STEEL DESIGN DETAILS
Dear Frds,
I have modeled a steel frame and design using EN 1993-1-1:2005.
I have attached the model for your reference i that model correct or need to add any other steel design parameter??
I have attached the design report also in which member length and effective length are same is this correct ???
If wrong then what is correct parameters for steel design???
Plz guide guys.../
 PDF3007.zxc.std
