Factor) 18-12-18.dgn
